Use this guide to bring life back to your iPhone 7 Plus with a new battery. If your battery is swollen, take appropriate precautions.
This guide instructs you to completely detach the display assembly; this is intended to prevent damage to the display cables. If you feel comfortable removing the battery without putting undue strain on the display cables, you can skip the steps for disconnecting the display.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2936621:0crwdne2936621:0
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
crwdns2935267:0crwdne2935267:0Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
No hair dryer so GENTLY heated over stove burner
Hello,
What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
I used a heated tea kettle and a tea towel, it worked!
I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
I attached it to the after burner of my rocket ship and that worked.
I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
Hairdryer works fine for this step. No issues.
The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
. . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
Apply a suction cup to the lower half of the front panel, just above the home button.
Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
Get a suction cup pliers. It’ll make this part fun
iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
- For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
- Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
After struggling for 30m, I looked up some alternate methods and found this helpful:
https://www.youtube.com/watch?v=25zAK5mG...
- I used a utility knife and pried up right under the home button
- the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
- tilt utility knife left to right once you’ve got it under to work it in
- leave the utility knife in, and now add that pick
Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
Suction cup pliers. Dead easy
After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
Stop near the top left corner of the display.
My Plektrum worked ok, but the edges broke off a bit towards the end
I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
Gently pull up on the suction cup to lift up the bottom edge of the display.
Pull on the small nub on the suction cup to remove it from the front panel.
Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Nach RECHTS klappen - nicht nach links!
Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
“Up from the left” means lift up the left side.
Which is the same as folding to the right.
“Like the back cover of a book” explains it even more clearly.
Maybe it gets lost in translation?
Fold to THE RIGHT - not to the left!
When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
Three 1.2 mm screws
One 2.6 mm screw
Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
Mark -
The tri wing screws are so hard to remove. What's the trick?
At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
@katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
what do i do if one of the screws dont want to come off
Remove the lower display cable bracket.
I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
Use the point of a spudger to lift the battery connector out of its socket on the logic board.
You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
I slipped a small piece of paper under the flap.
After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
What can happen if the battery is not disconnected before the two lower display connectors?
Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
ibisiki -
Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
One 1.3 mm screw
Two 1.0 mm screws
Remove the bracket.
Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
What happens if you break “tear in half” the black tape stuff?
Unfortunately if you tear the black cable you will need to replace it !!!
Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
I called the y tip a triangle tip until I read these comments. Thanks for the correction
Hello is it if I put wrong screw can damage the board?
Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
Would appreciate any advice!
Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
Disconnect the front panel sensor assembly connector from its socket on the logic board.
Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
That's save my life!thanks god!
neg -
I also made this mistake! Thank goodness it didn’t break anything.
Remove the display assembly.
When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
Hannes -
I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
Remove the following two Phillips screws securing the barometric vent to the rear case:
One 2.9 mm screw
One 2.1 mm screw
I skipped this step and go straight to step 25. I skipped it because I couldn’t get the screws to come off. But skipping those step did not prevent me or has any detrimental effects on performing step 25.
I agree, I don’t see any reason to remove the Taptic engine to remove the battery…It seems like more of a chance of screwing something else up…keep it simple…
If you’re replacing the battery, removing the Taptic Engine gives you a much better chance of removing the battery adhesive strips successfully. To keep them from snagging and breaking, you want to pull them from as low an angle as possible. With the Taptic Engine in the way, you have to pull them at almost 90 degrees, or risk snagging them on the Taptic Engine.
i can’t get the 2.1 screw 2 come out pls help anyone
I agree with Jamie Liao above. Skips steps 18-24 as described. Before proceeding with step 25, I heated a microwavable hot/cold compress (used to treat muscle strains). I set the iPhone back casing on the heated compress before pulling out the adhesive strips.
Again, there is no need to do steps 18 through 24.
i didn’t remove this and had major issues pulling the adhesive strips out. I literally couldn’t grasp them and then when i did, they broke! UGH! I was able to complete the installation but i must have done something wrong because my phone still isnt working. It just ‘flashes’ the apple logo. Won’t do anything else. Should have just taken it in for repair. Now i have to buy a new phone anyway.
Gently push the barometric vent in the direction of the Taptic Engine to separate the adhesive securing it to the bottom edge of the iPhone.
Adhesive may require a tiny amount of tugging of the barometric vent to free it…
Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
Remove the three 1.5 mm Phillips screws securing the Taptic Engine to the rear case.
what do you do if the top left screw is not coming out?
There is a little guide pin for the Taptic Engine proper seating
Peel back the three adhesive strips on the lower edge of the battery.
Use a fingernail to get one corner started, then the flat end of a spudger does a good job of getting the rest.
In your step 24 going on to step 25 you recommend peeling all three battery adhesive tabs up, and then pulling them out.
I STRONGLY RECOMMEND peeling ONE tab up at a time, and then pulling it out immediately in one action.
This prevents the pulled up, but as yet not pulled out, tabs contracting back, lost underneath the battery.
I also reccomend pulling the outer tabs first leaving the centre one until last as it's easier to hold on to a battery straight, than one which is additionally trying to rotate
Followed Peter’s advice, and the battery came out no issues. Pull up one at a time (leaving the other adhesive strips in place), and pull the adhesive strip straight out, parallel to the table you’re working on. Instead of continuing to pull one long piece (like the photo in Step 25), I’d pull some, bunch in up in my fingers,then keep pulling. This allowed for more control over the phone and this step in general.
Just as a precaution: to guide where I’d put the battery back into place (I took it out while replacing the lightning connector), I marked with a metallic sharpie the outline of where the battery was, to help me make sure I put it back exactly where the original had been.
Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
the 1.5 yr old ifixit adhesive tears super easy in comparison to dozens of 3-5 yr old originals which never tore so keep alcohol ready which loosens it up like butter in a hot pan
I broke 2 out of three of the adhesive strips doing it this way. On my third attempt I would pull a little bit of the adhesive strip out with one hand. And with the other hand use a finger to press down lightly on the adhesive strip as I was pulling it out. This pushes the strip down from the battery and frees the adhesive from it. You can feel the adhesive strip give way as you do. I did this very incrementally for what seemed like forever. I then used my tweezers to retrieve the first two adhesive strips out from under the battery ( They did not recoil too far) and repeated the same tactic as I did with the third adhesive strip. It was not too difficult to finish the job after that.
One important remark : once you start pulling out one band, do not stop/pause in the middle of removing the band (to get a call or anything). Gently pull until it’s fully out.
Repeat the previous step for the second and third strips.
If you removed all adhesive strips successfully, skip the next step.
Otherwise, if any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
Step 26 is when it’s time to remind ourselves we’re having fun! That tape material sure does stretch a lot so be mindful of your work station. I almost knocked a drink off the table. Thanks
After about a minute, gently lift the battery.
i messed up and broke the strips. I had to carefully use a blow dryer on the back of the phone to heat the strips to the point of removal. VERY careful not to let the phone get too hot. I was nervous all the time that the battery which was a bit swollen, was going to explode.
If a piece of the adhesive is left underneath the battery you can try to use some tweezers to tease it out to continue the pulling with your fingers.
Remove the battery.
Adhere the battery, disconnect it, and continue reassembling your device.
When it came time to adhere the new battery in place, I realized there was a little space on all sides of the battery. I wasn’t sure how to position it, so I just centered it. But when I went to reattach the connector back to the logic board, it wasn’t aligned. I had to remove part of the strips and was able to salvage enough adhesive to reposition it. It was frustrating and I think giving people a heads up in future would be helpful. Maybe this is noted somewhere, but if it is, I missed it.
I’m super pleased with the process otherwise. And with a new battery, it’s like I have a new phone!
If you bought the glue strip for the display, you have to place it before you reconnect the display to assemble the iPhone to the back shell. Be careful while removing the plastic protection, the glue will stick at the protection foil.
These glue strips gave me issues. I ended up putting them on backwards and therefore the little edges that needed to be tucked under on the bottom were opposite and i had to tear them off on both the top and bottom because they ‘hung-over’. I have a bad hangover from hanging over this iphone for 3 hours trying to find tiny screws and not break my back or have an old bulging battery explode in my face. Not worth it.
And the phone still doesn’t work
I ran through this, and on reassembly the home button didn’t function properly. I found a link that said if you used alcohol to clean the edges in preparation for the new seal, that the alcohol will affect the home button. Drying it out gently with a light blast of compressed or warm air should resolve this. For me it didn’t. Next link I found warned that if the home button screw was too tight try backing it out and retightening it just to the point of resistance. Doing that restored the home button functionality.
One other tip: reinstall the haptic generator before installing the battery to ensure the correct battery placement.
Great instructions! Thanks iFixIt!
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
crwdns2935229:0406crwdne2935229:0
crwdns2944067:051crwdne2944067:0
can the battery from iPhone 7plus fit in the 6s plus? looks to me like is the same type of connector and same dimensions so it would be an easy way to gain 150 extra mah by using the iphone 7 plus battery
Alex
No, because the size are diferents
Of course you can! WHY NOT?
How can I attach the screen back to the body after replacing the old battery,do i need any adhesive to attach the screen to the body?
Not necessarily.
No you don’t need adhesive, but you should probably use it. I ended up not doing so as I still need to replace the screen at another time.
Calen B. -
Do I need any adhesive to attach the screen back to the body after replacing the old battery with a new one?
The display is held in with screws and clips, so everything will work fine if you reassemble the phone without replacing the adhesive. That said, your phone won't be as waterproof as it used to be. We do have replacement adhesive available for you, but we're still working on putting together a clear guide on how to install it properly. (Stay tuned!)
no, you can use the same, unless you dont use the hairdryer/iOpener, then you will have to use a special adhesive
Yesterday I'm buyed new iPhone 7plus
I have kept 100%charging
I have not used the phone
The charging will decreasing automatically
Wt is the reason I want
Will this break it’s water resistance?
Yep. It’s not worth the risk. Just take the device to an Apple Store and pay the $80. That way you not only have a water resistant device, you also have a 90 day warranty on the battery AND the work performed on it. So if the phone’s water resistance fails because of the adhesive, Apple will replace the device without any additional cost.
the glue around the body must be put before reassembling the connectors of the display unit or after ?
Sooo…in Step 24, DO NOT use the metal-tipped tweezers to “jam” under the Battery and try to pry up on it. You WILL risk puncturing the battery and catching the iPhone on fire.
I’ve replaced the battery. But it won’t turn back on? I can’t force restart it because my fingerprint button doesn’t work? Can you help?
Mine did the same thing, what do I do?
I did it and now my Iphone shows No service
and the cellular option in Settings is completly blank. Anyone knows what can I do?
Excelente guia he completado el trabajo, muy util para no aprender hechando a perder los equipos, los soguientes seran pan comido, saludos muchas gracias
Is the battery Apple genuine
when you open up the phone you might think that you don’t need to remove the Taptic Engine for the battery change. But when the adhesive breaks and you will need more space to pull the remaining adhesive out.
Don’t skip the steps.
on ios 13.4 after replacing the battery the phone is indicating recharging but the % never goes up try with and older apple original same thing reinstalled my battery that i wanted to replaced and it recharge % goes up
Procedure rating is difficult. Very capable person here. I used to replace cracked screens on the 3 and 3S all the time when I was a lower end SE at my old software dev employer. (I had replaced everything on the 3s, home button, camera, battery, screen, etc.) Granted it's a different phone today, but I'm cautious, careful, and patient. Off the bat I cracked the screen because the instructions said to "twist the spudger to widen the opening". Tuck me. Crack spread out from the home button to ear piece. I used a Dyson hair dryer for 45 seconds to heat up phone base. After the crack I taped the screen w box packing tape to keep glass from going all over. Removal was fine after that. Didnt need additional heat, but it doesn't matter. Separated the phone and didn't bother replacing the battery now that I need a $75 screen. Using work phone as only phone for now.
After almost 3 and 1/2 years my wife’s and my batteries were at 77% capacity. Fresh batteries installed in both.
so i replaced the battery, speaker and front camera/proximity sensor and now my phone is acting crazy. It randomly shuts down, no vibration, no sound, no wifi, and cant hear anyone when i call. What did i do? I work at a computer repair shop so this is kind of embarrassing….
So….my experience: Completed installation, Home button didn’t work. <Reason: Installed the connector in Step 16 upside-down>. Now ok, but….Fingerprint ID doesn’t work. Any thoughts?
Great guide I felt so accomplished after replacing my battery
I used 2 iFixit kits to replace batteries in an iPhone 7 Plus and an iPhone X this week. Both jobs went smoothly, thanks to these online guides. The batteries showed 100% capacity with 0 cycles in coconutBattery Plus readouts. The batteries even were recognized by iOS as “Apple” batteries in the Settings/Battery app. This is a huge change as previous iFixit batteries I have installed were not recognized by iOS. Both iFixit kits contained all the exact tools needed, plus perimeter gaskets to reseal the screen to the body. The iPhone X kit even contained a new speaker gasket. Wow! iFixit is the best resource for Apple do-it-yourselfers. Thank you!
hi guys i just wanted to ask whether u need 2 have the battery below 25% or can i start before?
I replaced my battery but after I could hear any incoming calls on the ear speaker, can anyone help?
Replaced the battery and the rear camera module in 30 minutes, great guide and replacement parts. Thank you iFixit
Replacement successful. Didn’t attach adhesive yet. But i replaced the battery. Tip. Removing screws is easy but putting back in is a pain. If the screw is not fitting on the end of your screwdriver. Your using the wrong screwdriver. Realizing this makes it way easier
Guide is really clear, took a little bit of time to clean the gunk from the adhesive from the phone to get the phone back together, but the ifixit battery fell in place perfectly and I’m happy overall with how the phone got back together.
Thank you! Like a glove! Correction: STEP 15 - Need Phillips screw driver
Shouldn't we use the adhesive on the battery while reassembling?
I replaced my battery and now my phone is stuck in Reboot loop. What’s the issue?
Worked Perfectly!!! Thank you guys so much, $30 for a new battery AND tools, cannot beat that!
I need some help, please. The battery on my iPhone 7 plus swelled (not original ) so I bought a replacement and I changed it, at first it wasn’t charging even though it was showing as it was, the percentage still the same, then it started to do some funny things like draining the battery, going from 83 to 20 in a minute, and then it was impossible to use as it was restarting all the time. I thought something wasn’t connected properly or maybe I damaged something when I replaced it, I tried many times but it was doing the same. I put back the old swelled battery and it was fine, so I realised the battery was faulty, so Ive got a new replacement and its doing the same…. the only difference that I can see between the new replacements and swelled one is the APN number being 616-00249 and the old one 616-00250 but i’m not sure if that has anything to do with this problem…
We are the Best Interior Designer in Noida specializing in exclusive, cost-effective and luxurious interior design, detailing and space planning in Noida.
I broke the glass at Step 9. Used the spudger instead of the opening pick. Glass broke when I preyed on the top right hand corner. Fortunately the glass had a screen protector on. So, no shards. Be careful! Maybe a WARNING should be added to Step 9.
Hmm after replacement of the battery the phone powers up nicely; but now the home button doesn’t work. For the rest the phone is fully functioning again. (calling, silent/ring/vibrate all works, but the homebutton does not ‘tick’ nor activates anything. Any suggestions?
Thanks for making me look Soooooo smart !!!
Hello.
After installing the new battery, I noticed that the phone is warmer on the right side. The battery temperature is 35.8 degrees celsius. The phone seems much warmer on the right side looking at the screen. Is this normal?
These are instructions for removal, not replacement. It would be helpful to include instructions on when to install replacement adhesive.
In your step 24 going on to step25 you recommend peeling all three battery adhesive tabs up, and then pulling them out
I was sent a case with the battery but not for the phone I fixed. Insight case iPhone 7, repaired iPhone 7+.
I did every thing you explained on removing the iphone battery. However, I never found any strips to remove the battery and also it looks like its literally glued to the phone. I didnt want to remove it because I dont want to damage the phone but please can you tell me where to go from here with out me damaging the phone
Thank you very much!!!!!!!
Another well laid-out guide. No complaints! Thanks iFixit
Just finished and the phone turned on when I put it on the charger so that is a good start. I didn't know what the blue card in the battery box was (it's the adhesive) so I didn't use it.
My iphone 7plus has a model # MN4V2VC/A . Bought in 2017 in Canada. Are all batteries compatible? Some model #'s start with A
The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
pargoff - crwdns2934203:0crwdne2934203:0
The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
Jeff Suovanen -
@jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
iHelpU.Tech - crwdns2934203:0crwdne2934203:0
Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
Vanessa Pinter - crwdns2934203:0crwdne2934203:0
How do you turn off if the screen isn’t responding to touch?
adam - crwdns2934203:0crwdne2934203:0
The replacement battery came with the seal—but how do you put it on???
lkollar - crwdns2934203:0crwdne2934203:0
Instructions for replacing the seal are here: iPhone Display Adhesive Replacement
bester - crwdns2934203:0crwdne2934203:0
I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
Charles Meitin - crwdns2934203:0crwdne2934203:0
Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
My favourites are:
Use a hot water bottle.
Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
Test the lightning assembly at step 13
There is a Standoff driver bit in the box, don't use a screwdriver.
etc...
Neil Eriksen - crwdns2934203:0crwdne2934203:0
A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
Herb
Herb Adler - crwdns2934203:0crwdne2934203:0
The screw size for those with a screw set is P2.
Gareth Flandro - crwdns2934203:0crwdne2934203:0
