crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Shredder Won't Power On
You turn on the switch but nothing happens.
Plugged Into Wall
If you are experiencing no power then you should see if the shredder is plugged into the wall outlet. There may also be something with the Power cord and it needs replaced
Faulty Outlet
If the shredder is plugged into an outlet but does not power on, then test the outlet by plugging another device into it. If the other device does not work then try another outlet.
Power Cord Loose On Shredder
Power Cord is not fully attached to the shredder. Power Cord is damaged, not delivering power to motor.
Faulty Power Switch
The power switch will not work properly.
Switch Is Fixed in One Position
Open up device to address needed technical repairs. look at the Switch replacement and Mother Board Replacement guides for more details on replacement.
Shredder Will Not Shred
You insert paper into feeder but nothing happens.
Shredder Attached to Basket Correctly
The shredder will attach to the basket one way. On the bottom of the shredder there is a safety switch and when attached to the shredder will deactivate the safety and will allow you to shred.
Faulty Feeding Sensor
In the feeding slot there is a white plastic wedge. When this wedge is compressed it sends a signal to the motor and the shredding begins. If this wedge is not visible when not shredding paper, it is stuck inside the device. This can be fixed by opening the shredder and replacing the spring or entire wedge assembly. If the wedge is visible but does not activate the shredder, the whole mechanism needs to be replaced. The Feeding Sensor Replacement and Trigger Assembly Replacement guides should help with the identification and solution of this problem.
Shredder Basket Needs Emptied
If the basket is to full, you will not be able to place the shredder on the basket properly. As mention above if the shredder is not attached to the basket correctly, then the safety of the bottom the shredder will not deactivate.
Stops Shredding Half-Way Through
Shredder stops mid shredding
Paper Jam
Too much paper or too many credit cards could have been put into the shredder at once. Try reversing the wheel rotation using the on, off, and reverse switch located on top of the shredder. If that is unsuccessful remove the obstruction from the shredding wheels and try again. If the shredder is still jammed removal of the shredding wheels is necessary. To remove the obstruction follow the Gear and Shaft Disassembly.
Broken Gear
If the shredder motor is running but the wheels are not turning there may be a broken gear. To fix this open up the motor case and replace the broken gear. Here is a guide to help with this process.
Shredder Overheating
Paper shredder is really hot
Over Use
This paper shredder should only be run for 3 minutes with 5 minutes in-between sessions. Not following this procedure will cause heat to be generated. The lubricant inside the shredder can also be too low. This is fixed by opening the case and re lubricating the system. Use this Shredder Case disassembly to strip the machine down to the part you need.
Humming Sound
If there is an abnormal humming or banging sound coming from the shredder, there is most likely something broken in the internal systems. Open the shredder casing and look for visible problems with the gears, shaft, or wiring of the shredder. Here is a complete disassembly of the Shredder Case
Bent Shaft
A bent shaft will produce a grinding or shrieking noise. If the shaft of the engine is bent try unbending it. If unbending does not work a replacement shaft or motor unit will be required. Use this Shaft Replacement guide for help.
Smoke Coming From Shredder
This could be caused by an electrical short or putting too much strain on the motor unit. Stop using the shredder immediately. After 30 minutes try running the shredder again. If the shredder continues to smoke open the shredder casing and determine the cause. Most likely it is a faulty motor unit. This can be fixed by replacing or repairing the motor unit.
Austin Roudebush
crwdns2935283:010/12/16crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
IUPUI, Team 2-2, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 2-2, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S2G2
crwdns2935297:096crwdne2935297:0
crwdns2944067:025crwdne2944067:0
Shedder has power and won’t shedder
sunshineocomc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The basket won’t go all the way in and there is no blockage. The 4th indicator light is red
woody.hood - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I droped a dog tag into the schredder and stopped the schredder, but I cant get the tage to drop back out. Any suggestions?
Patricia J Capps - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
First time using shredder in newly built house. First use and it throws the breaker in any room we try it in. Do you think there is a “short” in the machine? Nothing else throws the breaker but this shredder.
Its Me - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Shredder just starts by itself, and goes for about 3 minutes or sometimes doesn’t stop. I have checked paper sensers, there is no paper in the machine.
Jackie Posthuma - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 48,062
