iPhone 12 mini Rear-Facing Cameras Replacement
  1. iPhone 12 mini Rear-Facing Cameras Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    is it oem apple battery, because at some photo shows(Ifixit) and another shows (apple) ... wait your answer?
    karim - crwdns2934203:0crwdne2934203:0
    BEWARE! This screen isn’t the same as older iPhone models’ screens. The iPhone mini 12-screen comes with a thin plastic frame around the screen on its back. Thus, make sure you don’t insert the pick in between the screen and its plastic frame, as you’ll seperate the screen and leave the plastic frame still sitting in the phone’s metal housing (this cost me 100 dollars…). Carefully heat the sides of the metal housing and do not heat directly on the glass, as doing so will potentially loosen the glue from the plastic frame stuck to the screen. My suggestion is that you watch a video of this repair as this step-by-step-guide is undercooked.
    Dan - crwdns2934203:0crwdne2934203:0
    This is an excellent comment. Following this step-by-step guide to the letter will break your screen; it's by far the worst iFixit guide I've seen to date.
    Dormouse -
    Yup, that’s what happened to me. I will be reading the comments next time
    pinballnc -
    Ive finished mine and Soooo absolutely dont do this yourself🙌🏽 unless your a mechanic because first of all they didnt send me all of the right tools🤗 and secondly the battery they gave me has an overly large component so it wont fit into my phone. And the absolute HASSEL i had to go through to even just get the package was insane it was a whole month of struggling just for the stuff to not even be right, in conclusion will NEVER order from here again..🤗
    Chanell - crwdns2934203:0crwdne2934203:0
  2. iPhone 12 mini Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone 12 mini Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 12 mini Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 12 mini Rear-Facing Cameras Replacement, Heat the bottom edge of the phone: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • Heating the bottom edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
    you need to clarify that you're heating the metal frame, not the glass. I gently heated the glass front with a heat gun and proceeded to pull the display apart, destroying it. :-(
    Jim Harger - crwdns2934203:0crwdne2934203:0
    Don't heat up the display for too long or else you could destroy the display like I did. Now I have a phone with a giant white stripe. So don't be a fool like me. 1 to 2 minutes is enough!
    K T - crwdns2934203:0crwdne2934203:0
  8. iPhone 12 mini Rear-Facing Cameras Replacement, Apply a suction handle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Apply a suction handle: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    I would recommend starting with a bottom corner, not the bottom middle. If the adhesive isn't softened enough, you will pull the middle out but the sides will still be stuck on, causing extreme flex to the panel and damage to the panel down the middle (white bars down the middle in a worst case). I did this to my phone.
    Drew Kosir - crwdns2934203:0crwdne2934203:0
  9. iPhone 12 mini Rear-Facing Cameras Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
    • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    I ended up separating my screen rather than getting under the scren casing.. BE CAREFUL TO MAKE SURE YOU ARE UNDER THE PLASTIC PART - otherwise you just ruin your screen... No mention of this precaution here and as a result, my phone is more broken than when I started
    Tyler Ludwig - crwdns2934203:0crwdne2934203:0
    Hi, I don’t get it. Should the plastic part stay with the display or with the phone?
    Paul - crwdns2934203:0crwdne2934203:0
    The plastic frame should stay with the display.
    Carsten Frauenheim -
    Be sure you see two layers: glas and plastic (Step 6, Clamp, last picture). You have to go underneath the plastic frame otherwise you are tearing your displayglas off the frame and destroy your OLED!
    Johnny RS - crwdns2934203:0crwdne2934203:0
    Broke the screen. Too bad. I've done maybe 5 battery replacements before. But this one is very very tight. Got a new phone. :P
    Gilles van Leeuwen - crwdns2934203:0crwdne2934203:0
    Same thing, I broke my screen too. I think the warning should be in all caps and show more clearly where is the right place to put the pick and where is not — without the need to click on the link.
    Judging by amount of people who reported it here (and should also account for those who didn't bother to report), I'd say that there is a problem with instructions.
    It is honestly not so hard if you know what does mistake looks like and that it is possible to separate the screen so easily from the frame. I repaired more than a dozen phones — screens and batteries — and this is the first time I made such a mistake that costs 100+euros.
    Axel Mort - crwdns2934203:0crwdne2934203:0
    something, broke my screen by inserting the pick in between. also wish the hair dryer has pointed to the side rather than the display. damaged my display after replacing battery, so my phone is more broken than when I started
    Ghalia Naseer - crwdns2934203:0crwdne2934203:0
  10. iPhone 12 mini Rear-Facing Cameras Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
    The pictures show the left side. I know that the left side is the correct one to heat, but for others it might be confusing. 😊
    Donát Viosz - crwdns2934203:0crwdne2934203:0
    @dviosz You mean the right edge! The picture shows the left edge but the right edge is the correct one to heat. As described in the text next to it. Opening the phone from the left will damage it!
    catchMyException - crwdns2934203:0crwdne2934203:0
    Yeah, sorry, you are right! (tried to make something less confusing and created more confusion by accident… 😃 )
    Donát Viosz -
    THIS ONE HERE (lolz)
    weebeast -
  11. iPhone 12 mini Rear-Facing Cameras Replacement, Separate the screen adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Separate the screen adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Separate the screen adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Be very careful your tool does NOT go in between the screen and the screen frame but rather in between the screen frame and the phone frame. If not you will damage the screen and need a new one. This has happened to MANY people. The screen is attached to the screen frame with an adhesive that can also be accidentally pried apart if not done carefully. This is probably more likely if your tool is too thin, if you dont heat enough, or dont suction and pull enough to create a big enough separation between the screen frame and the phone frame.
    Ezra Gilbert - crwdns2934203:0crwdne2934203:0
    Yes, this happens to me, too. It took a long time until I could remove the screen using a heat gun with a heat gun set to 120°C (after trying first with 90° and 100°). Now the right side of the display shows white stripes and the touch doesn't react. -> New display necessary...
    Bernd Löhr - crwdns2934203:0crwdne2934203:0
  12. iPhone 12 mini Rear-Facing Cameras Replacement, Heat the top edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick underneath the top-right corner of the display panel.
    • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
    • Slide the pick along the top edge and cut any remaining adhesive securing the display.
  14. iPhone 12 mini Rear-Facing Cameras Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 mini Rear-Facing Cameras Replacement, Screen information: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two delicate cables along the left edge of your iPhone, one near the top and one slightly below the middle. Don't insert your pick here, as you may damage the cable.
    There are two cables, one near the top, another lower than the middle on the left side. Further steps show where the second one is, but this picture doesn't show it...
    mesanos - crwdns2934203:0crwdne2934203:0
    Welches Ersatzteil benötige ich, wenn die obere Verbindung gerissen ist?
    Claudia T. - crwdns2934203:0crwdne2934203:0
    If the inside of your phone looks different than these photos (like me) then you may have only removed the top layer of the screen assembly. The bottom layer should pry up easily enough with tweezers.
    macro - crwdns2934203:0crwdne2934203:0
    I accidentally tore the cables off. What can I do?
    Alma Hernandez - crwdns2934203:0crwdne2934203:0
    The display flexy is in the middle of the left side, please update the picture showing the flexy connected and highlight in red, so other users don't damage it as I did :(
    Juan David Zuluaga - crwdns2934203:0crwdne2934203:0
    Updated -- thank you! Does this look better?
    Spencer Pennington -
  16. iPhone 12 mini Rear-Facing Cameras Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Don't go from just one corner (like on the right side). I've done that (forgot this step) and broke my screen.
  17. iPhone 12 mini Rear-Facing Cameras Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the battery and display connector cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the battery and display connector cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    hallo, ich sehe in Schritt 17 nur EINE markierte Schraube... (?)
    marrei1964 - crwdns2934203:0crwdne2934203:0
    So i got the kit how do you expect with the tools you gave me i should get that tiny screw out?? Its requires a 3 way screw i have a 4 and 2 5 ways 🤔
    This Shield is garbage and once it's taken out it's next to impossible to get back in. I'm not even going to put the shield back in I'm just going to put kapton tape over it and call it good.
    Zach Benson - crwdns2934203:0crwdne2934203:0
  19. iPhone 12 mini Rear-Facing Cameras Replacement, Remove the battery and display connector cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Remove the battery and display connector cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the battery & display connector bracket.
    • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
  20. iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the OLED display cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the OLED display cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the front sensor assembly cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the front sensor assembly cover: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
    There is an error here. There are different screws. 2 large and 3 small.
    zeidin09 - crwdns2934203:0crwdne2934203:0
    what 3 are the small ones? I don't know anymore
    Thomas Klep - crwdns2934203:0crwdne2934203:0
    in case anyone else reads this, the 3 small ones screw directly onto the board. the two longer ones screw into standoffs (the two top screws, based on the picture above)
    Skyejobs -
  23. iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the front sensor assembly bracket.
  24. iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the front sensors: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the front sensors: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
  25. iPhone 12 mini Rear-Facing Cameras Replacement, Remove the display assembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  26. iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the camera module cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Unscrew the camera module cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.6 mm-long Phillips #000 screws.
  27. iPhone 12 mini Rear-Facing Cameras Replacement, Remove the camera module cover: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Remove the camera module cover: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the camera module cover bracket.
    • On the right side of the bracket are two little nibs which are tucked into the iPhone frame. Grab the bracket on its left edge and pull it in the direction of the volume buttons in order to remove it safely.
    • During reassembly make sure to align the two metal nibs with their appropriate slots in the iPhone frame.
  28. iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the camera flex cables: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Disconnect the camera flex cables: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The camera flex cables in the iPhone 12 mini are layered above each other and therefore need to be dis- and reconnected in correct order.
    • Use a spudger to disconnect the ultra wide angle camera flex cable by prying it straight up from its socket.
  29. iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the wide camera flex cable by prying it straight up from its socket.
  30. iPhone 12 mini Rear-Facing Cameras Replacement, Pry up the camera module: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Pry up the camera module: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a supdger between the upper edge of the camera module and the iPhone frame.
    • Use the spudger to pry the camera module out of its recess by tilting the spudger downwards.
  31. iPhone 12 mini Rear-Facing Cameras Replacement, Remove the camera module: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12 mini Rear-Facing Cameras Replacement, Remove the camera module: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the camera module.
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 mini Answers community for help.
crwdns2935229:013crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
234.863 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.821crwdne2935297:0
Removing these screens is no joke folks. There is a backing on the screen that is also adhered to the phone casing, and it is very easy to separate this from the front of the screen, destroying or at the very least damaging it in the process.
Hunter Strathman - crwdns2934203:0crwdne2934203:0
Once the stupid screen is off, it's an easy task. I wasn't able to get it off without the clamp. So I would order the clamp straight away with it!
Robertvo - crwdns2934203:0crwdne2934203:0
I managed to replace the camera. Now I am stuck with a not functioning foto app, that won't save pictures and a really slow loading time generally. Also I can not switch to wide angle camera mode. how do I fix this?
Max von Nordheim - crwdns2934203:0crwdne2934203:0
Will you get the "Finish Repairing Your Camera" warning with Ifixit rear camera part?
Tim - crwdns2934203:0crwdne2934203:0
Yeah head the warnings about the screen, destroyed my screen trying to open this.
Nathan Nohr - crwdns2934203:0crwdne2934203:0
I separated the display from the bezel on my attempt, and ruined the display. I didn't understand I was doing it wrong until I lifted the entire thing off. To me it just seemed like i was sliding the picks around the edge and everything was going to plan. I saw that I had only one cable connecting the display to the phone; the second cable (for the sensor assembly) stayed down in the body and separated from the display. Bad.
When you're putting the first pick in, look very carefully to make sure this isn't happening to you. You should be lifting out a little two-layer sandwich, the glass layer on top, and the black plastic bezel still connected.
I'd like to know how to avoid this reliably. I suspect it was the heating step. I pointed the dryer from above the phone, which probably loosened the adhesive under the display more than around the bezel. Maybe pointing the heat at at the edge of the phone, aiming from the side, is the way to go? Can anybody confirm if that's how they did it?
Jason T - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 37
crwdns2936753:07crwdne2936753:0 307
crwdns2936753:030crwdne2936753:0 1,274
crwdns2942667:0crwdne2942667:0 40,715
