This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace a worn-out or dead battery in your Google Pixel 6 Pro.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Caution: The Pixel 6 Pro contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You’ll need replacement adhesive to reattach components when reassembling the device.
Fully power off your phone and unplug any cables.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your phone.
Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
Squeeze the cups together to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the phone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
Insert an opening pick into the gap between the screen frame and the phone assembly.
Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
Insert a third opening pick underneath the bottom left corner of the screen.
Slide the opening pick along the left edge of the screen to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner of the screen.
Slide the opening pick along the top edge of the phone to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
Remove the screen.
If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
Follow this guide if you're using custom-cut adhesives for your device.
Follow this guide in case you're using a pre-cut adhesive card.
If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the motherboard shield.
Remove the graphite film.
Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top right corner of the battery.
Fold the graphite film in direction of the selfie camera to get free access to the battery.
Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the charging port metal bracket.
Use a pair of tweezers to remove the charging port bracket.
Use a Torx T3 screwdriver to remove the five 5.1 mm-long 3IP Torx Plus screws securing the motherboard cover.
Use a pair of tweezers or your fingers to carefully remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bring your phone assembly to an ~45° angle.
Apply a few drops of high concentration (over 90%) isopropyl alcohol into the gap between the motherboard and the top left and bottom left corner of the battery.
Insert an opening pick into the gap between the top right corner of the battery and the midframe.
Use your opening pick to pry up the battery by tilting your pick downwards and widen the gap between battery and the midframe.
Work your way along the right edge of the battery and widen the gap between battery and midframe until you have enough space to insert a plastic card.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card underneath the right edge of the battery.
Slide the plastic card along the right edge of the battery to separate it from the midframe.
Use your plastic card to pry up the battery.
Peel the battery off the remaining adhesive.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
crwdns2935229:024crwdne2935229:0
crwdns2947412:013crwdne2947412:0
White flickering screen after battery replacement. I checked all the connections and it seemed that they were all right.
Same AF, got to take it back apart and try to reconnect my screen
I found an important and critical piece missing in this guide. In steps 6 through 10 your goal is to get the screen separate from the phone chassis. While they do mention to be sensitive around the front camera the guide doesn't mention that you also need to be sensitive around the left-side center of the phone as well. This is where the screen cable connects to the motherboard. I wouldn't even put a pick or tool anywhere near that area. I didn't put too much pressure or anything but it looks like I somehow hit that cable while removing the screen. I don't see any damage to the cable or the screen but when I turn the phone on my screen now outputs several always on bright pink and green lines running through it indicating something went wrong here. So I went from replacing the battery to having to replace the screen too. Between the cost of the new battery and a new screen it probably would've been cheaper to just buy another used Pixel 6 Pro.
Sorry, I have a question, did you change the screen?
RICCC -
I went through this process successfully; Several notes;
1. As Dan Mentions, careful of the screen cable, but also be careful of the alignment pins top left and bottom right of the screen - they block the insertion of the pry picks.
2. A hair dryer (750W) on low speed, high heat, works a charm and is much faster and easier than the iOpener.
3. There's an additional wiring ribbon cutting across the battery from top middle to left-middle. It can be easily disconnected, but it isn't shown on the pictures, nor mentioned in the instructions.
4. When you've reconnected the screen wiring ribbon, it says "Don't touch the screen as it needs to calibrate." Mine did nothing. It just turned on and presented the login screen. I used my fingerprint and the device worked. So I powered off and proceeded to affix the screen to the adhesives.
5. Once everything was assembled, I powered on and the finger print reader stopped working (was undetectable). There is a solution to this, but it really should be in this Guide.
