Follow this guide to remove or replace the logic board in your iPad Air 4.
The Logic Board is paired to the power button. You'll need to transfer the power button with the logic board to keep Touch ID capability.
If your battery is swollen, take appropriate precautions.
This guide is written with an A2324 (cellular + mmWave) model iPad Air. If you're fixing a Wi-Fi model, you can still use this guide—there will be some visual discrepancies, and you'll need to skip the steps related to the cellular antennas.
Unplug any cables and fully shut down your iPad.
Apply a heated iOpener to the left edge of the screen for two minutes.
The iopener didn't work for me at all. I tried many times, and the screen wouldn't budge at all.
Camera module and ambient light sensors
Display cables
Screen magnets
Display edges
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the top left edge of the screen.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick in the gap you just created.
Slide the opening pick along the left edge to separate the adhesive.
Leave the pick in the bottom left corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom left corner.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick in the bottom right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the right edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner and slide along the right edge to separate the adhesive. Make sure to note the following marked areas:
Don't insert an opening pick more than 2 mm or you'll damage the screen magnets.
Don't insert an opening pick more than 3 mm or you'll damage the display and digitizer cables.
Don't insert an opening pick more than 5 mm or you'll damage the display edges.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Insert a new opening pick in the top right corner and slide along the top edge to separate the adhesive. Make sure to note the following:
Don't insert an opening pick more than 3 mm or you'll damage the ambient light sensors.
Don't insert an opening pick more than 2 mm or you'll damage the front camera module.
Leave the pick in the top left corner to prevent the adhesive from re-sealing.
Grip the left edge of the screen and fold it open like a book.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
der schritt ist nicht ganz aussage kräftig wie er gemacht werden soll
Achtung! Die kleinen Kontakte sind sehr empfindlich und brechen leicht, wenn sie seitlich gebogen werden.
Beachte das unbedingt bei Schritt 18! -
Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
Insert the card strips on each side of the battery connector until they stop.
ACHTUNG: Bewege die Streifen niemals seitwärts! Die kleineren Kontakt können dabei leicht abbrechen und dann hast Du ein größeres Problem.
Der Teil ist besonders tricky - mit der Spielkarte habe ich es nicht geschafft, sondern mit dem Teil einer Plastikabdeckung, das ich (etwas schmaler als 6mm geschnitten) per Pinzette eingeschoben habe.
This one was tricky indeed. I could manage it with playing card strips but it wasn't easy. If you do use strips of card or plastic, one tip is cutting them a lot shorter once they are in, to prevent accidentally bumping into the ends later and moving them around, potentially breaking the contacts. Then when you need to get them out, just grab the short ends with the tweezers. Or, get the ifixit Battery Blocker tool, which can't slide around once it's in.
Use a Phillips screwdriver to remove the three screws securing the display and digitizer cable brackets to the logic board:
Two 1.1 mm screws
One 1.5 mm screw
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers or your fingers to pivot the latch out from the top and remove the bracket.
It wasn't initially clear to me how it was "held in place" and how to pivot it out. The bracket has a hook on the far end (the end opposite the one with the hole) that hooks into the tiny silver-colored part you can see in the third picture (between the four cables and the diagonal part of the flex cable). To remove, just lift up the bracket on the right as shown in the picture, then slide to the left to unhook it from that thing.
Use tweezers or your fingers to remove the digitizer cable bracket.
Use the flat end of a spudger to disconnect the two display cables by lifting straight up on the press connectors.
Repeat the previous step for the digitizer cable.
Grip the left edge of the screen and lift it away.
Use a Phillips screwdriver to remove the 1.2 mm screw securing the front camera cable bracket to the frame.
Use tweezers or your fingers to remove the front camera cable bracket.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Use tweezers to remove the front camera.
Use a Phillips screwdriver to remove the 1.8 mm screw securing the rear camera cable bracket to the frame.
Use tweezers or your fingers to remove the rear camera cable bracket.
Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
Lay the iPad screen side down.
Apply a heated iOpener to the rear camera for two minutes to weaken the adhesive.
Lay the iPad screen side up.
Use the flat end of a spudger to pry up the rear camera.
Remove the rear camera.
Use tweezers to peel away the tape covering the top microphone ZIF connector.
Use tweezers or a spudger to lift up the latch on the ZIF connector.
Use tweezers to pull the top microphone cable out of its socket.
Use the pointed end of a spudger to disconnect the top speaker cable by prying straight up on the rear of the connector.
Use the flat end of a spudger to disconnect the top left interconnect cable.
Use the pointed end of a spudger to disconnect the top left Wi-Fi antenna cable.
Use tweezers or your fingers to peel the top left Wi-Fi antenna cable off of the top interconnect cable.
Use the flat end of a spudger to disconnect the power and volume button cables.
Insert the flat end of a spudger under the volume button and rear microphone cable.
Bend the cable to the right so the two Wi-Fi and cellular antenna cables underneath are accessible.
Use the pointed end of a spudger to disconnect the two top right antenna cables.
Use the pointed end of a spudger to disconnect the top right antenna cable.
Peel the tape away while removing the cable.
Disconnect the top right antenna interconnect cable:
Peel off the tape
Flip up the latch
Pull out the cable
Apply a few drops of high-strength (>90%) isopropyl alcohol along the edges of the top interconnect flex cable.
Let the alcohol soak for one minute to soften the adhesive under the cable.
Insert an opening pick under the interconnect flex cable.
Slide the pick under the cable towards the logic board to separate the adhesive.
Use the pointed end of a spudger to disconnect the four antenna cables below the volume buttons.
Use tweezers to peel back the tape covering the Apple Pencil charger connector.
Use the pointed end of a spudger to disconnect the Apple Pencil charger cable.
Use the pointed end of a spudger to disconnect the bottom speaker cable by prying straight up on the rear of the connector.
Disconnect the SIM card reader cable:
Peel off the tape
Flip up the latch
Pull out the cable
Disconnect the bottom right antenna interconnect cable:
Peel off the tape
Flip up the latch
Pull out the cable
Use tweezers or your fingers to peel back the bottom right antenna interconnect cable.
Use your fingers to lift and unroute the antenna cable harness away from the right edge of the iPad.
Gently pull on the antenna cable harness to separate them from the frame.
Disconnect the Smart Connector cable:
Peel off the tape
Flip up the latch
Pull out the cable
Insert the flat end of a spudger under the Smart Connector cable.
Slide the flat end of a spudger under the cable to separate it from the frame.
Repeat the previous step to disconnect and separate the lower left antenna interconnect cable.
Use a Phillips screwdriver to remove the two 2 mm screws securing the USB-C port to the frame.
Insert a spudger under the USB-C port cable.
Lift the USB-C port out of its slot in the frame.
Use tweezers to remove the two grounding contacts in the USB-C port recess.
Prop the top side of the iPad up so the isopropyl alcohol can flow under the USB-C port cable.
Apply a few drops of high-strength (>90%) isopropyl alcohol along the top edge of the USB-C port cable.
Insert an opening pick under the USB-C port flex cable.
Slide the pick along the cable towards the logic board to separate the adhesive.
Prop the right side of the iPad up so the isopropyl alcohol can flow under the logic board.
Apply a few drops of high-strength (>90%) isopropyl alcohol along the right edge of the logic board.
Let the alcohol soak for one minute to soften the adhesive under the logic board.
Insert an opening pick under the right edge of the logic board.
Pry up and slide along the right edge of the logic board to separate the adhesive securing it to the frame.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card under the right edge of the logic board.
Pry up and slide along the right edge of the logic board to separate any remaining adhesive.
Grip the logic board at the top and bottom edges.
Lift out the logic board.
Video "iPad Air 4 (10.9/2020) Charge Port Repair" shows Logic Board replacement steps very well: https://m.youtube.com/watch?v=BZlhqoOobt...
a very detailed step by step process...Great job! thanks for sharing this.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 4 answers community for help.
Hello, any idea where i can get a top left interconnect cable replacement part? I cannot find the part anywhere. Thanks
Anyone any luck finding the logic board? Or will it even work... seems risky.
How about a schematic for the logic board?
I have one thats not displaying image and I can't seem to find the issue.
