Google Pixel 6 Pro Fingerprint Reader Replacement
  1. Google Pixel 6 Pro Fingerprint Reader Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Please, how can I turn it off when screen is broken?
    Thubbe - crwdns2934203:0crwdne2934203:0
  2. Google Pixel 6 Pro Fingerprint Reader Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Anti-Clamp instructions: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Pro Fingerprint Reader Replacement, Loosen the display adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Do you think that removing the SIM card, also will be a wise step? I'm pretty sure that heating the SIM card is not a good idea.
    Emil Teofanov - crwdns2934203:0crwdne2934203:0
    The SIM is probably no more sensitive than the rest of the phone.
    ScottMcNay - crwdns2934203:0crwdne2934203:0
    What does "be sure to have replacement adhesives for both the rear glass and the screen." I only had one it didn't mention another one?
    alberte - crwdns2934203:0crwdne2934203:0
    I didn't have the replacement adhesive for rear glass nor the 2 sided tape they talk about when putting it back together. It's Sunday, so I don't expect an answer. I decided to go ahead and work up until that point
    StlrFan -
  6. Google Pixel 6 Pro Fingerprint Reader Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Pro Fingerprint Reader Replacement, Slice the adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Slice the adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
  8. Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Pro Fingerprint Reader Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Open up the phone assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
    I don't know if it's an earlier or later design, but I am combining 2 phones (1 crushed glass but operational into the casing of one that quit functioning but has good glass) and on both, the ribbon cable for the LCD is a tiny bit too short to fold out flat like this. If you are working on one like mine, extreme care must be taken while holding the LCD up while simultaneously trying to plug the cable back into that very small recessed socket. Almost like you need 3 hands or robot fingers...
    Stephen P. Thurman - crwdns2934203:0crwdne2934203:0
    I also felt that the cable was too short to fully open like a book, however it is possible that the hinge side of my screen was still pressed in to the adhesive and I did not properly open the screen or I was being overly cautious. Be careful on first approach either way.
    Nick Harris - crwdns2934203:0crwdne2934203:0
    I luckily had a T2 torx that fit the screw on my phone. Be sure you have one handy in case yours is like mine.
    Daniel P deLaureal - crwdns2934203:0crwdne2934203:0
  12. Google Pixel 6 Pro Fingerprint Reader Replacement, Unfasten the display bracket screw: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
    I don't know if it's an earlier or later design, but I am combining 2 phones (1 crushed glass but operational into the casing of one that quit functioning but has good glass), and on both, the metal holder plate shown here is simply spring connected and that 2mm screw is instead slightly off to the side as part of the aluminum bracket's screws.
    Does anyone know the exact dimensions/specifications of this screw? I've misplaced mine and need to find a replacement.
    Alternatively, what are the chances the display cable might come loose if I install the display bracket without screwing it in? I would expect there's not too much clearance between the bracket and the display, so it should still mostly hold in place once the display is installed.
    Chris Gutkowski - crwdns2934203:0crwdne2934203:0
  13. Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the display cable bracket: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the display cable bracket: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 6 Pro Fingerprint Reader Replacement, Disconnect the display cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Disconnect the display cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    Reconnecting the display port cable was the longest part of my first repair. It helped when I carefully folded the ribbon connector at each end to get the most length out of it and bent it into the proper shape to hover just right over the small port. I lightly bent the cable back at the base and at the connector end.
    This connector feels delicate, so it definitely made me take my time and be cautious. The snap is unmistakable, but be careful afterward as you're on a short leash again. I folded the new screen closed like a book and snapped it into place easily.
  15. Google Pixel 6 Pro Fingerprint Reader Replacement, Screen information: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  16. Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the screen: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Before reassembly, clean around the edge of where the screen was, to remove any debris that may have been captured.
    After reassembly, the fingerprint sensor appears to be a common issue with new screens:
    * Go to https://pixelrepair.withgoogle.com/udfps on a computer.
    * If using Windows, click the help link to install the USB software. After installing, restart the computer and return to https://pixelrepair.withgoogle.com/udfps.
    * Follow the steps given to install the fingerprint calibration software.
    * Restart the phone.
    "Be sure to remove all adhesive liners from your replacement screen. Check the selfie camera recess and make sure you've removed the liner there."
    A photo with blue highlight square would've been helpful here...also it's very easy to miss this instruction as you'd be on the adhesive page...
    I did take the selfie camera liner this is a bad problem
    Austin Curtis -
    This is very true. I only realized after turning on my phone the next day that the film blocking the front camera is still there. I had to re-open the screen to remove that black film, which was not obvious at all. I only opened the upper half to remove the film, hopefully the adhesive is not compromised too much...
    Esmerando Escoto -
    All went well except for the adhesive. It was simply too small so when Iaid it down it was fine on one side as well as the top and bottom, but the other side required me to pull it over. As it is quite sticky, it bunched up. I cut out part of it and used my own double-sided tape to secure part of it. Otherwise, it was great. Thanks to those who made special note of the cover on the selfie camera window, and the procedure to set up the new fingerprint scanner.
    Arnold Bosman - crwdns2934203:0crwdne2934203:0
    They do not highlight the part that needs to be removed from the new screen, this should be added as the part looks and feels like it is a part of the new screen and removing it could break the new screen. So make sure you remove the selfie screen camera cover even if it looks and feels like there is not one there, it's there.
    I ordered Google Pixel 6 pro- fix kit in IFIXIT. I followed the steps mentioned in the repair guide. During repair the finger print symbol is blinking in the screen. I thought it would get set when i do re calibration as mentioned in repair guide but it did not worked. It displays " Can´t use finger print sensor Visit a repair provider or g.co/pixel/fingerprintunlock". Does anyone have same problem??
    Surendra Reddy Velagala - crwdns2934203:0crwdne2934203:0
    You have to go to that link and you can re calibrate the new finger print scanner by logging into your account and approving it.
    dot Ducky -
    New Finger Print Reader
    Boot into fast boot and connect your pixel to your pc
    On your PC go to pixelrepair.withgoogle.com/udfps
    Follow the Prompts
    dot Ducky -
    Replacement process went smoothly. I reattached the screen after seating the connector. No sign its working. Just black blank screen. However text and notification sounds still coming through. Even receiving calls. etc on que. I know the phone works, just not the screen.
    I figure maybe I didnt seat the connector all the way so I break the adhesive liner (figuring I'll buy another and apply again) and this time I clip in the connector for sure. Still nothing on the screen.
    What can I do? Is the screen defective?
    If phone is working should I see the display after the connector is seated but the phone still open? Or does the screen need to be seated all the way in the case to turn on? The screen does not display anything in either state by the way...
    As an aside, your instructions are so detailed until the point where the screen needs to connect and seat. It would helpful to get more pointers for this final step...
    Chobby - crwdns2934203:0crwdne2934203:0
    It's so frustrating that paper instructions are not included considering I'm about to pull the screen off my phone. It's also very frustrating that I have to load and read multiple sub instructions in the middle of the main instructions, just include all instructions in one booklet and include the booklet in the kit.
    Jeremiah Miller - crwdns2934203:0crwdne2934203:0
  17. Google Pixel 6 Pro Fingerprint Reader Replacement, Open the ZIF connector: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Open the ZIF connector: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you replace the fingerprint reader in the Pixel 6 Pro or switch it between two different displays you need recalibrate it to maintain its functionality.
    • Use one arm of a pair of tweezers to carefully open the ZIF connector at the rear side of the screen.
  18. Google Pixel 6 Pro Fingerprint Reader Replacement, Disconnect the fingerprint reader: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Disconnect the fingerprint reader: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to disconnect the fingerprint reader by pulling its cable out of the ZIF connector.
  19. Google Pixel 6 Pro Fingerprint Reader Replacement, Loosen the fingerprint reader adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the screen where the fingerprint reader is located to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
  20. Google Pixel 6 Pro Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide an opening pick underneath the fingerprint reader to slice its adhesive.
    • Be very gentle during this procedure. Too much force might damage the display. If the adhesive is hard to cut, reapply your iOpener for another minute to loosen it.
    • Be careful not to overheat the screen—the display is susceptible to heat damage.
    • Use your opening pick to separate the fingerprint reader from the screen.
    Do not bend the fingerprint reader as you attempt to remove it. It is the most fragile thing in the universe and will crack at the slightest flexion.
    James Attil - crwdns2934203:0crwdne2934203:0
  21. Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the fingerprint reader: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 6 Pro Fingerprint Reader Replacement, Remove the fingerprint reader: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to carefully remove the fingerprint reader.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing. Remove the old fingerprint reader adhesive before installing a new one.
    Ok. So I asked about getting all the stuff off the old screen before finding this article and now I know what the IFR looks like and that it can be removed. So... Once removed, if extra special careful doing so, (asks this bull in a china shop) can that very same IFR be installed on the glass of the new screen? Or once removed is it just junk at that point?
    Karen Holcomb - crwdns2934203:0crwdne2934203:0
    Also, upon further reading on the site, it occurs to me that I do not use the Fingerprint deal or any other biometrics and I never will. The passcode is more than sufficient for me. So do I even NEED that IFR to be removed and placed on the new piece of glass that will be my screen? Or can I just disconnect it when removing my old screen and leave it at that? Thanks again.
    Karen Holcomb -
    Question:
    If I take a pixel 6 pro screen including fingerprint scanner fps from device (a) and install it in pixel 6 pro (b), can I just install and activate that screen and fps of (a) in (b)? Or does only the original fps work in (b)?
    Thanks!
    Mark Forster - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2935229:08crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
238,017 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,014crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Where the heck can you buy a replacement one? I broke mine during screen replacement
Olek - crwdns2934203:0crwdne2934203:0
did you find any place where to get the replacement fingerprint module? I need to buy one too
luk355 -
The new screen did not come with the plastic frame. This would be helpful to discuss.
jkroblez - crwdns2934203:0crwdne2934203:0
Yeah, that depends on what the screen comes with when you buy it. Some places sell replacement displays with nothing else and also an option with the frame, shieldings and fingerprint reader attached
Mark Student -
Hi my name is Greg is there a way to just get a fingerprint reader for a pixel 6 pro separately I broke mine replacing my screen???
Gregory aul - crwdns2934203:0crwdne2934203:0
FYI you can try asking some sellers on aliexpress. If they sell OEM screens they also should have replacement FP sensors
I need to reapply my fingerprint do a new screen. Where is the other half of the guide?
Zach Benson - crwdns2934203:0crwdne2934203:0
Hallo ich habe den fingerabdrucksensor beim demontieren kaputt gemacht und finde keinen Ersatz im Internet wo kann ich den Sensor neu kaufen??
Jan Philipp Dexler - crwdns2934203:0crwdne2934203:0
I have seen sensors on Mobilesentrix however I am not sure about the quality or originality of the part
obsurd hotdog - crwdns2934203:0crwdne2934203:0
Bonjour, Suite au changement du bloc écran, mon empreinte ne fonctionne pas, je l'ai changé aussi l'empreinte et elle ne fonctionne pas, j'ai du mal à la paramètre erreur et ma page se ferme quand j'essaye de reparamétrer mon empreinte.... QUOI FAIRE?
Techniphone12 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 348
crwdns2942667:0crwdne2942667:0 17,963
