iPhone 13 Pro Max Taptic Engine Replacement
crwdns2942287:0crwdne2942287:0The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Follow this guide to remove and replace the Taptic Engine in an iPhone 13 Pro Max.
crwdns2944105:0crwdne2944105:0
Power off your iPhone before beginning disassembly.
Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
the picture shows 3 cm but the description says 3 mm's. Which one is it?
That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
VauWeh -
Oh, come ON!
Big Ed -
It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
@leifdewolf I wouldn't skip it for a first repair.
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Be EXTRA CAREFUL at this step, to put the opening pick at the right place. I broke my fkin screen at this step by putting the opening pick between the screen and the screens plastic bezel
I broke my screen at this step. heated it multiple times and pull until I can see a gap, I inserted the tool and I heard a snap and saw a crack on the screen. Ended up returning the set as I wasn't able to use it and broke my screen.. well, new phone for me.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
Leave the pick in the top left corner before continuing.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert a second opening pick in the bottom left corner of the iPhone.
Twist both picks simultaneously until the left edge clips release.
Remove your suction handle from the screen.
Rotate your iPhone so the right edge faces you.
Open your iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Y000 screwdriver to remove the three 1.3 mm screws securing the battery connector cover.
Use the pointed end of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use the pointed end a spudger or a clean fingernail to pry the display connector up from its socket on the logic board.
Use a Y000 screwdriver to remove two 1.1 mm screws from the front sensor connector cover.
Use a Phillips screwdriver to remove the remaining two screws from the front sensor connector cover:
One 1.5 mm screw
One 1.8 mm screw
Remove the front sensor connector cover.
Use the pointed end of a spudger to disconnect the front sensor assembly cable connector.
Use your fingers to gently peel the adhesive-backed strip off of the loudspeaker.
Pry up with the pointed end of a spudger to disconnect the Taptic Engine cable.
Use a Phillips screwdriver to remove two screws securing the Taptic Engine:
One 1.8 mm screw
One 1.9 mm screw
Use a standoff screwdriver to remove the 2.9 mm standoff screw securing the Taptic Engine.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Pro Max Answers community for help.
crwdns2935229:05crwdne2935229:0
Hey what part would change the serial number if replaced?
Are waterproof seals part of the replacement kit, if not why?
Jim Langston - crwdns2934203:0crwdne2934203:0
I ordered the screwdriver for the 13 ProMax (Y000) as well as the full kit which has this Y000 head. Neither tip works to remove the screws. Any suggestions?
Barbara Nuckles - crwdns2934203:0crwdne2934203:0
