Google Pixel 7a Battery Replacement
  1. Google Pixel 7a Battery Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
    If you purchased the iFixit kit, now is a good time to ensure you have all the parts: If you go to the kit page, and expand Kit Contents, you'll see the full list. The full list contains links to details on adhesive sets. These links are also in this guide document, in the upper right, in a scrollable window.⏎
    Newer batteries seem to come with the 1IP Torx Plus bit taped in the tray of the battery part tray (Repair Part box). It is not in the Tools, found in the Repair Tools box (if you purchased the Fix Kit).⏎
    Familiarize yourself with all the parts, including the six adhesive items. Ensure none of the components fell behind the parts tray and are left in the parts box (they are tiny adhesive tabs). The adhesive is VERY sticky. Don't remove the backing until you are ready to use, and then be prepared to lay the piece in place once ANY contact is made. Removal, even an edge, to better align an adhesive part is often not possible(!). The adhesive will stretch and bunch up.⏎
    As noted at the beginning of the guide, proper installation of the adhesive is required to maintain water resistance, but also to transfer heat correctly.
    Chris Romer - crwdns2934203:0crwdne2934203:0
  2. Google Pixel 7a Battery Replacement, Soften the adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
    If you have an IR Thermometer or Thermal Camera, you're going for 85C/185F. Even with mini heat guns, this comes up fast; just a few seconds of heat.
  3. Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Secure an Anti-Clamp: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
  4. Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Use the Anti-Clamp to create a gap: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel 7a Battery Replacement, Insert an opening pick using the Anti-Clamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
  6. Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Insert an opening pick using a suction handle: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  7. Google Pixel 7a Battery Replacement, Adhesive information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Adhesive information: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
    There is also a plastic bezel attached to the rear cover which you DO NOT want to remove. It's a very similar (temperature wise) adhesive that connects that bezel to the cover, as connects the bezel & cover to the frame, but since only the frame side adhesive is provided in the kit, you want to try not removing that bezel from the rear cover.
    If you did remove the rear cover bezel, while removing the rear cover, grab some T7000 glue, which has a precision application needle tip. Follow the instructions on how to apply the iFixit adhesive which you'll reach at and perimeter pieces at the end of this guide, but hold off on removing the blue tape pieces facing the cover. Make sure you know how to orient the bezel (there is a little notch ridge that goes over the USB-C power port. Clean up the bezel of adhesive, but don't remove the cover liner, which seems to stay in place even with the heat and prying that accidentally broke the bezel adhesives. Install rear cover, with loose bezel, to check you have it right.
    Remove, apply a bead of T7000 around the rear cover and then lay the bezel into that bead, carefully checking orientation. Pull your blue strips, install the cover with freshly glued bezel, and press the assembly overnight (using some clean cloths and a few books works - I used soft auto polishing microfibers and a kit of hydraulic caps).
  8. Google Pixel 7a Battery Replacement, Angle the opening pick: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Angle the opening pick: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Angle the opening pick: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
  9. Google Pixel 7a Battery Replacement, Separate the bottom edge adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the bottom edge adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
  10. Google Pixel 7a Battery Replacement, Soften the right edge adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
  11. Google Pixel 7a Battery Replacement, Separate the right edge adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the right edge adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the right edge adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
  12. Google Pixel 7a Battery Replacement, Soften the left edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
  13. Google Pixel 7a Battery Replacement, Separate the left edge adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the left edge adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the left edge adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
  14. Google Pixel 7a Battery Replacement, Soften the top edge adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
  15. Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the antenna bracket adhesive: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
    This is the trickiest part, because the camera bar wants to keep the back cover from lifting. It's like a break in the leverage, of the lower part of the case. Go easy.
  16. Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the remaining top edge adhesive: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
  17. Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Rotate your top edge opening picks: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
  18. Google Pixel 7a Battery Replacement, Pry up the camera bar: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Pry up the camera bar: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Pry up the camera bar: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
  19. Google Pixel 7a Battery Replacement, Finish separating the adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Finish separating the adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Finish separating the adhesive: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
  20. Google Pixel 7a Battery Replacement, Remove the rear cover: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the rear cover: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
    This reassembly link, "Follow This Guide" is really important. It's a shame they did it this way, but make a note of it for when you come back through.
  21. Google Pixel 7a Battery Replacement, Soften the flash unit adhesive: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Soften the flash unit adhesive: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use a hair dryer or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  22. Google Pixel 7a Battery Replacement, Separate the flash unit adhesive: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Separate the flash unit adhesive: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
    Not a good place to pry as there is a little ridge blocking access to the flash unit. Just use a tweezer to slightly lift the other side of the cable, the unit comes out easily (with proper heating).
    Yong Wang - crwdns2934203:0crwdne2934203:0
    Cuidado en este procedimiento, algo dañe y el flash quedo en color azul.
    Aurelio Garcia - crwdns2934203:0crwdne2934203:0
  23. Google Pixel 7a Battery Replacement, Clean the logic board cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Clean the logic board cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Clean the logic board cover: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
  24. Google Pixel 7a Battery Replacement, Remove the old copper tape: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the old copper tape: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the old copper tape: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to damage the battery with your tool during this step.
    • Apply a heated iOpener to the underside of the flash for one minute.
    • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
    • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
    It can be a little tricky applying the new copper tape. I was able to get through it by:
    - Pressing down the black adhesive on the logic board cover,
    - Lining up the new copper with the flash's backside,
    - Sandwiching them both when pressing the flash back into place.
    pinballwizard - crwdns2934203:0crwdne2934203:0
    Did not find the new copper tape in my kit, and this was really confusing. Would be helpful to show the part, from the kit here.
    I didn't notice the replacement copper tape until I got ready to put the back cover on again. In the kit, it's attached to the same piece of plastic that has the edge adhesive.
    David Y - crwdns2934203:0crwdne2934203:0
  25. Google Pixel 7a Battery Replacement, Unfasten the logic board cover: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Unfasten the logic board cover: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • While the Pixel 7a uses Torx Plus screws, standard Torx drivers may still work. If your kit came with standard Torx bits, use the T2 bit to remove 1IP Torx Plus screws, and the T3 Torx bit to remove 3IP Torx Plus screws. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the thirteen 4.3 mm screws securing the logic board cover.
    • Use a 1IP Torx Plus driver to remove the 1.5 mm screw securing the right edge of the cover.
    The T2 Torx driver that came with the tool kit does not fit. It seems a bit too large. Is this really T2 Torx?
    This is right. This is because the Pixel 7a uses Torx Plus screws, which are less commonly available than regular Torx bits. We're only able to provide regular Torx bits in our kits, for now. So, the bit size is slightly different to reduce the likelihood of stripping your screws out. When using the T2 bit to remove Torx Plus 1IP screws, use constant downward force to keep the bit fitting as well as possible.
    Clay Eickemeyer -
    こんにちは、1IPネジが少し舐めたので、交換しようと思っています、代替となるものはM1 1.5mmでしょうか?
    勝山ゆ う や - crwdns2934203:0crwdne2934203:0
    結論から言うと、おそらくネジの専門家でも現物を見ないと判断できないので、長さ1.5mmのM1ネジを入手できるお店をご存知ならネジの現物を持っていって判断してもらうのが間違いないです。そのようなお店をご存知なくて、元々のネジが再利用できそうなら、再利用するのが正解だと思います。
    私はPixel 7aの実機を持っていないのでネジ頭の種類は画像で判断するしかないのですが、おそらく低頭ネジ(pancake head、締め付け面が平ら)か皿ネジ(flat head、締め付け面が円錐形)かと思われます。トルクスプラスの1IPネジを作っているメーカーのサイズ表を見てみましたが、低頭ネジについては太さの情報がありませんでした。皿ネジについてはM0.9とM1の2種類の記載がありました。
    仮にこの2種類のどちらかであるとしても、どちらかを判別するには専用の道具が必要になりますし、別のサイズの特注品の可能性もあります。また、自力で判別できたとしてもこのサイズのネジを扱っているのはネジの専門店だけだと思われますので、結局ネジの専門店に現物を持ち込んで相談するのが最適解になるかと思います。
    なお、トルクスプラスIPネジと普通のトルクスネジではネジ頭の溝形状が異なるので、トルクスプラスIPネジを通常のトルクスドライバーで扱おうとすると隙間ができるはずです。そもそも強い締め付け力が必要な場所でもなさそうですし、ネジの締め付けや取り外しに問題ない程度の舐め具合であれば、元々のネジを再利用するのが現実的ではないかと思います。
    なお、私はネジの専門家ではないですしPixel 7aの実機を持っているわけでもありませんので、上記の内容に問題がある可能性があることはご了承ください。また、不備を見つけた方がいらっしゃいましたら訂正していただければ幸いです。
    最後に参考資料として、トルクスプラスネジの寸法規格表を紹介しておきます。どちらも英語です。
    Weha Tools社のトルクスプラスネジ寸法一覧表
    ポップリベット・ファスナー社のトルクスプラスねじパンフレット(PDF)(サイズ表は14ページ)
    Servause -
    It is unbelievably disingenuous to claim that the T2 Torx bit you supply fits the 1IP Torx Plus Screws. I'm sitting here with my phone half-dissembled searching Amazon to see if I can find a T1 Torx bit or a Torx Plus bit that can be delivered today. Hopefully anyone who reads this guide before buying, opens these comments and decides you aren't worth their time. I also plan to leave a review on the kit itself. I can't believe I paid $10 in shipping and waited a full week for this half-assed kit.
    Nick Hughes - crwdns2934203:0crwdne2934203:0
    This si a scam, don't waste your money on this. They make you buy a hole set of tools even when the know the don't have the proper tools to get the work done! That T2 Torx IFIXIT is selling doesn't work.
    Cristian González - crwdns2934203:0crwdne2934203:0
    Agree with previous comments. Included T2 bit does not even come close to fitting in the torx plus 1ip screw. Having to overnight a T1 bit in hopes it works.
    Aaron - crwdns2934203:0crwdne2934203:0
    After overnighting a precision bit set, it now appears that the T2 bit included in the iFixit kit may be out of spec. The T2 bit from the Amazon bit set fit as described and allowed me to complete the fix.
    Aaron -
    Got this far just to realize the same as above. The t2 bit that comes with the kit is wayyy to large to fit this screw
    Bilal Shaikh - crwdns2934203:0crwdne2934203:0
    Also chiming in here to advise that the T2 bit supplied is too large...hopefully this gets addressed!
    Elliott Marter - crwdns2934203:0crwdne2934203:0
    I am another person who is Too late to read this comment :). And further I have a Torx set with a T1 and even that doesnt work on this tiny complicated screw. I will be taking this to a local shop for repair and hope for some luck.
    h a. S - crwdns2934203:0crwdne2934203:0
    The provided T2 bit in the kit does not fit the screw here
    Joseph - crwdns2934203:0crwdne2934203:0
    I borrowed a friends T2 bit and it fit the screw perfectly. The ifixit T2 bit was the problem here.
    Joseph -
    This is a complete rip off to advertise a one stop shop kit and then knowingly include the wrong bit, which doesn't fit the phone. What a terrible experience. I've got a disassembled phone and now have to wait to order the proper bit. Never using ifixit again. Terrible experience.
    Ludwig von Rochau - crwdns2934203:0crwdne2934203:0
    I have a half disassembled phone that I can't take to work because of this t2 issue. Do not recommend
    Konrad Cichocki - crwdns2934203:0crwdne2934203:0
    Read through the guide before buying the kit, but I wish I had read the comments. As mentioned by everyone else, they literally do not provide the proper tools in the battery replacement kit...
    Mikko Saavalainen - crwdns2934203:0crwdne2934203:0
    Can confirm that I wasn't able to unscrew the 1LP Torx plus screw with the torx 2 bit which came with the kit. I'm stuck with a half disassembled phone :(
    Anup - crwdns2934203:0crwdne2934203:0
    My kit came with a 1lP bit in the battery package, so was able to complete the battery replacement no issues.
    Graeme Watson - crwdns2934203:0crwdne2934203:0
    Mine was the same.
    Chris Romer -
    I was able to use a 0.7 Allen bit( i think its Allen, not sure though) from my Mako kit to unscrew it. the screw on my phone wasn't tight thankfully so it came off rather easily but if the screw is too tight it might strip the screw so beware
    Graystar3 - crwdns2934203:0crwdne2934203:0
    This needs to get fixed. Same issue as everyone else. Disassembled phone, now unable to fix it due to wrong bits included. Not very happy with ifixit.
    Sam Hoffman - crwdns2934203:0crwdne2934203:0
  26. Google Pixel 7a Battery Replacement, Unclip the logic board cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Unclip the logic board cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
    • Pry up to release the clip securing the cover.
    iFixit Staff - Please provide instructions for how to secure this clip during reassembly.
    ChelseaH - crwdns2934203:0crwdne2934203:0
  27. Google Pixel 7a Battery Replacement, Free the flash unit: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Free the flash unit: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Free the flash unit: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board into place.
  28. Google Pixel 7a Battery Replacement, Remove the wireless charging assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the wireless charging assembly: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wireless charging assembly.
    For Step 28, during reassembly, thread the flash through its cutout as you lower the logic board into place. (This note from Step 27 should really be provided here).
  29. Google Pixel 7a Battery Replacement, Remove the connector cover: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the connector cover: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the connector cover: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your 1IP Torx Plus driver to remove the 1.5 mm screw securing the connector cover.
    • Use tweezers or your fingers to remove the cover.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before installing its screw.
    For my model (from T mobile), it is T1 Torx, not T2. The one underneath is also T1, not T2. In other words, a T1 Torx driver works OK but not T2.
    Very unimpressed that you ship a product that does not have the correct hardware. This device needs a T1. Unable to get a T2 bit to work.
    Dan Pawlowski - crwdns2934203:0crwdne2934203:0
    I was also unable to get the T1 screw out in this step. I'm not sure why the correct tools weren't just provided, but it creates an incredibly frustrating experience when trying to complete the repair.
    Stephen Caren - crwdns2934203:0crwdne2934203:0
    Yeah, I had the same issue as the above people - and I literally don't have a T1 bit. I assumed the guide would include it.
    I will be complaining, but first I have to figure out how to get a T1 bit.
    Jared Elick - crwdns2934203:0crwdne2934203:0
    The ifixit T2 bit provided in the kit did not fit the screw. I borrowed another T2 bit of another brand from a friend and it fit perfectly on the screw.
  30. Google Pixel 7a Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Verizon model (G0DZQ) Google Pixel 7a has an extra cable and connector for the 5G mmWave antenna. Unless otherwise mentioned, the rest of the guide procedure is the same for either type of phone.
  31. Google Pixel 7a Battery Replacement, Disconnect the battery: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Disconnect the battery: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the top edge of the battery press connector.
    • Pry straight up to disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  32. Google Pixel 7a Battery Replacement, Disconnect the 5G mmWave antenna: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Disconnect the 5G mmWave antenna: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Verizon models: Use the point of your spudger to pry up and disconnect the 5G mmWave press connector.
  33. Google Pixel 7a Battery Replacement, Move the cables: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Move the cables: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Move the cables: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the battery cable toward the bottom of the phone, out of the way of the battery.
    • Verizon models: Move the 5G mmWave cable toward the top of the phone.
  34. Google Pixel 7a Battery Replacement, Peel up the battery jacket: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Peel up the battery jacket: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Peel up the battery jacket: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel up both sides of the battery jacket from the battery.
    • If you're using a tool, be careful not to puncture the battery.
  35. Google Pixel 7a Battery Replacement, Soften the battery adhesive: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Soften the battery adhesive: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two strips of adhesive secure the upper half of the battery. The battery jacket is just below these strips.
    • Flip the phone over and use a hair dryer, heat gun, or hot plate to evenly heat the screen until the entire frame is warm to the touch.
    • Be careful not to overheat the screen, as it's susceptible to heat damage. Don't concentrate the heat in any one spot.
  36. Google Pixel 7a Battery Replacement, Slide the battery jacket: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Slide the battery jacket: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Slide the battery jacket: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grip both sides of the battery jacket. Hold them at a low angle, but up high enough so they don't snag on any logic board components or the frame.
    • Slide each end of the jacket toward the top of the battery in a sawing motion to cut through the bottom portion of adhesive.
    • It might take a lot of back and forth sawing motions before the adhesive comes loose. If the jacket rips, skip down two steps for an alternate method.
    • Stop sawing when the jacket reaches halfway up the battery.
    This step should mention that if you use the battery jacket sawing motion up too far, you will for sure cut the 'side button tab' which is not mentioned until the next step. If you cut this tab, your volume buttons will no longer work, and you will need to purchase "Power On Off/Volume Buttons Flex with Flash Light Sensor for Google Pixel 7A" (iFixit does not sell this part). You will also then need to fully remove the logic board to replace that part. This really screwed me up.
    Mekkel Richards - crwdns2934203:0crwdne2934203:0
    I fully agree with Mekkel's comment - this step should have a warning about the side button tab, which is also black, touches the battery and will get cut with the "sawing motion". It is crazy that this is only mentioned in point 39!, when the damage is done.
    I now need to get the new cable and replace it, including the complex motherboard removal (which may damage other parts if I rely on the poorly written iFix instructions.
    Mirek Bober - crwdns2934203:0crwdne2934203:0
    Just did the same thing, UGH. Plan on just using menu controls and ditching the buttons since I don't want to open it again.
    Patrick Smolinsky -
  37. Google Pixel 7a Battery Replacement, Lift the battery: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Lift the battery: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull up on each end of the battery jacket for one minute to slowly allow the adhesive to loosen.
    • If the battery still feels stuck, apply more heat or skip to the next step for an alternate method.
    [Step 37] Warning! Pay a special attention to the side button tab on the left (better picture on the step 39). I broke it while using the transparent tab to pull the battery. It is not a plastic part, it has wires in it and then if you break it you loose the volume up and down buttons. This wire is awful to replace and not sold by iFixit so be very careful at this step
    TomTomLaBricole - crwdns2934203:0crwdne2934203:0
  38. Google Pixel 7a Battery Replacement, Alternate method to remove the battery: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Alternate method to remove the battery: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you couldn't remove the battery using the jacket, follow the next three steps for an alternate method.
    • Fill a pipette or syringe with highly-concentrated isopropyl alcohol (over 90%).
    • Apply a few drops of isopropyl alcohol between the left edge of the battery and the frame.
    • Wait one minute for the adhesive to soften.
  39. Google Pixel 7a Battery Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the side button tab to the left, away from the battery.
    • Insert the flat end of an opening pick between the left edge of the battery and the frame.
    I broke the side button tab that is mentioned in step 39. How screwed am I? :'-(
    Laura Speich - crwdns2934203:0crwdne2934203:0
    Mine tore on the volume button side -- did your phone at least still turn on? Im hoping I can just control the volume from menus.
    Patrick Smolinsky -
    Same happened to me. Well, I'm actually sure it was broken before, like... When my battery swell so much it pushed open the phone and tore of the back cover slowly?
    Anyway.... How to fix the side button tab? Cuz now the loud and quiet button is useless and its just some small, thin plastic, it seems
    Ann Christin S - crwdns2934203:0crwdne2934203:0
    I just did the same thing -_-
    Patrick Smolinsky -
  40. Google Pixel 7a Battery Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take care not to deform or puncture the battery—a damaged battery is a potential safety hazard.
    • Firmly bend the opening pick away from the battery. Keep steady pressure on the pick for one minute.
    • Once the adhesive begins to separate, slide your pick deeper under the battery and continue prying it up.
    • If, after a minute, the adhesive doesn't loosen, apply a few more drops of isopropyl alcohol and try again.
  41. Google Pixel 7a Battery Replacement, Remove the battery: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 7a Battery Replacement, Remove the battery: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  42. Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Prepare your frame for reassembly: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next three steps show how to apply new adhesive and install a new battery.
    • Use the flat end of your spudger to scrape an edge of the old adhesive into a ball large enough to grip with a pair of tweezers.
    • Use tweezers or your fingers to peel and remove the old adhesive from the frame.
    • If any residue remains, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the frame and wipe it with a lint-free or microfiber cloth.
    Isopropyl or Denatured Alcohol works here on the residue. Dampen a cloth with either, and wipe over residue. You'll see it roll up.
  43. Google Pixel 7a Battery Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your battery comes with adhesive pre-installed, remove its adhesive liners and skip this step.
    • Peel the two strips of battery adhesive from their large liner.
    • Apply the short strip of adhesive to the right side of the battery recess, using the white lines on the frame to position it.
    • Apply the long strip of adhesive to the left side of the recess.
    • Remove the blue liners from the adhesive strips.
    Hardest part of this portion. As you can see in the photo, on the right, short strip, they might not lay flat (see bubble near top - the tweezers are pointing right at it). You might get a wrinkle, but you can't work that out. Little imperfections will be fine. What you DO NOT want to do, is try to recenter a piece once it touches. Once it touches, you are committed. If you try to pull it off, it will stretch and become a mess. Try your best to align it, and once it touches, you must lay it down.
  44. Google Pixel 7a Battery Replacement, Align and secure the battery: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Align and secure the battery: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 7a Battery Replacement, Align and secure the battery: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the battery just above its recess in the frame, reconnect its cable.
    • Press the battery into place.
    • Disconnect the battery.
    So, I wish they would NOT have said reverse the order after this step, and I can't comment there, so I will comment here. Step 20 has a link to the precise steps in applying the THREE adhesive components (perimeter, long skinny piece, and shorter wider strip). Be careful with all of these adhesive pieces. Keep scraps away from the assembly, and don't make contact until you want to commit to the placement.
    ...also, I believe this should say "Connect the battery."
To reassemble your device, follow these instructions in reverse order, starting from this step.
Calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
crwdns2935229:046crwdne2935229:0
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86 475 crwdns2915208:0crwdne2915208:0
crwdns2935297:0454crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013 563crwdne2935297:0
crwdns2947412:024crwdne2947412:0
I may have made a mistake in this process. I have a question for you. How can I chat with you?
先輩ゲーマー - crwdns2934203:0crwdne2934203:0
Through here is just fine! If you have a more general question, I might recommend you ask in the answers forum.
Clay Eickemeyer -
Which part did you lose?
Clay Eickemeyer -
Hello- I started to replace my battery, but I had two serious problems:
1) The small brass sticker under the flash had unstuck from it's lace on delivery. I eventually found it, but it was stuck to another piece of the packaging. As was the black foam. But, I am not sure if that's a problem yet because...
2) My Torx t2 bit DID NOT fit the one screw it was supposed to. Perhaps it was a t1? Now, I think I have stripped that screw out trying to make the T2 bit work.. I'm not sure what to do from her except get a new phone and request a refund from you.
I've put all the screws back in and resealed my phone, but the batter has not been changed. Thoughts?
Thank you,
~Paul
Paul Bernard - crwdns2934203:0crwdne2934203:0
Beyond drilling it out, you can try dab some hot wax into the screw and see if you can make a bit get traction. Otherwise cut a small slot into the screw so you can use a small flat-head bit.
Imad Knight -
Great guide, however I ended up needing to buy a 1IP bit to complete the guide, otherwise I would have stripped the screw in step 29.
Peter Farkas - crwdns2934203:0crwdne2934203:0
Yeah, I was too broke to pay their shipping again, and no hardware store locally had it - so my phone was unsafe to use for almost 2 weeks while I fought them to update the guide and kit.
Jared Elick -
Good guide, easy to follow and execute. However here are some tips to anyone else doing it:
- If you have trouble with the plastic tab under the battery, and don't have any isopropyl alcohol at hand, I can recommend (gently!) pushing some dental floss under the battery, and then working the adhesive loose. A long piece wound around two fingers gives better leverage - just be careful as not to rip off the little ribbon cable on the left side by the battery!
- It would have been nice to have a step on re-applying the back adhesive. I stuck it onto the phone itself, but I think that sticking it to the back glass would have been smarter, as I managed to twisted one edge.
- Also, I agree with @paulbernard & @peterfarkas1513 regarding the incorrect bit being specified/provided in the fix kit. I made the t2 bit work as I needed the phone up and running asap, but I could have been left with a stripped screw.
Finally, I'd recommend starting the phone after reconnecting the battery, before gluing it down, to make sure everything works.
Imad Knight - crwdns2934203:0crwdne2934203:0
Thanks for the excellent guide. The crisp, high-res photos and detailed explanations made a world of difference.
I can't imagine having to do this job without this guide.
Well done.
Don't Buy it! The tools they send doesn't work. Read the comments on the 25th step.
Very bad. The 1IP screw cannot be opened using the T2 bit provided. I'll ask for a refund.
Alessandro Dragoti - crwdns2934203:0crwdne2934203:0
Worked fine .. had to have some extra stuff other than the things provided .. having proper screw driver etc helped a lot. Would not like to take the screws out manually with tools provided.
Thanks
Ian Home - crwdns2934203:0crwdne2934203:0
DO NOT use a Torx 2 driver. It will not work. Quickly order or request the right bits, you can only damage it, you cannot unscrew it, with any T2 bit I've found.
And their "compensation" is a $20 off $50 or more coupon, and some cheap stickers that advertise for them... Which is really a discount, not compensation
I can not open the Torx Plus 1IP screw with the provided Torx T2 in the kit (step 25)
The provided ifixit T2 bit did not fit the 2 1IP screws. I borrowed a friends' T2 bit of another brand and it fit the screw perfectly and I was able to complete the replacement.
Joseph -
Extremely disappointed. This "kit" does not include the required T-1 bit, but includes an unneeded Phillips bit. This is unacceptable.
Dave A - crwdns2934203:0crwdne2934203:0
Step 39 problem... Even tho I used step 37 method....
How to fix the side button tab if it broke off? I'm still pretty sure the battery did it when it tried to brake itself out of the case because it had developed Adipositas.... But problem remains the same and I can't find any replacement in store :((
背面カバーの接着剤は何をつかうのがベストですか?
よろしくお願いします
b-7000 が良いようですが、別のものでも大丈夫ですか?
Kazumi - crwdns2934203:0crwdne2934203:0
Google純正の交換用接着剤を使うのがベスト、というのが模範回答だと思います。
このページの右上にある「必要な工具と部品」のパーツのコーナーにあるGoogle Pixel 7a Rear Cover Adhesive Set - Genuineが該当しますので、お求めの場合はそちらから購入するのがよろしいかと思います。
Servause -
Good guide, but a warning about the risk of cutting volume up/down cable in step 36 is needed. It is noted in step 39, but this is TOO LATE!
My pixel 7a battery expanded and in the process it caused a little tear in the black plastic thing between the wireless charging coil and the battery. I just want to ask if its okay to keep it or is the black plastic thing important?
Louise Berania - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 237
crwdns2936753:07crwdne2936753:0 1,545
crwdns2936753:030crwdne2936753:0 6,824
crwdns2942667:0crwdne2942667:0 91,850
