Google Pixel 6 Loudspeaker Replacement
Dominik Schnabelrauch
crwdns2944107:0crwdnd2944107:0Dominik Schnabelrauchcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 27, 2025crwdne2944111:0
30 - 40 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the loudspeaker in your Google Pixel 6.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Caution: The Pixel 6 contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You’ll need replacement adhesive to reattach components when reassembling the device.
crwdns2944105:0crwdne2944105:0
  1. Google Pixel 6 Loudspeaker Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    If I cannot use my screen, how do I power it off?
    Craig Joseph Van Vliet - crwdns2934203:0crwdne2934203:0
    I was thinking the same. Could let the battery run down.
    Jack Adrian Zappa - crwdns2934203:0crwdne2934203:0
    You can turn the Smartphone off via the boot menue. Push the on/off-button plus the volume up button at the same time. Once the smartphones goes off to restart, hold the volume down button. The smartphone will boot and you can select between recovery mode and other options. You will find the option turn off, which you can select then with the buttons on the side.
    Jonas R. - crwdns2934203:0crwdne2934203:0
    This is only helpful if you can read your screen. I have a black screen and over 60% battery. It will take days to drain the battery. I need to power it off.
    William Maine -
  2. Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Loudspeaker Replacement, Loosen the display adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    what area of the phone do i apply it to?
    middle, edges, diagonal?
    johnathandoe - crwdns2934203:0crwdne2934203:0
    Only on the edges.
    bogdan dobrin -
  6. Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Loudspeaker Replacement, Slice the adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Slice the adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  8. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
    No step about removing the picks?
    ALR - crwdns2934203:0crwdne2934203:0
  11. Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
  12. Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
    Don't be afraid to bend that clip. I had to bend mine to around 90 degrees.
    Thank you very much for the information
    Carlos López (España - Spain) -
    Don't forget to put the bracket back on during reassembly!
    I only realised I had forgotten to reattach it when I was putting the tools away and saw the bracket on the desk... both halves are already glued together so far too late for me. Let's hope it doesn't come loose or I'll be meticulously scraping off all that glue again lol
    Sam Hobbs - crwdns2934203:0crwdne2934203:0
    The absolute same thing happened to me...! I just saw it laying around on the table after cleaning up... Did you experience any issues so far? Not keen on opening it up again eager haha.
    Milkiman -
    Any chance someone has an update on how bad it is to just go on and use the phone without that bracket?
    Leilin -
    My bracket was a little bit stuck. I bent the tab on the left side to 90 degrees, as Jack mentioned. Then I folded the bracket with my finger to the right side and then upwards. When reinstalling, you can bend the bent tab back to its original position.
    Alessio - crwdns2934203:0crwdne2934203:0
    I couldn't get the bracket back installed. Just wouldn't click back in place no matter what I tried. Hopefully screen cable doesn't pop out anytime soon 😂
    Thomas Russ - crwdns2934203:0crwdne2934203:0
  13. Google Pixel 6 Loudspeaker Replacement, Disconnect the display cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Disconnect the display cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  14. Google Pixel 6 Loudspeaker Replacement, Screen information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  15. Google Pixel 6 Loudspeaker Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Has the issue with the fingerprint not working after screen replacement been sorted?
    [deleted] - crwdns2934203:0crwdne2934203:0
    I bought the repair kit that included the adhesive & fingerprint module. If that's what you bought as well, you will have to use the google repair tool. https://pixelrepair.withgoogle.com/udfps. I had to manually download the google usb drivers & install them on Windows 11 because the phone wasn't being detected by the pixel repair tool.
    Kwame Bailey -
    Hello, fingerprint does'nt work now.... any tips ? thank !
    willy kedziora - crwdns2934203:0crwdne2934203:0
    I had the screen on my 6A replaced at a U-BreakiFix got home fingerprint reader does not work. It says enrollment not complete. Go to your repair facility. I guess they must have some magic that makes it work again due to security issues
    Lynne Ayers - crwdns2934203:0crwdne2934203:0
    This guide is clear and easy to follow. The other one where you actually replace the screen and put the new adhesive is much less easy to follow, and takes much more time to complete because you have to remove all traces of the old adhesive. I used GooGone and a 2mm flat head screwdriver as a scraping tool and it worked well.
    The fingerprint reader was not working after the upgrade, but I got it to work by visiting https://pixelrepair.withgoogle.com/udfps and since I'm using Ubuntu, I had to run those two commands:
    sudo usermod -aG plugdev $LOGNAME
    sudo apt-get install android-sdk-platform-tools-common
    And then reboot my computer before my phone could be connected. I rebooted my phone manually after the upgrade and all was working normally. In fact, the new fingerprint sensor works better than the one I got before. The new one is actually usable.
    My Pixel 6 is like new! (except perhaps for the water resistance)
    Francois Lord - crwdns2934203:0crwdne2934203:0
    Great tips! I wish I had thought of Goo Gone. By far the longest part of the procedure was cleaning out the old adhesive, and using alcohol swabs (including a few spares on hand) was slow and not very effective.
    After Chrome on ubuntu was unhappy with recognizing my phone I had to resort to using a Mac, but I would prefer your solution.
    Gary Smith -
    Alternate solution, without installing anything:
    Determine the USB bus and device ID of your phone.
    lsusb
    Assuming, the bus ID is '004', and the device ID is '001', temporary allow access to this USB device for all users.
    chmod 0777 /dev/bus/usb/004/001
    Thomas -
    Easy enough and excellent guide! Thank you!
    Jason - crwdns2934203:0crwdne2934203:0
    The guide was very helpful, but could be improved somewhat. I made the mistake of removing the screen without the bracket & didn't realize until I had attached the adhesive & tried to put the new screen on. So I had to remove the adhesive & the bracket before the new screen would fit, since it has it's own bracket. Another tip would be to include the instructions for getting the fingerprint module to work. Including https://pixelrepair.withgoogle.com/udfps & downloading & installing the google usb driver.
    Kwame Bailey - crwdns2934203:0crwdne2934203:0
    I agree that the guide was good. To be more clear, after the screen is completly installed you have go here https://pixelrepair.withgoogle.com/udfps to fix your fingerprint sensor, but my phone was not recognized by the utility when you plug it in Fast Boot Mode. This requires the usb drivers to be installed on the computer. Go here to download the usb https://developer.android.com/studio/run... Once you have the drivers you will have to go to device manager and you will see your Pixel 6 with a exclamation point on it. Right click on the Pixel 6 and select update drivers. Now browse to the folder that you extracted your drivers to that you just downloaded. This will fix the pixel 6 to be recognized by the utility. Now run the utiltity, and just make sure you reboot your phone when the utiltiy is done and it should be fixed.
    Wedge Fike - crwdns2934203:0crwdne2934203:0
    Just finished a screen replacement on my pixel 6. Everything was pretty straight forward and the instructions and guide was really clear. Scraping all the old tape/glue and making sure I get every last piece out of the phone was the most time consuming part, but totally doable in the end. Using something like goo gone or lighter fluid helps greatly in dissolving the tape residue and the include plastic scraper tool helped scraping every single last piece of goop off the phone.
    Had a little scare with the fingerprint scanner not working even after following the guide and calibrating the fingerprint scanner through google's website. I did it on a win11 computer at first, but thought I would use another computer with win10 to see if that made any difference. Fortunately that worked and my phone is back to 100% working again.
    Lawrence Chan - crwdns2934203:0crwdne2934203:0
    Thank you very much, worked as expected! Had also to recalibrate fingerprint censor AND then reboot the phone manually.
    For Ubuntu, you have to add some udev rules or use some other trick to make Chrome/Chromium access your USB devices.
    Alexis Le - crwdns2934203:0crwdne2934203:0
    Never explains how to snap the bracket of the new phone screen onto the device. Incomplete.
    Orlowski Sal - crwdns2934203:0crwdne2934203:0
  16. Google Pixel 6 Loudspeaker Replacement, Loosen the graphite film adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  17. Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top edge of the battery and the motherboard shield.
    • Remove the graphite film.
  18. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the graphite film is hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  19. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The graphite film at the bottom edge of the battery only needs to be removed when replacing the battery or the loudspeaker.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the loudspeaker assembly.
    • You'll also remove a piece of foam that bridges the display and the speaker. Be sure to replace the foam after installing a new graphite film.
    There was one tint tiny (1 cm) long graphite(?) piece left over in the battery kit. I didn't see it here in these instructions and I didn't see it on my phone nor did I remove it. Any idea what it's for?
    Ryan Y - crwdns2934203:0crwdne2934203:0
  20. Google Pixel 6 Loudspeaker Replacement, Unfasten the motherboard cover screws: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $17.96
    • Use a Torx T3 screwdriver to remove the screws securing the motherboard cover:
    • Eight 4.8 mm-long screws
    • One 2.4 mm-long screw
    I lost the 2.4 mm-long screw (marked orange)! It seems to be the ground connection from the lower board to the upper board. Will the phone work without this screw?
    Google Pixel 6 Battery Replacement
    Pixel - crwdns2934203:0crwdne2934203:0
  21. Google Pixel 6 Loudspeaker Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift up the motherboard cover and remove it.
  22. Google Pixel 6 Loudspeaker Replacement, Disconnect the battery cable: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Disconnect the battery cable: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    I have a cable that runs over the battery that is not shown here. How to I move this when changing the battery?
    Stephen Dewes - crwdns2934203:0crwdne2934203:0
  23. Google Pixel 6 Loudspeaker Replacement, Unfasten the loudspeaker screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T3 screwdriver to remove the five 4.8 mm-long screws securing the loudspeaker.
  24. Google Pixel 6 Loudspeaker Replacement, Pry up the loudspeaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Pry up the loudspeaker: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the bottom edge of the battery and the loudspeaker.
    • Use the opening pick to pry up the loudspeaker by tilting it downwards.
  25. Google Pixel 6 Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
    • Compare your new replacement part to the original part—you may need to transfer remaining components like the protective foam cushions.
    Mein Lautsprecher funktioniert häufig nur noch, wenn ich das Gerät seitlich oder von hinten quetsche. :(
    Wie sieht die Verbindung zum Mainboard aus, ist die über ein Kabel oder nur durch auflegen realisiert? Das wird auf den Bildern leider nicht ersichtlich.
    Andi - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
crwdns2935283:011/23/16crwdne2935283:0
237.303 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.739crwdne2935297:0
Ein Foto der Unterseite des Ersatzteils wäre sehr hilfreich! Ich frage mich, wie der Lautsprecher verbunden ist und ob er bei mir nur verrutscht ist, da er funktioniert solange ich das Gerät seitlich quetsche...
Jedes Öffnen des Geräts birgt leider die Gefahr, das OLED von hinten beim Wiederzusammenbau zu punktieren, über die bescheuerten kleinen Antennen, deswegen benutze ich jetzt erstmal Bluetooth Lautsprecher.
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 242
crwdns2942667:0crwdne2942667:0 10,570
