iPhone 11 Battery Replacement
crwdns2942287:0crwdne2942287:0iPhone batteries degrade with use—over time, they lose their ability to hold a full charge. Apple's batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. When your battery's chemistry is degraded, it may also cause your iPhone to run more slowly. Use this guide to replace your battery and restore your iPhone 11 to full performance.
If your battery is swollen, take appropriate precautions.
Note: After the repair, your iPhone may display a warning about the “genuineness” of the battery, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
You'll need replacement adhesive in order to complete this repair.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
crwdns2936621:0crwdne2936621:0
            Power off your iPhone before beginning disassembly.
            Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
            Measure 3 mm from the tip and mark the opening pick with a permanent marker.
 Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick? Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used? I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair. what fix kit? My fix kit didn't include an opening pick either Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes. My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary the picture shows 3 cm but the description says 3 mm's. Which one is it? That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm. VauWeh - Oh, come ON! Big Ed - It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it! @leifdewolf I wouldn't skip it for a first repair. It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well. No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case? Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided. For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point! Will the phone still work if the sensor assembly on the back of the screen is damaged? I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini? an old credit card will do that job, although you'll have to pull a little bit more if the credit card is thicker than the picks, just again, be careful and don't insert it that far The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit. Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler… indeed!!!! I agreee!!! Lonnie - I bought the kit of five just in case. I used two and marking them at 3mm was definitely helpful.
            Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
            If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
   crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95-
            Pull the blue handle backwards to unlock the Anti-Clamp's arms.
            Slide the arms over either the left or right edge of your iPhone.
            Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
            Squeeze the cups together to apply suction to the desired area.
            Pull the blue handle forward to lock the arms.
            Turn the handle clockwise 360 degrees or until the cups start to stretch.
            Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
            Heat an iOpener and thread it through the arms of the Anti-Clamp.
            Fold the iOpener so it lays on the bottom edge of the iPhone.
            Wait one minute to give the adhesive a chance to release and present an opening gap.
            Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
            Skip the next three steps.
 Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself. Any suggestions if the screen is broken and the anti-clamp just separates the screen from the bezel?
            Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
 어짜피 못쓰고 버릴 거라면, 이것보다 인두기를 직접 대는 방식을 추천 합니다. 어짜피 유리라 연기나 반응도 없고 무엇보다 금방 열기가 올라와요. Gut gehen auch Kirschkernsäckchen. Damit hatte ich Erfolg!
            If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
            Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
 This turned out to be the most difficult part for me. My old ifixit suction cup didn't suck hard enough to generate enough force to pry the display from the case. I ended up applying heat at least a dozen times, and I had to pull up on the suction cup forcefully over and over and over while repositioning it several times. I finally had success inserting my pick into the tiny gap after 30 or so rapid tugs on the suction cup. I pulled the screen by accident instead of the bottom layer, now what? I have the same question After heating (I used a hair dryer for 4-5 mins, moving around whole frame, to make sure was pretty hot, then let sit for 1 minute), insert a razor blade between the bezel and the frame, at the bottom edge. Lever upwards, the screen will easily pull away. You won’t even need the suction cup.
            Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
            Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
 Instructions are confusing as the last step says not to insert at certain points, while this says to slide all the way up the right side - is it that sliding is ok but inserting isn't (whatever that might mean) or just not more than 3mm? Just slide slightly and the display will rise without problems on all iPhone models, sometimes if I have long nails I even insert a fingernail and lift the display. Tonynox -
            Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
            Insert your pick into the top-right corner of the phone.
            Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
            Slide the pick to the top left corner and cut any remaining adhesive securing the display.
            Pull the small nub on the suction cup to detach it from the front panel.
            Open the iPhone by swinging the display up from the left side, like the back cover of a book.
            Prop the display up against something sturdy.
            To access the screws in the following step, tilt the display by slightly lifting its lower edge.
   crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95-
            Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
 During reassembly, I had to connect my phone to the charger before it would power up. Die Schrauben sind wahnsinnig kurz, tatsächlich winzig klein. Nach dem Herausdrehen könnte es im ersten Moment so aussehen, als habe man die Schrauben ausgebohrt anstatt herauszudrehen, sie sind jedoch sehr schnell gelöst und liegen dann entweder im Gehäuse oder sind neben dem Gehäuse herausgefallen. In jedem Fall sollten sie nie auf den Boden fallen, da sie dann kaum mehr auffindbar wären. I got to this point thinking/hoping I could eek by with a Y1 orY0 or even a PH000 driver but no such luck. The Y000 is in fact necessary. Finishing this repair will have to wait for now. ALSO thanks Apple, there is ABSOLUTELY no reason AT. ALL. to use so many random, oddball screw heads, BUT to make self repairs more difficult and expensive. A real F-U to the consumer!
            Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
            Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
 i didnt do this step because i didnt know and now my phone wont work at all does the brackets need to be all the way on also, or is it a motherboard issue?
            Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
            Use a spudger or a fingernail to disconnect the LCD panel cable connector.
            Disconnect the digitizer connector next to it.
 Be mindful when reconnecting LCD panel connector and digitizer connector. It’s looks very similar. These 2 ribbon connectors a slightly different. Pay attention. 내 아이폰이 디스플레이 분리 단계를 거친 후, 전원이 들어오지 않습니다. 층전기를 꽂아도 배터리에 미세한 전기 반응이 느껴지지 않고, 탭틱 엔진도 작동하지 않게 되었습니다. cpu 온도는 여전히 뜨껍습니다. 내 마더보드가 디스플레이 분리 후 갑자기 고장난건가요? Hast Du das Problem gelöst? 커넥터 핀을 빼거나 다시 넣기 위해 구부러졌을 수 있습니다. 핀이 구부러진 경우 돋보기 등으로 살펴보고, 그렇다면 적절한 매장에 가져가세요. Hampter - Hier war mein Problem schon gelöst. Durch einen Sturz hat sich der Touchscreen Stecker gelöst. Wieder eingesteckt funktionierte die Touch-Eingabe wieder.
            Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
 There needs to be an extra step between 24 and 25 for reassembly, telling folks to apply adhesive here. I got the thing almost all the way put back together before realizing that the adhesive was a single piece that needs the cables to be disconnected in order to apply it.
            Remove the display assembly.
 After this step its probably a good idea to test the new screen (you dont have to plug in the front camera assembly) Not a technician, so correct me if I'm wrong: I think that it's at this step of reassembly (before you reattach the screen) that you apply waterproof glue, if you have it. You are both correct. Testing the screen before putting on adhesive means the screen can be returned if faulty. Many places will not accept a screen return that has adhesive on it. So if it works apply adhesive at this point. When testing don’t just rely on Apple logo test touch functionality also .
            Using a Phillips driver, remove the five screws securing the bracket below the Taptic engine and speaker:
            Four 1.6 mm screws
            One 1.3 mm screw
 The top right screw (1.6 mm marked red) is actually different from the other three 1.6mm screws as it's thread is slightly thicker. yep same experience here Yes, same here. The guide should be updated. me too same Experience
            Remove the lower bracket.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use tweezers to lift and remove the black tape and rubber pad covering the Taptic Engine connector.
            Remove the five screws securing the speaker and brackets:
            One 1.9 mm Phillips screw
            One 2.3 mm Phillips screw
            One 3.1 mm standoff screw
            Two 1.6 mm Phillips screws
 In my experience, the two green screws are not interchangeable the two green srews are not equally thic Wtf? I buy a repair kit and it doesn’t have all the screwdrivers I need? The repair kit does not have bits for all the screws The battery kit includes the bit for the standoff screw marked in yellow. I can't get it to remove with any of the three provided bits. Doesn't even engage. The green screw for the ground clip is longer than the second green screw. Keep the ground clip with that screw
            Remove the small grounding clip on the top right corner of the speaker.
            Remove the Taptic Engine connector cover.
            Lift and push aside the small board covering the remaining speaker screw in the bottom right corner of the iPhone.
            Remove the 2.4 mm standoff screw underneath.
 Use the standoff bit that should be in the box with the battery and adhesive.
            Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
            Gently pry up and lift the top edge of the speaker.
            Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
            Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
 You want to pull the speaker out exactly as they have shown. If you rock it the other way, it will pull off the board that's not mentioned, but still pictured against the edge of the phone. Also, the kit frustratingly doesn't include the speaker gasket. So get that before you start, or you'll be remolding the used gasket. No adhesive gasket included in my kit? So dumb. Guess I'm out of luck because I can't wait for that to arrive in the mail. Need it now. Guess I'll see what I can do with this mangled old stuff I tore off. smh. Hopefully this never gets wet because now it won't be water-tight.
            Remove the speaker.
            Peel away any remaining adhesive with tweezers.
            Prep the area underneath by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly.
            Install a new gasket onto the speaker, and then install the speaker.
 It seems that a bracket which held a screw to the charging port is holding the part to the phone even though adhesive and all screws are removed, not sure why but I can't remove the speaker. I had this same problem with another bracket of the speaker which held a screw but ripped it off the lower speaker part as i couldn't get it unattached from the screw port. All screws and adhesive were removed, I don't understand what is wrong do you sell the speaker's adhesive gasket replacement? Do you sell the speaker adhesive? It's unfortunate to have gotten this far and feel ill prepared to replace something that seems very important. You guys should have included it or indicated it as a highly recommended option. Im Reparatur-Kit ist keine Ersatzdichtung für den Lautsprecher enthalten! 😢 No speaker adhesive included? Well..... that's just dandy. 😑
            Use a Phillips driver to remove the two 1.8 mm screws securing the Taptic Engine.
            Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
            Remove the Taptic Engine.
            Each piece of adhesive has a black pull-tab at one end, which is lightly adhered and folded onto the top of the battery.
            Peel back the three battery adhesive pull tabs from the bottom edge of the battery.
            To increase your odds of success:
            Don't press down on the battery. Hold the iPhone firmly by its sides.
            Keep the strips flat and unwrinkled as you pull.
            Pull very slowly, giving the strip time to stretch and separate. It takes around 30 seconds of stretching to remove each strip.
            Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
            If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
            Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
            Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case.
            If the battery adhesive tabs break during the removal process, use your fingers or tweezers to retrieve the remaining length of adhesive, and continue pulling.
            If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the other strips, and then proceed as instructed below.
            Repeat the above steps to remove the other two adhesive strips near the bottom edge of the iPhone.
            Peel back the three battery adhesive tabs from the top edge of the battery.
            Pull the top adhesive strips out one at a time, using the same method you've used to pull the bottom strips.
            If you removed all of the adhesive strips successfully, skip the next step.
            If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
            If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s).
            After about a minute, gently lift the battery.
 This is a very good tip, it is hard to remove all the adhesive without breaking one of them, but the alcohol is very helpful. the glue tabs on these batteries are extremely hard to loosen without tearing them. I followed the directions exactly as stated, and still managed to have all 6 of mine rip. Maybe the older the phone, the more brittle they become? Mine seriously were thin and shredding until they would just tear. Luckily, with a combination of the alcohol, the dental floss, and a lot of patience I got the battery loosened enough underneath to take one of the angled spudger tools and slowly pryed around the edges of the battery little by little until it finally came free. But what a pain
            If your battery is stuck and an appropriate liquid solvent is not available, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
            Flip the iPhone back over and thread a strong piece of string (such as dental floss) underneath the battery.
            Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
            Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
            Remove the battery.
            Adhere the battery, disconnect it, and continue reassembling your device.
            If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
            Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
 Das einkleben der Dichtfolie sollte besser beschrieben werden. Es sind drei Schichtenblaue Schutzfolie. Mir hat es geholfen sie quer zu zerschneiden. Das Handy ist danach sowieso nicht mehr wasserdicht weil das mikrofon auch eingeklebt werden müsste
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
crwdns2935229:0208crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:027crwdne2947412:0
Also, it would be nice to have a step by step of how to reprogram the new battery to bypass the “non-genuine warning”
I have been looking for a solution for this! Seems the only way is to remove the BMS board from the original battery. Requires soldering.
Apple specifically does this to prevent 3rd parties from repairing their products. A Simple google search would have yielded this.
"A simple google search would have yielded this" 🤓🤓🤓
Anyone figure out a way to hide the badge on the settings icon?
La guida consiglia di rimuovere molte parti, in realtà basta solo rimuovere lo schermo ed acquistare una batteria già assemblata.
Io personalmente o impiegato 45 minuti andando molto lento e molto attento alle mie operazioni.
When opening up a phone, why doesn't ifixit recommend to use a static electricity grounding wrist band since such charge can damage phone electronics if not grounded? (Apple technicians use such).
How come ifixit does not give advice after a battery change how to reprogramme the phone to its full functioning capability since some are lost when a battery is replaced? (Apple technicians include this service in a battery change).
What are the statistics on after market batteries not performing as good as OEM parts and what are statistics where such after market batteries harm the phone? All batteries are made in China but Apple endorsed battery makers are required to adhere to strict standards.
Ok Tim Apple
Aneta M -
Just noticed on the video at 6:02-6:03 the screw is being screwed into the wrong hole on the speaker and at the wrong stage
Also keeping the black rubber pad cover the tactic engine connector should be mentioned earlier in the video
Apart from that - great video
Thanks for this guide! I successfully replaced/upgraded my wife's battery. She'd had this phone for 2+ years and it was time. Replaced it with one of the increased capacity batteries available on Amazon. Removing the old and installing the new battery was easier than I thought it would be. Opening the dang thing was the hardest part.
Successfully completed using this guide. Thanks Jeff
Die Anleitung ist, wie immer bei IFIXIT, super verständlich! Ich bin jedoch nur bis Schritt 25 gefolgt und habe die haptic engine und den Lautsprecher nicht ausgebaut. Das Akku ließ sich auch so mit etwas Geschick und den richtigen Werkzeug (z.B. einer guten Pinzette für die Klebestreifen) und etwas Isopropanol aus einer Spritze (100%) gut lösen. Eine alte EC-Karte o.ä., um vorsichtig (!) von oben unter den Akku zu kommen kann helfen (das Akku nicht stark verbiegen!). Ab hier wieder zusammengebaut - und voila! Einiges an Arbeit erspart. Einziger Nachteil: die unteren Klebestreifen am Akku reißen leicht, da man diese wegen der haptic engine nicht flach herausziehen kann. Aber mit ein paar Tropfen Isopropanol kein Problem und Fehler beim Zusammenbau werden evtl. vermieden, da weniger Schritte beim Aus- und Einbau notwendig sind. Ich hoffe, der Tip hilft dem ein oder anderen, die Reparatur zu vereinfachen. Würde mich freuen. Ist übrigens nicht mein erster Akkuwechsel :-)
Your tutorial help me a lot thanks for your contribution !
If anyone wonder you can actually change you battery without removing taptic engine and the speaker
Probably not, it would be impossible to peel the strips out I’m pretty sure.
I have done many iPhone 11 battery replacements and I typically remove only the taptic engine and not the speaker. You could definitely do it without removing the taptic engine as well, but it's less of a hassle to remove the taptic engine than it is to work with such little clearance IMO.
Cable -
Hat jemand Erfahrungen mit Akkus welche eine grössere Kapazität aufweisen als die originale? Halten die wirklich länger, bzw wie ist die Qualität der Zellen? Gibt es da Erfahrungswerte?
Moin, ich habe die Ladebuchse meines iphone 11 gewechselt weil es zuvor nicht geladen hat. Nun Läd es Trotzdem nicht mehr. Woran kann das liegen?
Hallo, ich gebe hiermit ein Update zu meinen ersten Kommentar. Ich habe einen Nagelneuen Ladeadapter gekauft und der hat nicht Funktioniert. Daraufhin habe ich Ladebuchse und sogar das Akku ausgetauscht und es hat trotzdem nicht funktioniert. Dann habe ich mir einen anderen Kabel bestellt. Statt USB-C auf Lightning "was nicht Funktioniert hat" benutze ich "USB auf Lightning was nun funktioniert" Ich habe den alten Akku auch wieder eingebaut uns es funktioniert einwandfrei :D Hat jemand einen reim hier drauf warum es der USB-C Anschluss auf Lightning nicht Funktioniert?
Ferhat -
BE WARNED!! Do not be fooled I bought the screen kit from here and it never arrived and I never got my money back too. Good luck to you. I been trying to reach DHL only to find out the product was never send. What a wast. How are they allowed to run a scam
Actual hours spent is more like 5, when including ALL aspects of repair including gathering parts and tools, deciding which parts and tools are needed, thoroughly reading entire instructions several times, fiddling with battery that won't come out, worrying about overheating phone while trying to loosen screen and bezel, picking up the tiniest screws on earth and trying not to lose them. Perhaps a person who does this several times could reduce that time, but most people only ever do this once.
Doing this somehow broke the digitizer in my screen, and now 100$ is down the drain.
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided. Totally worst.
Unbelievably detailed instructions!! Im impressed - and pretty convinced I shouldn't try it LOL!
The instructions are thorough and it worked. 1-2 hours for someone doing it first time is not realistic. I'm pretty mechanical and it took me 3+. You can keep track of the tiny screws by pressing them lightly through a piece of paper and then labelling/drawing a diagram on the paper.
I replaced the battery successfully, but now face id isn't working. When trying to re-train it either tells me to center my face in the frame or almost instantly gives "Face ID not available" error.
I checked with a microscope, but found no damaged parts from wrong flex cable removing, flex cables are not ripped or otherwise damaged or bent.
Maybe some lens was misplaced when reassembling? Are there other pitfalls?
Not my first battery replacement, but I repaired like 100 macbooks, so I'm cautoíous and used to flex cables and stuff.
the right screws wouldn’t come off
Yusef San Inocencio - crwdns2934203:0crwdne2934203:0
ok one came of but my right wont come of either!!!!
Aisa Jawara -
Hello guys, I still haven't found away to power off the iphone without using the screen. Cheers!
danielaguirre93 - crwdns2934203:0crwdne2934203:0
You can try this.
Quickly Press and release the volume up button.
then Quickly Press and release the volume down button.
then press and hold the power button and wait until it turns off.
worked for me :D
Benóný Egilson - crwdns2934203:0crwdne2934203:0
Where does one get replacement seals? Is this the same as the display assembly adhesive?
Brian Baker - crwdns2934203:0crwdne2934203:0
not of the screwdrivers i have seem to be able to turn the screws
Aisa Jawara - crwdns2934203:0crwdne2934203:0
how do you change battery of an iPhone 11 and still the battery health shows, do you use a software for that?
Great Me - crwdns2934203:0crwdne2934203:0
Battery health won’t show on a non Apple battery.
DON’T forget to discharge old battery before removing it. Very impressive fire (and smoke!) if you puncture it. Ask me how I know
Doug Harrowing - crwdns2934203:0crwdne2934203:0
Does anyone know which size pentalobe screws (step 1) they are ? I have P2 if that’s a size, is that the right one?
Jannn - crwdns2934203:0crwdne2934203:0
Yes, P2 is the correct one!
Russ Torrez -
