iPhone SE 2022 Lightning Connector Assembly Replacement
  1. iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the right edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the pentalobe screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the pentalobe screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  3. iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
    Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
    Alasdair Cameron - crwdns2934203:0crwdne2934203:0
    I bought the kit of five just in case. I used two and marking them at 3mm was definitely helpful.
    Megolina - crwdns2934203:0crwdne2934203:0
  4. iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  5. iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  6. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  7. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
    Neal Sofge - crwdns2934203:0crwdne2934203:0
  8. iPhone SE 2022 Lightning Connector Assembly Replacement, Heat the front panel adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  9. iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  10. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  11. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  12. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  13. iPhone SE 2022 Lightning Connector Assembly Replacement, Lift the screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift the screen: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  14. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  15. iPhone SE 2022 Lightning Connector Assembly Replacement, Disengage the front panel clips: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disengage the front panel clips: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  16. iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  17. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the lower display cable bracket screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  18. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the lower display cable bracket: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the lower display cable bracket: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  19. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the battery: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
    I’d like to replace the battery while I’m here. How to !??
    Richard McGinley - crwdns2934203:0crwdne2934203:0
  20. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  21. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the front sensor assembly bracket screws: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
    3개 볼트 자석 드라이버에 안붙어요.
    경북의성 (경북의성) - crwdns2934203:0crwdne2934203:0
  22. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the front sensor assembly bracket: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the front sensor assembly bracket: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  23. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the front sensor assembly cable: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the front sensor assembly cable: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  24. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the display assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the display assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display assembly.
  25. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector bracket screws: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the three screws securing the Lighting connector bracket:
    • One 1.2 mm-long Y000 screw
    • One 2.7 mm-long Phillips screw
    • One 2.9 mm-long Phillips screws
  26. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector bracket: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector bracket: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the Lightning connector bracket.
  27. iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide an opening pick between the antenna flex cable and the top of the speaker.
    • This portion of the flex cable is lightly adhered to the speaker. If you're struggling to separate the cable from the speaker, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
  28. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Wi-Fi diversity antenna: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Wi-Fi diversity antenna: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna by prying its connector straight up from its socket.
    • The socket of this connector sits loosely between the speaker and the Taptic Engine and it's a bit fiddly to disconnect the cable. To make the disconnection easier, you can use an opening pick to hold down the connector socket during this procedure.
    • Reconnecting this cable can be tricky. Make it easier by using tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
  29. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna from the logic board by prying the connector straight up from its socket.
  30. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Wi-Fi diversity antenna: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Wi-Fi diversity antenna: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the Wi-Fi diversity antenna.
  31. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Taptic Engine screws: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the Taptic Engine:
    • One 2.1 mm Phillips screw
    • One 2.1 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  32. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the grounding bracket: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the grounding bracket: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the grounding bracket at the left edge of the Taptic Engine.
  33. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry the antenna cable socket: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry the antenna cable socket: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry the antenna cable socket up and away from the Taptic Engine connector below.
  34. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Taptic Engine: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Taptic Engine: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
  35. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Taptic Engine: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Taptic Engine: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the Taptic Engine.
    Note that the grounding connector on the Taptic Engine's left side goes under the fixed contact, you'll need to remember than when reassembling.
  36. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the barometric vent screws: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the barometric vent:
    • One 1.9 mm-long Phillips screw
    • One 1.7 mm-long Phillips screw
  37. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the barometric vent.
    • The barometric vent is lightly adhered to the rear case. If you're struggling to separate the vent from the case, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the barometric vent safely.
  38. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the rear camera: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the rear camera: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the rear camera by prying the connector straight up from its socket.
  39. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the rear camera bracket screws: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm-long standoff screw
    • One 3.1 mm-long Phillips screw
  40. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the rear camera bracket: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the rear camera bracket: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the rear camera bracket.
  41. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the flash: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the flash: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the flash by prying the connector straight up from its socket.
  42. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the upper cable bracket screws: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the upper cable bracket:
    • One 2.8 mm-long Phillips screw
    • One 1.2 mm-long Phillips screw
  43. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the upper cable bracket: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the upper cable bracket: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the upper cable bracket.
  44. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the upper flex cable: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the upper flex cable: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the upper flex cable by prying the connector straight up from its socket.
  45. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the top left antenna component screws: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the three 1.2 mm-long Phillips screws securing the top left antenna component.
    • Don't try to remove the antenna component yet. There's a fourth screw securing it to the rear case.
  46. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the 1.4 mm-long Phillips screw securing the antenna component to the top edge of the rear case.
  47. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left antenna component: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left antenna component: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the top left antenna component.
  48. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the grounding bracket screws: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the two screws securing the top left grounding bracket:
    • One 1.5 mm-long Phillips screw
  49. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left grounding bracket: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left grounding bracket: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the top left grounding bracket.
  50. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the logic board screws: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the four screws securing the logic board:
    • One partially threaded 1.7 mm-long Phillips screw
    • This screw is covered by protective foam surrounding the rear camera connector. Use a pair of tweezers to peel just enough foam off to unfasten the screw.
    • One 2.5 mm-long standoff screw
    • One 2.2 mm-long standoff screw
  51. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board grounding bracket: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board grounding bracket: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully pry up the logic board grounding bracket in the top right corner of the rear case.
  52. iPhone SE 2022 Lightning Connector Assembly Replacement, Position the SIM card eject plunger: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Position the SIM card eject plunger: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to move the SIM card eject plunger out of the logic board's way by pushing it to the right edge of the rear case.
  53. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the Lightning port cable by prying the connector straight up from its socket.
    • Use the pointed end of a spudger to disconnect the wireless charging coil cable by prying the connector straight up from its socket.
  54. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to gently pry up the battery connector end of the logic board.
    • Be careful not to pry against any cables. If you feel resistance, check that all cables, connectors, and components are clear of the board.
  55. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasping it by the edges, lift the logic board near the battery connector and remove it.
    • Make sure that none of the surrounding cables are tangled with the logic board or blocking its way.
  56. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the loudspeaker screws: crwdns2935265:056crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfasten the two screws securing the loudspeaker:
    • One 1.4 mm-long Phillips screw
    • One 2.1 mm-long Phillips screw
  57. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the loudspeaker.
  58. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector assembly screws: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector assembly screws: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unfasten the five screws securing the lighting connector to the rear case:
    • One 1.3 mm-long Phillips screw
    • Two 2.3 mm-long Phillips screws
    • Two 1.4 mm-long Phillips screws
  59. iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to gently pry the two microphones on the left and right of the Lightning connector free from the adhesive securing them in place.
    • Don't try to completely remove the microphones; just separate the adhesive as shown.
  60. iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the charging port assembly adhesive: crwdns2935265:060crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom of the rear case to loosen the charging port assembly adhesive, angling it as shown.
  61. iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the top portion of the Lightning connector assembly flex cable, and begin separating the cable from the rear case.
    • Part of the wireless charging coil lies directly underneath this portion of the Lightning connector flex cable. Aggressive prying may damage the coil.
    • If needed, use your hair dryer or iOpener repeatedly to re-heat the area behind the Lightning connector assembly flex cable in order to further soften its adhesive.
    • Continue separating the upper portion of the flex cable, being careful not to damage any other components along the way.
    • Keep the battery connector gently folded out of the way to avoid damaging it.
    • Be very careful not to damage the battery itself. A punctured battery can leak dangerous chemicals and/or catch fire.
    • Stop sliding the pick once it passes the lower edge of the battery.
  62. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the corner of the phone, slide the pick underneath the cable towards the Lightning connector.
    • Stop sliding the pick when it reaches the Lightning connector.
  63. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the Lightning connector out of its recess in the rear case.
    • Don't try to remove the lightning connector assembly all the way yet. It is still partly adhered to the rear case.
  64. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening pick below the Lightning connector to further separate the assembly from the rear case.
    • Continue to slide the pick until the Lightning connector assembly is no longer adhered to the bottom of the rear case.
    • Don't try to remove the lightning connector assembly all the way yet. A last bit is still adhered to the left edge of the rear case.
  65. iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening pick between the left edge of the rear case and the remaining adhered section of the Lightning assembly.
  66. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: crwdns2935265:066crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: crwdns2935265:066crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: crwdns2935265:066crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Before removing the adhesive backing on a new assembly, make sure the Lightning connector assembly is correctly positioned by aligning the hole in the flex cable with the screw post. If the cable is misaligned, you won't be able to reconnect it to the logic board.
  67. iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    • Check if your new part comes with an antenna converter cable. If it doesn't, use the pointed end of your spudger to pry up and transfer the cable from your old Lightning assembly to the new one.
    If transferring the antenna converter cable, check it fits the new board before re-assembling.
    robato - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Compare your new replacement part to the original part—you may need to transfer other remaining components or remove additional adhesive backings from the new part before installing.
crwdns2935229:08crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237.912 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022.002crwdne2935297:0
After doing this my loudspeaker has static. Anyone else experience this?
yzcheema11 - crwdns2934203:0crwdne2934203:0
Brilliant guide, thank you. I found the donor antenna converter cable in the last step (67) to be really difficult to handle. It came loose between connecting the taptic engine (step 35) and wifi diversity antenna (step 28), because I had to put the taptic engine connector under the antenna converter cable, so this twisting motion probably lifted it out of the co-ax(?) connector. Had to undo logic board and remove WIFI diversity antenna + loudspeaker to fix it.
I would suggest re-fit in this order: lightning connector assembly (step 66), taptic engine (step 35), connect donor antenna converter cable to lightning connector assembly and sit it on top of the taptic engine connector (not really shown in the current guide, but around step 28), loudspeaker (step 57), WI-Fi diversity antenna (step 30) - this then secures the Wi-Fi bits but can easily be reversed should it become dislodged; then continue with remaining steps from logic board (step 55) onwards.
In the end, re-assembled successful and very useful guide.
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 522
crwdns2942667:0crwdne2942667:0 10,728
