iPhone 7 Plus LCD and Digitizer Replacement
  1. iPhone 7 Plus LCD and Digitizer Replacement, Pentalobe Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - crwdns2934203:0crwdne2934203:0
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - crwdns2934203:0crwdne2934203:0
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - crwdns2934203:0crwdne2934203:0
    How do you turn off if the screen isn’t responding to touch?
    adam - crwdns2934203:0crwdne2934203:0
    The replacement battery came with the seal—but how do you put it on???
    lkollar - crwdns2934203:0crwdne2934203:0
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - crwdns2934203:0crwdne2934203:0
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - crwdns2934203:0crwdne2934203:0
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - crwdns2934203:0crwdne2934203:0
    The screw size for those with a screw set is P2.
    Gareth Flandro - crwdns2934203:0crwdne2934203:0
  2. iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
  3. iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
    Tape doesn’t hold. suction cup doesn’t work. Tape folded over doesn’t work as a handle. I’ve used 3m’ s Gorilla duct tape. The glass is so shattered I cant get a point started to remove the glass. Phone has been in an otter box for years. dropped it and shattered glass while replacing case. Now what?
    Martin Speedy - crwdns2934203:0crwdne2934203:0
    When all else fails, you can superglue your suction cup (or tape) to the display, wait for it to cure, and pull.
    Jeff Suovanen -
    I had issues getting the suction cup to stick on my cracked screen, so I tried using scotch tape (only tape I had around), but it didn’t work. This best thing I did was to forcefully pry the screen off (I wasn’t worried about damages because it’s already cracked) with the spudger. I think its best to find something stickier (like Duct Tape) and used that to lift up the screen.
    Definitely surprised how sticky the adhesive was.
    Jeffrey Robinos - crwdns2934203:0crwdne2934203:0
    When using packing tape: the suction won’t hold well with the overlapping pieces, so add a square of tape where you want to put the suction cup, so it will provide an unbroken surface for the seal.
    Christa - crwdns2934203:0crwdne2934203:0
    It’s amazing how a heat gun or hair dryer makes life easier to soften up the adhesive. Then use a thin iSesame opening tool to get in under the screen (start @ 90 degrees/vertical either side of the home button & slowly go horizontal) the need to use suction cups. Run the opening tool along the front and down both sides to cut the adhesive before trying to lift the screen.
    Cheers Wayne
    Wayne Lyell - crwdns2934203:0crwdne2934203:0
    I didn’t have a hair dryer so I (gingerly) used an iron over some wet coffee filters (I mean , it is waterproof) . Then, quickly dried i off with paper towels, used gorilla tape and my fixit metal splunger . worked like a charm .
    MajorCouillon - crwdns2934203:0crwdne2934203:0
    What about baby cracks? skip to step 3 or not…
    Andruw Holland - crwdns2934203:0crwdne2934203:0
    As others have mentioned, suction cup and tape doesn’t work. I used the blade of a box cutter (watch fingers) and inserted just below and right of home button. Then moved spudger along the crack to tear adhesive/seal. Easy peasy.
    Stephen Smith - crwdns2934203:0crwdne2934203:0
  4. iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 7 Plus LCD and Digitizer Replacement, Heat the display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    No hair dryer so GENTLY heated over stove burner
    John Toth - crwdns2934203:0crwdne2934203:0
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - crwdns2934203:0crwdne2934203:0
    I was about to ask the same Question...
    Enno Winch -
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - crwdns2934203:0crwdne2934203:0
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - crwdns2934203:0crwdne2934203:0
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - crwdns2934203:0crwdne2934203:0
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - crwdns2934203:0crwdne2934203:0
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - crwdns2934203:0crwdne2934203:0
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - crwdns2934203:0crwdne2934203:0
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - crwdns2934203:0crwdne2934203:0
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - crwdns2934203:0crwdne2934203:0
    Hairdryer works fine for this step. No issues.
    tripmusic - crwdns2934203:0crwdne2934203:0
    Agree! Just did it for 2 times to make sure I didn't overheat the phone.
    André Lopes -
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - crwdns2934203:0crwdne2934203:0
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - crwdns2934203:0crwdne2934203:0
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - crwdns2934203:0crwdne2934203:0
    This part was actually much easier than I thought. I used a hair dryer on max for 2 minutes on each side of the phone, less than half an inch away from the phone, just on the bottom half. It was hot! Screen came right out!
    Nuno Lopes - crwdns2934203:0crwdne2934203:0
    I used a tube sock full of about 1 cup of white rice. Tied a knot in the top of the sock. Put the sock of rice in the microwave on 60% power for 1 minute. Kept doing this until the temp felt right. Put the sock of rice down, put bottom edge on sock, then covered w/ other half of the sock/rice. Put a piece of paper towel between phone and sock/rice to absorb any moisture. When lifting up on front panel, I rested the phone on the sock/rice. Worked nicely once I got the temp of the rice high enough.
    (threw the rice away later :-) )
    Burning Sensation - crwdns2934203:0crwdne2934203:0
    “Threw the rice away later” has to be the best advice here. I wrapped my phone in a small heating pad and turned it up to 6 of 8. Worked great in 5 min or less! No need for water bottles, microwaves, heat guns, volcanoes, …. I kept the heating pad later ; )
    dantegd - crwdns2934203:0crwdne2934203:0
  8. iPhone 7 Plus LCD and Digitizer Replacement, Separate the display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Separate the display: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - crwdns2934203:0crwdne2934203:0
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - crwdns2934203:0crwdne2934203:0
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - crwdns2934203:0crwdne2934203:0
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - crwdns2934203:0crwdne2934203:0
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - crwdns2934203:0crwdne2934203:0
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - crwdns2934203:0crwdne2934203:0
  9. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - crwdns2934203:0crwdne2934203:0
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - crwdns2934203:0crwdne2934203:0
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - crwdns2934203:0crwdne2934203:0
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - crwdns2934203:0crwdne2934203:0
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - crwdns2934203:0crwdne2934203:0
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - crwdns2934203:0crwdne2934203:0
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - crwdns2934203:0crwdne2934203:0
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - crwdns2934203:0crwdne2934203:0
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - crwdns2934203:0crwdne2934203:0
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - crwdns2934203:0crwdne2934203:0
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - crwdns2934203:0crwdne2934203:0
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - crwdns2934203:0crwdne2934203:0
  10. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - crwdns2934203:0crwdne2934203:0
  11. iPhone 7 Plus LCD and Digitizer Replacement, Screen information: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - crwdns2934203:0crwdne2934203:0
  12. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    No pick in the kit you sent me.
    Ted Cooper - crwdns2934203:0crwdne2934203:0
  13. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - crwdns2934203:0crwdne2934203:0
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - crwdns2934203:0crwdne2934203:0
  15. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    I had trouble sliding down the display and found I hadn't separated the stop enough.
    Jeffrey Anderson - crwdns2934203:0crwdne2934203:0
    When you are pulling the display downward, be very careful! I pulled a little too hard and the display cables tore from the downward (toward home button) motion. Now I have to replace the display! 😭
    So Munch Love - crwdns2934203:0crwdne2934203:0
  16. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - crwdns2934203:0crwdne2934203:0
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - crwdns2934203:0crwdne2934203:0
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - crwdns2934203:0crwdne2934203:0
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - crwdns2934203:0crwdne2934203:0
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  17. iPhone 7 Plus LCD and Digitizer Replacement, Battery Disconnection: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - crwdns2934203:0crwdne2934203:0
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - crwdns2934203:0crwdne2934203:0
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - crwdns2934203:0crwdne2934203:0
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - crwdns2934203:0crwdne2934203:0
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - crwdns2934203:0crwdne2934203:0
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - crwdns2934203:0crwdne2934203:0
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - crwdns2934203:0crwdne2934203:0
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - crwdns2934203:0crwdne2934203:0
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - crwdns2934203:0crwdne2934203:0
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - crwdns2934203:0crwdne2934203:0
    I was having a hard time removing one of the screws before I discovered the tip of the screw driver that comes with my replacement battery had already deformed. However after I switched to a better screw driver the screw came off easily. Make sure the tip is in good condition, and avoid those cheap drivers if possible.
    aquila_zyy - crwdns2934203:0crwdne2934203:0
  18. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lower display cable bracket.
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - crwdns2934203:0crwdne2934203:0
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - crwdns2934203:0crwdne2934203:0
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - crwdns2934203:0crwdne2934203:0
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
  19. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - crwdns2934203:0crwdne2934203:0
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - crwdns2934203:0crwdne2934203:0
    I slipped a small piece of paper under the flap.
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - crwdns2934203:0crwdne2934203:0
  20. iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - crwdns2934203:0crwdne2934203:0
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - crwdns2934203:0crwdne2934203:0
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - crwdns2934203:0crwdne2934203:0
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - crwdns2934203:0crwdne2934203:0
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - crwdns2934203:0crwdne2934203:0
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - crwdns2934203:0crwdne2934203:0
  21. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - crwdns2934203:0crwdne2934203:0
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - crwdns2934203:0crwdne2934203:0
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - crwdns2934203:0crwdne2934203:0
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - crwdns2934203:0crwdne2934203:0
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - crwdns2934203:0crwdne2934203:0
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - crwdns2934203:0crwdne2934203:0
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - crwdns2934203:0crwdne2934203:0
  22. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - crwdns2934203:0crwdne2934203:0
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - crwdns2934203:0crwdne2934203:0
  23. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - crwdns2934203:0crwdne2934203:0
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - crwdns2934203:0crwdne2934203:0
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - crwdns2934203:0crwdne2934203:0
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - crwdns2934203:0crwdne2934203:0
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - crwdns2934203:0crwdne2934203:0
  24. iPhone 7 Plus LCD and Digitizer Replacement, Earpiece Speaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
  25. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the earpiece speaker bracket.
  26. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
    How is this bit waterproofed on re-assembly?
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    The screen/display that I got, already included a camera/speaker. So I didn’t have to remove it.
    I finished my repair and then started to use the phone again. I noticed Facetime was not working anymore (cameras, speakers and microphone was OK). I tried a few solutions I found on the Internet but nothing seemed to work. I open the phone back up and replaced the pre-installed camera with the old one I had on the broken screen/display. Closed the phone again and now Facetime works without any issues. I just wanted to pass that along.
    Federico Montes - crwdns2934203:0crwdne2934203:0
  27. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the earpiece speaker.
    • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
    If you’re looking to continue on and replace the speaker mesh, take a look at the camera/cable replacement guide.
    iPhone 7 Plus Front Camera and Sensor Cable Replacement
    tgruetzm - crwdns2934203:0crwdne2934203:0
    I almost forgot to clean the spring contacts, thanks for reminding me.
    Maganafixes - crwdns2934203:0crwdne2934203:0
  28. iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
  29. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
    • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
  30. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
    I accidentally removed the sensor from the cable. It doesnt stick back. Anything I can do?
    Mikko - crwdns2934203:0crwdne2934203:0
  31. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
    • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
    • Pry up to separate the edge of the flex cable from the back of the display.
    prying this up is sometimes difficult. I always keep a new one on hand incase. they are not expensive. if you separate the black strip, prox sensor will not work.
    Lee Attaway - crwdns2934203:0crwdne2934203:0
    what if the black tape and the flex got seperated, is there a solution to get the earspeaker work gain? coz i tried putting the adhesive tape again behind the flex but still no luck.. what can i do?
    Mac -
    i think this just happened to me…
    william seiji marini - crwdns2934203:0crwdne2934203:0
    With this repair, you can just re-apply light heat to the front glass before removing this flex cable. The heat will transfer to the adhesive and will allow you to remove this flex cable very easily. Ensure that you have followed the previous steps so that you do not damage the ambient light filter and the proximity sensor. Always make sure that you pull very gently here as this is one of the most common damages caused to an iPhone 7 series. If the black strip sticks to the frame during removal, just make sure to put it back in it’s right place and you should have no issue; assuming you didn’t damage the flex cable. Always wear gloves. - TM
    Tyler Massey - crwdns2934203:0crwdne2934203:0
    Acabei separando o flex nesse ponto 🤦🏻 tentei colar mas não funcionou , tive que comprar outro mas quando liguei o celular não ligava mais , ficava em loop e reiniciava , alguém sabe o motivo?
    Sergio Sousa - crwdns2934203:0crwdne2934203:0
  32. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
    • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
  33. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
  34. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front camera and sensor cable assembly.
    • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
    • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
    Is there instruction on how to bend the cable?
    Steven Martinez - crwdns2934203:0crwdne2934203:0
    You really need that tape, If still no sound after placing the tape in place, then you might have damaged the flex cable. Worthy to mention, that some replacement screens come without the ambient light filter (white film seem on the screen) and without the plastic brackets for the camera and proximity sensor, which in those cases, you would have to transfer those parts to the new screen. Also in some screens, the holes for the proximity sensor are not properly done and you might end up with a non-working proximity sensor. In those cases, just remove the pain with the spugger where the proximity sensor locates (removes the black paint) and then add some black permanent marker over it to make it black. That way, it will look pristine form the outside but just thin enough for the proximity sensor to work.
    H. Alves - crwdns2934203:0crwdne2934203:0
    I had issues regarding sound after reassembling the iPhone. I initially used kapton tape. I could hear the caller but they could hear me. I checked every avenue I thought of, I recorded myself speaking which was fine so there was nothing wrong with the mic. I ended up heating the black insulator and transferring it and reseating the earpiece and flex assembly. After a couple attempts the mic was restored to normal operation.
    Paul Wilson - crwdns2934203:0crwdne2934203:0
    yeah the mic and the earpiece not working , what is the solution for this problem ?
    يوسف الريمي - crwdns2934203:0crwdne2934203:0
    Do not pull on the cable an be gentle with the heat. There is a potential that the cable, which is soldered together on this part.
    I had an issue with a costumers flex cable an the ear speaker stopped working bit the cable looked okay and I did not pull on it. So I used an soldering iron with a small tip, put some flux tape where the doubled-sided tape sits on the pads and soldered the cable back together at about 390 degrees celsius. It now works perfectly again.
    Raphael - crwdns2934203:0crwdne2934203:0
    After replacing screen, front camera doesn’t work. Replaced camera cable cable with a new cable; still no front camera. Rear camera works fine. Also, have a software “Home” button showing up. Finger Touch ID works and works as the Home button should as far as I can tell, How do I get rid of it?
    So i had the same problem that the erapiece only is not working after replacement..
    my soulotion was to reassmble all the flat out the there is a black double sided tape that need to put exactly on the back of the golden points behind the flat.
    once the tape back on those golden tips it should work properly
    aviel3019 - crwdns2934203:0crwdne2934203:0
    Another thing to be careful of is the area where the black tape sits is actually two pieces of cable that are glued together and are connected by about 15 tiny contacts.
    I must have heated the cable too much and ended up separating these two layers when prying… I put them back together but it must have not been lined up correctly as the proximity sensor and earpiece speaker did not work (the parts on the layer that came off), whereas the front camera did as that is on the same layer as the camera and was therefore intact.
    I may attempt to re align the connectors again but I feel as though a replacement flex assembly may be the more appropriate solution!
    I admit that this is my fault for overheating the component and not taking enough care, but what a weird design! Why couldn’t it have been one whole cable?
    Ed Beckett - crwdns2934203:0crwdne2934203:0
    Did the replacement flex fix this issue?
    Danielle Lewis -
    is it okay to use electric tape in that case to cover the copper pieces? i installed everthing and the front camera works and the speaker works just when i make a call it turns off.. any recommendations?
    3dvapeandsmoke - crwdns2934203:0crwdne2934203:0
    why wouldnt it come with the tape on already? Im about to put electric tape because i dont have anything else.
    Anthony Fieno - crwdns2934203:0crwdne2934203:0
    なぜiPhone7Plusのフロントカメラフレックスケーブルには裏面に金属端子のような部分があるのでしょうか?
    iPhone7やiPhone8にはこの部分がありませんが必要な役割がありますか?
    bakkas-3.30 - crwdns2934203:0crwdne2934203:0
    After replacing iPhone 7+ screen I can’t call out or answer calls everything else works cleaned contacts with alcohol wipes put it back together and same thing the time is right I even updated the os since installing the new screen but phone reboots every time a call comes in or I dial out any suggestions
    wachteldane69 - crwdns2934203:0crwdne2934203:0
  35. iPhone 7 Plus LCD and Digitizer Replacement, Home/Touch ID Sensor: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
    Why is the screw over top of the home button so difficult to get out… has anyone else experienced this..? This is twice now I've struggled to get that screw
    Brandon - crwdns2934203:0crwdne2934203:0
    The screw to the left holding the heatshield is never mentioned in this guide
    Beerbo - crwdns2934203:0crwdne2934203:0
    No reason to touch that screw unless you’re removing the shield—in which case, this step instructs you to remove it.
    Jeff Suovanen -
    The link that was mentioned takes you to the heat shield for iphone 7 plus. There’s a slight difference in the two models.
    Jason Glenn -
    To clarify: the regular/smaller iPhone 7 has no screw on the far left there. The 7 Plus does, but there’s no need to touch it unless you’re removing the large metal shield covering the back of the display. The procedure in the guide is correct.
    Jeff Suovanen -
    So I stripped the screw furthest to the left, how can i possibly remove it now? Can I just buy a new LCD shield and home bracket button and screw and will that work just fine on the new screen replacement? this stripped screw of mine is not coming out
    Bryan Ferrer - crwdns2934203:0crwdne2934203:0
    That should work, as long as you can still get the home button/sensor out without damage. For removing a stripped screw this size, I’d probably try supergluing it to the driver—or else just drill the top of the screw off and then remove the bracket, leaving the screw shaft embedded in the old display. Good luck!
    Jeff Suovanen -
    I used the same driver for all of these screws. Had to apply a lot of pressure before trying to unscrew it and it was fine.
    jessica harlow - crwdns2934203:0crwdne2934203:0
    This is wrong, the size you need is Y00 for the 1.1mm screws and Y000 for the 1.3mm one.
    Robert Clark - crwdns2934203:0crwdne2934203:0
    The heads on those screws are identical. I’ve never had any trouble using a Y000 for all of them. Use whatever works for you I guess.
    Jeff Suovanen -
    I’ve managed to strip the screw on the right hand side - not the far right, just right of the home button. Any ideas on how to get it out without glue (I don’t have any)
    Christie Ellen - crwdns2934203:0crwdne2934203:0
    My screwdriver is too big to get out the screws
    Coolinee Kerman - crwdns2934203:0crwdne2934203:0
    My eyesight isn’t what it used to be. That said, the replacement screen that arrived already had screws in the two outside positions. It took me a minute to figure this out when I was trying to install the home button. I couldn’t figure out why the screws weren’t going in. I thought the holes were filled or something… Nope. screws. Took them out and used them.. all good.
    Critter - crwdns2934203:0crwdne2934203:0
    My 7 had quite a bit of loctite holding these bad boys on. I stripped the one to the right of the home button and after using many “sentence enhancers” I was able to remove it using good tweezers and quite a bit of hand strength. I think that heating up the screws here is not an option because the cables lie underneath the plate and would probably get damaged from the amount of heat needed to loosen the loctite. Be patient here, and maybe have spare Y000 drivers because you may damage your driver getting these screws out.
    P Park - crwdns2934203:0crwdne2934203:0
    If your having trouble. I recommend you guys to buy the Y00o driver at amazon. It look golden. It works very will .
    Jonathan curz - crwdns2934203:0crwdne2934203:0
    Read instead of: “Remove the four Y000 screws”. “Remove the four Philips 00 screws”. Thats the case what occurs to me.
    Henk - crwdns2934203:0crwdne2934203:0
    Hi all, I’m really hoping someone will be able to give me a hand here, so the 1.1mm screw on top of the home button is stripped, and absolutely refuses to get out. I have tried the superglue technique mentioned and am worried it may have even glued the screw to the bracket. The only solution I can think of is to bend the home button bracket on either side of the middle screw, and use the bracket itself to remove the screw from the home button. I have ordered a new home button bracket either way, does anybody have any other ideas? Should I even attempt what I am proposing?
    Thanks in Advance.
    llamalulu42 - crwdns2934203:0crwdne2934203:0
    This worked for me take a Stanley blade and saw a grove across the screw with the edge ofcourse then heat the home button with hair dryer for a couple of minutes take the blade and press it into the groove you scored and turn it
    Paul -
    Does the ground strap go over or under bracket?
    Marcos Polos - crwdns2934203:0crwdne2934203:0
    over the bracket
    David Proudman -
    my home button does not work anymore! do you know why?
    josé - crwdns2934203:0crwdne2934203:0
    I magically used an X-acto knife tip to lift the edges of the home button screw to loosen it, and then turned it slightly with the X-acto blade tip in the screw slot to get it started, then the 000 screwdriver could finish it.
    Jim Pflasterer - crwdns2934203:0crwdne2934203:0
    I can’t stress how important it is to not overtighten the one on the button. I undertightened the center one at first in fear, and then tightened it more when I realized the button was loose. It ended up ruining the home button :(
    Brendon Parker - crwdns2934203:0crwdne2934203:0
    I was completely unable to get the screw directly over the homebutton off. I definitely stripped it some. Here’s some tips!
    1. If you are trying to unscrew and it skips instead of locking in—STOP. Apply more pressure, and then try again. Keep doing this until it comes out. If you continue turning without doing anything, you’ll strip the head of the screw and end up in a way worse situation.
    2. If your screw is stripped, first try putting a rubber band between the screwdriver and the screw to fill the gap. Duct tape has worked for many people as well.
    3. If you can’t get the screw directly above the home button off of the home button, I found this video that shows how to remove the home button without unscrewing the screw!! Bend the protective plate up 90° on both sides of the home button so the bent plate now fits through the home button hole. Then you can continue to
    the next steps and remove the home button with the plate still attached to it.
    https://www.youtube.com/watch?v=DTCQA-jn...
    silas - crwdns2934203:0crwdne2934203:0
    Don’t know if I did something wrong, but the home button no longer works. I’ll see if I can get someone to repair it.
    David Proudman - crwdns2934203:0crwdne2934203:0
    Found a software workaround, go to General > Accessibility > Assistive Touch. Now you don’t need the home button to work to use the phone
    David Proudman -
    I enabled assistive touch before making a go on this part. Screws are very small, easy to strip, and difficult to find if they go flying when you;re just trying to seat them properly.
    jack jones - crwdns2934203:0crwdne2934203:0
    VERY SMART!! I would not have thought of doing that. Depending on what my local repair guy charges I may be doing this myself, but in all honestly if the home button does not work on the new screen I'm getting another phone
    FallenAnjel -
    I’ve never been so stressed at trying to assemble something, O_O I should really get some glasses. I just reassembled all the screws, tried to not screw too tight, but how does one know? Maybe they could include “only twist 3 times, or 2…and maybe provide an ocular. Those screws are very very very tiny, and yes - be careful, because if you attach the right screw first, the left one can be catapulted if not secured and just “set” waiting to screw in. Thankful for the magnetism, but also had to find myself holding the screw in place while securing or else it would just attach to the screwdriver and come out. I'm TOTALLY looking forward to turning this ON after all assembled based on all the disheartened comments…..oy. Here. We. Go.
    Nicole Crome - crwdns2934203:0crwdne2934203:0
    There’s a small square rubber piece that has a screw hole in it. does anyone know if it goes over the home button? I missed it when I took it apart, but then , there it is on my table.
    MajorCouillon - crwdns2934203:0crwdne2934203:0
    It slips over one of the posts that the pentalobe screws in step 1 go through. Like a mitten over a hand. It’s incredibly hard to see where the slit is in that tiny rubber piece though.
    Jared Cook -
    What do you do if you overtighten the screws? I assume that is why my home button won't click
    Andrew Targett - crwdns2934203:0crwdne2934203:0
    How can you tell if you’ve over-tightened the screws or if the home button isn’t working for some other reason (other physical damage, shorted out, etc.)?
    Jared Cook - crwdns2934203:0crwdne2934203:0
    Die Schraube auf dem Home-Button ist wohl von Apple gewollt schwer zu entfernen. Man sollte sie daher zuerst herausdrehen; denn, ist die Unterlage unterm iPhone nicht hart genug und man drückt jetzt mit Kraft über den Schraubendreher auf die Schraube, wird der Home-Button hinausgedrückt, dabei verbiegt sich die Halterung und besonders schlimm, das eine untere Flachbandkabel reißt ab und der Home-Button ist unbrauchbar.
    Hartmut Kruse - crwdns2934203:0crwdne2934203:0
    So from those that do many repairs what do you think is the percentage of repairs in which the home button doesn't work after moving it to a new screen? 10%? 30%? 70%?
    FallenAnjel - crwdns2934203:0crwdne2934203:0
  36. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket that secures the home/Touch ID sensor.
  37. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Well, I just damaged the home button connector in step 31. It is completely off the cable. What now? Can I buy this home button?
    I think you can not do it because your phone is not identify for new cable.
    Ali Alsaed - crwdns2934203:0crwdne2934203:0
    Best thing to do here is to NOT pry up on the connector, but to insert the pry tool on the left side until the connector is dislodged.
    Oscar Moreno - crwdns2934203:0crwdne2934203:0
    Good tip. Worked perfectly. Thx.
    Klaus M -
    That worked perfectly, thank you!
    Emily Kretschmer -
    use one pry tool to hold down, another to pull up.
    Christa - crwdns2934203:0crwdne2934203:0
    Anyone having difficulty reconnecting the two ? I’ve been trying for ages with no luck.
    Patrick McKenna - crwdns2934203:0crwdne2934203:0
    Same problem here - can reconnect them once the new LCD is being installed. Not sure what the trick is.
    edcraigslistaccount -
    Yes I had to fiddle with it for about 20mins to get it to finally click in place, just don’t apply too much pressure it doesn’t take much, if the alignment of the connector is right you should feel it snap into place. connect the cables together before you screw it in place, also raise the assembly up off the small locator pin until after you get the connectors together. Hope this helps
    Callum Cross -
    my Homebutton don´t work after I reconnect all, I checked all flex cables but it still dont work. what can I do?
    Dr. Dieter - crwdns2934203:0crwdne2934203:0
    so, i’m working on an iPhone 7. I was very careful not to break anything, I even bought an iOpener heat pack and applied it, and everything went off without a hitch, but when I tested the button, It does not work, would it help to reconnect it or something?
    Thanks a lot!
    Peter Keller - crwdns2934203:0crwdne2934203:0
    iPhone 7 home “buttons” can be really fussy. You’ll find some good troubleshooting tips here and here. Hope this helps!
    Jeff Suovanen -
    Broke my cable. The picture is not clear but you have to separate the thin silver end of cable from what looks like a black piece of rubber. I pulled up on it from under the black rubber like the picture shows and broke mine.
    bart.hutchings - crwdns2934203:0crwdne2934203:0
    This helped me SO much. Watch it before removing home button. Around 4:56ish
    https://youtu.be/An9kUJshRjA
    Gina Torres - crwdns2934203:0crwdne2934203:0
    Thank you so much!
    Jakob Kloppenborg -
    That’s a very good view. Thank you!
    johanbogg -
    Yup, this video helped me know what people were talking about. It worked and I didn’t rip or break anything…so far XD
    Christopher Villavicencio -
    Well, I just damaged the home button connector in step 21. It is completely off the cable. What now? Can I buy this connector ?
    dima shynin - crwdns2934203:0crwdne2934203:0
    I’m having a really hard time reconnecting the two together. Any advice?
    Ben Carter - crwdns2934203:0crwdne2934203:0
    I used the tweezers in step 21 to separate this connector. I squeezed the tweezers shut then put the flat edge of the points between the connector and slowly released the tweezers. The connector separated really easy.
    sschaffer - crwdns2934203:0crwdne2934203:0
    This tip worked a treat. Thanks!
    Admin4CBowra -
    any tips on reconnecting the connector. I assume it needs to be snuggly fit back in. I can’t seem to connect the two agin. Is it supposed to ‘snap’ together or should I use an adhesive?
    rwalz - crwdns2934203:0crwdne2934203:0
    Figured it out. I just needed to make sure I aligned them better when feeding the home button backthrough
    rwalz -
    勢い余ってケーブルを
    ブッちぎってしまいました(>_<)
    MARU - crwdns2934203:0crwdne2934203:0
    Hi, After fixing Iphone 7 Plus screen, my touch sensor is not working, What is the alternative .. Please help me . Thanks
    kalyan c - crwdns2934203:0crwdne2934203:0
    I found it quite difficult to reconnect the home button cable connector. After putting everything back together, my iPhone said there was an error with the TouchID. I disassembled the phone again, pried off the home button connector and found that I had not lined it up properly with the mated part. I had to push the connector upwards (toward the top of the phone) in order for it to seat properly. It almost felt unnatural to push the connector so far up to make it seat properly. I tested the phone again before reassembling and everything worked fine. If you break the cable on this home button piece, you can only buy a generic home button (about $8 here on Amazon) that will allow you to use the button for navigation but it will not work for TouchID (you will have to use your phone permanently unlocked or use a numeric code to unlock). The original home button is specifically mapped to your phone and cannot be replaced.
    awillimd - crwdns2934203:0crwdne2934203:0
    Yeah, I couldn't snap it back together either and after giving up a few times, probably the third time I came back to it, about the 10th time trying to line it up, the cable just totally snapped off....
    nlr_fairygirl - crwdns2934203:0crwdne2934203:0
  38. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
    Make sure that you fold this cable out when fitting your replacement before you fasten the shield back down. I didn’t but managed to loosen 2 screws on the shield to get the cable out.
    chris_sawyer - crwdns2934203:0crwdne2934203:0
    If you have isopropyl alcohol on hand. You can use it to help weaken the adhesive temporarily when lifting up the adhered home button.
    Ben - crwdns2934203:0crwdne2934203:0
    Just one tiny drop of isopropyl alcohol or it will reach the lcd screen.
    Stefano Restuccia -
    Heat is absolutely vital during this step. Care should be taken and you should work very slowly. A new playing card will be useful in separating the ribbon from the device, using heat periodically to soften the adhesive as you go along. The ribbon cable changes size between the connector and the button, creating a weak area that can begin to rip if stressed. Use a card flat against the frame to slowly separate the cable from the frame.
    The isopropyl alcohol did the trick for me; all it takes is for you to dip the prying tool in a bit of the alcohol and the rest is magic. I did not have to apply heat and I was able to remove the home button from the original screen to transfer it to the new screen without any issue! Be careful, go slow, don't force things, and when it doubt view and review the video and instructions!
    Lemuel Gonzalez - crwdns2934203:0crwdne2934203:0
    Alcohol or Ifixit adhesive remover is the trick. I used the tweezers to dip in the remover and just a smidgen is all you need, start on the connecter side and work towards the button. - On reassembly, I kept the screen protector on and just peeled it up enough to slide the button in, then used it to hold the button in place while I finished up.
    William Riggles - crwdns2934203:0crwdne2934203:0
  39. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    If you don’t have that heating tool, a hair straightener n a T-shirt worked just fine for me
    www.tertlegerl - crwdns2934203:0crwdne2934203:0
    A hair dryer works well too. 2mins is all you need
    Mr Tegs - crwdns2934203:0crwdne2934203:0
    I did with a heat gun instead. I found the i opener not helpful.
    David Gordon - crwdns2934203:0crwdne2934203:0
    I need just 1 min with my hair drier, then the screen starts to pop and crackle
    Andrew Sims - crwdns2934203:0crwdne2934203:0
  40. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
    It cannot be stressed enough that this is the one part of this repair that you can’t screw up. Anything else you’ll deal with during this repair can be easily replaced (The screen, and the sensor/microphone/camera assembly). Tearing this cable means an expensive trip to the apple store. or a very unhappy customer if you’re doing this for someone. Heat is your friend. I don’t even use a spudger or a guitar pick for this one, I use a new playing card to pull this up. Even with the card, you have to be careful. The edge of the playing card can nick the cable if you’re not careful to get it under the ribbon cable. If the adhesive isn’t soft enough for the card to get it up, apply more heat. Again, you can’t screw this step up. It’s all or nothing.
    Spartan99 - crwdns2934203:0crwdne2934203:0
    Thanks for the tip! worked great!
    Isaac Ham -
    Do you know what I need to do if I damage the cable?
    Hey hermano -
    Yes playing card is what I used too, worked very well. Just heat it up(I used a 3D printer bed for 30 seconds at 80°). Just go slow from right to left.
    cheap parts -
    Well, no visible damage but the home button won’t work. I contacted a local Apple Authorized Service Center to check options. Since I had personally replaced the screen assembly, they wouldn’t even look at it per Apple policy. They said they would jeopardize their Apple Authorization if they even looked at it. Seems like more of the “Right to Repair” problem to me. Frustrated, but at least I have the accesibility home button working.
    bandman - crwdns2934203:0crwdne2934203:0
    Make sure the home button screws aren’t overtightened; that often causes issues. If there’s any damage to the button cable, a repair shop with a skilled microsolderer can patch a new cable on and restore functionality. iPhone 7 home button not working after screen replacement? Worst case scenario, you can also buy a screen repair from Apple, and they’ll include a new home button. I am not a lawyer, but the response you’re describing from the AASP sounds way out of bounds. Good luck!
    Jeff Suovanen -
    I don’t know why this step does not include a major warning about it being by far the most challanging step. I started before reading the comments and most likely screwed my home button with it,
    I don’t know if it is a broken cable or if it was too much heat later…but I scratched the cable on the first try with the plectrum. It took lots of heat to soften the adhesive and then it worked WAY better for me to start removing the connector from the near side of the home button. And not, as shown, on the far side.
    Wish I had known that before - the homebutton ist not working anymore now (and it’s not the screws).
    Robert -
    Just keep in mind that this is a very delicate step that requires a lot of patience. the part is attached to the body of the phone so firmly and there is no gap to put the opening pick under. So the way I did it was applying a good amount of heat onto the part and not from behind. I did it constantly for 5 minutes, a few minutes at a time, then I pulled the connected up slightly (a little too much pressure on the pull and you will break the wire). Pull it constantly and If the heat has been enough to melt the adhesive, it should come off easily and slowly.
    ashkan eslami fard - crwdns2934203:0crwdne2934203:0
    Hi, a little thing to help : i heatened up and then insert a cutter blade to start. Work better
    Crasset Renaud - crwdns2934203:0crwdne2934203:0
    Okay the home button is connected, as touch id works, but I can’t get any motion out of it. I backed off the screws, but that didn’t help. What else can I try?
    kathwick2 - crwdns2934203:0crwdne2934203:0
    The home button on an iPhone 7 Plus doesn’t move at all. Anything you feel during normal operation is a small vibration from the Taptic Engine that tricks your brain into thinking the button is moving.
    markpetereit -
    Salve, vorrei un vostro aiuto, ho un problema con il tasto home (il tasto è originale preso dal vecchio display rotto) una volta sostituito il Touch ID funziona perfettamente (l’iPhone si sblocca e legge l’impronta digitale) il tasto invece no (il click per intenderci) cosa può essere? Grazie!
    bernabbo - crwdns2934203:0crwdne2934203:0
    I had to use the iOpener tool twice before the adhesive was soft enough to remove the cable with the pick.
    How do I get the home button out? I got the ribbon up.. just not sure how the button comes out
    Ash - crwdns2934203:0crwdne2934203:0
    Hi, i replaced the screen and home button, the home button was a bit difficult. When i turn on the Phone, touch id works fine but not home button function. Any idea ?
    Jim - crwdns2934203:0crwdne2934203:0
    More precisely, i was wondering if the home button could not work while touch idea does…
    Jim -
    Wow…I did a lot of praying during this step.
    tomnape - crwdns2934203:0crwdne2934203:0
    This was a very difficult step… I found using heat wasn't removing the adhesive for my home button. Found a video online that recommended using a playing card and a tiny bit of rubbing alcohol on the corner and slowly sliding it under. I was able to finally remove my home button using this tip.
    ryan pouliot - crwdns2934203:0crwdne2934203:0
    Heat via hairdryer applied for a solid 3 minutes worked for me.
    natjpollard - crwdns2934203:0crwdne2934203:0
    Thank the stars that I looked at these comments. I managed to do this and transferred the home button successfully. The pick is not good enough to do this job. The suggestion to use a new playing card helped. I also found that if you use a single edged razor to ply apart the bezel from the screen then when you apply heat with the heat gun the bezel will melt and bend a bit out of shape allowing you to use the playing card to lift the home button strip away from the bezel. The adhesive on the old home button strip was enough to stick it to the new screen bezel without having to buy new adhesive.
    Thanks for the tip on the new playing card and rubbing some isopropyl alcohol on the corner of the card! I also peeled back the metal plate on the broken screen to get that bracket out of the way for better access to the cable. After applying heat and slowly and steadily working up the cable with the card, the home button popped out in proper working order.
    Nick Nave - crwdns2934203:0crwdne2934203:0
    Given that the old screen was already broken. I cut away the part of the screen where the button is, this gave easy access to the side of the ribbon cable which made it simple to gently pry it up and separate it from the plastic case.
    Charles Hope-Lang - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. All tips about direct heat, new playing card, bending back the metal bracket on the broken screen, screen protector to hold the replaced home button in place … perfect. Slow and patient, heat and almost no pressurel! Thank you all!
    dantegd - crwdns2934203:0crwdne2934203:0
    I wish I have read the comments first. Was not patient enough and despite applying heat for several minutes I used force with the thin pick and "successfully" cut away the connector 😔 Can't stress enough I should have been patient and do slowly... even without reading the good advice above!
    vabogie - crwdns2934203:0crwdne2934203:0
  41. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
    True to this picture, the home button can only be removed (and put back in place) through the front of the LCD assembly.
    OHMYGOD! Thank. you for this! After ruining *three* displays while inserting the home button from the back, I finally saw this comment…
    In my defense I had no internet access through some of these replacements… but really, I’m sorry to say, this merits a MAJOR warning on the guide.
    Cam F -
    Very good comment Talon. That was the first thing I was looking for here. There should be a bullet point in step 24 - Carefully remove home button from front of display being careful not to damage cable.
    Tracey - crwdns2934203:0crwdne2934203:0
    Had an issue when putting the screen back on, the side where the cables attach would not sit flush. At first I thought the cables were pushing the screen up. Turned out to be the battery cable shield was just a fraction too far down toward home button. After loosening screws, nudging it up slightly and screwing back in, the screen sat flush as it should. In case anyone else has same issue.
    jbarry - crwdns2934203:0crwdne2934203:0
    Is there anything special about reassembling the "home" button ?
    I tried several times with several buttons but none works.
    Lambiel - crwdns2934203:0crwdne2934203:0
    must use original button
    Christa -
    My phone is no more turning on after I replace the screen, no reaction if I press home button or power button
    cheryl.iseli - crwdns2934203:0crwdne2934203:0
    Why doesn’t this tutorial also cover the earpiece assembly?
    James - crwdns2934203:0crwdne2934203:0
    This guide is missing the camera transfer and the stupid little black sticker on the earpiece assembly that causes the earpiece not to work if that sticker is not transferred. This guide is wholly incomplete
    Mason Schild - crwdns2934203:0crwdne2934203:0
    This guide is meant for the ifixit parts, not other third-party screens.
    Ben Carter -
    Since I bought the replacement screen from iFixit and it has NO camera and speaker part anymore, the replacement of those parts should also be in this guide.
    And, the replacement of those parts (camera, speaker, true light sensor, and aprox. sensor) is the most difficult!
    Hannes -
    James and @computermason—You’ll want to look up the correct guide for your repair, especially if you’re not using one of the kits for which this guide is designed. The guide for transferring all the smaller components is here.
    Jeff Suovanen - crwdns2934203:0crwdne2934203:0
    No home button functionality? I just watched a video on YouTube from two years ago saying that the iPhone 7 and 7+ have to be taken to an Apple repair center for the home button to work. Is this still the case? If so why didn’t you tell me this before I ordered this! Please confirm before I start warning everyone not to purchase from you!
    Gregory Haycock - crwdns2934203:0crwdne2934203:0
    @ghaycock If you’re replacing a screen, the home button will work fine as long as you carefully remove it from the old screen and transfer it to the new one, exactly as explained in the guide. The button itself can’t be replaced without help from Apple (which is why iFixit doesn’t sell home buttons for this model).
    Jeff Suovanen -
    @jeffsuovanen If you’re replacing a screen, the home button will work fine as long as you carefully remove it from the old screen and transfer it to the new one, exactly as explained in the guide. The button itself can’t be replaced without help from Apple (which is why iFixit doesn’t sell home buttons for this model).
    Jeff Suovanen - 06/11/2019
    Jeff Suoven-I bought a new home button from Ifixit for this phone (along with a digitizer assembly) and it doesn’t work.
    Jeff Steffens -
    One thing I don’t see mentioned is the replacement of the rubber gaskets that are on the pentalobe holes. The replacement screen did not come with these on it. I was able to remove them from the OEM screen, but there was no easy way to get them to adhere to the new screen. If they move just a little, you might not be able to properly thread the pentalobe screws. Worst case is that they fall into the body of the phone during this last step of re-assembly. At that point, you’ve already started to have the screen stuck to the adhesive, so you would need to redo the entire adhesive gasket.
    You can see the gaskets in this picture: https://d3nevzfk7ii3be.cloudfront.net/ig...
    Here they are near the new screen: https://drive.google.com/open?id=14FwpSB...
    Andre LeBlanc - crwdns2934203:0crwdne2934203:0
    Thank you! I was wondering what those things did, and even lost one but later was lucky enough to find it.
    Ben Carter -
    I saw one mention about those small gaskets in a guide and now I cannot find it. I was able to slip them off the old screen and onto the new one. I would think this is an important step to help seal those holes for the waterproofing. They should edit these screen replacement guides to include this step. Thanks for mentioning it in this guide.
    sschaffer -
    If your home button doesn’t work after transferring to the new screen you might have a faulty screen. I spent a lot of time chasing all the suggestions here, but eventually resolved the issue by installing a replacement screen.
    nigel - crwdns2934203:0crwdne2934203:0
    WARNING: When you reassemble the phone, the little screws… You have to be VERY careful to not put any pressure on them until they’re really well seated, otherwise you will flick the screws into another dimension… they’re so small they literally just vanish out of existence lol. I ended up losing two of the smallest screws, one per bracket, and everything seems fine so far.
    The glue/seal is also nearly impossible to get right. Just mash it down into the general area that it belongs if it gets stretched/twisted and can’t go in perfectly. Some glue is better than no glue, just assume that any repaired iPhone isn’t water resistant at all.
    Nicholas Tenney - crwdns2934203:0crwdne2934203:0
    The biggest issue I'm having now Is replacing the gasket that goes around the home button. The original one got stretched out and the new on is too thick to seat correctly into the hole without being exposed and potentially coming off of the home button after a while.
    Eric R Deshields - crwdns2934203:0crwdne2934203:0
    I ordered a replacement screen from ifixit, but contrary to the description it arrived without the ancillary parts attached. So I had to transfer the front camera & sensor assembly, and the lcd shield. In case anyone else needs to do this, be sure when transferring the lcd shield that the screen cable sits properly underneath it (ie as far up towards the top of the screen as possible) or else the rectangular block on the cable will foul the loudspeaker.
    If this happens, the bottom right corner of the screen will stand very slightly proud of the case, and you will end up with a pressure spot on the screen.
    See Pressure spot on iPhone after screen replacement..
    Neil Wilson - crwdns2934203:0crwdne2934203:0
    Well I transferred all the parts properly, but the front camera wasn’t working. Reseating it fixed the camera but then when I closed the screen it cracked. I backed out to the old screen which is held together by tape, but miraculously everything including the camera and Touch ID is fine. Better luck next time.
    I did not realize that the much cheaper 3rd party replacement I purchased also required the further steps of removing and replacing front facing camera and speaker. I was pretty bummed initially as it looked intense…however i totally pushed through using another ifixit guide and saved $50. My only advice to a first timer would be get a $15 heat gun or the bean bag microwave thing, the hardest part is getting it open.
    Cramps Delight - crwdns2934203:0crwdne2934203:0
    The cable is more than fragile and immediately broke right off my phone! Mine is no good anymore, but I wanted to warn everyone else just one more time…BE SO SUPER GENTLE and PATIENT…and even then, I’m not totally convinced that it is possible!! I was doing so well, right up to the point when I got to the one part that only Apple can fix and that will totally ruin your repair!!! SHAT!!!
    Good Luck all!!!
    jenn ross - crwdns2934203:0crwdne2934203:0
    I don't understand whether I need to glue the ribbon back down on the new screen. I have not been sent any adhesive for it. The guide mentions replacing adhesive for the screen, but do you mean the home button ribbon itself? If so, what should I use?
    charlie B - crwdns2934203:0crwdne2934203:0
    I can’t get the home button to stay in place when reataching it to the phone. Anyone know what I’m doing wrong?
    johanbogg - crwdns2934203:0crwdne2934203:0
    The ribbon in steps 16 and 17, when reconnecting and sealing the phone, is really something to be careful with. I feel like I smooshed it in, and while the phone works after the replacement, I feel like the right side of the phone, near the power button, isn’t quite set in 100 properly. I wish I would have taken better note of how it looked prior to removing the broken screen. Hopefully, it will settle in better once the adhesive sets. At this point, however, the fact that I got through the process with what I would call 99% success is a win for me. Just be careful of the aforementioned ribbon when setting the new screen on.
    Mike K - crwdns2934203:0crwdne2934203:0
    So I put the home button onto my new screen and the touch ID works however, when you press down on the button to return home for example, it doesn’t work. Any ideas what might be causing this? I made sure not to tighten the screws too much when reinstalling.
    Hayden - crwdns2934203:0crwdne2934203:0
    The home bottom sensor cable does not plugin into the new screen, if put it back to old screen it plugin nicely and directly , but on the new screen it does not stay, it does not plug in the new screen, what to do?
    mohamed elzaiady - crwdns2934203:0crwdne2934203:0
    The comments suggest the home button is well stuck down.
    Does the home button need adhesive to stick it back onto the new screen? If so, what do you use/where do you get it?
    Thanks
    Andrew Murtha - crwdns2934203:0crwdne2934203:0
    Very disappointed. Front camera and home button not working. And overheating too. I would like a refund Ifixit.
    Xavi Rojas - crwdns2934203:0crwdne2934203:0
    Esta incompleto, falta el desmontaje de los elementos de la parte superior de la pantalla
    Alfredo Alvarez - crwdns2934203:0crwdne2934203:0
    Did this back in 2021 after using i fix it tutorial on replacing battery i accidentally cracked screen when trying to pry it up with suction device and using spudger which felt wasn’t best tool for the job.
    Maybe i didn’t heat up device enough to loosen adhesive enough, who knows it was the first time doing this.
    Screen alone much easier than a battery replacement, especially second time around after cracking screen had more awareness of job.
    They make good tutorials here always like fixing thins myself then paying more to have someone else do it.
    DJSan - crwdns2934203:0crwdne2934203:0
  42. iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the upper, rectangular portion of the LCD shield plate sticker to separate it from the flex cable underneath.
    • You don't need to remove the sticker completely unless you intend to replace it.
  43. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Y000 driver to remove three 1.1 mm screws from one side of the display EMI shield.
    • If you have trouble loosening these screws, press the driver harder onto the screw as you turn it. If necessary, use the flat edge of your spudger to brace each display clip from behind so you can apply more pressure to the screws, without bending the clips.
    glad apple pre-stripped these for me
    Tade Mutrie - crwdns2934203:0crwdne2934203:0
  44. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Y000 driver to remove two more 1.1 mm screws from the other side of the EMI shield.
    I wonder why this part is separated from step 38. You’re doing the same thing on 38 and 39.
    Yusuke Tsuji - crwdns2934203:0crwdne2934203:0
  45. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1.8 mm Phillips screw securing the EMI shield near the bottom of the display.
  46. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the LCD shield plate while pressing down on the flex cable it surrounds.
    • Feed the flex cable through the cutout in the LCD shield plate, being careful not to snag it.
    What if the black rectangle part that goes around the little silver rectangul is broken
    Brittany Jackson - crwdns2934203:0crwdne2934203:0
    I broke one. It just would not go back around the part, so I just put it around what I could and the phone worked fine. I’m replacing the panel on another one right now that someone else had already replaced, (the girl broke her screen again) and the little black part was just laid on top of the silver part and it worked fine. Don’t have a clue why that little black rectangle is even there. It doesn’t appear to be needed.
  47. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD shield plate.
  48. iPhone 7 Plus LCD and Digitizer Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the LCD and digitizer remains.
    I finished and my phone was like new but then I removed the glass from the old lcd and put that in by itself into the the phone and didn’t work so I put my replacement screen back in and now it doesn’t work and the connector smells
    John - crwdns2934203:0crwdne2934203:0
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
crwdns2935229:0197crwdne2935229:0
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
440.605 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2935297:019.768crwdne2935297:0
crwdns2947412:018crwdne2947412:0
Step 14 Pic# 3 the second cable damaged , what can i do ?!
Ameed Bader - crwdns2934203:0crwdne2934203:0
If you damaged only the cable and nothing else, replacing the display should solve the problem—it will come with new cables attached.
Jeff Suovanen -
For anyone performing hardware exchanges, there is a free app on Apple store called Dr. Phone that can be used to test the several hardware components… Nice to do before closing it up..
Has anyone else had trouble getting the Y000 screws out from the bracket over the home/Touch ID sensor? All other Y000 came out no problem. These are fighting me. The driver seems to be spinning in place as if too big. Follow up question. If I strip these screws, any idea how to get them out then?
jferguson757 - crwdns2934203:0crwdne2934203:0
In my situation the Y screw behind the Home/Fingerprint Button seems to be GLUED ON by design to prevent inexperienced non-certified Apple replacers to remove it. So what I did was left it on to prevent stripping the screw and breaking the button. I just CAREFULLY BENT the metal bracket AT AN ANGLE so that I can maneuver the whole assembly into the hole of the screen and remove it.
Eric Vengeance -
I'm having the same issue. I stripped out the home button screw help please!
Chris Ellis - crwdns2934203:0crwdne2934203:0
Step 16 remember to not put the cable back upside down -.-
onikristy - crwdns2934203:0crwdne2934203:0
Excellent guide. Thank you very very much.
roycomp10 - crwdns2934203:0crwdne2934203:0
i changed the screen and iphone 7 plus is not working at all… central button is making crazy noises (bumpings) when i touch it. any help plz?
la la - crwdns2934203:0crwdne2934203:0
Usually my replacements go great, but I’m not having any luck this time and I think I may have damaged a connector. I’ve attached the new screen, but it doesn’t turn on. I tried attaching the old and it no longer lights up. If I call the phone, it vibrates, so I know it is working. I also noticed that pressing the power button when it is vibrating from a call does not silence it. So I don’t think that button is working either…
Has anyone else run in to this issue?
Christopher - crwdns2934203:0crwdne2934203:0
Sounds a lot like a blown backlight circuit. Usually when this happens, it’s because the battery wasn’t disconnected properly when removing or installing the display connectors. You can confirm by shining a bright light on the display when the phone is switched on—if you see a faint image, that’s a backlight failure. This is a common issue, and perfectly fixable, but requires board-level repair skills and equipment (read: not a DIY). Good luck!
Jeff Suovanen -
Many Thanksgiving Jeff.
Your guide is fantastic.
You have had on mind all the details.
Contratulations for this guide.
jaimero - crwdns2934203:0crwdne2934203:0
Phew! That was tricky. Had some trouble getting the tri-lobe screws out of the Touch ID assembly - they were done up real tight. Swapping it over and reinstalling in the new digitiser was a breeze.
I assembled the phone (without adhesive) first to test everything. Touch ID, camera and speaker all leapt into life, but the proximity sensor didn’t seem to work. I took the phone apart and dismantled the camera/speaker/proximity sensor assembly, cleaned the contacts, replaced the double-sided insulating tape, and reassembled it. This time I managed to seat the proximity sensor with a positive click, then everything went together easily. I trusted that this had fixed it and went ahead with adhesive installation before finally reattaching the front panel.
Thanks to the author, plus several useful comments, my iPhone 7+ is now fully operational again!
meadowend - crwdns2934203:0crwdne2934203:0
After doing this repair, the new screen has problems with the response to tapping icons, and sliding for shutting down the telephone. I kitnd of have a lack in responsitivity, if it responds at all.
Any suggestions to the reason for this or for a way to fix it? The screen and LDC was bought at iFixit.
Carsten Heegaard - crwdns2934203:0crwdne2934203:0
Check the connectors in this step. Make sure they’re clean and fully seated. If you still have problems, follow the troubleshooting wiki or contact Customer Service. Good luck!
Jeff Suovanen -
Procedure works well and is easy to follow. Thank you.
Americo Garcia Jr - crwdns2934203:0crwdne2934203:0
The app is Dr Fone not phone in case someone needs to find the app
Tyler Dearden - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 81
crwdns2936753:030crwdne2936753:0 431
crwdns2942667:0crwdne2942667:0 204,594
