iPad Air Wi-Fi Rear Case Replacement
  1. iPad Air Wi-Fi Rear Case Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - crwdns2934203:0crwdne2934203:0
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - crwdns2934203:0crwdne2934203:0
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - crwdns2934203:0crwdne2934203:0
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - crwdns2934203:0crwdne2934203:0
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - crwdns2934203:0crwdne2934203:0
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - crwdns2934203:0crwdne2934203:0
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - crwdns2934203:0crwdne2934203:0
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - crwdns2934203:0crwdne2934203:0
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - crwdns2934203:0crwdne2934203:0
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - crwdns2934203:0crwdne2934203:0
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - crwdns2934203:0crwdne2934203:0
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - crwdns2934203:0crwdne2934203:0
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - crwdns2934203:0crwdne2934203:0
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - crwdns2934203:0crwdne2934203:0
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - crwdns2934203:0crwdne2934203:0
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - crwdns2934203:0crwdne2934203:0
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - crwdns2934203:0crwdne2934203:0
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - crwdns2934203:0crwdne2934203:0
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - crwdns2934203:0crwdne2934203:0
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - crwdns2934203:0crwdne2934203:0
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - crwdns2934203:0crwdne2934203:0
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - crwdns2934203:0crwdne2934203:0
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - crwdns2934203:0crwdne2934203:0
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - crwdns2934203:0crwdne2934203:0
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - crwdns2934203:0crwdne2934203:0
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - crwdns2934203:0crwdne2934203:0
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - crwdns2934203:0crwdne2934203:0
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - crwdns2934203:0crwdne2934203:0
    Can’t you just use a hair curler instead?
    Aspect22 - crwdns2934203:0crwdne2934203:0
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - crwdns2934203:0crwdne2934203:0
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - crwdns2934203:0crwdne2934203:0
  2. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - crwdns2934203:0crwdne2934203:0
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - crwdns2934203:0crwdne2934203:0
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - crwdns2934203:0crwdne2934203:0
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - crwdns2934203:0crwdne2934203:0
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - crwdns2934203:0crwdne2934203:0
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - crwdns2934203:0crwdne2934203:0
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - crwdns2934203:0crwdne2934203:0
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - crwdns2934203:0crwdne2934203:0
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - crwdns2934203:0crwdne2934203:0
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - crwdns2934203:0crwdne2934203:0
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - crwdns2934203:0crwdne2934203:0
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - crwdns2934203:0crwdne2934203:0
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - crwdns2934203:0crwdne2934203:0
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - crwdns2934203:0crwdne2934203:0
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - crwdns2934203:0crwdne2934203:0
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - crwdns2934203:0crwdne2934203:0
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - crwdns2934203:0crwdne2934203:0
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - crwdns2934203:0crwdne2934203:0
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - crwdns2934203:0crwdne2934203:0
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - crwdns2934203:0crwdne2934203:0
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - crwdns2934203:0crwdne2934203:0
  3. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - crwdns2934203:0crwdne2934203:0
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - crwdns2934203:0crwdne2934203:0
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - crwdns2934203:0crwdne2934203:0
    This thing melts when placed up side down in the microwave…
    Mark - crwdns2934203:0crwdne2934203:0
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - crwdns2934203:0crwdne2934203:0
  4. iPad Air Wi-Fi Rear Case Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - crwdns2934203:0crwdne2934203:0
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - crwdns2934203:0crwdne2934203:0
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - crwdns2934203:0crwdne2934203:0
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - crwdns2934203:0crwdne2934203:0
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - crwdns2934203:0crwdne2934203:0
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - crwdns2934203:0crwdne2934203:0
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - crwdns2934203:0crwdne2934203:0
  5. iPad Air Wi-Fi Rear Case Replacement, Front Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Front Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Front Panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    If you add clear packaging tape, it will create bubbles and the suction cup will become inefficient. To me it was impossible to remove the glass with the suction cup. Since the glass was very cracked, I had to resort to some tweaking with strong tape and pull the this off.
    jfmartin67 - crwdns2934203:0crwdne2934203:0
    If your screen is significantly cracked to the left edge, abandon this entire setup, prepare yourself for a 5-6 hour repair, expect a lot of patience, a lot of cursing and some good old American ingenuity. The suction cup and picks will not work. You have to carefully crack the glass yourself (w/out damaging the panel underneath and carefully pull it apart from the inside to the outside edges. Use a hairdryer to soften the glue under the cracked panel along the edges. Then use an exacto-knife to separate the pieces of the glued panel from the frame body, all the way around the device. Watch out for the home button ribbon connector when using the exacto-knife. There will be glue residue left over, carefully apply some goo-gone to a small area of a paper towel and wipe gently around the frame body to loosen the glue. Then use the plastic spudger tool to scrape off the excess glue.
    The iPad repair is VERY difficult. If you are a working adult, hire a pro. This is not for the faint of heart.
    aaroncope - crwdns2934203:0crwdne2934203:0
    The hairdryer option was way faster and easier than the iOpener. Be VERY careful not to damage the LCD- one small mistake will cost you an extra $100!
    Mike Martin -
    but I’m not American
    Andrew Williams -
    If your digitizer is shattered, the tape will help, but you’re going to need extra picks. Or a razor blade. See below.
    Blair Miller - crwdns2934203:0crwdne2934203:0
    Friendly observation that the image on this step is actually of an older ipad model as the side bezels are far too big. I don't know if that matters to anybody but a noob might see it and think this manual doesn't apply to them. : )
    notalawyer - crwdns2934203:0crwdne2934203:0
    Thank you! Yes things like this matter so much. I successfully replaced an iPhone 6LCD&Screen from the guide. Next was my iPad 2 and the guide said nothing about the power flex cable. They were only stressing about not severing the wifi cable. I followed instructions carefully. Got the screen off and bam. Power flex severed because it was left out of the guide. I saw it in the comments after. I’ll never follow a guide here again without reading the comments. I did receive a discount code for my next purchase but it still caused a lot of inconvience.
    Haley Hodges -
    I had the same experience. My glass was cracked all the way to the left side and the suction cup would not pull the glass up. The packaging tape also didn't help. The heat caused it to lift. I finally abandoned the tape, used a heat gun aimed very carefully at each broken piece of the screen. The picks did work with patience, but I just pulled off each broken part of the glass. I also found that pulling up on one broken part while heating in front of me would let the next piece pull up. I continued heating and breaking all the way around. Do the right side last. Took about 1 hour to get it off, and another hour to clean the old glue off the frame. BTW thanks to this web site and all the comments! No way I would have done this without all the help here! I am now clean and waiting for my new digitizer. I couldn't free the battery (below), so I left it powered up, and verified it till worked before throwing away the old glass. Vince
    Vince Asbridge - crwdns2934203:0crwdne2934203:0
    Taping with package tape doesn't work. You'll need a very large piece of tape if you go this route.
    Just finished successful repair. I would add this: most folks will be here because of cracked screen. This is not easy; believe the 'complex' rating on this repair. I put tape on my screen because it was badly cracked. This made the suction cup useless, because it just sucked the tape off the scree.n. I used the razor blade technique which worked great, it should be used in the demo, and a good blade should be in the kit.
    dale kingsbury - crwdns2934203:0crwdne2934203:0
    I thought this shouldn’t be too hard - I only had some cracks in the glass, but then at every spot I worked on, the glass turned into nothing but tons of tiny shards. I had to use the points of the tweezers plowing along only the outer edge all the way around, sometimes with a razor blade and often using a hair dryer up close (briefly, over and over). After I got every bit of glass out, I used ordinary rubbing alcohol and Q-tips but I had to rub hard and quickly 100 times on each area to slowly dissolve the glue. I only scratched the LCD once slightly with a tweezer slip. The large chucks of display held together by the packing tape needs something under it to protect the LCD while you are working.
    Using Goo Gone to get rid of the adhesive residue is 20 times faster than using rubbing alcohol, even if it is 91% isopropyl alcohol.
    Skipping the iOpener and using a hair blowdryer, and using Goo Gone in place of the rubbing alcohol are 2 simple changes that will make this job much much easier than the default instructions if the screen is shattered.
    Scott Walker -
    I found the hair dryer is far more effective and less dangerous than using the iopener. If you overheat the iopener you end up pulling a hot plastic bag spewing hot glycerine out of your microwave! Not fun!
    Clifford Sullivan - crwdns2934203:0crwdne2934203:0
    Packing tape won’t do anything. You need to use duct tape to prevent glass shards from spraying everywhere. If your screen is only partially cracked (mine was the top only), modify the directions and focus on the areas that aren’t cracked first. I was able to get the lower 90% of the screen off, and then worked the cracked pieces with a heat gun and metal razor spudger. The entire repair took around 3 hours, and prob 2 hours and 30 min of that was getting the shards out and pieces off. And lots of cursing. I also told my kids if they crack another screen they are out of luck. I am not doing this again.
    Janie Hughes - crwdns2934203:0crwdne2934203:0
  6. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
    The iOpener doesn't work because the heat isn't strong enough. I used a hair dryer which proved to be much more efficient.
    The iOpener didnt work for me either. seems like it gets hot enough but it must not. I spent 30 min with the iOpener, then tried a hair dryer.
    kinchma - crwdns2934203:0crwdne2934203:0
    “At least a minute.” Bullshit. Get the iOpener good and hot, place it on the area you’re going to work on clear side down, and cover it with a towel. Walk away for 2 minutes. Make yourself a drink — you’ll need steady hands later.
    I've done this with an iOpener and at least in my case, it worked fine. You may have to modify the heating instructions though, since not all microwaves are created equal.
    Jeff Suovanen - crwdns2934203:0crwdne2934203:0
    ii i just did this and it took a while but i figured it out it is true this thing doesnt get hot enough BUT heat it 2 times and then the 3rd time when u place it on the ipad put the ipad box on top and then maybe a second ipad on top of the box so it kinda smashes i down but not too much for it to break and then wait for it to turn warm THEN use the succion THEN the gap appears. the glue is super strong on the ipads so yea it will take some time lol
    Joel Tyson - crwdns2934203:0crwdne2934203:0
    Doesn't work. Perhaps include more copy on exactly how to do it?
    The iOpener does not work. It simply it is not hard enough to soften the glue. The heat hair dryer method does not work either.
    Javier Lozada - crwdns2934203:0crwdne2934203:0
    The goal is simply to weaken the glue enough that you can use your suction cup to open up a tiny gap under the glass, so you can insert an opening pick and slice through the adhesive. It doesn't actually take all that much heat; the picks will do most of the work once you get them in there. iOpeners, hair dryers, heat guns all work fine in my experience—the iOpener is just a bit more foolproof because it won't get hot enough to cook the display panel underneath.
    I used iron..surprise!! yeah pretty fast tho…put a layer of fabric (towel in my case) ontop, along the edge of screen and start ironing..
    carvelera - crwdns2934203:0crwdne2934203:0
    If using a hair dryer or heat gun make sure it is not too high heat. My heat gun has two settings, one 750 degree and an 1100. After using it on high I discolored the digitizer and warped the LCD slightly (only shows on pure white backgrounds). Low worked for the rest of the repair just fine. Also using a razor blade or something besides the pick works nice for the initial pry. Once you have a gap big enough, insert the pic and you’re all set.
    Robert - crwdns2934203:0crwdne2934203:0
    I don’t have an iOpener, my heat gun wasn’t handy. The last time I did something like this it was a 90-100 degree day, so I just put it out in the sun for a while, and it worked great. This time it’s fall, so I used a 420W halogen Light that I have for photography. (A standard heat lamp would probably work too, but might take longer.) I held it close to the light until it felt hot to the touch, just a couple minutes, then I left is sitting about 16” below the light for 5-10 minutes to sink in and warm uniformly. It worked great.
    For me, steps 8-31 were basically one step "Carefully pry off the digitizer glass with the plastic tools" took all of 30 seconds.
    Seth Childers - crwdns2934203:0crwdne2934203:0
    Although very hard this does work. The first time opening the ipad after buying it 8+ years ago it took about 3 times of heating the iopener. It did require an amount of pressure I did not expect but it did come open as instructed. I did add a towel and apply pressure to the iopener to make sure the heat transferred.
    hmcarbajal - crwdns2934203:0crwdne2934203:0
    The iOpener didn’t work for me at all, zero, it literally did nothing. I resorted to my heat gun on low and yeah you need to be super careful, but once I started the adhesive came off pretty easy.
    David Yutzy - crwdns2934203:0crwdne2934203:0
    I used a 2-level heat gun, too. Supposedly 707 degrees/923 degrees.
    I kept the heat gun about 1” away from the glass and used only the low setting. Even so, I did alter the digitizer pretty quickly in a few locations around the edge. It still functions fine, and you only see it under certain circumstances, so not a huge deal. But irritating. Be cautious about too much heat. It just looks like sort of a faint, polarized grid.
    Don’t be afraid to put tension on the glue and just hold it. If it is warm enough, the glue will relax under sustained tension. This isn’t a speed event. Don’t try to rush it, or you’ll break something.
    Now that those infrared surface thermometers have become so inexpensive, it would be great if someone posted a target temperature for softening the glue without damage. That would take some of the guesswork out of this process.
    Tim - crwdns2934203:0crwdne2934203:0
    If you heat the iOpener somewhat longer than they recommend, and get it about as hot as your hand can stand, then place it on the iPad and cover with a towel for at least 3 minutes. Then really be patient. I got a bit impatient, and took a chance and slipped a really fine “exacto-type” of blade vertically beside the suction cup as I lifted, and thankfully that worked. That made enough room to get one of the “guitar pick” wedges in. The rest went fine.
    Pete - crwdns2934203:0crwdne2934203:0
    I used the iOpener to soften the adhesive. I was extra careful and it took me about 90 minutes to get to Step 30. With my acquired experience I would say, it may be done in about 30 minutes. Most important: Be patient! You may have to reheat the iOpener a few times until you will be able to do Step 9. Once I had this part done, it was a lot easier. So I would say the first 60 minutes I spent on steps 1 through 9.
    I’ve been using a heat and isopropyl alcohol combo on iPhone screens with no problem. This specifically says “only” heat. I feel like she’s trying to tell me to keep a lid on my IA. Because I don’t know what other methods some rogue might be trying in their efforts to compromise adhesive.
    Audi Archer - crwdns2934203:0crwdne2934203:0
  7. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
    Don't assume anything!! I thought I was pulling on the screen connector and I was pulling on an antenna component instead. Didn't ruin its connection range but I sure remember doing it and now my iPad has a little internal flaw only I'm aware of.
    Correct me if I’m wrong but the LTE version apparently has 2 antennas on each side of the front-facing camera and it’s not shown on this post to avoid prying. I just scratched one of them following these instructions.
    Pacman - crwdns2934203:0crwdne2934203:0
    A note about the multiple image thumbnails - roll your mouse over them to get an animated effect, rather than clicking on them individually
    Rusty - crwdns2934203:0crwdne2934203:0
  8. iPad Air Wi-Fi Rear Case Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  9. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  10. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  11. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    In this picture above, the glass isn't cracked at all so it helps the suction cup to be effective as it is hermetic. With cracked display, it won't work.
    Suction cup would not work for me. No amount of heating with iOpener or hair dryer would allow even the slightest gap to form. I ended up looking at some YouTube videos and used a razor blade. I put the razor blade perpendicular to the top glass, right at the edge of the glass and pushed down until the blade went down 1/4". Then heated some more and pried up the glass enough to put in an opening pick. I spent a lot of time working with the suction cup. Glue was just too strong.
    It's funny that iFixit changed the image they used. Even they themselves realized how stupid it was to try a suction cup on taped up surface. C'mon guys! You should at least make foot notes for your readers and let them know what to do if the glass is already shattered. It's a slow methodical process that involves working with a iOpener type tool. I personally have one that looks like a prison shank (lol)
    Scott S - crwdns2934203:0crwdne2934203:0
    Not sure what you are referring to there—I see no evidence in the document history of the photos having been changed. Suction cup + packing tape can work, but it depends how badly the glass is broken and the quality of the tape. Sometimes it takes a couple attempts. You can also skip the suction cup and try using tape alone to pull on the panel, if your tape is sticky enough. There are no guarantees though, which is why we have the disclaimer right in Step 4 that the procedure can be pretty fussy if you're working with a shattered panel. Depending on where it's broken and how badly, you're going to have to improvise.
    Jeff Suovanen -
    Jeff, the change is evident from image 4, where all the surface is taped up. In this picture you show a clean not broken surface and yes, the suction cup works...
    Simone Gabbriellini -
    Ah, I see what you're saying! I can understand why you guys would assume that, but in reality the entire guide was originally photographed using an intact panel. We later added a step showing how to protect yourself if you have a shattered panel (with photos to go along with, obviously). I'm afraid it wouldn't be practical to re-shoot the entire guide every time we make a small change like that.
    Jeff Suovanen -
    The suction cup is useless if your glass is shattered. Use a new, sharp razor blade, and insert it vertically between the edge of the glass and the metal back of the iPad. Don’t worry about pressing too hard — there’s a lip that stops the blade from going in too far and damaging anything. You’ll probably have to do this several times, but eventually the blade will “bite” into the edge of the glass well enough for you to pry it up. Insert a pick underneath the razor, then remove the razor and continue as directed.
    After having to read several comments on this screen removal and the clear packing tape, I too have to agree that the tape method does not work well at all if your screen is already shattered. I combined several methods, with lots of patience to remove the screen on my iPad Air 2. What I found it very helpful was the heat gun used for paint removal. The heat gun generates a lot of concentrated heat at lower air velocity, unlike generic hair dryer, so you must be very careful not to ruin the electronics, and risk burning your hands and anything around it. My heat gun that I purchased from Home Depot had a nozzle to direct and focus the heat on a small area. That was helpful in working small area at a time. This method work thoroughly well.
    Taiji Saotome - crwdns2934203:0crwdne2934203:0
    It would work if you leave iopener in microwave for 1 minute.
    Don’t trust the instruction from ifixit.
    you can put iopener in microwave for 1 minute without any harm.
    Note. you have to make sure that it is in cold position before you put it into microwave.
    phongsiri nirachornkul - crwdns2934203:0crwdne2934203:0
    Suction cup didn’t work for me either, went the razor blade route (using an exacto knife blade) with very minimal damage to the aluminum shell. Be warned, if your screen has cracked along the edge (as it almost 100% certainly has if you’re reading this guide), the screen will continue to shatter and splinter as you make your way around the edge. That’s when having the screen taped up well will be to your advantage. There’s also a good chance you’ll have to re-insert the razor blade on the other side of a fracture and start the lifting process again, but keep going, being sure to avoid the points called out in this guide and you should be fine.
    Also, do not apply the suction cup to an area of the screen with cracks and no tape. If you’re near the edge you run the risk of brutally shattering that area of the glass if the glass gives before the suction cup.
    Micah Sledge - crwdns2934203:0crwdne2934203:0
    In order to get this to work for me I had to heat the IOpener to over 104 C - I needed to get the screen over 40 C before the adhesive would loosen.
    Also I had to put the ipad on a towel - the granite countertop it was on was sucking the heat out too fast.
    Jack Williams - crwdns2934203:0crwdne2934203:0
    This step was brutal on my nerves - read about too many people ruining their iOpener and I don’t have a heat gun. I had to keep heating the iOpener incrementally hoping I wouldn’t pop it. … but if you’re patient, persistent, and cautious, you can definitely tell when you’re seeing separation. The iOpener ended up being WAY hotter than 30 seconds was getting me - borderline scorching my hands.
    William Thompson - crwdns2934203:0crwdne2934203:0
    Could not loosen the adhesive using the iOpener. Had to use hair dryer.
    Erwin yi - crwdns2934203:0crwdne2934203:0
    As the others noted, the suction cup is useless on a cracked screen, especially if you’ve applied tape (like the instructions say you should). The screen I was working on was busted up pretty bad, I ended up removing it and then going back to remove the edge glass and adhesive. When you have a really busted screen just take your time and use a heat gun or good hot hair dryer and it will eventually come off.
    I used an iSesame tool vs a razor to pry the edge (from a previous replacement project) but again, the iOpener and suction cup are useless.
    Thank you for the comments above. I was using the iOpener unsuccessfully, then turned to the hair dryer and heated it up for over 3 minutes. This gave me the gap I needed to insert the opening pick and begin the process. So, with patience and a hair dryer, I was able to get the digitizer off.
    0812mgr - crwdns2934203:0crwdne2934203:0
    You really need a lot of patience here (30-45min). But then it works. The best way was with this plastic "crowbar" to get the beginning. You really have to press hard to get in between.
    Arne Meier - crwdns2934203:0crwdne2934203:0
    The suction cup provided in the toolkit didn't work on anything. Tape helped, but I eventually went in through a small cracked shard to create an entry point at the bezel
    I've passed on the iOpener as suggested in these comments and have tried to use a hairdryer. heating on high at medium speed for 1 minute then trying the suction cup. heating for another minute then using the suction cup. Been doing this for 1/2 an hour but it isn't working. Need to take a break because I'm afraid I'm going to hurt in internal components of the iPad 6 (just trying to replace a dead battery) Any suggestions ???
    Just a guy - crwdns2934203:0crwdne2934203:0
    LOL...i tried the pastic clear tape to hold the cracked glass then apply the hairdryer. It melted the plastic tape glue and thus making the handle with the duct tape useless and the duct tape just pulled the melted glue from the plastic packing tape up like butter. But the screen still not budging. I've tried the hair dryer for 5 mins and nothing. I've tried the iOpener and that's useless. I'm heating it up 30 secs a time. I tried 1 min. The screen is welded shut.
    brian -
  12. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
    I found it much easier to use a single edge razor blade instead of the pick. After getting that inserted, it was easy to slip the pick between the blade and the case. Disclaimer - Razor blades are very sharp and you could easily hurt yourself or your iPad if you use one.
    donprius - crwdns2934203:0crwdne2934203:0
    This is an amazing tip! After trying for 10 minutes to use the pick with no luck, I grabbed a small razor blade and that worked perfectly to get me started!! Thanks!!
    Ashley Garner - crwdns2934203:0crwdne2934203:0
    The suction cup also didn’t work to create a gap - it cracked the screen when i tried to lift (the screen was already cracked). This was after rotating between the iOpener and a microwavable hot pack for food. The iOpener was around 175 degrees, it brought the surface of the iPad to 130. I was finally able to lift the glass using a razor blade and then the picks like donprius. I continued to use the iOpener to loosen the glue around the rest of the iPad but I think a heat gun would have been more efficient.
    Marc Ducret - crwdns2934203:0crwdne2934203:0
    You have to heat the glue really much, or you will, as i did, crack the glass.
    Linus Grüne - crwdns2934203:0crwdne2934203:0
    Best bet is to mark the pick with a sharpie line on how far your maximum limit is so you don’t damage the LCD.
    Jon Snyder - crwdns2934203:0crwdne2934203:0
    The iOpener works well, be patient and keep reheating until you can see the screen start to give a little. I kept putting mine in the microwave and it worked faster when the iOpener was hotter. 40 second intervals did the trick for me eventually
    Jackson Taylor - crwdns2934203:0crwdne2934203:0
    I spent an hour trying to lift the screen of an iPad Air first gen. The trick I found was that its a combination of lifting the screen a millimetre and then wiggling a razor blade vertically in the slot between the screen and the metal frame (yes its a microscopic slot). I used a hair drier on a section of the edge of the middle of the screen as above. The middle area allows for a bit of flexibility in the rail - we’re talking 0.5mm which is just enough for the razor.
    So hit a section of the screen edge with the drier till its hot to touch, do the suction cap thing as above, insert the blade vertically and wiggle it *ever so slightly* in the slot as you don’t want to break anything. Keep repeating this until you see even the slightest rise in the screen under the cap. At this point, remove the razor and insert the blue pick. It should easily dig in and under the screen, but no further than the black border.
    Remember, small wiggly steps will avoid breaking anything. Better a number of small heat and wiggles than a lift and snap.
    for those who need to open more than one iPad, the iflex is safer and more effective than a razor blade. i use it to get started then switch to a pick
    iFlex Opening Tool
    Stow - crwdns2934203:0crwdne2934203:0
    Yea, this suction cup cracked my glass. This made it near impossible to slide the picks around. I may try again another day, but I suspect it’s toast at this point.
    Jason Prothero - crwdns2934203:0crwdne2934203:0
    I should have noted the difficulty rating before thinking I could replace the battery myself. I could have saved myself the cost of replacing a cracked screen, which happened when I attempted this step. I did not want to overheat the iOpener but consequently, I could not get a pick inserted underneath the screen. (I think the glue must take a lot more heat than expected to melt.) So just a warning to more novice tinkerers—this repair wasn't the same as fiddling with screwdrivers and a million small parts.
    mlliu - crwdns2934203:0crwdne2934203:0
  13. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    This says "Always wait at least two minutes before reheating the iOpener", however the iOpener itself has a warning printed upon it that says wait at least 10 minutes. And that 10 minutes warning is also mentioned in Step 2 above.
    Scott - crwdns2934203:0crwdne2934203:0
    Sorry about that! We fixed the text on this step. The two-minute interval was for an older version of the iOpener—the text printed on your iOpener will have the correct interval, which is indeed ten minutes. It can burst if overheated or reheated too quickly.
    Jeff Suovanen -
    It still says 2 Minutes up there in the warning
    Sandro Krumbein - crwdns2934203:0crwdne2934203:0
  14. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    You guys really need to show how it's done when your iPad isn't perfect like the one pictured above.. C'mon..
    This is for BATTERY REPLACEMENT not CRACKED SCREEN REPLACEMENT!!
    Corey Barcus -
    How do you slide the picks when the glass is broken? Even with the glass taped, it pulls away from the tape rather than the housing. I've just further shattered the glass with my attempts.
    chrisweiler - crwdns2934203:0crwdne2934203:0
    With my shattered screen, I was able to remove it using the suction cup slightly and a metal pry, had to break the edge glass some for removal also but it didn’t do damage. More layers of shipping tape helped to make the screen stay together better and come off more intact.
  15. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    This gives a false illusion to the difficulty of these repairs when you guys make guides using perfect devices. What about devices with dinged corners? A reader is gonna slap on a new screen and shatter it the second they apply pressure thinking it will fit into a dented corner lol
  16. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
    I managed to get a couple of fingerprints on the LCD.
    What's the best way to clean 'em off?
    What's the safest way?
    Mike McIntosh - crwdns2934203:0crwdne2934203:0
    What I’ve read, and seems to work, is gentle circular pressure with a very clean, dry microfiber cloth. Lacking that, use a TINY drop of water ON THE CLOTH, not on the LCD. Small amounts of alcohol can be used, in my experience, but only if the above don’t work, and with better results if used in small amounts and applied to the cloth, not the LCD.
    Bonnie Baxter - crwdns2934203:0crwdne2934203:0
    Can confirm. Microfiber with a little isopropyl worked great to clean off any adhesive or fingerprints from mine. Thanks for the tip.
    Robert -
    If you dare to use alcohol on your device, at least use isopropyl alcohol, not ethanol!!!
    Pierre-Aurélien - crwdns2934203:0crwdne2934203:0
  17. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  18. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    I broke the screen glass of my ipad just right when I moved the guitar pick towards the upperleft corner of the screen as depicted in your instructions. (Whereas my ipad screen was in perfect condition : no scratches, not broken at all...). There must be something wrong here. Be advised: move the pick towards the corner with caution !!!
  19. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  20. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
    At this point I’d use paper tape on the margins of the screen to mask off areas where you should use caution with the pick. Its just a visual reminder not to run the picker too deep in these areas. They are: the camera lens, lower right hand side and where the two antenna are along the base. Step 6 third image highlights these areas.
  21. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  22. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  23. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
  24. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  25. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
    Why there’s such an obsession with not damaging the cables is beyond me. Be careful, so as not to damage what the cables are connected to. But the cables are part of the replacement digitizer, so if you nick or even slice through them (like I did with the one closest to the bottom) don’t worry about it.
    Keep in mind that some people are here to open an intact display to replace internal components! In those cases, keeping the cables un-harmed is quite important ;)
    Sam Goldheart -
    My digitizer WAS ok and I was only replacing the battery I wasn't careful enough when coming around the side with the pics and got a hold of the cable just enough with the pic to pull it off the underside of the panel. The battery replacement went great other than now I have to replace the digitizer. :(
    BE CAREFUL WITH THIS STEP!!!
    Dylan Bouterse - crwdns2934203:0crwdne2934203:0
    And if you are replacing the digitizer, you have to reuse the fingerprint sensor home button. I sliced through mine and now I’ll not have fingerprint sensor. Each home button is matched to the main board and if switched out you will loose that sensor ability.
    David - crwdns2934203:0crwdne2934203:0
    Like others, I damaged my digitizer cable while doing a battery replacement. It would be a good idea to use some blue tape to mark the spots to avoid during the glue slicing procedure.
    I also damaaged the digitizer cable while doing a battery replacement. Use just the tip of the opening pick.
    Dean Gross - crwdns2934203:0crwdne2934203:0
    People need to realize iFixit routinely duplicates instructions for more than one type of repair/replacement. However, all of the comments are combined, which leads to confusion.
    laura moon - crwdns2934203:0crwdne2934203:0
  26. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  27. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  28. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  29. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  30. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
    This step needs a BIG CAVEAT to not insert the pick far enough to damage the home button/touch ID cable, as it is DIRECTLY above where you’re directing people to insert the pick. I just ruined a ribbon cable by following this guide too closely.
    tabormeister - crwdns2934203:0crwdne2934203:0
    Sadly only after damaging my home button flex cable, I read your comment. There should be a big warning here as it is very easy to tear this cable.
    Bouke - crwdns2934203:0crwdne2934203:0
    I also damaged the home button cable. Check the placement of the cables in steps 37-44.
    Paul Klein - crwdns2934203:0crwdne2934203:0
  31. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  32. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
    You will end up having to scrape the outter ledge to remove the old screen. I bled and got glass shards everywhere. Good luck!
    That won't happen if you use gloves and protective glasses!
    tanner85 - crwdns2934203:0crwdne2934203:0
  33. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
    This is very tricky if the screen is cracked (which I would assume most people are replacing the screen because of a crack). Use duct tape to try and secure the shards as much as possible, but be prepared for shards flying everywhere. Search for videos on cracked screen removal, there’s a good ifixit one. Maybe they can link it here? I finally was able to get it all by using a heat gun and metal spudger/razor like the guy in the video.
  34. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
    Detailed pictures that better indicate the difference between the remaining adhesive and the two mylar cables (the very cables you are trying to avoid damaging!) would be much appreciated. On my unit the two were VERY hard to distinguish.
    dlcatftwin - crwdns2934203:0crwdne2934203:0
    This step does not need to be performed here. I cut this adhesive once I had removed the lcd and display cables. This makes it much easier to avoid damaging anything. Just prop the glass up on something while you perform steps 31 - 42, then cut remaining adhesive and remove.
    The front camera has a black bezel cover but it is attached to the broken glass digitizer. Peel it off and save it. I plan to tack glue it to the camera instead of gluing it back to the new digitizer glass. It has two alignment bumps so maybe it doesn’t need gluing to either side but I found it on the ground when it came off of the the broken digitizer. I almost tossed it as part of the broken glass.
  35. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
    my replacement digitizer has rigid flex with adhesive tape where the connectors extend. how does this “fold” back inside the frame?
    Same here. I removed the adhesive tape, but now what?
    Dvi -
    It looks like I have the same or similar question: the “hinge” part of the digitizer cables (the flap portion) looks like it is supposed to tuck into the crevice between the LCD panel and the side of the aluminum body - my replacement (from iFixit) has sticky contact on the upper side of this flap, making me think that its supposed to adhere to the side of the LCD panel, but the instructions do not make this clear - is my assumption correct?
    Or, does the flap adhere to the underside of the front panel’s right edge?
    I attempted to put this protrusion underneath the LCD, and it kept coming up above the LCD. As there were no instructions, I put it as best as I could underneath the LCD as I cannot imagine that it folds up against itself?
    Dvi - crwdns2934203:0crwdne2934203:0
    I tried to put it ‘inside’ the case but was not able to - at the end, I just glued it against the front glass.
    I must have done something wrong with the new home-button assembly as the fingerprint sensor does not work anymore - However, I am not going to go through that repair again so passcode it is.
    Michael Berneis - crwdns2934203:0crwdne2934203:0
    My screen from ifixit had the rigid flaps with adhesive also. I removed adhesive and adhered it to the new glass, it worked fine and solved the problem with the flaps not pushing down.
    if there is adhesive glue on the inside of the digitizer and the top of the LCD what do you recommend to clean it.
    scprillwitz - crwdns2934203:0crwdne2934203:0
    Isopropyl alcohol (and certainly not ethanol!!!)
    Pierre-Aurélien -
    Don’t throw away your old screen until you take the home button off of it! My screen was shattered and I kind of have a phobia of broken glass, so I bundled it all up and threw it into the trash can immediately. Next day when I went to continue the job I was sad that my roommate had finally taken out the trash for once and my home button was halfway to the dump by then.
    Sparky - crwdns2934203:0crwdne2934203:0
    Cleaning with isopropyl alcohol is not really working well. I am using it with a qtip. Is there a certain way you recommend in order to actually the adhesive off?
    Brooke Parkhouse - crwdns2934203:0crwdne2934203:0
    Yes, the flap seemed to want to be attached to the glass, not go down the slot. All went together well, except that my home button doesn’t work. I suspect the connections wasn’t right, although I did my best to (gently but firmly) push it in. Too late to do anything about it now.
    Mussollini - crwdns2934203:0crwdne2934203:0
    I got my repair kit yesterday, had a go at it today on my iPad Air 1 (A1474). I’ve opened up phones before (the kind that open up easily), but first time dealing with a glued-together device. Anyway I got there, and now I’m putting things back together. I have a question regarding the pre-cut adhesive to hold the glass back on. Is it meant to be applied to the glass, or the frame?
    SHL - crwdns2934203:0crwdne2934203:0
    Ok never mind - I just looked at the digitizer for this iPad and saw that the adhesive is preapplied to the glass, which confirms my suspicions. Now I can proceed and bring this repair to a conclusion.
    SHL -
    And it’s done! Doing the battery calibration now, but I’m relieved that the battery is working. I did turn on the iPad prior to removing the blue strips on the adhesive to make sure it was working before committing to fix the glass in place.
    To reiterate the point, the adhesive strips go on the glass. The way they are packaged with the clear plastic makes it go very smoothly.
    There are 2 oversize pieces of plastic sandwiching the adhesive sections. These keep the strips in their original shape free of dust off until you are ready to use them. Once you remove these, there is another clear plastic strip which has an inside edge that matches the adhesive section’s inside edge. This plastic allows you to position the adhesive accurately on the glass while keeping your fingers away from it. This is especially important on the right side where the digitizer cables are. Once you remove this clear plastic, there is still the blue film with pull tabs. You can leave these on to do a power up test, then remove them. …cont
    SHL -
    … After doing the power on check, you can also check that all the buttons work, home button, camera, speakers etc. Then I turned it off (probably wasn’t necessary), removed the blue strips and pressed the glass in. For this last step I suggest lining up the left edge of the glass with its corresponding edge in the aluminum shell, and then gently pressing down on the right side. ALSO: while doing this last step, look carefully at the right side for the ribbon cables there. In my case (reusing original digitizer), they were protruding just a smidge, so I used the spudger to just nudge it a bit and they got into place, and then I pressed the right side down. I then pressed down all around the edges of the glass.
    SHL -
    quick question... if this is a replacement, why are we worrying about the digitizer cables? My glass is shattered pretty bad on the to the left of the home button where he says to work. So I can't apply suction cup there. I don't understand the need to be concerned about the cables if the digitizer is going to be trashed...
    Michael M - crwdns2934203:0crwdne2934203:0
    I'd like to add when at this stage and you notice some of the old black adhesive may be hanging off the digitizer DO NOT remove any of it. Wait until you have to thing fully removed. It's way too easy to tear one of the cables if you try removing it now.
    Lindsey W - crwdns2934203:0crwdne2934203:0
    I would clarify a detail for this step...Before turning the screen like a book page, LOOK CAREFULLY at the state of the Home button cable... Despite I turned the screen slowly, the cable resulted cut... Now I will have to order a home button group. Sigh!
    Migraz - crwdns2934203:0crwdne2934203:0
    I would like to clarify a detail of this step. BEFORE turning the screen like a book page, LOOK CAREFULLY at the home button cable... You risk to cut the cable during the turning operation.
  36. iPad Air Wi-Fi Rear Case Replacement, LCD: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, LCD: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, LCD: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove any tape obscuring the LCD screws.
  37. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
    Use the provided replace screen case's square compartments to place your screws into as you remove them. Really helpful and you likely won't mess up.
    Travis Dixon - crwdns2934203:0crwdne2934203:0
    I tape a stripe of double sided tape on my workbench. You can place the screws on the tape on the location where the screw would be if it was in the screen assembly. In this step, your screws would be in the four corners of the tape stripe, with the longest screw (4,8mm) in the upper left corner. The other screws from the next steps can also be placed on the tape this way.
    Brecht Bocket - crwdns2934203:0crwdne2934203:0
    **I believe you mean the “top Right corner” Is where the longer screw goes.. not left.
    Amanda Felske -
    ! went to Office World bought 4 packs of bluetac stuck them on a sheet of paper to give approximately size and shape of iPad put it in a flat cardboard box
    John Smith - crwdns2934203:0crwdne2934203:0
    Where can I buy these screws please ?
    Anthony Roberts - crwdns2934203:0crwdne2934203:0
  38. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    Got a cracked screen from toddler stepping on the iPad. My repair went well, everything worked. Except I scratched the LCD. It seems to scratch easily.
    At this step, be careful when folding over the screen, as it may scratch on the aluminum frame (third picture). When they say “soft lint free surface” that is needed, specifically where the LCD meets the frame. Place a thin cloth like sunglass cleaning cloth over the edge of the frame.
    Cobus de Beer - crwdns2934203:0crwdne2934203:0
    Thank you, very much, for this tip.
    rcrandall85 -
    At this step, possibly depending on date of manufacture, there may be black silicone present on/around the four screws that mount the display. It needs to be carefully scraped away and the two screw mount holes at the top of the screen pried up and away from the chassis. Between the chassis and the plastic portion of the mounting frame, there is a slim sheet of metal. Be sure to pry this off WITH the mounting frame. It is part of it. DO NOT try to separate it.
    rcrandall85 - crwdns2934203:0crwdne2934203:0
  39. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Battery Blocker
    $3.99
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
    Not having the isolation pick, I used 2 thin guitar picks instead, which did the job fine.
    goodcyning - crwdns2934203:0crwdne2934203:0
    I couldn't disconnect the battery connector - I applied some force, nothing happened and I was afraid of applying too much force - so I just left it connected and I was very careful not to short out any terminals with metal tools. I completed the repair without any other issues and the iPad now seems to be working fine.
    Peter Gray - crwdns2934203:0crwdne2934203:0
    Mine was missing. Made one with scissors but still didn't do the trick. I just worked with the batteries still plugged in.
    Couldn’t get the battery terminal disconnected so I continued with repair. I didn’t short anything but now it won’t do anything. It worked before, just a cracked glass to replace. Any solutions?
    Tech-ER - crwdns2934203:0crwdne2934203:0
    Why do you say you didn’t short anything? Your result would seem to suggest otherwise
    John Marx -
    I don’t know if it applies to the iPad Air, but I saw elsewhere in my researches in reference to a iPad mini (or was it an iPod mini?) that disconnecting the LCD and/or digitizer with the battery still connected will blow a “fuse” for the backlight. Might yours still be working, just with no screen illumination whatsoever? Dunno. Just a thought.
    It apparently can be repaired, but is no longer a DIY job.
    Tim -
    try lifting the board and not blocking the connector. If you block the connector there are pins that could be damaged.
    Bryan Cruse - crwdns2934203:0crwdne2934203:0
    A replacement of the battery connector is required if pins are bent should you get power on or charge issue after battery disconnection. This can be replaced with the right tools and low melt solder to remove the connector and replace.
    Best method to disconnect battery is to carefully lift the logic board near the battery connector enough to slip a piece of thin plastic or paper between the batter connector and the logic board battery connector and pins.
    Failing to isolate battery so can result in blown back light or touch filters or diodes in backlight circuit.
    At the very least run down the battery flat prior to repair but you are really best to isolate battery.
    markduff - crwdns2934203:0crwdne2934203:0
    From a repair point of view. This connector is a royal pain. For assembly it's great, well, nearly great.
    This connector is SOLDERED to the motherboard side. Never lever this on the motherboard side, I will call it the right hand side. It will break leaving it's soldered pins behind. Yes I did it.
    The pins, on the battery side of this connector, just rest on the batteries plated pads. They are kept under tension by the screw. It should be noted though that removal of the screw will not disconnect the connector pins from the battery pads. Natural tension is still present.
    I suggest strongly that you take a look at the battery connector online to see the nature of the pins and you will see that some are quite delicate.
    The tools purpose is to raise the battery side of the connector ; the left side, so there is some clearance between the pins and the batteries pads. If you have seen a picture of this connector then you will realise the potential of damage to this connector and will have a better idea of what to do.
    Biskwit2 - crwdns2934203:0crwdne2934203:0
    Contd.
    Lifting the connector and simultaneously sliding a thin piece of card or plastic under the pins should be done carefully. In fact, to minimise damage I just slid it under ONE of the main battery pins, plus or minus, which are in the middle and quite robust compared with the tiddlers on the side of the connector.
    The second point, the battery and the motherboard have protection circuitry. When I broke my connector the battery dropped to 0.5V at the terminals. Connecting the charger, when all the connections were sound and not shorted raised it from the dead back to over 3.2V
    I replaced the battery, and got things hooked backup. For the test, the screen came on, digitizer seemed to be functioning fine. But I couldn’t get it to charge. I used the i-fixit battery blocker by using my spooger to put a little up pressure on the board, and then sliding the blocker in. I don’t think I damaged the pins, but its possible. This is a friends ipad, and its obviously been dropped a few times. I started eye balling the charging port, it LOOKS ok, but looks can be deceiving. When plugged in, even trying different cables, the ipad is not showing the charging symbol. Some of the comments here seem to imply, if I damaged the battery connection pins, I would still get a charging symbol. My question is, if I damaged those battery connector pins, would the ipad show the charging icon or not? Should I be looking at replacing the charging port?
    Mike Lindsay - crwdns2934203:0crwdne2934203:0
    If you gently use the plastic opening tool as shown in step 94 to lift the board slightly it makes it MUCH easier to slide the battery blocker in.
    Kevin - crwdns2934203:0crwdne2934203:0
    I did not unserstand clearly where to put the battery blocker. I checked the iPad 6 Guide. There are more images for clarification:
    https://de.ifixit.com/Anleitung/iPad+6+W...
    Nikongen - crwdns2934203:0crwdne2934203:0
  40. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
    Be careful when re-installing screws on reassembly. I mistakenly put the longer screw from the battery connector in the outboard hole, and wound up twisting off the lug that is only lightly soldered to the metal below. Still have 2 screws and system seems to work fine.
    Brian Anderson - crwdns2934203:0crwdne2934203:0
  41. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
    bough my digitizer from ebay and have everything done up to this step. The screwdriver the kit came with said to be a #000 but it stripped the screw on the plate... I have tried rubber bands, tape and paper to no avail...anyone got an idea on how to remove the screw. Also I am currently studying in St. Kitts and they lack some products found in the US.
    originalpaintballpanda2 - crwdns2934203:0crwdne2934203:0
    I'm sure you've moved past this by now, but I've had some success with stripped screws using a comparable, if slightly larger flathead screwdriver. The screwdrivers that come in those kits tend to suck quite a lot... iFixit actually has a guide for stripped screws: How to Remove a Stripped Screw
    goodcyning -
    Does anyone know where I could purchase a replacement display cable bracket?
    gwarren - crwdns2934203:0crwdne2934203:0
    Note:Be rly carefule with unplugin homebutton-connection.
    The plug-connection (Homebutton) is not similar to the plug connections the basic-plugs got.
    The homeputton-plug-connection is sensetiv and cant unplug easly.
    IPad - crwdns2934203:0crwdne2934203:0
  42. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD.
    Andddddd continue this iFix folks! It's not a matter of working backwards. Most people must have cracked screens and end up having to rip the screen off and won't have a chance to inspect connections.
    He is far from complete…..if lcd is being replaced its probably because top screen is busted too. He didn’t show anything about how to remove the cables for that.
    B. A. Computer Services - crwdns2934203:0crwdne2934203:0
    If the battery blocking method is outdated and dangerous, why not show us the new, safer method? Just a thought.
    hdrjunkie - crwdns2934203:0crwdne2934203:0
    There is a separate guide for replacing the outer glass ;)
    Gerald Bowen - crwdns2934203:0crwdne2934203:0
  43. iPad Air Wi-Fi Rear Case Replacement, Front Panel Assembly: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Front Panel Assembly: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape covering the home button ribbon cable connector.
    I totally skipped steps 39-98 I didn’t see any need to remove all these components and the logic board just to get the battery out. I gently pried up the board where the battery connector goes in, slipped it out, and slipped in the new one.
    That is a great tip. There is plenty of space inside the case to lever out the battery without taking out all of the components. I laid the iPad on top of a large bean bag, heated for 3 minutes in the microwave. After 4-5 minutes, I was able to lever out the battery with the spudger and the credit cards. It came out after a few minutes of careful levering and cramming the credit cards under the battery. I unscrewed the earphone connector and carefully taped it back to the iPad housing with paint tape to have more room to maneuver.
    Jonathan Koehler -
    I second this.
    Just be careful to make sure you don’t squish or tear any wires or anything else surrounding when you’re fighting with the batteries, and it’s still way easier than removing everything else in there first.
    I’ll add one bit, though. The hole in the battery connector that accepts the screw through the logic board also apparently slips over a pin in which the screw seats. I couldn’t see that. So when I got the last bit of battery adhesive to let go, the pin tore out the battery connector hole. Since I was replacing the battery, it wasn’t a problem, but did produce a little conductive piece that I had to fish out before putting anything back together. Wouldn’t want that little torn out piece running around in there to short something out later.
    Also, that pin will locate the battery correctly, so that in one of the last steps of reassembly, the battery connection screws together properly. Make sure you find it before the battery adhesive grabs on to the back of the case.
    Tim -
    Careful removing the tape. The home button has a zif connector and if you aren’t careful the tape can rip the zif flap right off. You might have to hold it down while you pull it off or pull the tape from a different direction to make sure you dont tear the zif tab off.
    Sarah Ybarra - crwdns2934203:0crwdne2934203:0
  44. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
    I got through the repair, only to have the new screen give me problems that I can not find solutions to any where. The digitizer is working on its own without my input, it will start apps, switch windows, etc. I have pulled up the new screen and checked my ribbons and cables seem to be fine. ANY IDEAS??
    Moses Roman - crwdns2934203:0crwdne2934203:0
    Moses Roman
    Same exact problem that I have. I think it has something to do with the glass touching the ipad. Something like on the iPad mini, where you had to cover some areas beside the home button.
    I would love to see a real solution, as im stuck with unhappy customers and frustrated me :)
    Bilal Kinali - crwdns2934203:0crwdne2934203:0
    I had mine replaced TWICE by a local repair shop. Soon noticed both times that the iPad would soon go haywire after a few minutes use with random clicks, ghost typing, opening apps, etc.
    The iPad Air's such a poor quality, un-durable product anyway. I only had my screen replaced in the first place because it cracked with no apparent drop or trauma and Apple wouldn't replace.
    daviddesignbristol - crwdns2934203:0crwdne2934203:0
    I have also the same issue, does anyone know what the problem is?
    Please give us some feedback.
    Elektromic - crwdns2934203:0crwdne2934203:0
    Have seen this with multiple repairs where the digitizer was replaced. In each case it was a problem with the digitizer cables where it gets tucked under the glass near the edge of the frame. Not yet sure if they are badly made digitizers or if the cable gets damaged trying to tuck it under frame during installation.
    RayM - crwdns2934203:0crwdne2934203:0
    To avoid the digi sending the ipad crazy. In the same way you tape the copper/silver edges on the back of the glass for the iPad Mini. You tape all the way around, making sure not to dirty the protective cover when placing back down after taping one edge.
    Make sure all the metal surround is cover by tape, but careful not too go over the edges too much. It will be visible when using the device.
    Like i said earlier, the real skill is not too dirty the screen when lifting the protective sheet.
    Have fun!
    Josh - crwdns2934203:0crwdne2934203:0
    Thanks man, I'll give it a try. Any idea what kind of tape should I buy?
    Luis Tamborrell -
    Kapton tape otherwise known as heat tape or polyamide tape
    Neil Davis -
    Just fitted the screen, the digitizer works, display all good but I had a message saying I could not use touch ID and the home button doesn’t work at all…is this expected?
    Paul Kelly - crwdns2934203:0crwdne2934203:0
    I break the ZIF connector. Is tat touch connecter.?
    aiyathurai Aathee - crwdns2934203:0crwdne2934203:0
    How do you take the ribbon cable off from the home button site???
    BP Thompson - crwdns2934203:0crwdne2934203:0
    Pull the ribbon horizontally out, not up
  45. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    What are those connectors for because i kinda half broke the left one on the screen on the glass frame and now the lcd wont turn on
    SuperCow_man - crwdns2934203:0crwdne2934203:0
  46. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    THIS PICTURE IS PERFECT AND PERTANANT TO THE NEXT STEP REGARDING “GHOST OR PHANTOM TOUCH” - See that foam around the edges? For some reason, the ifixit replacement digitizer doesn’t come with it (but it does come with new adhesive applied already.) With your screen, also purchase their “tesa tape” : Tesa 61395 Tape / 4 mm - it comes in different widths fyi. I choose 4mm as advised by a staff member.
    scottgogos - crwdns2934203:0crwdne2934203:0
    On the replacement screen I received from you, the home screen ribbon cable does not fully seat inside the Zif connector like the original and will not lock in place as a result. It seems too fat. Any tips to make it work?
    Greg DeCelle - crwdns2934203:0crwdne2934203:0
    I can’t think of any reason for that other than it’s the wrong display for your model, or it’s defective. Double-check the model very carefully and make sure you ordered/received a compatible part. If you ordered from iFixit, contact customer support directly for returns or exchanges. Good luck!
    Jeff Suovanen -
    I didn’t receive any of the two sided tape…I assume it needed to be ordered separately??
    So, when I removed the glass, the bottom cable tore and I have to replace it. The video is not as clear regarding replacement. The old button had a round rubber gasket but the new one does not. No inst. how to re-use it. I can’t attach and keep in place the new button.
    Michael Goss - crwdns2934203:0crwdne2934203:0
    In a previous repair, i broke the zif, what you want to do is hold it down while removing the tape, otherwise it will pull the parts up with it.
    Since it was broke i put a piece of electrical tape on top for the pressure the zif would push down, then another piece from the screw hole to the bend in the cable, so it does not come loose when putting back together.
    Neil Rogers - crwdns2934203:0crwdne2934203:0
  47. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    In your conclusion, which doesn't have a comments area, you say to reverse the procedure - simple enough, BUT what about the sticky adhesive residue along the edges of the (a) the just-remove-glass (if re-using) and (b) along the 'inside' edges of the iPad chassis? Typically Apple says to remove the adhesive residue (careful) with alcohol wipes (lint free & 98% isopropyl). Thanks for the instructions!
    Joe Kazura - crwdns2934203:0crwdne2934203:0
    the hardest part of this repair for me is actually aligning the ribbons (especially on the aftermarket version) so they don't jumble and cause the glass to mush away from the adhesive leaving a gap. Would would be very helpful to see how to fold the ribbon cables back on the aftermarket digitizers. They are slightly different than the originals, or at least they appear different. This repair is super useful but we could really use a step 44 because re-assembly has a sequence and a folding technique.
    TJ Hellmuth - crwdns2934203:0crwdne2934203:0
    The ribbon cable is a little tricky to figure out. But if you look closely at the old ( Broken) screen you will see they stick to the underside of the screen thin the remaining ribbon slides down into the ipad between the display and ipads frame.
    I used a heat gun and suction cups to loosen screen.
    This was a very good ifix ii
    Rowell - crwdns2934203:0crwdne2934203:0
    Reassemble huh? What about how to move the home button to the new panel?
    xsubguy - crwdns2934203:0crwdne2934203:0
    This is what I need too!
    Sarah Ybarra -
    It is not as simple as reverse disassembly steps, the ribbon cables need to be tucked into the pocket on the side of the iPad. There is tape on them that has to adhere to the side of the digitizer too. Mine did not make it all the way down into the gap, and stuck on the other adhesive, now I have a gap by these two cables. To tuck these into this area is difficult at best. I now need to remove the glass, hoping it does not shatter and purchase more tape.
    Other than this the task was not bad.. BTW: YES People use the capton tape
    Randall Hooper - crwdns2934203:0crwdne2934203:0
    I’ve read that people are putting glue at each corner. I haven’t figured out what glue. One person said Glue Dot 1” 16lb, another said rubber cement, 1 video shows 5 min epoxy… Heard that some sort of glue (not super glue) needs to be used to avoid the glass lifting later on. And to use 3m red tape along the edges. I’ve been searching for which glue because I still have an ipad air to do screen replacement on.
    tsolorio - crwdns2934203:0crwdne2934203:0
    Would be helpful if the tape were listed in the master supplies for the guide. I got the whole kit overnighted, but then had to wait a week to get the tape from Amazon (since I wasn’t going to shell out another $50 for overnight shipping). Otherwise, it’d be nice to know if the displays through iFix it included the foam or not—mine didn’t.
    Second the concern about the foam. I bought the full repair kit, but was surprised there wasn’t already polyimide tape on the digitizer or in the kit. At least mention that it needs to be purchased extra.
    Ronny Barlow - crwdns2934203:0crwdne2934203:0
    @baron9 The displays we sell have the proper insulation and don’t require any tape. That note is more for folks who use our guides while buying the parts from somewhere else. (They tend to complain here, even though it’s the part that’s at fault, not the guide.) I’ve updated the instructions to try to make things a little more clear. Sorry about that!
    Jeff Suovanen -
    My digitizer kit from ifixit also looks like it is missing the polyimide tape on the digitizer. Can someone confirm that i do not need to get the tape with the original ifixit kit and just slap the digitizer on there?
    Alex -
    what is the difference between the right and left antenna?. My right antenna is damage and cant find a replacement. Can I use only the left one?
    Daniel C - crwdns2934203:0crwdne2934203:0
    I did not realize that aftermarket screens (besides the one ifixit sells) do not come with adhesive strips. Well worth the time to figure out what kind of adhesive you’re going to use to re-adhere the glass before you begin. Stopping while you’re so close to the end of the repair (or having to open the ipad up again after the screen doesn’t stick back down) is slightly frustrating.
    Robert - crwdns2934203:0crwdne2934203:0
    I used a b-7000. 48 h cure time.
    Jean masaoka -
    Thank you for your guide, it helped me fix my son’s iPad!
    Bill - crwdns2934203:0crwdne2934203:0
    Just wanna say thank you. I replaced my LCD and digitizer today…. took a LOT longer to get that adhesive off than I expected. And the IOpener busted in my microwave despite following all directions (eg only 30 sec at a time, out for at least 10 min before reheating. So that sucked. Turns out the rice in a sock worked pretty well too.
    GC Mitts - crwdns2934203:0crwdne2934203:0
    Regarding assembly: even with carefully tucking the ribbon cables down the side while reassembling, it’s still hard to get that area to stick down.
    Gary Wolfe - crwdns2934203:0crwdne2934203:0
    Some advice when reassembling that I have learned in the hard way.
    One good hint is to those who buy replacement parts that are not exactly the original ones. Some of the parts come with a 3M adhesive tape on the tab of the flex cables (I guess original parts are already folded and glued). I would strongly recommend to be very careful when you try to glue it on the front panel and maybe watch a video on how to fold it properly, so as not to fold or pinch the flex cable on an unrepairable way. Also, some of the low cost parts come with a very strong protection sticker on the front glass. It is advisable that you peel off the sticker before reassembling the ipad in order to not end up ruining the glue that was supposed to hold the front panel .
    Jean masaoka - crwdns2934203:0crwdne2934203:0
  48. iPad Air Wi-Fi Rear Case Replacement, Right Antenna: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Right Antenna: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
    Skip to the step 98 or even 100 if you just need to replace the power button - I think you should even consider this to replace volume buttons. I am fixing mine right now and screwed up the speaker cable. I did follow the instruction but totally missed the cable right below the tape. I proceeded further, but I just realized I didn't have to go through all the troubles. I wish ifixit.com can manage this type of direction clearly so that dis-assembly is minimum.
    msgfromside3 - crwdns2934203:0crwdne2934203:0
    After you replace the Digitizer if you are getting random key presses it is likely to be because Kapton tape has not been applied to the edges of the digitizer. You need to cover the silver strip around the edge of the digitizer with kapton tape before reassembling. Works every time.
    Richard - crwdns2934203:0crwdne2934203:0
    This is my first ipad and when the battery dies, it will be my last, way overrated and no options like memory cards or mini usb ports, and the battery thing is ridiculous,I wish I would have never bought this knowing this stuff , and way over priced.
    Gary - crwdns2934203:0crwdne2934203:0
    It always helps to Google something before buying it. "iPad Air reviews" in Google would have saved you. I just find it funny how in this day and age, people STILL make "purchase mistakes" because they didn't take the time to research the several-hundred-dollar device they are about to commit to purchasing. You should have seen the amounts of research I did before buying my $1,399 Asus G751JY laptop. I'm absolutely pleased with it and am happy I don't deal with issues other people have. Just be weary, buddy. ALWAYS GOOGLE.
    Scott S -
    If you just want to replace the battery, skip to step 99. You can easily get to most sides of the battery without removing all other components. It worked for me. Good luck!
    Thomas Van den Dries - crwdns2934203:0crwdne2934203:0
    I wish I read this comment. Would have saved me a lot of time.
    leo -
    I followed your piece of advice and went to step 99. My new battery works just fine without removing all those components including the logic board - thanks a lot!!
    Charlotte M -
    An important note - as per the comments lower down, you can skip ahead to step 95 (unsticking the battery) just fine if you're just changing the battery, but after you've unstuck the battery you will need to go back to step 88 and soften the logic board adhesive so you can pry it up about a cm and lift the battery terminal up and over the post to remove it. I didn't realise the post was there, and broke off a piece of the original battery terminal that got stuck under the logic board. This prevented a good connection with the new battery, and caused random restarts after I put everything back together until I realised and went back to recover it.
    Rory Condon -
    Don’t skip to 99 because you need to remove the logic board.
    Cesar Hernandez - crwdns2934203:0crwdne2934203:0
    I have successfully replaced the Battery without removing any components other than the Screen Assembly and LCD. You can skip steps 44 thru 99 by using a spudger as a wedge to lift & hold the Logic Board high enough to lift the battery contact over the post that holds it in place… this will save you a lot of time and frustration and makes the repair sooo much easier.
    firestormmedia -
    My goal was to replace the battery. As some suggested I skipped some steps. I did Step 46 and left out 47 to 100. But I think Step 46 can be skipped too. iFixit probably does not recommend skipping these steps because it is riskier to bend the batteries and damage them. But if you work carefully enough and make sure the adhesive has been softened well, you should be fine. It was no problem for me. It saved me quite some time. (I will write a comment in Step 102 to help you get the batteries out without Steps 46-100.)
    marcelflueeler - crwdns2934203:0crwdne2934203:0
  49. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
    You may partially skip steps 46 to 100, as it is not really mandatory to remove all those parts in order to remove the logic board and the battery.
  50. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
    The pick was not thin enough but the razor worked.
    Moon & Snow - crwdns2934203:0crwdne2934203:0
    In my view there is a few destructive steps here. I have been able to remove this entire assembly by lifting only the adhesive tape anchoring it to the back without touching this fine metal bracket as touched in in Step 46 & 63 or tearing the foam in Steps 48 & 65 on both the left & right sides. Remove the screws as in Step 47 & 57 and the one’s either side of the charging port in 64 & 71. Once removed, the only thing securing these to the rear is adhesive tape. Lift the tape and walk the units out by nudging them from side to side.
    Neil Cross - crwdns2934203:0crwdne2934203:0
    Thanks. Made the whole next chunk much simpler :)
    Sarah Ybarra -
  51. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
    I would strongly advise not to follow this step and following ones: removing the 2 Wi-Fi antennas is not required for complete disassembly of the motherboard and battery, and you may potentially destroy your antennas: I scrupulously and foolishly followed this tutorial step by step and now I have severe Wi-Fi problems on my iPad because one of the 2 antennas has been damaged during the process (and by reading all the comments on this page you'll see that I'm not the only one to have this issue...).
    => As someone else already mentioned it in the comments, just skip most of these steps and go directly to something like step 79.
  52. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
    Este paso es innecesario, ya que con solo quitar los tornillos es suficiente, no hace falta despegar la goma espuma que mantiene la antena de la bocina.
    Anthony Aguilar - crwdns2934203:0crwdne2934203:0
    tout a fais il n'est pas nécessaire de décoller l'antenne du haut-parleur ! Il faut juste enlever les vis et continuer le démontage du haut-parleur en laissent l'antenne fixer a lui !!!
    dordetivan - crwdns2934203:0crwdne2934203:0
    Faire de même pour le deuxième haut-parleur !
  53. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right antenna from the iPad.
  54. iPad Air Wi-Fi Rear Case Replacement, Right Speaker: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Right Speaker: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  55. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
    What can I do if I accidentally peel
    off the speaker ribbon from both
    speaker connecters? Can I get a replacement part?
    mike - crwdns2934203:0crwdne2934203:0
    This step was not very well explained. It fails to mention the speaker cable attached on to the tape. This caused the speaker cable to be torn since it is so thoroughly attached to the tape. Guide made no mention that it was under there or that you should be careful about it. Not even the usual remove the tape gently they just tell you to rip it right off no problem. Not sure how this was missed when the guide was so thorough about this beforehand.
    Holden Bott - crwdns2934203:0crwdne2934203:0
    Approx. 3/4 of an inch past the bend in the cabling underneath the tape lies the right speaker cable. Beyond this point proceed with extreme caution. Delicate cables and ZIF connectors underneath the tape will be torn or damaged if they aren't separated from the underside of the insulation tape first. Use fingernails or thin-edged tools.
    An update to this would be nice. Will the Ipad work with a broken spaker cable? Is it possible to get replacement part? Maybe this step should be rewritten.
    Nathaniel Johnson - crwdns2934203:0crwdne2934203:0
  56. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  57. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the tape toward the home button to uncover the speaker cable connector.
  58. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:058crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  59. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape holding the speaker to the rear case.
  60. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel the LCD buffer tape up off of the rear case.
  61. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  62. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
    It is really not necessary to remove either speakers for a logic board swap.
    sergeymkl - crwdns2934203:0crwdne2934203:0
  63. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:063crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
    When did you remove the blocker after installing the battery blocker? No photos with blockers after this procedure.
    Prof.Sakamoto - crwdns2934203:0crwdne2934203:0
  64. iPad Air Wi-Fi Rear Case Replacement, Upper Component Cable Bracket: crwdns2935265:064crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  65. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  66. iPad Air Wi-Fi Rear Case Replacement, Logic Board: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Logic Board: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  67. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  68. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
    I didn’t need to take the left antenna and speaker out. If you just get the wire and tape out of the way so you can unplug the speaker flex cables and take out the lightning connector, then you should still be able to get the logic board out. the left speaker isn’t in the way at all.
    Reed Deemer - crwdns2934203:0crwdne2934203:0
  69. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  70. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left antenna from the iPad.
  71. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:071crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:071crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape covering the left speaker cable connector.
    Pulled out the connector doing this step. Best to hold down cable while pulling tape.
    doug - crwdns2934203:0crwdne2934203:0
  72. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:072crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:072crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  73. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:073crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:073crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  74. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:074crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:074crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  75. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:075crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  76. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:076crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:076crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  77. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:077crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:077crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  78. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:078crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:078crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:078crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the left speaker from the iPad.
  79. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:079crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:079crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:079crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  80. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:080crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:080crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:080crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  81. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:081crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:081crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:081crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
    Note for others. On this connector, i have some tape keeping it down, it's rather difficult to remove without ripping it. So i ripped the tape to remove it.
    justin Booras - crwdns2934203:0crwdne2934203:0
    "Ripping" the tape seems ill-advised. A sharp ceramic craft paper cutting knife or the very tip of a fine-tip Exacto blade work well. Once the tape is cut on one side, the blade slides through it like it's nothing. Zero force required.
    Be careful not to insert a blade too far or it may come into contact with conductive components.
  82. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:082crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:082crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  83. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:083crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:083crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape covering the upper button assembly cable connector.
  84. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:084crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:084crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  85. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:085crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:085crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the upper button assembly cable straight out of its ZIF connector.
  86. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:086crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
    NOTE for others who might miss this: this picture is looking down, out the bottom of the iPad. There are four other screws near the lightning port, two for the speakers and two for the port. You see these four easily, looking down at the battery and motherboard. These two are additional to those, and perpendicular to them. Both pairs of lightning port screws, one set perpendicular to the other, must be removed.
    Bonnie Baxter - crwdns2934203:0crwdne2934203:0
    Where did the battery blocker go? It was introduced in step 35. Nowhere has it been said it can be removed . . . yet it is now absent in this picture. I took it out when I got to steps 93-96.
    Randy Burgess - crwdns2934203:0crwdne2934203:0
    Yes this is a deceptive image as the battery and connector strap seem to be missing. Hold your iPad vertically and look down at the lightning port and you’ll see these hidden screws.
    Rusty - crwdns2934203:0crwdne2934203:0
    Thanks for your comment! I’ll add a note in the step.
    Arthur Shi -
  87. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:087crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:087crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:087crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
    Thread a piece of dental floss under the tip of the logic board. Be careful when rounding the corner not to snag any ribbon cables. This easily released the foam tape up to the battery connector.
    ROBERT MORELLA - crwdns2934203:0crwdne2934203:0
    Les 2 images suivantes sont contradictoires. elles donnent l'impression de devoir enlever la carte mère.
    Humair - crwdns2934203:0crwdne2934203:0
    @totoy Effectivement, cela peut-être perturbant, mais ces images servent de référence et expliquent où se trouvent les six morceaux d'adhésif qu'il va falloir décoller au cours des étapes suivantes pour retirer la carte mère.
    Claire Miesch -
  88. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:088crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  89. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:089crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:089crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:089crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  90. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:090crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:090crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:090crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  91. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:091crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  92. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:092crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:092crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:092crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  93. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:093crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:093crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  94. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:094crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:094crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
    There are two screws holding the lightning connector to the rear case, I didn’t see them in this guide. I recommend removing them before you attempt to remove the lightning connector, otherwise you’ll look like an idiot struggling with it for around 1/2 an hour like I just did.
    Will Young - crwdns2934203:0crwdne2934203:0
    I had this problem too!!
    Jocelyn Hall -
    Will Young is correct. The two extra screws are horizontal - they are in addition to the vertical screws mentioned in step 82.
    @usablethought AFAIK there are only two screws securing the actual port to the chassis. You can tell by looking at the part—there are only two screw holes. Those additional screws can be left in place, as shown in the photos. At least, that was my experience. If you’re working on a different model, then of course you may need to improvise—the instructions are only for the model indicated.
    Jeff Suovanen -
  95. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:095crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:095crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Lightning connector straight out of its recess in the rear case.
    there were two screws holding the lightening connector in place on my iPad
    Nate Czupinski - crwdns2934203:0crwdne2934203:0
    Yep! In this guide those screws are removed in Step 82, but you can remove them at any point prior to taking out the Lightning connector.
    Jeff Suovanen -
    CAUTION - there are two ‘hidden’ screws holding the lightning port that face the battery. Hold the iPad vertically and look down to see them. I almost broke the cable trying to remove it thinking it was just stubborn adhesive. Yes its mentioned at Step 82 but its a confusing illustration and easily overlooked.
  96. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:096crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  97. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:097crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:097crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:097crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  98. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:098crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:098crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:098crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  99. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:099crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:099crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:099crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  100. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0100crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0100crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0100crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
    Don't touch the small components which are under the motherboard !!! If you do it your iPad is definitively dead.
    Easy Repair - crwdns2934203:0crwdne2934203:0
  101. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0101crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0101crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  102. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0102crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board from the iPad.
    Nice guide, thank you, very helpful. There would be no way to guess where the glue stripes are located and a couple of connectors are very difficult to spot. I don't see any need to remove the antennas and the speakers though, they are not really an obstacle to remove the board and can be left in place. The lightning connector is secured in place by two other two horizontal screws which are not shown in the guide.
    Thanks again !
    arbaman - crwdns2934203:0crwdne2934203:0
    Technically, you are correct. But those screws are holding a bracket-like piece for the lightning connecter to screw into- which if you think about it, it wouldn't be considered apart of the lightning port (or at least that's what i think). Not trying to start an argument, as this comment is old, but yeah.
    Kaz -
    This is a bear of a job, and I wouldn’t have had any hope of completing it without this guide. THANK YOU for all your hard work!!!!
  103. iPad Air Wi-Fi Rear Case Replacement, Battery: crwdns2935265:0103crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Battery: crwdns2935265:0103crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Battery: crwdns2935265:0103crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Adhesive Remover
    $19.99
    • The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive.
    • Reheat the iOpener in the microwave for 30 seconds.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
    • Place the heated iOpener in the center of the back of the iPad. Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the right (away from the rear-facing camera), and let the iOpener sit for another 90 seconds.
    • Finally, move the iOpener to the right-hand edge of the iPad for 90 seconds.
    • The iOpener may cool significantly between sittings—if it does, reheat for another 30 seconds between each position.
  104. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0104crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0104crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0104crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Insert a plastic card under the lower battery cell, at the lower right-hand corner.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
    Did you skip Step 46 through 100, then this is for you: Because the logic board is still in, you will have less space to loosen the battery pack. Be extra careful not to bend it. Work from the sides that are more accessible like in Step 113 and slowly work your way underneath the battery pack to loosen it all over. As I was loosening the battery I had the heated iOpener underneath the part I was working on. This really helped a lot. And be patient. You do not want to force it.
    First of all, thanks @marcelflueeler and everyone else who gave advice on skipping ahead. This is definitely the way to go if you're just changing a battery! Once you've unstuck the battery you'll find you can't pull it out because it's stuck at the terminal though. Don't try and force it here! You'll need to return to step 88 and soften the logic board adhesive so you can pry it up about a cm, then you can lift the battery terminal up and over the locking post that's holding it in place. I didn't realise this and broke a piece of plastic off the old battery terminal, which got lodged under the logic board and prevented a good battery contact until I realised and retrieved it.
    Rory Condon -
  105. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0105crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0105crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0105crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the card roughly halfway inserted, slide it toward the top of the iPad, stopping before the battery contact post.
  106. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0106crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0106crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0106crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the card up from the rear case slightly to allow it to pass over the battery contact mounting post.
    • Slide the card from the center of the battery cells to the upper right corner of the battery.
  107. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0107crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0107crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a second plastic card about halfway under the left hand battery cell to prevent it from readhering when you reapply the iOpener.
  108. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0108crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place an iOpener on the right side of the battery, opposite the cards, to loosen the adhesive.
  109. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0109crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0109crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0109crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the card around the lower right corner of the battery.
  110. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0110crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0110crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the plastic card to the lower left corner of the battery.
  111. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0111crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0111crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0111crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
    • Place the plastic card underneath the lower left corner of the battery.
  112. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0112crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0112crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0112crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the card around the upper right corner of the battery.
    • Be extremely careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  113. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0113crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0113crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0113crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the plastic card to the upper left corner of the battery.
    • Be careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  114. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0114crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0114crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0114crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the plastic card underneath the upper left corner of the battery.
  115. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0115crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0115crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0115crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip both cards firmly and twist them to lift the battery off of the rear case.
    • Remove the battery from the rear case.
    Apple aren’t stupid are they
    bob - crwdns2934203:0crwdne2934203:0
    It took me nearly 3hrs, but i finally made it. Thanks for the great instructions
    Oliver Wegen - crwdns2934203:0crwdne2934203:0
    New battery installed. Battery wont charge. Any ideas?
    David F - crwdns2934203:0crwdne2934203:0
    REASSEMBLY TIPS:
    The adhesive strips that come with the iFixit battery have no labels to say which goes where. Look at them carefully and one side has a blue protective cover that runs the length of each strip. This faces up and is to be removed at the last moment when you’re ready to stick the screen down permanently. One strip has a narrowed section in the long length to clear the glass touch screen cables, so stick this one down first to avoid mistakes.
    Before removing the protective strips, close the touch screen and boot the iPad. Test both cameras, wifi and speakers. (I found the rear facing camera connector hadn’t bedded properly which was easily fixed). Clean the screen and remove dust from LCD before bedding in touch screen.
    The iFixit site has updated battery calibration instructions which differ from the card packed with the battery:
    Charge it to 100% and keep charging it for at least 2 more hours.
    Then use your device until it shuts off due to low battery.
    Finally, charge it uninterrupted to 100%.
    Great tip to boot the iPad before removing the adhesive from the battery. There are quite a few comments here about faulty batteries. Fortunately, mine worked just fine.
    Jonathan Koehler -
    The iFixit battery replacement kit worked great! The repair guide is very good also. So glad I didn’t just try buying the battery. While testing everything after finishing the battery replacement, the digitizer, volume controls and the sleep button did not work. I was very happy when I went back in and found the cable connections had just come loose. My wife couldn’t believe I fixed her iPad.
    Randal Haufler - crwdns2934203:0crwdne2934203:0
    The guide was pretty good but a few comments:
    I didn’t liked the iOpener that much. I used an heat gun with good temperature control instead.
    Any advice on how to remove the old glue residu would have been welcome. I used a combination of physical scraping and cleaning afterward with isopropyl alcohol.
    An extra guide on how to apply the new adhesive strips would also be nice.
    mlombaers - crwdns2934203:0crwdne2934203:0
    Fixed!....The guide is very clear and well laid out. I also had issues with the iOpener not working, I needed more heat, used heat gun with temp control. Also used floss to remove the logic board. Would have appreciated more clearer instructions on adding the adhesive strips.....Thanks
    hzulu88 Zulander - crwdns2934203:0crwdne2934203:0
    The iOpener is really bad. It isnt hot enough to keep the iPad that cools down to roomtemperature in a few seconds. I used an hair dryer which was also not warm enough but at least made it warm enough to create a gap where I was able to fit my pics under. Unfortunately my Digitizer still died. Battery works but I cannot turn off my iPad now lol
    Luca Steuer - crwdns2934203:0crwdne2934203:0
    Very good guide to a very tedious project! Thank you for the detailed description of the digitizer separation. I didn’t sever any cables. The iOpener isn’t bad; it’s just too small. This project really requires the Anti-clamp, the acetone/isopropanol adhesive softener, and a heat gun that can be used at a low heat setting. I didn’t try a hair dryer, but I think that it might be too windy. Like other fixers,I skipped steps 47 thru 100 something and took my chances manhandling the battery. I opted to insulate the digitizer with Kapton tape. I only have a wide roll of Kapton, so I stuck it to the stiff plastic backing for the battery, then cut narrow strips and peeled them off the backing. Finally, I’d like to see a show of hands of the people who forgot to put in the four corner screws for the display. Maybe I’m the only one …
    Laetiporus - crwdns2934203:0crwdne2934203:0
    I successfully replaced the battery in my A1954. But I stopped at step 40 and then I just pried the old battery with the plastic cards that came with the new battery and some isopropyl alcohol. Next step I pried the logic board upwards with a blue pick around the screw area. The board needs to flex upwards more than you're comfortable with in order to make room for the new battery connector to slide underneath the pick but over the screw hole underneath the logic board. I dint't really feel like gutting the entire housing of all the parts but I was risking damaging both the logic board and the new battery. So do it at your own risk.
    redishman - crwdns2934203:0crwdne2934203:0
  116. iPad Air Wi-Fi Rear Case Replacement, Rear Case: crwdns2935265:0116crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Rear Case: crwdns2935265:0116crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement, Rear Case: crwdns2935265:0116crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to gently lift the front-facing camera housing up and out of the case.
    • Depending on how you performed the digitizer removal, this component may be adhered to the inside of the iPad's front panel.
  117. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0117crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0117crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0117crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a spudger under the front-facing camera to separate it from the adhesive securing it to the rear case.
    • Remove the front-facing camera from the iPad.
  118. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0118crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0118crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the tape covering the headphone jack cable toward the top of the iPad to free the cable for removal.
  119. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0119crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0119crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the flat end of a spudger under the headphone jack cable to free it from the adhesive securing it to the rear case.
  120. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0120crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0120crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to slide the spudger under the end of the headphone jack cable to remove the last of the adhesive.
  121. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0121crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 4.3 mm Phillips #000 screw from the headphone jack.
  122. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0122crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0122crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the headphone jack cable to gently remove the headphone jack from its recess in the case.
  123. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0123crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0123crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0123crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a plastic opening tool under the rear-facing camera, and pry upward to free it from the adhesive and two small pegs securing it to the rear case.
    • Newer iPad units will not have a peg to align with the camera unit. Rather the camera should sit in a shallow recess.
    • Remove the rear-facing camera.
  124. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0124crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the top portion of the iPad on a reheated iOpener.
    • This will soften the adhesive holding the microphone assembly to the case.
  125. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0125crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0125crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0125crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the case and the microphone cable.
    • Carefully scrape the lower portion of the microphone cable off of the case.
  126. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0126crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0126crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0126crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry the delicate upper portion of the microphone cable up off of the adhesive holding it to the rear case.
    • Remove the dual microphone assembly from the iPad.
  127. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0127crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.3 mm Phillips #000 screws from the power button cable bracket.
  128. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0128crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0128crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert an opening pick between the power button ribbon cable and the edge of the case.
    • Slide the pick along the length of the cable, stopping at the corner of the case.
    • Go slowly and carefully—if you slip, you could cut the ribbon cable.
  129. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0129crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0129crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push the power button into the rear case from the outside.
  130. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0130crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0130crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the power button cable bracket loosened, peel it off of the rear case with a set of tweezers and move it out of the way.
    • Do not attempt to remove the power button cable bracket or cable from the iPad, as it is still attached to the rest of the button cable assembly.
  131. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0131crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the power button into the case and remove it from the iPad.
  132. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0132crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 2.3 mm Phillips #000 screws from the button cable bracket.
  133. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0133crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a heated iOpener on the upper left corner of the rear case to loosen the button bracket's adhesive.
  134. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0134crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0134crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick under the far right corner of the button bracket, between it and the rear case.
    • Slide the pick around the corner to loosen the adhesive—but do not cut any further, or you may damage the button cables.
  135. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0135crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0135crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry in the gap made by the opening pick, lifting the bracket off of the adhesive.
  136. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0136crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0136crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a set of tweezers flip the front end of the button bracket up to allow access to the rest of the button ribbon cable.
    • Do not remove the bracket entirely—it is still attached to the ribbon cable. Be very careful in moving the bracket, or you may tear the fine offshoots of the ribbon cable.
  137. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0137crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0137crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the connector end of the cable slightly off the rear case.
    • Be very careful not to sever the small offshoot cables leading to the volume buttons.
  138. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0138crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0138crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0138crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the point of a spudger under the ribbon cable near the button cables to free it from the adhesive holding it to the rear case.
  139. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0139crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0139crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the button assembly carefully out of the rear case.
    • When reassembling, make sure the black tab on the side of the bracket fits into the orange recess in the rotation lock/mute switch, as shown in the second photo.
  140. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0140crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0140crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a set of tweezers to remove the rotation lock/mute switch from the rear case.
    • Note the orientation for reassembly: the small gray tab should line up with the groove in the rear case.
    • The 5th generation iPad does not have this switch.
  141. iPad Air Wi-Fi Rear Case Replacement: crwdns2935265:0141crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rear case remains.
crwdns2935229:018crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
472,723 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,876crwdne2935297:0
I managed to strip down following this guide. Unfortunately I was unsuccessful. So a word of warning to hopefuls. First of all 3 hours is a fair time. Take your time on heating the screen. I managed to shatter it as I hadn't heated enough of it. (In the end I used a Hair dryer on high which made it soo easy the shattered screen just peeled out). I did this strip down to replace the lightning port and missed the important point that it's cable is micro-soldered to the main board. After shattering the screen I've put it away for spare parts.
Stephen - crwdns2934203:0crwdne2934203:0
iPad Air LTE repair attempt
Since there is no guide for replacing the back for the LTE version I tried to use this one. I managed to get down to the camera, the cable tore I tried to continue but then I broke the zif connector connecting the volume buttons. May my iPad rest in pieces. :’(
Ruth Azmon - crwdns2934203:0crwdne2934203:0
May I be of assistance?
Markus Norstrøm -
Tried this repair. Took off the connector to the power button flex. Would definitely make this a red point on the guide
Markus Norstrøm - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 124
crwdns2942667:0crwdne2942667:0 39,393
