Follow this guide to replace the screen on your iPad Air 5th Generation.
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Unplug any cables and fully shut down your iPad.
Apply a heated iOpener to the left edge of the screen for two minutes.
The iopener didn't work for me at all. I tried many times, and the screen wouldn't budge at all.
Camera module and ambient light sensors
Display cables
Screen magnets
Display edges
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the top left edge of the screen.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick in the gap you just created.
Slide the opening pick along the left edge to separate the adhesive.
Leave the pick in the bottom left corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom left corner.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick in the bottom right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the right edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner and slide along the right edge to separate the adhesive. Make sure to note the following marked areas:
Don't insert an opening pick more than 2 mm or you'll damage the screen magnets.
Don't insert an opening pick more than 3 mm or you'll damage the display and digitizer cables.
Don't insert an opening pick more than 5 mm or you'll damage the display edges.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Insert a new opening pick in the top right corner and slide along the top edge to separate the adhesive. Make sure to note the following:
Don't insert an opening pick more than 3 mm or you'll damage the ambient light sensors.
Don't insert an opening pick more than 2 mm or you'll damage the front camera module.
Leave the pick in the top left corner to prevent the adhesive from re-sealing.
Grip the left edge of the screen and fold it open like a book.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
der schritt ist nicht ganz aussage kräftig wie er gemacht werden soll
Achtung! Die kleinen Kontakte sind sehr empfindlich und brechen leicht, wenn sie seitlich gebogen werden.
Beachte das unbedingt bei Schritt 18! -
Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
Insert the card strips on each side of the battery connector until they stop.
ACHTUNG: Bewege die Streifen niemals seitwärts! Die kleineren Kontakt können dabei leicht abbrechen und dann hast Du ein größeres Problem.
Der Teil ist besonders tricky - mit der Spielkarte habe ich es nicht geschafft, sondern mit dem Teil einer Plastikabdeckung, das ich (etwas schmaler als 6mm geschnitten) per Pinzette eingeschoben habe.
This one was tricky indeed. I could manage it with playing card strips but it wasn't easy. If you do use strips of card or plastic, one tip is cutting them a lot shorter once they are in, to prevent accidentally bumping into the ends later and moving them around, potentially breaking the contacts. Then when you need to get them out, just grab the short ends with the tweezers. Or, get the ifixit Battery Blocker tool, which can't slide around once it's in.
Use a Phillips screwdriver to remove the three screws securing the display and digitizer cable brackets to the logic board:
Two 1.1 mm screws
One 1.5 mm screw
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers or your fingers to pivot the latch out from the top and remove the bracket.
It wasn't initially clear to me how it was "held in place" and how to pivot it out. The bracket has a hook on the far end (the end opposite the one with the hole) that hooks into the tiny silver-colored part you can see in the third picture (between the four cables and the diagonal part of the flex cable). To remove, just lift up the bracket on the right as shown in the picture, then slide to the left to unhook it from that thing.
Use tweezers or your fingers to remove the digitizer cable bracket.
Use the flat end of a spudger to disconnect the two display cables by lifting straight up on the press connectors.
Repeat the previous step for the digitizer cable.
Grip the left edge of the screen and lift it away.
Compare your new replacement display to the original one—you may need to transfer remaining components or remove adhesive backings from the new part before installing it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 5th Generation answers community for help.
crwdns2935229:016crwdne2935229:0
crwdns2947412:013crwdne2947412:0
The spare part listed is for an iPad Air 4. Is this compatible with the ipad air 5?
Hi Dusun Tren,
The iPad Air 4 and 5 use physically identical screens. We swapped the screens and found them functional. As with most Apple product screen repairs, true tone will most likely disappear from settings after replacing the screen. It's case-by-case whether this will happen, but all other features are retained. Good luck with your repair!
Is it possible to replace only the glass while keeping the touch same or do we have to replace the whole unit
Unfortunately, this model of iPad combines the LCD and digitizer in one unit. Some iPad models have a separate digitizer + glass and LCD panel. In which case, you could replace just the digitizer and glass, like you mentioned.
I wonder why iPad Air 5 A2589 digetizers are sold, when they are in one unit with the LCD?
Where can I find a replacement front camera bracket for my iPad Air 5 since Amazon and eBay don’t have them?
Hello
I got my iPad fixed after I dropped it on its corner ( the screen wasn’t cracked but it stopped working ), my iPad is working now but I can’t really use my Apple Pencil as the touch thing of the screen became somewhat broken as in when I click on certain areas of the screen it does not work when I told the repairman he told me that’s the best he could do. Is it fixable
Apple is serializing the Apple Pencil so that it will not draw lines straight when the screen is not replaced by Apple. Your only option is to get the iPad fixed at Apple or have the old displays chip soldered to the new one.
“Apple is serializing the Apple Pencil so that it will not draw lines straight when the screen is not replaced by Apple. Your only option is to get the iPad fixed at Apple or have the old displays chip soldered to the new one.”
Hello again thank you for replying to me
The repairman harvested the LCD screen from another iPad he had so it’s basically as if Apple fixed it so the problem might be from somewhere else. Is there some instructions I could give him to fix it (there is no Apple Store in my country ).
I am no expert but I think the pen is married to the screen's serial number so using a different Apple screen won't work because of its different serial number. The repair man should have harvested the serial numbered chip from your original screen and transplant that to the replacement screen for the pen to work correctly.
Eric -
I just did this repair, but I seem to be missing the battery percentage indicator and the battery charging indicator. It makes a sound when I plug it in, and it functions for a short time after I unplug it. Is this normal behaviour, until it reaches full charge once, or have I broken something on the battery connector? (It has not been long since the repair, so I have not fully charged it since, and I thoroughly drained the battery before this guide.)
I just completed the repair, but I don't have a battery charge indicator anymore. It does make a sound when I plug it in, but I can't see the lightning arrow when plugged in, and it also reads as battery percentage 1% in the settings. Is this common after the repair, or have I messed up the battery connector?
I had to drain the battery 3 times before the iPad would not power on anymore.
I just completed the display repair, but the battery indicator is missing. The top right corner is missing the charging arrow and does not display charging percentages. The ipad does make the charging sound when i plug it in though.
In the settings, it always shows 1% charge, but the iPad functions normally for a short time after I unplug it.
Is this normal behavior after the batter has been fully drained?
I had to drain it 3 times for the iPad not to start again, or have I messed up the battery connector?
