Fellowes T7CM Trigger Assembly Replacement
crwdns2869540:0crwdne2869540:0: 3.5K
2
25
114
3,533
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:03crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931283:030crwdne2931283:0
crwdns2955970:0crwdne2955970:0: crwdns2937585:0crwdne2937585:0
This guide shows how to replace the trigger assembly in the Fellowes T7CM.
    1. Fellowes T7CM Trigger Assembly Replacement, Fellowes T7CM Casing and Trigger Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    2. Fellowes T7CM Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    3. Fellowes T7CM Trigger Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
    4. Fellowes T7CM Trigger Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
    1. Fellowes T7CM Trigger Assembly Replacement, Trigger Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the trigger assembly by gently twisting and pushing it.
      • The assembly should come off easily with little effort.
Michael Aldrich
crwdns2935283:010/12/16crwdne2935283:0
686 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 2-2, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S2G2
crwdns2935297:096crwdne2935297:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 114
crwdns2959996:0crwdne2959996:0 3,533
