iPhone SE 2022 Home/Touch ID Sensor Replacement
  1. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  2. iPhone SE 2022 Home/Touch ID Sensor Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone SE 2022 Home/Touch ID Sensor Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone SE 2022 Home/Touch ID Sensor Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
    Neal Sofge - crwdns2934203:0crwdne2934203:0
  7. iPhone SE 2022 Home/Touch ID Sensor Replacement, Heat the front panel adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  8. iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  9. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  10. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  12. iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift the screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  13. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  14. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disengage the front panel clips: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disengage the front panel clips: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  15. iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone SE 2022 Home/Touch ID Sensor Replacement, Unfasten the lower display cable bracket screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  17. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the lower display cable bracket: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the lower display cable bracket: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  18. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the battery: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
    I’d like to replace the battery while I’m here. How to !??
    Richard McGinley - crwdns2934203:0crwdne2934203:0
  19. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  20. iPhone SE 2022 Home/Touch ID Sensor Replacement, Unfasten the front sensor assembly bracket screws: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
    3개 볼트 자석 드라이버에 안붙어요.
    경북의성 (경북의성) - crwdns2934203:0crwdne2934203:0
  21. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the front sensor assembly bracket: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the front sensor assembly bracket: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  22. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the front sensor assembly cable: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the front sensor assembly cable: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  23. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the display assembly: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the display assembly: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display assembly.
  24. iPhone SE 2022 Home/Touch ID Sensor Replacement, Unfasten the home/Touch ID sensor bracket screws: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws securing the home/Touch ID sensor bracket:
    • Three 1.2 mm-long Y000 screws
    • One 1.1 mm-long Y000 screw
  25. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor bracket: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor bracket: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully remove the home/Touch ID sensor bracket.
  26. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry under the left edge of the home/Touch ID sensor cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of a spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
  27. iPhone SE 2022 Home/Touch ID Sensor Replacement, Heat the home/Touch ID sensor cable adhesive: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the screen where the home/Touch ID button is located for at least two minutes to loosen the adhesive underneath its cable.
  28. iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide an opening pick underneath the home/Touch ID sensor cable and separate it from the back side of the display panel.
    • Avoid damaging the cable connector during this procedure. The home/Touch ID sensor cable is wrapped around it and abrupt movements might tear the connector cable. Try to fold the connector up in direction of the selfie camera and out of the cables way instead.
  29. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
    Do you know where I can get a replacement part
    GamErPlayer - crwdns2934203:0crwdne2934203:0
    Sorry if this is a dumb question, but is there a guide to actually installing the part once these steps are all completed? I get the idea of going backwards, but it seems like there are places that adhesive must be applied, and perhaps some tips on how to do that correctly (or incorrectly! :D ) that might warrant spelling it our for us old folks.
    Jim - crwdns2934203:0crwdne2934203:0
    I’ve got a SE3 here and got the part from Apple self repair! How ever that does not configure
    Kurnaz Tilki - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before installing new adhesive and resealing.
crwdns2935229:05crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
234,590 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,688crwdne2935297:0
crwdns2947412:05crwdne2947412:0
So where can I buy one of these specially-made, universal-style home buttons? I'm on an SE 2nd Generation (A2296).
Sam Donald - crwdns2934203:0crwdne2934203:0
I'm in the same boat, a lot of the ones on Amazon and such either say they won't work at all and are purely cosmetic or don't specify anything related to functionality. Really makes it difficult to fix it and get whatever resale value might be left over afterward. If I was to reset the phone, I don't think I'd be able to even get into Settings to turn on Assistive Touch because the method I used was to use random notifications from the Settings app and enable it that way, how would I even make it past the pressing home to begin the iPhone setup process. Great design Apple.
abdullahcfix -
I have 3rd gen and cannot buy the sensor at any phone repairer. An eBay ad suggested they had one for SE. I bought that but more suitable to iPhone 7 and under. So at this stage it’s assistive touch only which is a real pain.
Rod G - crwdns2934203:0crwdne2934203:0
try looking on eBay KEY WORDS RETUN FUNTION
Ifix101 -
u guys realy need to start carrying this i replaced the battery in my 2022 se i damage absolutely nothing and now the home button stopped working
Jimmydean hilltow - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 155
crwdns2936753:030crwdne2936753:0 650
crwdns2942667:0crwdne2942667:0 15,187
