Use this guide to replace the short optical drive ribbon cable connecting the optical drive to the logic board.
            Remove the following ten screws securing the lower case to the upper case:
            Three 13.5 mm (14.1 mm) Phillips screws.
            Seven 3 mm Phillips screws.
            Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
            Remove the lower case and set it aside.
            Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
            Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
            Disconnect the camera cable connector from its socket on the logic board.
            Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
            Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
            Remove following two screws:
            One 8.6 mm Phillips screw
            One 3.9 mm Phillips screw
            Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
            Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
            Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
            Pull the optical drive cable out of the optical drive.
            Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
crwdns2935229:013crwdne2935229:0
