crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Black Screen on Power-On
Screen appears black while computer is on
Display Settings Misconfigured
There is a chance that the settings are making the screen appear off when it is not. Press and hold fn+F5. This should turn up the brightness in the event the monitor is simply too dark to see.
Try the fn+F8 key. This switches the display mode if the computer was trying to display to a different output.
Extra Monitor Interference
Try using an HDMI cable to an external monitor to see if it can display. See if the fn+F8 command to toggle display modes. If it works on the external monitor but not the in-built one, then that means the problem is a power issue or faulty connection.
If you were already connected to an external monitor try disconnecting to see if the display returns to the onboard monitor. Sometimes a monitor may quit outputting to its default monitor if another one is detected.
Battery Issues
The battery may not be transferring power correctly. To start, make sure your power cable is plugged in fully and its indicator light is glowing. The light should be located on the block of the cable. If it is not functioning you may need to replace the cable.
If the cable is working remove the battery as described in this guide*. Reconnect the power cable to the laptop and try powering it on.
Not Recognizing USB Devices
USB ports not recognizing USB devices can be caused by the currently installed drivers being unstable or corrupted.
Windows out of date
Updating windows can resolve the missing drivers or corrupted drives installed.
New drivers not working
Sometimes the devices will not recognize the new drivers until you restart the laptop.
Not connected correctly
USB devices may not be connected to the right ports make sure you are connected to the right ports for your device
Blue Screen
Occurs when the system abnormally restarts due to software or hardware problems.
Software issue
This is the most common cause of the the BSOD or blue screen issue. The easiest solution for this is to restart your computer. To do this hold down the power button for at least 8 seconds and turn the laptop back on after a full reset.
Out of date BIOS
The blue screen error may occur when your system bios is not up to date. To fix this problem download the update file from ASUS.com.
In case, you need help connecting to wi-fi
Unusually Short Battery Life
The battery is draining faster than it used to
Disable Extra Power Drainers
Adjust some quality of life settings. Lower screen brightness by using the fn+F4 hotkey. Additional power settings can be found under Start Menu(bottom left hand of windows)> Settings(gear icon)>Systems>Power & Sleep
Unwanted Programs
Having too many processes or programs running at once will cause unnecessary battery drain. Open tabs can be closed using the ‘X’ in the top right. Programs that are not visible can be seen by opening task manager (ctrl+alt+delete). Click on a task you do not need and click on it then press end task.
You may want to consider uninstalling or disabling some of these programs so they will not automatically run on startup. Microsoft OS features like Cortana/Xbox can be disabled through Settings>Privacy>Background and third party programs can be uninstalled through Settings>Apps & Features
Battery Issues
If the battery life has shortened, while running the same settings and programs it used to, you may need to replace the battery.
Touchpad Unresponsive
The reasons that it might cause the touchpad to be unresponsive is that the drivers are out of date.
Out of date Touchpad drivers
Open device manager, to find touchpad devices, click on Human Interface devices then right click the device you would like to update and select update driver.
Improper installation of the Touchpad drivers
Open device manager, right click the name of the device, then select the uninstall option. Restart the device after clicking the uninstall button and windows will automatically try to reinstall the driver. If windows does not update it automatically you can follow the same steps but select install instead of uninstall.
I've got an E210. Out of nowhere it shut off and won't power on. I hooked up an external ssd to it and kaput. Ideas? How can i test to assess the actual damage?
Hackem up - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
