iPhone SE 2020 Battery Replacement
  1. iPhone SE 2020 Battery Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - crwdns2934203:0crwdne2934203:0
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - crwdns2934203:0crwdne2934203:0
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - crwdns2934203:0crwdne2934203:0
    Maybe the screw is stripped…
    Gabriel-Science -
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - crwdns2934203:0crwdne2934203:0
    Does it lasted longer ?
    Gabriel-Science -
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - crwdns2934203:0crwdne2934203:0
    Same problem. The kit comes with a screw driver, but not for this pentalobe screw. This is a problem.
    Yuji Ishitsuka - crwdns2934203:0crwdne2934203:0
    I had to search what screwdriver bit I had to use from the ifixit toolkit; it's the P2 bit. (Maybe it's more obvious if you bought the battery kit, because it only has one type of pentalobe screwdriver.)
    Nathaniel Zielstra - crwdns2934203:0crwdne2934203:0
  2. iPhone SE 2020 Battery Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
    Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
    Alasdair Cameron - crwdns2934203:0crwdne2934203:0
  3. iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone SE 2020 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone SE 2020 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone SE 2020 Battery Replacement, Heat the display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    No hair dryer so GENTLY heated over stove burner
    John Toth - crwdns2934203:0crwdne2934203:0
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - crwdns2934203:0crwdne2934203:0
    I was about to ask the same Question...
    Enno Winch -
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - crwdns2934203:0crwdne2934203:0
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - crwdns2934203:0crwdne2934203:0
    Hey, that's smart !
    Gabriel-Science -
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - crwdns2934203:0crwdne2934203:0
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - crwdns2934203:0crwdne2934203:0
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - crwdns2934203:0crwdne2934203:0
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - crwdns2934203:0crwdne2934203:0
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - crwdns2934203:0crwdne2934203:0
    It won't work if you don't throw it in the lava.
    Gabriel-Science -
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - crwdns2934203:0crwdne2934203:0
    Hairdryer works fine for this step. No issues.
    Agree! Just did it for 2 times to make sure I didn't overheat the phone.
    André Lopes -
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - crwdns2934203:0crwdne2934203:0
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - crwdns2934203:0crwdne2934203:0
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - crwdns2934203:0crwdne2934203:0
    This part was actually much easier than I thought. I used a hair dryer on max for 2 minutes on each side of the phone, less than half an inch away from the phone, just on the bottom half. It was hot! Screen came right out!
    Nuno Lopes - crwdns2934203:0crwdne2934203:0
    I used a tube sock full of about 1 cup of white rice. Tied a knot in the top of the sock. Put the sock of rice in the microwave on 60% power for 1 minute. Kept doing this until the temp felt right. Put the sock of rice down, put bottom edge on sock, then covered w/ other half of the sock/rice. Put a piece of paper towel between phone and sock/rice to absorb any moisture. When lifting up on front panel, I rested the phone on the sock/rice. Worked nicely once I got the temp of the rice high enough.
    (threw the rice away later :-) )
    Burning Sensation - crwdns2934203:0crwdne2934203:0
    “Threw the rice away later” has to be the best advice here. I wrapped my phone in a small heating pad and turned it up to 6 of 8. Worked great in 5 min or less! No need for water bottles, microwaves, heat guns, volcanoes, …. I kept the heating pad later ; )
    dantegd - crwdns2934203:0crwdne2934203:0
    I popped my iPhone under a desk lamp with a 60w filament light bulb in it, switched it on, (See this photo) then read the iFixIt instructions and comments. By the time I’d done that, the glue had softened enough to start work. I managed to do the whole process, slowly and methodically, without incident. The iPhone even worked after I’d put it all back together. So we’ll done iFixIt. Another satisfied customer!
  7. iPhone SE 2020 Battery Replacement, Separate the display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement, Separate the display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - crwdns2934203:0crwdne2934203:0
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - crwdns2934203:0crwdne2934203:0
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - crwdns2934203:0crwdne2934203:0
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - crwdns2934203:0crwdne2934203:0
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - crwdns2934203:0crwdne2934203:0
    This was the time consuming part. I’d recommend having a thin bladed knife or similar to get things going. I used the small blade on my Swiss Army knife, but be careful. When it goes, it can be unexpectedly sudden. I also used a strong rubber band to stop any excessive opening of the screen.
  8. iPhone SE 2020 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - crwdns2934203:0crwdne2934203:0
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - crwdns2934203:0crwdne2934203:0
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - crwdns2934203:0crwdne2934203:0
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - crwdns2934203:0crwdne2934203:0
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - crwdns2934203:0crwdne2934203:0
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - crwdns2934203:0crwdne2934203:0
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - crwdns2934203:0crwdne2934203:0
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - crwdns2934203:0crwdne2934203:0
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - crwdns2934203:0crwdne2934203:0
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - crwdns2934203:0crwdne2934203:0
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - crwdns2934203:0crwdne2934203:0
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - crwdns2934203:0crwdne2934203:0
  9. iPhone SE 2020 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - crwdns2934203:0crwdne2934203:0
  10. iPhone SE 2020 Battery Replacement, Screen information: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - crwdns2934203:0crwdne2934203:0
  11. iPhone SE 2020 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    No pick in the kit you sent me.
    Ted Cooper - crwdns2934203:0crwdne2934203:0
  12. iPhone SE 2020 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone SE 2020 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - crwdns2934203:0crwdne2934203:0
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - crwdns2934203:0crwdne2934203:0
  14. iPhone SE 2020 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    I had trouble sliding down the display and found I hadn't separated the stop enough.
    Jeffrey Anderson - crwdns2934203:0crwdne2934203:0
    When you are pulling the display downward, be very careful! I pulled a little too hard and the display cables tore from the downward (toward home button) motion. Now I have to replace the display! 😭
    So Munch Love - crwdns2934203:0crwdne2934203:0
  15. iPhone SE 2020 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - crwdns2934203:0crwdne2934203:0
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - crwdns2934203:0crwdne2934203:0
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - crwdns2934203:0crwdne2934203:0
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - crwdns2934203:0crwdne2934203:0
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  16. iPhone SE 2020 Battery Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $17.96
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
    can same length screws mixed up?
    Brook布魯克 - crwdns2934203:0crwdne2934203:0
    It is not ideal, but possible for these screws.
    Arthur Shi -
    using the repair kit i purchased with my screen replacement, i am currently having issues removing these screws with the PH000. please help
    Mark Ordaz - crwdns2934203:0crwdne2934203:0
    I was too, thankfully I had another set that contained the PH00 bit, that worked great for me.
    William Mitchell -
    Ok. My screw is stuck. How do I remove it? Philips head is stripped.
    Kristina Graham - crwdns2934203:0crwdne2934203:0
    Solved it myself. Firm pressure did the trick.
    Kristina Graham -
    Takes a little pressure with the Philips head
    Upon this step, I noticed I had no bracket or screws. I had my screen replaced previously and I’m disappointed to find out the repairperson made no effort to replace these parts. I’ll start trusting myself more to do my own repairs.
    O D - crwdns2934203:0crwdne2934203:0
    took me awhile to figure out I needed to use PHOO bit for the 2 -1.3 screws
    It is important to keep careful track of the screws' position. Have a tidy workplace -- a few times when I tried to re-attach the very tiny screws with the tweezer, they slipped and flew away and I almost lost them.
    can you strip the screws / how can you tell if its strip or not
    antonio - crwdns2934203:0crwdne2934203:0
  17. iPhone SE 2020 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Make sure you pry the battery connector off from the right hand side as shown in the picture. Theres a delicate component on the logicboard near the battery connector called a Mosfet which is linked to the battery charging software. If you knock it off accidently you’ll loose battery charging and the phone will boot loop and youll need to have it re-soldered back on.
    Gareth - crwdns2934203:0crwdne2934203:0
    I can confirm this as I learned my lesson by unknowingly prying the mosfet off. The phone will not charge now and is useless. I really wish they would add a note about this on Step 12 as a warning.
    Jeff -
    So this is it. You don’t have to go any further removing the screen. You can replace the battery right from this point.
    John M - crwdns2934203:0crwdne2934203:0
    I wish I saw this comment 2 hours ago
    Kenneth Moore -
    If I have to repeat this, I'd also consider removing replacing the battery at this point. The loose display must be then carefully fixed so the connectors don't break. And then it is not possible to re-attach the waterproof seal.
    The waterproof seal was included in the kit, but there were no instructions for it so I now skipped that. I later found YouTube video which seems to describe it (starting at 7:40):
    https://www.youtube.com/watch?v=RcgGRhaX...
    Matti Haveri -
    This is where I broke my phone, a phone that was working quite well, paid for in full. Just because I had a cracked screen. Be super careful when connecting the cables. I was in a hurry and not paying attention, used too much force when re-connecting and broke those teeny little pins that could not be repaired. A tech tried for an hour to no avail. cautionary tale. Good luck
    The display ribbon is a certain length and allows for some give, but behind it is hidden the Home button/TouchID ribbon, which sits against what amounts to a razor blade. This ribbon is much more taut than the display one, and therefore you have far less freedom of movement than you think you do. This is absolutely an intentional trap to discourage replacing your own battery. Quite frankly, it’s despicable.
    Anyway, so beware of that, because although I was very careful and did not even swing the screen very far (not more than 90°), the Home button ribbon tore and now needs to be serviced. Home button is disabled now.
    Apple should be ashamed of themselves for this. Please do look at the legislation effort that people are doing to try to get this kind of sabotage illegal, as well as all sorts of other gimmicks they pull. For a company that makes phenomenal products, they’re controlling like an abusive spouse.
    Dan Knight
    daniel - crwdns2934203:0crwdne2934203:0
    That happened to me and I could not figure out how it got broken. It's the home button and fingerprint reader.
    But I'm not bothering to get it fixed and I'm not replacing the entire screen. I went into system prefs/accessibility and activated the on-screen home button. Oh, well.
    Mangled Jargon -
    I cannot get the new battery reconnected to the connection port. Any tips/tricks? New and old battery connections appear similar. It wasn't difficult to disconnect to old battery.
    Robert Ast - crwdns2934203:0crwdne2934203:0
    Some reports here seem to indicate that the battery must be the very last connector to re-connect because otherwise there might be malfunction in some display components?
    It wasn't difficult to disconnect to old battery. But the most difficult part for me was to get the new battery reconnected to the connection port. I tried many times to carefully position and press it down with my fingertip or the flat end of the spudger but it did not hold its position. Maybe I pressed too weak because I was afraid breaking the connector and the mosfet above (?) it. But finally to my surprise it connected (at that point I temporarily booted the iPhone with the loose display to verify that the battery was connected). Whew, it succeeded!
    The connectors have very little "click" to them when they do seat properly, and are covered with soft foam. Very challenging to attach them by feel, and having the screen propped up, blocks light from exactly where you need it.
    Steve Trotman - crwdns2934203:0crwdne2934203:0
    Make sure the new battery connector cable has similar length and width to the one of the original battery. I got a third party battery and the cable was longer and not folded in a "U" way near the connector, like the one in the genuine battery was, only folded at a 90 degree angle. That "U" actually perfectly fits in the small space between battery and connector port, so the cable doesn't stick up thus making connecting it or closing the screen impossible. So fold the cable, connect it, and while holding it to prevent it from disconnecting, stick the battery so the "U" curve of the cable sits down just between battery and connector port.
  18. iPhone SE 2020 Battery Replacement, Disconnect the display and digitizer: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement, Disconnect the display and digitizer: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I broke the lower display connector. Is it possible to replace that part separately or do I need to buy a full screen replacement?
    Ross Mckellar - crwdns2934203:0crwdne2934203:0
    You need to buy a new screen
    conrad veldhouse -
    이렇게 친절하게 정성스럽게 분해도 올리신 분은 처음이네요 진정 프로/ 기타 나머지 잡것들은 대충 올려 돈이나 벌어보자는 업자num들/ 배터리 교체하는 유툽 영상보다...업자가 올린 ...배터리 교체는 따라했으나 그후 배터리 교체와는 전혀 상관 없는 액정 뒤판을 jo빤다고 설명도 없이 뜯어 그것까지 따라하다 액정이 나가버려 지금 무주공산에서 홀로 검색하다 이걸 보게됨
    평생놀아난다 - crwdns2934203:0crwdne2934203:0
    The tip about how to re-attach press connectors without damaging them should really be at the last press connector step since we're following the steps in reverse order to reassemble.
  19. iPhone SE 2020 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to disconnect the second lower display cable.
  20. iPhone SE 2020 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    If you are replacing the adhesive liner, the remaining release liner strips will interfere with the two outer screws. I had to cut a working section out of the liner at each location and move it aside with the spudger.
    Thomas Tritt - crwdns2934203:0crwdne2934203:0
    This part is throwing me for a loop. Having difficulty finding the read head for these screws. Is it the same size as the two small 1.3mm screws in step 12?
    Jared Hensley - crwdns2934203:0crwdne2934203:0
    These are the same size screws mentioned in Step 17.
    Douglas Walker -
    ended up getting it with the PH000, I must of just been rushing it.
    My bracket looks different and none of the screw heads I have fits.
    Ray Rushing - crwdns2934203:0crwdne2934203:0
    Mine too? Any help?
    George Waller -
    These screws did not stick to the magnetic screwdriver. Extremely difficult to get them back in place - but with some patience i succeeded :)
    Niklas Brammer - crwdns2934203:0crwdne2934203:0
  21. iPhone SE 2020 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
    Do you have a link for the flex cord shown in the pictures so I can purchase it? Having a hard time locating that exact assembly
    Regal Carveiro - crwdns2934203:0crwdne2934203:0
    It’s of a piece with the front camera.
    xint - crwdns2934203:0crwdne2934203:0
    ここの、マザーボード側のピンが数本なくなっていた場合
    交換するには、どの部品名で探せば良いですか?
    ren12o7.2011 - crwdns2934203:0crwdne2934203:0
  22. iPhone SE 2020 Battery Replacement, Remove the display assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Hi ifixit, if you find my method dangerous, please remove it.
    After Step 17, I skipped Step 18 to Step 28.
    At Step 29, I lifted up the four adhesive black pull-tabs to expose the white adhesive side. Next, I use hot air gun and blow on the back cover of the iphone for about a minute (maybe a hairdryer will work too) .
    Warning: Don't overheat the iPhone, or you may accidentally ignite the battery.
    I think the temperature was around 60 DegC.
    Extreme Caution: Do Not overheat. I use my hand to gauge the hotness. Careful not to burn yourself or the board.
    I was able to pull out all the white adhesive tapes easily as the adhesive soften.
    DO NOT TRY this method if you are a novice or inexperience! I am not responsible if you hurt yourself or damage your iphone!
    Hey John! I’m glad the repair worked out for you!
    From our research, applying heat does soften the adhesive strips, but it also causes them to lose structural integrity and break more easily. That’s why we normally suggest using heat after the strips are already broken. Removing the Taptic Engine definitely takes a few extra steps, but we feel that it gives fixers the best chance of pulling out the adhesive strips intact.
    Arthur Shi -
    I agree with John, skip 18 through 27. These are to make it easier to remove the battery adhesive. I replaced the batteries on two IPhone 8s. The first one I did all that stuff and the adhesive still broken and I had to carefully pry the battery out anyway. When I reassembled the phone the Home button no longer worked. Looking it up, this is apparently fairly common due to all the fragile wires involved in these steps. The second I skipped these steps and when I reassembled it everything worked fine. Not one of the eight (both phones) adhesive strips came out properly. I fully drained the batteries before doing the repairs. By the way, I use the virtual home button on the one phone, it’s a little annoying, but the phone is still usable if you’re not ready to shell out for a new phone.
    Gary Berman -
    I also skipped removing the Taptic Engine. I could only half-way pull the lower battery tapes and completely the upper tapes after carefully prying them loose with the tweezer. I then used a hair-dryer for a minute to warm the battery and the other side of the phone (I used my other hand to make sure I did not apply too much heat. Make sure you do not blow the tiny loose screws away with the hair dryer!) and then slowly lifted the upper battery somewhat with the Opening pics tool, then re-heated the lower remaining tapes and quite easily lifted the battery out.
    I had bought two-sided tape to reconnect the battery but it had the tapes pre-installed (I wonder if it is necessary to tape the battery at all?).
    Matti Haveri -
    I also skipped these steps. I won’t say it was entirely successful - two of the four adhesive strips broke and could not be grabbed with tweezers. But I had gotten most of the adhesive out already and the battery was quite loose, so I used a warmer under the phone, then gently slid a flat plastic blade under one end of the battery and slowly worked it up the phone. (Dental floss would have been safer-don’t do what I did, kids!)
    Matt D - crwdns2934203:0crwdne2934203:0
    Likely can skip step 18-28 and all the risks. Battery tape is relatively removable by the following method
    - use a tweezer to pull up a corner of each tape. Then use fingers to peel back all the black tab on top of battery
    - use 2 hands. Index and thumb on both. Pull about 1/4” with one hand, hold the tension and pull 1/4” with the other hand. Alternate, go slow. Pull out all 4 tape completely. I think the pause after each 1/4” while holding the stretched tape firmly prevents the tape from over stretching to become too thin and break.
    - Don’t apply heat, I would guess that makes tape softer and break easier.
    Have tried other methods and failed in the past. Pulling too fast (tape will snap) or use a tweezer to twist/roll (sharp edges will cut tape) Anyway, just use index/thumb on both hands and alternately pull slowly
    I did do 2 iPhone 8 battery change this way. One removed all tape without breaking. Another broken all 4 tape after about 1/3 pulled so likely some factory assembly differeces.
    I second this, this method works well in most cases. Removing the haptics helps to keep the angle low and pulling the tape as straight as possible
    Hein Blöd -
    Howards method for removing the adhesive works like a charm. The only addition I made was to slightly warm the back of the iphone on a rice pack (used for sore neck muscles—haha). Going back and forth between hands is really crucial. While on hand gives a gentle pull, the other holds the phone from moving. Slow back and forth. Thanks.
    Lynn Thomas - crwdns2934203:0crwdne2934203:0
    Struggling with the glued down display, then properly cleaning all the remains of the old seal, then positioning the new seal is 95% of this job. I purchased my phone refurbished and it clearly had already been serviced once, there were remnants of an old seal below the current seal due to improper cleaning and prep that made getting the phone open harder than it needed to be.
    For my 2nd iPhone 8 battery replacement, I chose not to remove the display completely, or the Taptic Engine and I was successful. You have to pay extra attention and it is a bit trickier to keep the display from moving around too much, but I think minimizing the amount of screws and connections to take out, the better. You can easily lose the screws and you have to mind which ones go where, as there are so many different lengths. YMMV.
    In retrospect, I also would have skipped ahead to step 33. I didn't, but my efforts at removing the adhesive tape were also unsuccessful so steps 23-33 were for naught. Ended up applying isopropyl alcohol, then warming the back, and finally just physically levered the battery out. Battery was slightly deformed and became slightly warm, so as soon as I got it out I just put it outside on a brick.
    But the replacement worked.
    Peter Benson - crwdns2934203:0crwdne2934203:0
  23. iPhone SE 2020 Battery Replacement, Remove the Wi-Fi diversity antenna: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws securing the bracket next to the Taptic Engine:
    • One 1.3 mm Y000 screw
    • One 2.7 mm Phillips screw
    • One 2.9 mm Phillips screw
    My phone had Phillips screws in all three places, so I did not need the Y000 screwdriver bit.
    Daryl Maunder - crwdns2934203:0crwdne2934203:0
    I don’t see the point in steps 18-27 if we’re only changing the battery. I pulled out the sticky tape with taptic and all this other jazz still intact. Am I missing something? Reconnecting that taptic connection cost me 5 years off my life, needlessly.
    William Mitchell - crwdns2934203:0crwdne2934203:0
    Hey William!
    We instruct people to remove the Taptic Engine in order to minimize the chance that the battery adhesive will tear when you try to pull it out. The steep angle you have to pull the adhesive with the Taptic Engine installed dramatically increases the chance that the adhesive will break under the battery.
    Arthur Shi -
    since the sticky tape will usually tear anyway and it is no big deal, I agree stop at this point and take the battery out. Too many things can go wrong removing more screws and connecting/disconnecting all the connectors. Go to video instructions at this point. Wish I did.
    Bob McCall - crwdns2934203:0crwdne2934203:0
    My tape tore away and now my home button does not work, which from what I see is to do with the tapic engine. It seems to be more dangerous to do that than to use heat and pry the battery out (which I had to do anyway). You should at least put in an warning/option for users.
    Gary Berman - crwdns2934203:0crwdne2934203:0
    Hi Gary,
    The Home button connector is not related to the Taptic Engine and should not be affected by anything close to the battery adhesive. I would suggest carefully disconnecting and reconnecting the screen connectors, and make sure that there is no debris on the contacts. Be sure to disconnect the battery before you do this, or you will risk damaging the screen.
    Arthur Shi -
    Glad I stopped and watched the video at this point and skipped this step. Totally unnecessary, I used the iopener and heated the back of the phone before removing the battery with a pick and “ifixit card” came out easily. Not my first battery replacement.
    Rick Collins - crwdns2934203:0crwdne2934203:0
    Kompletter bullshit!! Im Video wird es anders gezeigt und die Schritte 18-27 werden komplett ausgelassen. Ist auch viel besser so, da so das Risiko, dass man die Taptic Engine schrottet, wie es mir jetzt beim ausbauen passiert ist, einfach nicht vorhanden ist. Ich kann auch nicht nachvollziehen, warum man in einer schriftlichen Anleitung zum Akku Wechsel komplett andere Schritte schildert als im Video. An der Stelle hat iFixit deutlich versagt. Ein Haufen Splasher…
    Maximilian Ament - crwdns2934203:0crwdne2934203:0
    Hallo Maximilian, du hast Recht, im Video wird die kürzere Methode gezeigt. Der Ausbau des Akkus ist für viele Menschen jedoch sehr schwer, wenn die Taptic Engine noch verbaut ist. Deshalb empfiehlt die Anleitung den Ausbau der Taptic Engine.
    Fabian Neidhardt -
    I can’t get the 2.7mm screw to tighten down the bracket.. not sure what i did wrong? the 2.9 will tighten in either place but the 2.7mm wont tighten anywhere.
    cb brooks - crwdns2934203:0crwdne2934203:0
    Kann es sein das dieser Schritt falsch ist? Ich habe einen Y000 Schraubendreher aus dem Iphone 7 Set. Der passt aber nicht bei der roten Schraube.
    Sebastian Dechent - crwdns2934203:0crwdne2934203:0
    The new part I received had two Phillips screws, so when you're doing the reverse, you may need to remove the screws from the new part before putting the old screws in, everything fit together otherwise
    Ronald Mitchev - crwdns2934203:0crwdne2934203:0
    I really hope you guys not to skip these steps. it is really hard to pull out string with taptic engine. 4 of 3 strings were cutted when I treid to detach batteries with taptic engine. So, I really recommend you to get rid of taptic engine before you start this step. But if you skipped and strings are cutted, there is a way. Use hair dryer 90 secs as maximum hot behind the battries and detach the batteries. It worked to me.
    Min Su Kang - crwdns2934203:0crwdne2934203:0
    The Y000 screw has an extremely shallow head and the screwdriver provided in the kit I used couldn't grip it at all. I skipped the entire taptic removal and was able to remove the adhesive with it in place by warming the phone then wrapping the end of the adhesive strips around a small screwdriver and gently rolling them out and away.
    You can totally skip removing the Taptic Engine. Even with broken adhesive strips, I was still able to get the battery out with some patience. I removed it once before on a replacement and the strips still broke off, so removing the engine was kind of a waste of time anyways.
    I skipped removing the Taptic Engine (this was my second iphone SE replacement). In both replacements, 4 tabs broke off at the top and bottom of the battery (no matter how slowly I pulled). I found the best success using 91% Isopropyl Alcohol in all 4 corners of the battery to dissolve the adhesive. I took a clear straw and put one end of it in the bottle of alcohol and covered the top end of the straw with my finger to create a vacuum to hold the liquid in the straw. I placed about 1/4 inch of alcohol in the bottom of the straw by keeping my finger on top to keep the liquid from leaking out of the straw). I placed 1/4 inch of alcohol at each corner of the battery and let it work it's magic for about 5 minutes dissolving the adhesive. I repeated this process a second time just to make sure all the adhesive was weakened sufficiently. I used the flat end of the Spudger to carefully pry out the battery. Do not pry in the top left corner as there is a cable embedded under the battery you could damage.
    Doug Dombek - crwdns2934203:0crwdne2934203:0
    1. I agree you don't need to remove anything from this point and jump directly to remove the battery.
    2. the Y screw you can remove with (closed) tweezers, if you really wish to follow this step and don't have Y screwdriver.
    Pawel @PL - crwdns2934203:0crwdne2934203:0
  24. iPhone SE 2020 Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  25. iPhone SE 2020 Battery Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide an opening pick between the antenna flex cable and the top of the speaker.
    • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
  26. iPhone SE 2020 Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board.
  27. iPhone SE 2020 Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the antenna flex cable to hold the socket down.
    • Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down.
    • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
    Don’t worry if the socket lifts up a bit as you get it out. You’ll need to lift it up later (Step 25) so don’t push it back into place yet.
    Every instruction online (including your YouTube video) leaves the Taptic Engine in place. This added step did not help with battery replacement, and led to an hour of frustration trying to get the connector back in place.
    jgrsf - crwdns2934203:0crwdne2934203:0
    I noticed the same thing and wondered if it was necessary. Thanks
    Laura Bernal -
    Yeah, I broke the connector off of my taptic engine trying to get it to reconnect to the lighting connector plate….freaking nightmare with that and the co-axe wifi connector……..I now have a working phone without haptics
    dave -
    I was glad I had the Taptic Engine removed when I failed to remove the battery adhesives. It leaves more room to work around the battery.
    Alexandre Deloffre - crwdns2934203:0crwdne2934203:0
    I agree. And when reassembling the wifi antenna, I connected the two plugs first, which worked fine, and only after that stuck the antenna back to its sticky place.
    dl7utx -
    I was following this for replacing the loud speaker. I found that during reconnecting the antenna flex, I slightly rocked the taptic connector and it came lose. I was frustrated because my pre-close up test had everything working, then I shut it down, made sure everything was connected and put it all together (including a bang-on job on the display adhesive!!) and wham - no taptic responses.
    Just finishing reseating it, fought with the antenna flex, then ensured the taptic connector was seated properly underneath. All good now.
    Bill Shannon - crwdns2934203:0crwdne2934203:0
    i cant get the small screw to tighten to hold the bracket in place. it just spins. the 2.7mm screw that is supposed to go into the lower left bottom. the 2.9mm screw that goes in lower right bottom will also snug down on lower left. I somehow messed up the hole I guess. can i use an extra 2.9mm instead of 2.7 mm ? if i can find one ? thank you
  28. iPhone SE 2020 Battery Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Wi-Fi diversity antenna.
    What is Wi-Fi DIVERSITY antenna?
    Nikko - crwdns2934203:0crwdne2934203:0
  29. iPhone SE 2020 Battery Replacement, Remove the Taptic Engine: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the Taptic Engine:
    • One 2.1 mm Phillips screw
    • One 2.1 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Tiene que ser una broma que en el kit no te venga el destornillador plano para abrir el tornillo separador. Me habeis dejado a mitad
    Charlie - crwdns2934203:0crwdne2934203:0
    Why is this screwdriver bit not included in the fix kit?
    It’s more important to get this unusual piece than a common Phillips head.
    When reinstalling the standoff that connects to the Taptic Engine, I found that the pointy tip of the spudger fits really well into the little hole at the top of the standoff, and helps with getting it into place and screwing it down if you don’t have a screwdriver bit for the standoff. Hope this is helpful!
    Daniel Timothy Case - crwdns2934203:0crwdne2934203:0
    Be sure to look through all the packaging if you bought the iFixit replacement battery - the Standoff Screwdriver bit was in the package with the battery and screen adhesive (the box labeled “Repair Part”) rather than in with the tools (the box labeled “Repair Tools”).
    Owen Edwards - crwdns2934203:0crwdne2934203:0
    Thanks! This really saved the day for me.
    Javier Sanz -
    I just used a sharp knife for the orange one
    jackjaggermanjanson - crwdns2934203:0crwdne2934203:0
    I broke (twice) the ribbon cable on the tapic engine while trying to reinstall the taptic engine. I ended up taking the loudspeaker out which gave my finger a bit more room to press down and connect the cable to the phone. It was a royal PIA.
    johnoconna - crwdns2934203:0crwdne2934203:0
    Such a nice kit, great instructions, and then not include the standoff bit…what a miss…
    Martijn Smits - crwdns2934203:0crwdne2934203:0
    I used a 2.5mm flat screwdriver for the standoff (orange) screw.
    Habel - crwdns2934203:0crwdne2934203:0
    During reassembly, I inserted the stand-off screw by holding it with the provided tweezers and pushing it into place with the pointed spudger. While still pushing down with the pointed spudger to keep it from falling over, I turned the stand-off screw using the tweezers until it was firmly seated enough to let go of the spuder without the screw falling over. Then I was able to switch over to my 2.4mm flathead screwdriver and tighten it down. Otherwise the screw was jumping all over the place, magnetically attracted to the other components.
    Disappointing that the stand-off screw bit was not provided with the kit. I expect better from iFixit.
    It appears that some aspects of the iPhone SE 2022 (3rd gen SE) began to appear in later versions of the 2020 model. I have an SE 2020 (A2275) that has a grounding clip anchored by the Phillips screw on LH side of the Taptic engine. This clip was not present in the original SE 2020 and thus, doesn’t appear in the images for this step. If you want to get a good look at the clip’s location and orientation follow these links to the corresponding steps in the iFixit guide for the 3rd gen model and Apple's own repair guide.
    SE 2022 (3rd gen) Lighting Connector Replacement -- Step 27
    Apple iPhone Repair Manual for SE 2022 (3rd gen) -- See bottom of page 49
    Robert Miller - crwdns2934203:0crwdne2934203:0
    THANK YOU ! I looked through the photos again and again and didn’t find this little thing on them.. now I finally know where to place it :-)
    Fabian -
    I agree with the previous comments. What I suggest is to do not remove the taptic engine. It's very frustrating to put back the connector, you have a very little space. If you don't remove it, you still have the space to work with the battery.
    Tamas Balogh - crwdns2934203:0crwdne2934203:0
    !!!!!!! ATTENTION !!! à faire à la toute fin, avant l'étape 59.
    la prise de la nappe d'antenne, et collée à la nappe du convertisseur de l'antenne (dernière étape 71).
    J'ai arraché la nappe du Taptic en essayant de la déconnecter...
    vincent “Siffleur” tortiller - crwdns2934203:0crwdne2934203:0
    For the 2.1 mm screw, there was a little piece with it too.
    Gabriel-Science - crwdns2934203:0crwdne2934203:0
  30. iPhone SE 2020 Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry the antenna cable socket up and away from the connector below it.
    Just a heads up, I found a small bit of adhesive tape between the antenna cable socket and the connector below.
    Nic Giannandrea - crwdns2934203:0crwdne2934203:0
    Yep, I did find it too. Thanks
    Stefano Restuccia -
    Hola,
    Se me ha roto ese conector pequeño de la antena y no encuentro donde puedo comprar un repuesto. ¿Alguna idea?
    Gracias
    Eduardo Moral - crwdns2934203:0crwdne2934203:0
    I also found adhesive between the antenna cable socket and the connector below. I was not able to separate the two (mediocre middle-aged vision and lack of leverage to create the separation), and therefore was not able to fully disconnect the haptic engine. Instead, I gently wriggled the haptic engine out and, leaving it connected, rotated it 180 degrees and out of the way toward the bottom right corner of the phone. I am hoping that I have not damaged the thin ribbon cable. On the up side, for the first time ever I was able to remove the adhesive strips from under the battery (they didn’t break).
    John Weise - crwdns2934203:0crwdne2934203:0
    I just want to follow up to say that I did not damage the thin ribbon cable connecting the Taptic Engine. I did forget to reconnect it, though. Once I got that straight, it worked fine.
    John Weise -
    I found that the Antenna cable socket is best to remain attached to the taptic engine cable has i find that it is very easy to brake.
    I have in the past also broking the Taptic engine cable when trying to fit it to its sockets. the Taptic engine cable is very easy to brake so would advise that great care is taking when both fitting and removing.
    Jake Hearle - crwdns2934203:0crwdne2934203:0
    Yep, broke my cable…hoping i can order a replacement taptic engine,,,,phone works without it, but no vibrator or haptics
    dave -
    What on earth is the secret to reconnecting the Taptic Engine?
    I have been messing with it for hours.
    mrmacfixit - crwdns2934203:0crwdne2934203:0
  31. iPhone SE 2020 Battery Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the Taptic Engine flex cable.
    I found that this cable was glued down with similar adhesive to the screen. It pulled away as I removed the taptic engine from the phone (next step).
    My taptic engine had two screws on the lh side. still worked the same.
    Chris Rainone - crwdns2934203:0crwdne2934203:0
    Be really careful here in the reassembly. I managed to rip the cable here, and now best case I won’t have any haptic feedback. :(
    Nick Cox - crwdns2934203:0crwdne2934203:0
    I’m sorry to hear that! If you’d like to get that fixed sometime, we do sell a replacement part!
    Arthur Shi -
    On re-assembly, the taptic engine might not work. Before panicking, ensure that the taptic engine connector didn’t get dislodged when fighting to get the antenna flex reconnected.
    on my A1905 iphone 8 - This is not correct!
    There is an extra leg coming off the taptic engine’s flex cable with a micro-coax antenna connector going underneath the speaker!
    You can’t take the engine off yet!!
    Jason Minahan - crwdns2934203:0crwdne2934203:0
    I have the same issue and confirm the coax connector under the speaker …. can you buy this Taptic Engine anywhere? The one with the extra leg ?
    James -
    same here so i ripped the taptic engine cable. you might want to make a better tutorial here, @ifixit...
    Ionah Mélin -
    A hint for reassembly: carefully crease the ribbon cable upwards along the edge of the connector so the stiff ribbon doesn’t touch the engine, pushing the upper connector too far away from the engine to line up with the lower connector. Once the cable isn’t interfering, you don’t have to worry as much about breaking it or having it get in the way. It’s still tricky to get the connectors lined up. I had luck by using one set of tweezers to hold and stabilize the short sides of the upper connector (silver rectangle). I used another set of tweezers (spudger would also work) in my other hand to finesse the connector alignment and push the connectors together. Look carefully at the first photo in this step: the connector is almost exactly centered below the taptic engine screw.
    jeffreyknicholson - crwdns2934203:0crwdne2934203:0
    my phone is doing a squeeking sound everytime i press the home button and sometimes if i press long on the screen.
    something is off with the taptic engine i think.
    any idea how to fix it?
    Rita H - crwdns2934203:0crwdne2934203:0
    Any suggestion on why the 2.7 mm screw no longer holds down the bracket. 2.9 mm screw works in either hole .but the 2.7 mm no longer secures the bracket, can I swap it out with another 2.9 mm screw?. And where do I find one. Will it work if it’s missing that screw? Space. I have an old iPhone SE maybe I can find 2.9 screw in that . Thanks
    Re-assembling the Taptic Engine connector is difficult. After struggling unsuccessfully for 45 minutes I ended up bending up the metal tab on the right side of the phone with tweezers, then with the Taptic Engine tipped on end (not positioned in phone) I could get the cables connected. With the tab on the phone bent upward I was able to slide the mounting tab on the left side of the Taptic Engine under the tab on the left side of the phone case and then bend it back down. This needs to be done carefully to avoid damaging the cable on the Taptic Engine.
    Mark Dige - crwdns2934203:0crwdne2934203:0
    Be careful -- there are two cable connectors stacked on top of each other here, and you want to attach the taptic engine to the bottom one. When reattaching the taptic engine connector, make sure that the antenna connector is pulled back -- it is designed to sit right above the connector for the taptic engine, and just by memory it rests back in the same spot. Without reviewing the previous step in reverse, it would be easy to attempt to connect to the top socket, potentially causing damage.
    brendonart - crwdns2934203:0crwdne2934203:0
    There’s two cables here that are almost impossible to separate. I put some effort on the haptic cable and it immediately sheared off. I have no idea how you’re supposed to properly separate them
    Nicholas Head - crwdns2934203:0crwdne2934203:0
    The reassembly is very difficult. The connector needs to be closer to the taptic engine than what the stiff ribbon allows. I had to bend the ribbon a bit with tweezers to narrow the gap between the connector and the taptic engine so that the connector would meet with the slot... after I spent half an hour trying to coax it.
    Scott Green - crwdns2934203:0crwdne2934203:0
    Be careful the taptic engine cable is less then paper thin and tears with less resistance then a peice of paper, use extreme caution!!!!!
    i ripped mine and after taking it out and testing the strength of the cable it took less force to tare then tearing a sheet of paper.
    there is plenty of room for this cable to be three times as thick with no interference, this is just anti repair design.
    penguin2fish4rain - crwdns2934203:0crwdne2934203:0
    Taptic engine is hard to put back
    Having the phone orientation taptic at the bottom, I used a pick vertically to the right of the connector (to the right of the stand off screw) to align the connector to the right place, then press it into place, glad that the pick is near the exact thickness needed to align the connector
    Danh Kyndt - crwdns2934203:0crwdne2934203:0
    Very difficult to reattach haptic ribbon into socket.
    You have to use spluger tip on one side of ribbon connector (wedge on edge of connector) and push it towards the Taptic Engine.
    Once the connector pushed against it and while the spluger is still in place holding it in position, then use other hand to gently push connector down to connect
    Coolj Coolj - crwdns2934203:0crwdne2934203:0
  32. iPhone SE 2020 Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Taptic Engine.
    • Be careful removing Taptic Engine flex cable as it may be glued to the antenna flex cable.
    Where there is the 2,1mm philips srew holding the taptic engine (left), there is a tiny piece of metal under the srewhead. Note its orientation, take it out and dont't lose it taking out the taptic engine, then reinstall it when reassembling. When reassembling, the said fixing hole of the taptic engine is not on top, but has to be pushed under a little metal piece, it won't even fit on top. Then reinstall the tiny metal piece and put the screw in.
    dl7utx - crwdns2934203:0crwdne2934203:0
    So glad someone else mentioned this. This piece may be a late model revision. Looks like it adds additional grounding to a point on the frame. It's easy to misplace!
    Demetri -
    Thanks for pointing this out! For me, the small metal piece popped out and I wasn't sure where it came from. The orientation seems to be just a single one that's possible luckily.
    Sam -
    I damaged the graphite film underneath the battery while removing stubborn adhesive. Can I buy replacement graphite film? Should I remove it altogether since some sections ripped? What purpose does this serve? Thank you for any information.
    Anne Marie Hammock - crwdns2934203:0crwdne2934203:0
    Hi Anne,
    The graphite film helps dissipate heat during wireless charging and to transfer heat out of the battery. It doesn't need to be in one complete piece in order to work—if the film can lay flat, I'd leave it in place.
    Arthur Shi -
    When putting this back, if yours sounds too loud or odd. tightening the screws is what fixed it for me, don't forget the bottom one where you have to use a flathead screw driver or what they suggested can use if you don't have the screw driver or bit for it. took me a bit to realize i didn't tighten that one. was a pain to get the connector back but see why its useful, the adhesives all ripped on me.
    Curtis Derrick - Harris - crwdns2934203:0crwdne2934203:0
    !!! Achtung: unter dem Lautsprecher ist die taptic engine nochmals verbunden. Mit dieser Anleitung zerstörst du die taptic engine!!!!
    Vris Müller - crwdns2934203:0crwdne2934203:0
    Yes. Same problem. Will try to keep it in.
    Max Effort -
  33. iPhone SE 2020 Battery Replacement, Remove the battery adhesive: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The iPhone's battery is secured by four pieces of stretch-release adhesive—two at the top, and two at the bottom.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the front surface of the battery.
    Be careful prying around the side button connector when trying to remove the top tabs. There is very little room to maneuverer
    Tom Millard - crwdns2934203:0crwdne2934203:0
    £ Tapes broke on me so I applied iISOPROPYL ALCOHOL using an Eye Dropper waited 30 seconds tHen heated up some oil in the bag rice for 2 minutes on 700W and the applied the unopened packet to the back of the iPhone for 90 seconds.
    Themn I used an out of date credit card with the raised numbers facing down to easily release the battery.
    David Howard
    David Howard - crwdns2934203:0crwdne2934203:0
    Great tip! Worked perfectly and easy. Thanks.
    Stephen Smith -
    It should read heated up some boil in the bag rice
    David Howard
    Very difficult. be very careful on the limited space end that you don't puncture the battery!
    Carl Schultz - crwdns2934203:0crwdne2934203:0
    I really hope you guys not to skip steps for detaching taptick engine because it is really hard to pull out string with taptic engine. 4 of 3 strings were cutted when I treid to detach batteries with taptic engine. So, I really recommend you to get rid of taptic engine before you start this step. But if you skipped and strings are cutted, there is a way. Use hair dryer 90 secs as maximum hot behind the battries and detach the batteries. It worked to me.
    I tried to remove the battery without detaching the taptic engine -and succeeded-: Just took into account the fact that it is by far easier and safer to start detaching the battery on the other-than-taptic side. I did it the tough way, knowing that the battery is then discarded. I hair-dried the back of the iPhone a little bit and then inserted a strong credit card all along the side of the battery and leveraged ! Yes, even without triying to remove the stickers. It bends the battery (however dead. This is why you change it, right ?!) but it comes after a few seconds. The 2 stickers detach, than it is easy ans simple to remvore the battery from the 2 other-side stickers.
    Jean Luc - crwdns2934203:0crwdne2934203:0
  34. iPhone SE 2020 Battery Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the first battery adhesive tab from the bottom right edge of the battery.
    • If possible, use your fingernails or blunt tweezers. Be careful not to poke the battery with any sharp tools.
    Vor Schritt 30 umbedingt die Rückseite des iPhone erwärmen. Ich habe das iPhone 10 Minuten auf eine heiße Wärmflasche gelegt.
    Moritz Hartges - crwdns2934203:0crwdne2934203:0
    Strongly suggest you remove the display. Also the picture shows the "perfect world" it is far ore difficult to remove and get to those white adhesive pull strips. be very careful!!!
  35. iPhone SE 2020 Battery Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
    • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
    This was the most frustrating step of the process. I found that if you pull steadily and slowly while continuing to grip the adhesive as close to the battery as you can there is a much smaller chance of breaking the adhesive strip and losing it under the battery.
    Benjamin Boldt - crwdns2934203:0crwdne2934203:0
    I did not have replacement adhesive tabs for my battery so I needed to re-use the old ones. First, I pulled back the black tabs from the top and sides of the battery (Steps 28 and 29). Then I laid the phone on a hot water bottle (Wärmeflasche for our German friends) while I very, very, very slowly prised the battery out of the body using the flat end of a spudger, starting at the corner closest to the volume buttons. The battery did deform somewhat during the process, but it was fully discharged and I had no combustion problems. After a few minutes of gentle pressure on the battery corner, it started to release from the adhesive. Full removal took about 5 minutes and the adhesive tabs were not damaged in any way and happily re-adhered to the new battery.
    I did all this after skipping over steps 18 to 27 and put the new battery in place after connecting it first to the circuit board to ensure correct alignment.
    jnbruin - crwdns2934203:0crwdne2934203:0
    All 4 strips tore after just removing a small portion… even though I took great care to pull slowly and at a small angle. Could not imagine how anyone could have managed this with my phone. Had to heat and pry out.
    I damaged the graphite film underneath the battery while removing it from stubborn adhesive using a card from the side. Can I buy replacement graphite film? Should I remove it altogether since it's ripped or will that cause problems for heat dissipation? Thank you for any information.
    Every time I've tried to remove these strips they just wind up breaking, regardless of the Taptic Engine being removed, or not.
    tripmusic - crwdns2934203:0crwdne2934203:0
  36. iPhone SE 2020 Battery Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the above steps to remove the remaining three adhesive strips.
    • Be sure to hold onto the battery as you remove the final strip, or it may fling out of the iPhone unexpectedly.
    • If you removed all of the adhesive strips successfully, skip the next step.
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
    If you have a thin flexible plastic shim shaped like a letter opener, you can slip it under the battery and take it off the adhesive.
    Spencer Chan - crwdns2934203:0crwdne2934203:0
    Good luck with the top two…. Virtually impossible to remove. Both of mine broke almost immediately. I tried floss and a strong thread and both broke before they did much good.
    so I took a plastic card (an old credit card would work, but you’ll have to cut it thinner or work from the sides. If you got the bottom two out successfully, you should be able to get enough lift to start prying gently with the card.
    Good chance you’ll scuff up the super-thin carbon film over the charging coil if you’re too aggressive. And DO NOT use alcohol to soften the glue because it will melt right through that thin carbon layer and make a mess. Best bet is to go gradually…. Put the plastic card under the battery, pull up a bit to add tension, and then stick a pencil or popsicle or something under the card to keep keep the tension and give it 5 minutes or so for the tape to loosen. Then pull up on the card to add new tension, move the stick up, and wait again. It’ll take 20-30 minutes. Repeat until free and don’t rush.
    Bigh - crwdns2934203:0crwdne2934203:0
    Thank you much -- I was planning to use alcohol until you brought up this point. Slow but steady leverage like you describe (with mild-to-moderate heat underneath) does indeed sound like the best bet.
    David Reynolds -
    Anne, I had little rips in that layer, and it doesn’t seem to have affected anything.
    @bigh I’m surprised nobody else mentions this problem! With the piece above the battery still in place, impossible to pull « at the smallest possible angle with horizontal » as for the 2 bands below: I suppose that’s why they make us remove the taptic engine! Why not similarly remove the things above the top of the battery?
    Jean Orloff - crwdns2934203:0crwdne2934203:0
    Or at least explain why removing the things above the battery is a bad idea. (Which I don't doubt.)
    I love how right after the previous step where they (rightly) put heavy emphasis on how exquisitely careful you need to be to pull at the lowest angle possible and not snag it on other components, in this step they glibly skip right past "Oh and that'll be effing impossible for the top two since you have to pull at almost 90° right next to components with narrow edges, so good luck".
    David Reynolds -
  37. iPhone SE 2020 Battery Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone SE 2020 Battery Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s). After about a minute, gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
    • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
    • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
    • Alternatively, thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
    • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. Do not deform or damage the battery.
    • To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
    In my case the floss caught on the sharp edge of the wireless charging coil pulling up the edge of the coil, butane cutting off the floss. I think the coil had been damaged by some previous repair, but be careful. After you pull past the first two adhesive strips, peek under the battery to make sure the floss is sliding over not under the coil. The coil doesn't look like a coil – more like a paper thin pad.
    Joel - crwdns2934203:0crwdne2934203:0
    Soaking the floss in rubbing alcohol helped also. It took some doing, but eventually came through without issue.
    Trever Knie - crwdns2934203:0crwdne2934203:0
    the wireless coil accidently got a little tear just to the right middle area. I put the new battery in and everything seems fine. I wonder if I should change the coil? anyone have any suggestions of what symptoms to look for if there were to be an issue ? thank you
    I ended up heating the back of the phone for 30-60 seconds (don't do anymore than that) and used the opening tool as a fulcrum to lift the battery. As long as you're careful it should work!
    Vladimir Stanev - crwdns2934203:0crwdne2934203:0
    We used my heating pad set on low, placed the case on it, about two minutes and using the opener tool, lifted the battery out. This was the only bump/snag we had, the remaining steps went well and I have my phone back.
    Pete P - crwdns2934203:0crwdne2934203:0
    All the adhesive strips broke, so I used the long plastic tool for brute force extraction, twisting the old battery in the process. Most of the old strips in the back remained, so reused them for the new battery.
    Boaz Ben-Zvi - crwdns2934203:0crwdne2934203:0
    A hairdryer and dental floss dipped in Isopropyl alcohol worked for me. You need to use the blue pick and pointy end of the spudger to get the floss down deep enough into the crevice near the taptic engine. Then I just slowly pulled both ends of the floss down the length of the battery. DO NOT use the blue triangle pick, or similar to try and pry the battery up. The last time I very nearly damaged the charging coil near the center of the battery.
    Of course skipping the screen and taptic engine disassembly, all 4 strips broke for me, so I ended up using a thin rubberband in place of the floss, and a flexible plastic card, slim enough to slip under the battery and pry it out. Took more than an hour but it worked out in the end, and I was glad I didn't have to deal with reattaching the screen and everything else to be honest. Be careful to not tear other small components with the edges of the card though, as I tore some unsuspecting black rubbery cover from a metallic case above the battery connector. Used some thin insulating tape to cover the exposed parts, just to be safe.
    Raziocinjo - crwdns2934203:0crwdne2934203:0
  38. iPhone SE 2020 Battery Replacement, Remove the battery: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the iPhone.
    • If your replacement battery came in a plastic sleeve, slide off and remove the sleeve before installation.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    Having received a replacement battery from CE Store, the phone is now OK with top battery performance. The one received earlier was just a scrap, not chargeable. Now, I’m quite satisfied.
    Miklos Barton - crwdns2934203:0crwdne2934203:0
    I made the mistake of powering the phone on once the new battery was connected to make sure it was working, before I put the screen back on. Now my home button doesn’t work, even after two hard resets. Anyone know how I can get it working again? Note I didn’t disconnect the screen or taptic engine or anything else. I just left the screen hinged 90°, the only connector I touched was the battery connector.
    Same issue. Home button is dead. No cables were damaged. Everything else works. Any ideas?
    Aaron Soderholm -
    I had the same issue with the Home button, I turned on Virtual Home Button, which makes the phone usable. Shutting the power off off and restarting the phone bring you to the login screen. go to Settings, Accessibility, Touch, Assistive Touch.
    Gary Berman -
    You maybe fried it.
    Gabriel-Science -
    I recommend making sure the battery connector is lined up with the socket before setting it down on in the compartment, mine was very close, but a little too high and it made getting it connected a little more difficult than it needed to be.
    I agree Benjamin. Eager to ask anyone starting this, since it added 90 minutes onto my project, be careful, though I can testify that the metal flex connector bends. In other words, I bent it about 3 times so the proper alignment could be attained - sort of a zig zag. Amidst that phase I had practically given up, almost started removing the new battery, but alas I got the phone to work again. We'll see if its function can last.
    Steph B -
    Performing a force restart at this point makes no sense. Shouldn’t it be performed after the display is installed?
    Richard Dempsey - crwdns2934203:0crwdne2934203:0
    Creio que a "reinicialização forçada" deverá ser feita "após a remontagem" do aparelho como está instruído.
    Samuel Vitor Alves dos Anjos - crwdns2934203:0crwdne2934203:0
    He said:
    I believe that the "forced restart "should be done "after reassembling" the device as instructed.
    Roman Khalikov -
    After you connect the new battery and before laying it down, make sure the end closest to the Taptic Engine has as much of a gap as possible and don't lay it down until you are absolutely sure that you are happy with the placement of it. This time around that end of the battery wound up being pretty much flush against the Taptic Engine and there really isn't much of a gap compared to the previous battery I put in there. I suspect there may be some inconsistencies with how the metal flex connector is attached to the battery itself from the factory and possibly the connector's length. With the battery connected, laying it down and leaving as much of a gap as possible, will help for the next time you replace it, especially if you choose not to remove the Taptic Engine.
    i've done a number of electronics repairs. failed badly at this one. when i was taking the two halves of the phone apart, the front sensor assembly cable sheared in half like it was made of jello. i would have been better off simply putting a new battery in and not attempting to reseal the phone. yes, it would have lost any water resistance, but the operation would have been much simpler. now a phone that i was happy with except for its battery life is going into the trash. i'll never open up an iphone again and i don't recommend it.
    Alex Redmond - crwdns2934203:0crwdne2934203:0
    It's the major risk of repairing your device yourself. However, if you feel confident enough and if it's not an hard repair, I would say « Do it ! ».
    Gabriel-Science -
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
crwdns2935229:0171crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
212,878 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:039crwdne2947412:0
Quick question on this guide, and maybe I missed the listing on this one, but like the iPhone 11, will this give you that message regarding the battery not being an apple part if you replace the battery?
Bryant Alvarez - crwdns2934203:0crwdne2934203:0
It might considering Apple is stooping to these antics.
https://www.ifixit.com/News/33147/apple-...
Imagine that. Your display breaks, by accident or by carelessness - no matter, you want to fix your own display or take it someplace that isn’t “Apple Authorized” and because you don’t go directly to Apple’s den of thieves, they pull this on you. You don’t want to pay out the yingyang? I guess you’ve got a faulty display then!
(Look, I get it. They do this to save their own butts legally. That does not make it right.)
Jesse -
I’ve looked at both the original SE and this next generation SE and I’m wondering if it’s really necessary to remove the entire display. I realize if the phone has its original battery in it that it likely is but if you’ve replaced it once before I don’t see why it’d be necessary to remove the display, just remove the battery itself and then you have less work. Maybe I’m missing something?
Jesse - crwdns2934203:0crwdne2934203:0
You would run the risk of tearing the flexes. It is totally worth the time removing the screen.
Daniel Allen -
if i put another new battery in se 2020, is this message come “non genuine battery warning”
Imran Khan - crwdns2934203:0crwdne2934203:0
You will get this.
Duck -
There is actually a trick(but you need too get your dirty), THIS IS NOT A RECOMENDED WAY AS IT MAY DESTROY THE BATTERY
the only way is un solder the bms from the old battery(and also from the new battery) and resolder the old bms to the new battery
battery health will stay low but there are some flex cables that would give battery health as 100% (but it wont drop below 100%)
febrockzz -
Always. It's a classic Apple move. But I think it becomes less annoying after a few days. I'm not sure though.
Gabriel-Science -
@febrockzz It's possible to reprogram it with a specific device after resoldering.
Gabriel-Science -
I think not because apple now lets 3rd party repairs, which is great :)
Bruno M - crwdns2934203:0crwdne2934203:0
@bruno
Official 3rd party repairs have access to apple software and to original parts, iFixit battery si not an official one.
Apple just released the repair program website and you can buy some original parts but still only for iphone 12, 13 and SE(2022).. for example they dont even sell the home button for the SE(2022), so you still got to buy a non official and lose the touch id feature
Tomas Caetano -
Non genuine battery doesn’t allow all features of the iPhone to work. Looks like I should have checked with Apple first as I could have had it repaired with genuine parts for $49.
James Bowkett - crwdns2934203:0crwdne2934203:0
Which features does it not allow to work?
Paul B -
The instructions were great. After changing the battery, I have a constant battery not Apple warning and my home button quit functioning. Who is to say if I may have stressed the display cable or Apple’s notorious retaliatory programming cut my home button out (IOS 16.02). With an inoperable phone, I could either try a new display or a different phone.
Joseph Ashment - crwdns2934203:0crwdne2934203:0
Update: As soon as I removed my sim card and transferred into another iphone, the home button started working. Apple’s self repair parts section does not have parts for older phones. It’s been made very apperent by Apple that repairs with any aftermarket parts will not be tolerated. Who actually owns these phones? I thought I paid for it…..
Joseph Ashment -
Did really well, and instructions were on point. But until I turned my phone back on, I get this message in software, saying "battery unkown", and it wont go away. How do I get this message to go away, without going to Apple Support?
Thank you.
Steven inSpired - crwdns2934203:0crwdne2934203:0
You probably can't. Apple makes it so that if the battery isn't genuine, warning messages and errors and that kind of stuff will pop up.
Dane Elliott-Dyson -
Just completed this successfully. I had to use a DEJI battery kit, as the iFixit was out of stock. All went well, and also used the linked guides for installing battery adhesive & display adhesive. The phone does show the battery warning, but I've read that it will disappear after a few days, so that's no problem. Thanks iFixit.
I did manage to carefully remove the bottom two battery adhesive strips without removing the taptic engine, but the top two strips both snapped quite quickly. Had to sneak some IPA underneath to finish the removal.
Dataq - crwdns2934203:0crwdne2934203:0
You'll get the Unknown Part warning in Settings > Battery even if you use a Genuine Apple battery.
iFixIt documents that for the iPhone SE 2022
https://www.ifixit.com/News/59510/apple-...
I think they now have made the iPhone SE 2020 do the same. Quoting the relevant section:
Installing a 3rd Gen iPhone SE 2022 battery in a 3rd Gen iPhone SE 2022: Possible, but…
This is the current standard, and a good sign for future battery replacements, but unfortunately you’ll still get the “unknown part” warning. The only feature you’ll lose is Battery Health. Yes even if you’re using a perfectly genuine battery, Apple considers the repairnongenuine” until they personally verify it.
Caveat: Apple will now let you pay for the privilege of verification, if you buy their part.
Colin Ng - crwdns2934203:0crwdne2934203:0
Hi, I have done the battery swap but my home button no longer works do you have an idea of what the issue is?
Oliver Colam - crwdns2934203:0crwdne2934203:0
YOU NEED a Y000 SCREWDRIVER. If you don't have one, order the whole kit, not just the battery. Also you probably need the screen adhesive. I had a bunch of iFixit tools from previous repairs so ordered just the battery. But those two items definitely slowed down the repair for me.
bruce - crwdns2934203:0crwdne2934203:0
Thank you, Adam for a clear and accurate step-by-step guide to replacing the battery in our iPhone SE 2020 phones. Both were a success though one required a reopening as I didn't get the haptic cable connector set properly. The illustrations were clear and accurate as well as the warning about getting the connectors to click on each end rather than pressing on the middle. Well done!
Ron Angert - crwdns2934203:0crwdne2934203:0
This how-to is excellent but could be improved with discussions of Taptic engine cable techniques and best practice with the iFixit replacement battery. It took me close to 30 minutes to get the Taptic engine connector set properly (finally did it with jeweler's flathead screwdrivers to line it up). I also couldn't figure out the wrapping for the battery and ended up tearing it apart. I also wasn't sure about battery placement so that the connector cable would fit properly. Used a silver Sharpie to mark a line on the battery and beside it so that I got it in the right spot once the adhesive backing was removed. Finally, a small metallic fitting popped out of somewhere when I got the last battery adhesive loose. Was confusing for a minute, but I finally decided the piece fit best under the Taptic engine 2.1 Phillips screw. All in all, excellent directions! Thank you.
Greg-n-Houston - crwdns2934203:0crwdne2934203:0
This is a great guide. Thanks for providing it. No problems, no guessing, good pictures.
Douglas Walker - crwdns2934203:0crwdne2934203:0
I need a battery for my 3rd generation SE (A2595) is this the one I need?
Jeffery Jones - crwdns2934203:0crwdne2934203:0
Ended up breaking the volume up button in the process… no idea how that happened since it’s not near the work done in this process. 5th battery I’ve done and first issue. In retrospect would have been better to have apple do it. At least volume can be changed in the OS and it’s just the physical button. If anyone knows a simple fix pass it along. Assuming a connector got damaged while struggling to reconnect the tiny little buggers
Steve Passmore - crwdns2934203:0crwdne2934203:0
Quick note for the battery - as of Nov 2023 and iOS 17, the battery sold by iFixit involved in this guide will result in non genuine alert on SE 2020. I got it on the next boot after the replacement and the reassembly. The battery health is no longer available with the new battery. :(
Vahan Yerkanyan - crwdns2934203:0crwdne2934203:0
So, I would rate this as a "moderate-plus" if not a "hard" repair. It ultimately worked (although the rear adhesive strip removal didn't - just make sure the old battery is discharged fully, and lever it out physically after step 22 with as little physical deformation of the old battery as possible.)
But these screws are tiny, and some (like the Y000 in step 23) require specialized drivers. And afterward, your iPhone will complain that it can't tell if it's an Apple authorized battery and so some battery info is unavailable.
In retrospect, I might have spent a little more and had a shop do this, honestly.
Hardest part was connecting the battery at the very end. It was lined up but took awhile to click in! Thanks!
Aaron Linder - crwdns2934203:0crwdne2934203:0
I did it: Used a new sealing! - I need 90 min for this. - But i worked carefully with changing the sealing of the display.
joachimschreiter - crwdns2934203:0crwdne2934203:0
There are two differences in my iPhone SE(2) (2020) from the description:
1. The left end of the bracket removed in step 24 has a curly ? extension about 2 mm long. I guess it is an earth strap.
2. I have a part left over that is not mentioned anywhere in the above description. It is a small box like structure with an arm and a hole that must have been secured down by a screw and is again probably an earth strap but I did not see where it came from (does anyone know). I've posted a picture at: https://www.dropbox.com/scl/fi/qf6sgwqwu...
rockjapan - crwdns2934203:0crwdne2934203:0
Further to previous comment I had another unit to do and discovered the part left over (above item (2)) that is not mentioned in this guide goes at the left side of the Taptic Engine here: https://www.dropbox.com/scl/fi/8y20tufxr...
Thank for your comments on 27.6.2024. That helped me a lot. Would be great to update the instructions.
Georg Hoßfeld - crwdns2934203:0crwdne2934203:0
Thanks for this clear guide. I replaced my lightning connector and battery at the same time. But now the phone restarts itself every 2-3 minutes. While it's on, everything functions normally, so I thought it might be the battery. I double checked the connection, and I also reconnected the old battery to make sure the replacement one wasn't the problem, but it still did the automatic restart. I'd appreciate any ideas about what to try next.
KSHomeRepairer - crwdns2934203:0crwdne2934203:0
I replaced my battery using a combination of this guide and youtube videos. Surprisingly the hardest part turned out to be getting that darn battery connector plugged back in at the end. It's nearly impossible to get a good look on the connectors and how well they're aligned. You kinda just have to hope that it all lines up when you push on it. I did have it plugged in when I aligned the replacement battery, so I'm not sure what happened there. Maybe I just didn't use enough force in fear of mangling the connectors or it somehow still ended up slightly misaligned. That part alone probably took me a good hour. In the end I found that carefully lifting the phone and screen with both my hands and using my left thumb to push up and in on the connector while pressing on the back of the phone finally did the trick.
I think these guides could benefit from having dedicated reassembly steps, because the process can definitely be quite a bit different when it comes to putting these things back together. ;)
Robin - crwdns2934203:0crwdne2934203:0
After three hours of apprehension, I successfully changed the battery on my iPhone SE. Disassembling the screen was straightforward. I used a suction cup to create a small gap and inserted a blue plectrum to slide along the edge and cut the adhesive. A useful tip from a YouTube video: use coffee to prop the display open at about a 90-degree angle. This makes it easier to work on the internals, screws, and cables. The battery, troublesome. Without alcohol, I had to pry it out with plectrum. Used hairdryer heat the back of the iPhone, softening the adhesive, and finally removed the old battery. Attaching the new battery, I first removed the protective plastic from the adhesive, then connected the battery to the to ensure proper alignment. After confirming the alignment, I disconnected the power cable and secured the battery. During this process, I misaligned and had trouble reconnecting power after assembling the other cables. The display glue was difficult to attach. Finally, it worked.
Stefan Moll - crwdns2934203:0crwdne2934203:0
I accidentally tore the thin metallic film behind the battery, which was glued to the case. Since then, I feel like the hotspot feature has drastically lost quality and signal strength. Is this related, or does it have nothing to do with it?
Emmanuel Cervetti - crwdns2934203:0crwdne2934203:0
Went well, including the resealing of the display. Everything is functioning on the phone in spite of the warning of a non apple battery. Thanks again iFixit!
Andrew Kencis - crwdns2934203:0crwdne2934203:0
Poste 38, vous avez écrit "S'il reste de l'alcool dans le téléphone" au lieu de "s'il reste de la colle" ! Dans conclusion, vous avez écrit " posez une couche d'adhésif ***sur l'écran*** avant de remonter ce dernier". Écrivez plutôt "au dos de l'écran" ! Cordialement
Jazzarte - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 238
crwdns2936753:07crwdne2936753:0 1,486
crwdns2936753:030crwdne2936753:0 6,327
crwdns2942667:0crwdne2942667:0 338,304
