AirPort/Bluetooth Board
crwdns2933315:04crwdne2933315:0 crwdns2934263:03crwdne2934263:0 |
bad crayon/body odor smell coming from keyboard |
crwdns2933315:05crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
Can I trick my MacBook into thinking it has a battery connected? |
crwdns2933315:07crwdne2933315:0 crwdns2934263:05crwdne2934263:0 |
Unresponsive Keys, but only sometimes? |
crwdns2933315:09crwdne2933315:0 crwdns2934263:023crwdne2934263:0 |
MacBook Pro 2011 to 2012 logic board swap? |
A1286 (EMC 2556 MacBookPro9,1) 2.3 GHz, A1286 (EMC 2556 MacBookPro9,1) 2.6 GHz, A1286 (EMC 2556 MacBookPro9,1) 2.7 GHz
Identification and Background
The MacBook Pro 15" Mid 2012 Unibody was released in June of 2012.
The Mid 2012 model has the same model number, A1286, as the previous iterations. As with the models from in 2011, the MacBook Pro 15" Mid 2012 Unibody's case is composed of a single block of aluminum, following the same process of the MacBook Unibody and the MacBook Pro 17" Unibody.
MacBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts. Check your machine against the details in this section. If they don't match, find your model under MacBook Pro 15" Unibody and check the Identification section on its page.
Technical Specs
Display:
- 15.4-inch (diagonal) LED-backlit glossy or optional antiglare widescreen display with support for millions of colors.
Storage:
- 500 GB or 750 GB 5400-rpm, hard drive
- Configureable to: 750GB 7200-rpm hard drive, 1TB 5400-rpm hard drive, 128GB solid-state drive, 256GB solid-state drive, or 512GB solid-state drive
Processor:
- 2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6 MB shared L3 cache.
Memory:
- Configureable to: 4 GB or 8 GB of 1600MHz DDR3L memory
Wireless Connectivity:
- 802.11n Wi-Fi wireless networking; IEEE 802.11a/b/g compatible
- Bluetooth 4.0 wireless technology
Graphics and Video:
- Intel HD Graphics 4000
- NVIDIA GeForce GT 650M with 1GB of GDDR5 memory and automatic graphics switching
- Thunderbolt digital video output
- 720p FaceTime HD camera
Battery:
- Built-in 77.5-watt-hour lithium-polymer battery
Ports:
- Two USB 3 ports
- Thunderbolt port
- MagSafe power port
- SD/SDXC card slot
- FireWire 800 port
- Audio line in
- Audio line out
- Kensington lock slot
Dimensions:
- Height: 0.95 inch (2.41 cm)
- Width: 14.35 inches (36.4 cm)
- Depth: 9.82 inches (24.9 cm)
- Weight: 5.6 pounds (2.56 kg)2
