How to Use the Anti-Clamp
crwdns2869540:0crwdne2869540:0: 69K
28
237
1,134
68,544
crwdns2955950:0crwdne2955950:0: 13
crwdns2960004:02crwdne2960004:0, crwdns2960008:011crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 129
crwdns2959974:0129crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 16
crwdns2959982:016crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Follow these instructions to use an Anti-Clamp to open a device.
    1. How to Use the Anti-Clamp, Prepare your device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Prepare your device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Prepare your device: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The Anti-Clamp needs smooth, even surfaces for its suction cups to adhere to.
      • If your device has cracked glass or a slippery surface, follow this guide to apply the included tape pad.
      • Packing tape also works to cover a cracked display.
      • If your back glass is badly shattered, the tape might damage it further. Refer to your specific guide to use a suction handle instead.
      • If your device can be opened from both its screen and back cover, follow this guide to apply the included tape strips.
    2. How to Use the Anti-Clamp, Unlock the arms: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Unlock the arms: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Clampy - Anti-Clamp
      $24.95
      • Pull the blue handle backward to disengage the arms of the Anti-Clamp.
      • The handle may be stiff the first time you unlock the arms.
    3. How to Use the Anti-Clamp, Center the suction cups: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Center the suction cups: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Center the suction cups: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Rotate the Anti-Clamp to the side so it doesn't obscure your starting edge. Refer to your original guide for which edge to start with.
      • Center the suction cups over a smooth area of the device near the starting edge.
      • Avoid buttons, gaps, seams, and speakers, as they will prevent a good hold.
    4. How to Use the Anti-Clamp, Secure the suction cups: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Secure the suction cups: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Squeeze the suction cups together to secure them to the device.
      • If the cups are stiff and hard to secure, use your hands to warm them up.
    5. How to Use the Anti-Clamp, Alignment information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Alignment information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The suction cups need to be aligned with each other for the Anti-Clamp to work properly.
      • Improper alignment may cause the cups to separate prematurely. Pull the cups off the device using their pull tabs and re-center them.
    6. How to Use the Anti-Clamp, Lock the arms: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Lock the arms: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the blue handle forward to lock the arms.
    7. How to Use the Anti-Clamp, Support your device: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a support under your device so the Anti-Clamp stands upright without being held in place.
    8. How to Use the Anti-Clamp, Apply tension: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Apply tension: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Most adhesives separate under constant tension rather than more force. Take your time during this process to avoid breaking the suction cups free or violently opening your device.
      • Twist the handle clockwise one full rotation (360 degrees) or until the cups begin to stretch.
    9. How to Use the Anti-Clamp, Heat your device: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Clamp, Heat your device: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • For smaller devices, thread a heated iOpener through the arms of the Anti-Clamp to heat your device.
      • For larger devices, or iPhone models 12 and newer, use a hair dryer or a heat gun to soften the adhesive along your starting edge.
      • iPhone models 12 and newer have a tougher adhesive that the iOpener is less effective at opening than a hair dryer or heat gun.
      • Be careful not to overheat your device. The edge should feel slightly too hot to touch.
    10. How to Use the Anti-Clamp, Open your device: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Open your device: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Open your device: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Wait one minute to give the adhesive a chance to release and present a gap.
      • If the Anti-Clamp doesn't separate the adhesive after one minute, apply more heat and wait another minute. Be patient and let the Anti-Clamp do the work for you.
      • If, after several rounds of heating, the device doesn't show any signs of opening, twist the knob one quarter-turn.
      • Don't twist the knob more than three additional quarter-turns. Only use additional heat at this point. The more you twist the knob, the more likely the device is to suddenly pop open.
    11. How to Use the Anti-Clamp, Insert an opening pick: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert an opening pick into the gap created by the Anti-Clamp.
    12. How to Use the Anti-Clamp, Remove the Anti-Clamp: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Remove the Anti-Clamp: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use the Anti-Clamp, Remove the Anti-Clamp: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the blue handle backward to the unlock icon to disengage the arms.
      • Pull the suction cups off of the device using their pull-tabs.
      • Remove the Anti-Clamp and set your device on a flat surface.
    13. How to Use the Anti-Clamp, Finish opening your device: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Return to your original guide and continue disassembly, skipping any steps that open the device with a suction handle.
For other general electronics skills guides, click here.
For a fun way to decorate your Anti-Clamp, click here.
crwdns2935229:0129crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
251,238 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,200crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:010crwdne2931471:0
crwdns2935297:062,178crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Very clear step-by-step guide. The next time I do a battery replacement I intend to use one of these.
4surferboy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Engaging the Opening Mode the first time takes a bit of a push, don't be afraid, keep pushing until you hear a click. Seems to be easier to engage after the first time.
Ed Reeder - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Ed,
Thanks for the helpful feedback! I've implemented your note into the guide step.
Arthur Shi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Looks like an answer to a problem that I don't have right now but I plan to purchase one of these before I do any more battery replacements.
glynn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I used mine to open a Samsung Galaxy Tab A7 tablet. Very frustrating, seemed like you needed three hands to put it in place (though later I found a better procedure). The OEM case glue was quite powerful (used a heating pad to get the tablet Very hot). The Anti-Clamp had difficulty holding to the back of the case and kept losing its grip. I didn't try the packing tape trick, just now noticed it. I mainly used the top suction cup just by itself.
The replacement battery had a very long battery cable and didn't lay flat, which caused a bright spot on the display where the cable "kink" was. So time to remove the case again. This time I stuck each suction cup individually, screen side first, the case - firmly pressing each cup flat after placement. No need to "fight" the Anti-Clamp to get it in place, plus I think I got a better hold with the cups. The B-7000 glue I used was much easier to break loose than the OEM case glue.
To loosen the suction cups I slid an opening pick under the edge of the cup.
crwdns2936751:024crwdne2936751:0 28
crwdns2936753:07crwdne2936753:0 237
crwdns2936753:030crwdne2936753:0 1,134
crwdns2959996:0crwdne2959996:0 68,544
