Follow this guide to replace the screen and battery assembly on your Samsung Galaxy S22+.
This guide is written for the screen and battery assembly. The assembly consists of the screen, battery, and frame together in one part. Be sure you have the right part before you begin the repair.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back cover for three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Remove the suction handle.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick inserted near the bottom left corner to prevent the adhesive from resealing.
Apply the heated iOpener to the left edge of the phone for 3 minutes to soften the adhesive.
Reheat your iOpener for 30 seconds if necessary.
Insert a second opening pick into the gap created near the bottom left corner.
Slide the opening pick along the left edge to slice the adhesive.
Leave the opening pick inserted near the top left corner to prevent the adhesive from resealing.
Apply your heated iOpener to the right edge of the phone for 3 minutes to soften the adhesive.
Insert a third opening pick into the gap created along the bottom edge.
Slide the opening pick around the bottom right corner of the back cover to slice the adhesive.
Continue sliding the opening pick up along the right edge of the back cover to slice the adhesive.
Leave the opening pick inserted near the top right corner to prevent the adhesive from resealing.
Apply your heated iOpener to the top edge of the phone for 3 minutes to soften the adhesive.
Slide the opening pick in the top left corner across the top edge to separate the remaining adhesive.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use the pointed end of your spudger to pry up and disconnect the charging coil's press connector from the motherboard.
Use the pointed end of your spudger to pry up and disconnect the NFC antenna cable from the motherboard.
Use your Phillips screwdriver to remove the six 3.5 mm screws securing the charging coil.
Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
Insert your spudger in between the left edge of the loudspeaker and the frame.
Pry up to disconnect the clips securing the loudspeaker.
Gently remove the charging coil & NFC antenna assembly.
Use your spudger to pry up and disconnect the battery's press connector.
Use your spudger to pry up and disconnect the primary interconnect cable from the motherboard.
Use your spudger to pry up and disconnect the secondary interconnect cable from the motherboard.
Use your spudger to pry up and disconnect the primary interconnect cable from the charging board.
Use your spudger to pry up and disconnect the secondary interconnect cable from the charging board.
Use tweezers, or your fingers, to remove the interconnect cables.
Use your Phillips screwdriver to remove the three 3.4 mm screws securing the charging board.
Insert the pointed end of a spudger between the top right edge of the charging board and the frame.
Pry up to lift the charging board enough to reach it with your fingers.
Pull the charging board towards the top of the phone at a 30-degree angle and remove it.
Use your spudger to pry up and disconnect the display cable from the motherboard.
Use your spudger to pry up and disconnect the display cable from its press connector below the battery.
Remove the display cable.
Use your Phillips screwdriver to remove the four 3.5 mm screws securing the motherboard cover.
Insert the pointed end of your spudger between the motherboard cover and the motherboard.
Gently pry the motherboard cover up and off of the motherboard
Remove the motherboard cover.
Use your spudger to pry up and disconnect the left mmWave antenna from the motherboard.
Use your spudger to pry up and disconnect the right mmWave antenna from the motherboard.
Reposition the battery and mmWave antenna cables to access the volume and power button press connector underneath.
Use the pointed end of your spudger to disconnect the volume and power buttons.
Use the pointed end of your spudger to pry up and disconnect the front camera from the motherboard.
Use your Phillips screwdriver to remove the 3.5 mm screw securing the camera module and motherboard to the frame.
Insert the pointed end of your spudger under the top left corner of the motherboard.
Gently lift the motherboard out of the phone until you can grip it with your fingers.
Prepare an iOpener and apply it to the front camera for three minutes.
Place the iOpener on your work surface and lay the top edge of the screen on it to heat the camera from underneath.
Use the pointed end of your spudger to pry the front camera up and out of the frame.
Use a pair of tweezers or your fingers to remove the front camera.
Remove the black adhesive liner from the front-facing camera recess.
Peel and remove the foam liner from the new frame.
My original phone's frame has this foam liner. Why is it unnecessary?
DO NOT DO THIS STEP, the kit does not come with the part in the next step.
Remove the clear liner from the front-facing camera adhesive.
Place the adhesive in the camera recess with its pull tab facing right.
Remove the blue adhesive liner using its pull tab.
Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
Neither my old phone nor the new frame come with such a liner. What on earth is this guide referring to?
the kit does not come with this part
Use your Phillips screwdriver to remove the two 3.5 mm screws securing the left 5G mmWave antenna.
Use the point of a spudger to pry up on the left 5G mmWave antenna bracket's lower screw tab until you can grip it with your tweezers.
Use your tweezers to remove the left 5G mmWave antenna.
Remove the antenna and connector from the old bracket.
Remove the L-shaped adhesive liner from your new bracket.
Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
Use the pointed end of your spudger to pry the right 5G mmWave antenna up until you separate its adhesive.
Use tweezers or your fingers to remove the right 5G mmWave antenna.
Be EXTREMELY careful with this step. If it doesn't come up easy, heat it longer. If there's any resistance, heat it longer. The board cracks VERY easily...ask me how I know...
Insert the corner of your spudger in the tab on the side button bracket.
Twist the spudger upward to pry and loosen the side button bracket from its recess in the frame.
Use blunt nose tweezers or your fingers to grab and remove the side button bracket.
Use your fingers to grab and remove the button pad.
Insert one arm of your blunt nose tweezers into the side button's recess.
Push the power button's peg through the frame until you can grab the button with your fingers.
Use your fingers to grab and remove the power button.
Push both pegs of the volume buttons through the frame until you can grab the buttons with your fingers.
Use your fingers to grab and remove the volume buttons.
Only the screen and battery assembly remains.
To the right of the front facing camera is a speaker that also needs to be moved to the new screen
crwdns2935229:010crwdne2935229:0
Very VERY detailed step by step instructions, will be performing this procedure In the next few days and this guide will most definitely be the most important tool to have on hand! Thank you for taking the time to put this together so completely!!
The most thorough guide I've seen. Thank you for your effort!
Thank you for this nice tutorial.
Quick question : when you’ll replace the screen, will the finger lock work with the new screen or will it be disactivated like when you replace your main “home” button on iPhones ?
Useful guide. Thank you. I believe instructions for removing the top loudspeaker assembly are missing.
