iPhone 13 mini Screen Replacement
Adriana Zwink
crwdns2944107:0crwdnd2944107:0Adriana Zwinkcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 22, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
If your iPhone 13 mini screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
Note: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality on genuine screens purchased from Apple.
You’ll need replacement adhesive to reattach components when reassembling the device.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. iPhone 13 mini Screen Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 mini Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone 13 mini Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screenuntil the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Yes, tape to cover the cracks. Guess what also loses adhesion when you apply heat to it,&&^&^$^ tape.
    dylan brune - crwdns2934203:0crwdne2934203:0
  4. iPhone 13 mini Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 mini Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 mini Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Make sure as you are prying the screen that the thickness of the screen looks like it does in the picture. Be very careful to slice the adhesive between the bezel and the device not between the screen and the bezel as I did.
    Reed - crwdns2934203:0crwdne2934203:0
    i shouldve bought this tool... now i ripped the cable to the screen cuz the screen came off easier than i thought. now i gotta buy a new screen lol since i was just trying to replace the back shell...
    Hayabusa 530 - crwdns2934203:0crwdne2934203:0
  7. iPhone 13 mini Screen Replacement, Heat the bottom edge: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 mini Screen Replacement, Apply a suction handle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
  9. iPhone 13 mini Screen Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Insert an opening pick: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • Make sure to insert the pick between the plastic bezel and the metal frame. If you insert the pick between the glass screen and the plastic bezel, you'll damage your screen.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Take care on this step: it's possible to delaminate the glass from the frame holding the screen and vital components together. If you're not aware, you could continue working away (as I did) delaminating the entire glass from the frame only to discover you've messed up. The entire assembly is about 1mm thick and visually looks like two layers (as shown in the last photo here).
    Brent L - crwdns2934203:0crwdne2934203:0
    I broke my screen here. There is a seam in between the glass and the components. Don’t stick your pick in there or it will break. Stick it below the black bezel
    ecwskier - crwdns2934203:0crwdne2934203:0
    As with Brent above, I managed to separate the glass from the frame. Didn't realise until I was at step 18 below. Everything felt fine and looked unbroken until it was too late. So; the glass / screen could be 2x as thick as you think.
    David Wall - crwdns2934203:0crwdne2934203:0
    I’m grateful for the words of caution. I really had to take my time on this step. Actually had to reheat the phone multiple times without any success. Then I tried using an alcohol wipe along the edge of the phone, squeezing the wipe to allow some of the alcohol down along the edges. That was the magic touch that finally let the adhesive loose. Patience is the word.
    wade walters - crwdns2934203:0crwdne2934203:0
    I was doing the heating - pulling process but at a certain point, the screen cracked. Now I can't pull anymore and my screen is destroyed even though it can still work. I don't really know how to repair this...
    matthieu tremblay - crwdns2934203:0crwdne2934203:0
    Even though I read the comments, I crashed the screen. I inserted the plectrum carefully and instantly slipped between the screen and its board. I might have not heated the device enough as I used the iOpener.
    I would highly appreciate a better instruction here and a closer zoom on the removed screen.
    sbb - crwdns2934203:0crwdne2934203:0
  10. iPhone 13 mini Screen Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 13 mini Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, and don't force it through unheated sections of adhesive, or it may slip and damage internal components.
    • Leave the pick in the top right corner before continuing.
    This procedure cracked my screen. Do not move too fast with the pick, and make sure to heat it before hand. Not sure what else can be done to prevent a cracked screen here
    Kristo Jorgenson - crwdns2934203:0crwdne2934203:0
    cracked my screen to. The pleck sliped cause I was to afraid to damage something intern so it sliped out and cracked the display.
    Tariguz - crwdns2934203:0crwdne2934203:0
  12. iPhone 13 mini Screen Replacement, Heat the top edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 13 mini Screen Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 13 mini Screen Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 mini Screen Replacement, Screen information: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Wo ist die "linke Seite"? (Blick auf das Display?) Was bedeuten die roten Quadrate auf dem Bild vom geöffneten Gerät? Zur Orientierung wäre es passend, die Lage der Lautstärke + bzw. - Tasten anzugeben.
    anyone nobody - crwdns2934203:0crwdne2934203:0
    Immediately ripped left cable here. Have done iFixIt repairs many times. Very disappointed!!
    Seth Kaplan - crwdns2934203:0crwdne2934203:0
  16. iPhone 13 mini Screen Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
    In my opinion, twisting the picks is setting yourself up for disaster. Done too hard, even slowly, and the potential energy buildup in the display at the clips could send the display flying fast enough to rip the cables you’re trying to protect. Unfortunately there is no real good way that I know to open the left side. I managed with only slight difficulty to open it by sliding the puck as you would on the other edges, but being very careful to do it slowly, paying particular attention to how deep the pick is inserted and how far up from the bottom to slide before getting too close to the cable. You can slightly lift the screen enough to see where the cable is so as not to damage it. When you’ve slid the pick close enough that you don’t feel safe sliding it any more there should be enough of a leading gap that you should be able to put another pick in in front of the first on the other side of where the cable is. Once you do that the last clip is right there around mid way up from the bottom of the phone.
    Thousand Sunny - crwdns2934203:0crwdne2934203:0
  17. iPhone 13 mini Screen Replacement, Remove the suction cup(s): crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the small nub on the suction cup to remove it from the front panel.
  18. iPhone 13 mini Screen Replacement, Open the iPhone mini: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Open the iPhone mini: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  19. iPhone 13 mini Screen Replacement, Unscrew the battery and display connector cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the 1.2 mm-long Y000 screw securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    나사가 1개 밖에 보이지 않는데 왜 나사 2개를 풀라고 하는 거죠?
    hello world - crwdns2934203:0crwdne2934203:0
  20. iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the battery and display connector cover.
    This cover has an almost hinge like catch. If the cover is still laying flat you should apply lateral motion toward the battery, taking extra care to not damage the battery connection ribbon.
    James - crwdns2934203:0crwdne2934203:0
  21. iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement, Disconnect the battery and the OLED display cable: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the battery and OLED panel cable connectors up from their sockets on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 13 mini Screen Replacement, Unscrew the front sensor connector cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws (securing the front sensor assembly cover):
    • One PH000 1.4 mm-long screw
    • One Y000 1.8 mm-long screw
    • One Y000 1.2 mm-long screw
    Please fix your kit! You ship a PH000, but in the video you show a PH00 (and that’s what it is)
    Connor Luckett - crwdns2934203:0crwdne2934203:0
  23. iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the front sensor assembly connector cover.
  24. iPhone 13 mini Screen Replacement, Disconnect the front sensors: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Disconnect the front sensors: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the front sensor assembly cable connector.
  25. iPhone 13 mini Screen Replacement, Remove the display assembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  26. iPhone 13 mini Screen Replacement, Unscrew the metal cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.4 mm-long tri-point Y000 screws securing the sensor assembly cover.
  27. iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Remove the cover: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to remove the metal cover.
  28. iPhone 13 mini Screen Replacement, Heat up the top edge of the display: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  29. iPhone 13 mini Screen Replacement, Separate the ambient light sensor: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement, Separate the ambient light sensor: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry the ambient light sensor out of its recess.
    • Take care not to damage the light sensor ribbon cables while prying.
  30. iPhone 13 mini Screen Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to pry the proximity sensor and the microphone out of their recesses.
  31. iPhone 13 mini Screen Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hairdryer or heat gun or prepare an iOpener and apply it again to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  32. iPhone 13 mini Screen Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 mini Screen Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide an opening pick underneath the front sensor assembly cable to loosen the adhesive.
  33. iPhone 13 mini Screen Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front sensor assembly.
    • During reassembly, check the position of the sensors and the microphone. Avoid obstructing them with any adhesive.
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Check out our iPhone 13 mini Answers community for troubleshooting help.
crwdns2935229:023crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
57,848 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,686crwdne2935297:0
crwdns2947412:09crwdne2947412:0
is the 'The iPhone 13 disables the Face ID function when you replace the screen' issue still happening since IOS 15.2? all the other pages for iPhone 13's mention its been fixed since then, does this apply to the mini as well?
Nick - crwdns2934203:0crwdne2934203:0
I was scared about this one too, but Face ID seems fine after yesterday's screen replacement.
Artemiy -
Also ich repariere als Hobby häufiger Handys aber das 13er in dem Fall das Mini heute das erste mal und ich muss sagen ich hatte noch nie solche Probleme wie bei dem Gerät. Dazu muss allerdings gesagt sein es war recht stark gesplittert am unteren rand Saugnäpfe und Kleber hat alles sehr schlecht gehaftet. Anfangs klebte der Kleber, vom Display, noch so stark das ich das DisplayGLAS auseinander genommen habe ohne den Rahmen was ich anfangs nicht bemerkte, danach sah das "Display" so aus. Ebenso die schrauben ich habe sonst nie Probleme mit den Y000 schrauben hier habe ich gleich zwei kaputt gemacht und musste diese Aufbohren! Kaputte Schraube / Aufbohren
Am Ende war man erstmal erleichtert das alles funktioniert :)
Jonas Borgers - crwdns2934203:0crwdne2934203:0
Hi Jonas, das klingt wirklich nach einem komplizierten Displaytausch und die Bilder sprechen für sich. Danke fürs Teilen deiner Erfahrung und schön, dass die Reparatur am Ende doch noch geklappt hat!
Adriana Zwink -
I’ve been told by an Apple repair technician that to keep True Tone and Face ID working, you have to turn off find my.
Aspect22 - crwdns2934203:0crwdne2934203:0
Turn it off before you change over the display? Is so, how do you do that is your screen is completely bused?
Luke Oliver -
Eine Frage: Sind die Displays von iphone 12 mini und iphone 13 mini identisch und somit untereinander austauschbar? Der Displayconnector sieht gleich, aber das zweite Flexkabel mit den Sensoren scheint anders zu sein. Diese Sensoren könnte ich vom defekten 13er Display nehmen, passt denn der Rest?
caesar polubiec - crwdns2934203:0crwdne2934203:0
My iphone screen damaged and i asked a technician to change the lcd for me but after that face id is working but auto-brightness is not working! I disabled and re enabled this feature but still its not working. how can i fix that? i followed repair assistant to finish the procedure but it couldn't complete and now it shows (Display Unknown). I live in Iran and there is not any apple partner here to fix it for me. is there any way i can fix it myself?
Farshad Foroughi - crwdns2934203:0crwdne2934203:0
I too replaced the screen of an iPhone 13 Mini, but for me it is the same as for @Farshad Foroughi - auto-brightness is not working anymore. FaceID works perfectly without setting it up again, so I think the sensors were moved to the new screenn without any damage. And I also checked that the sensors do not get dirty and are in place as before. The iPhone runs iOS18, and the repair assistant went through (but also showing it as an unknown display which is probably no original apple part). The repair itself went well and the display works - besides auto-brightness - without any flaws. Setting the brightness manually works fine, so I have no clue what went wrong :( Any Ideas???
However - thanks for the great work @ifixit @Adriana Zwink and all the other contributors!
BUT: When opening the display the first time, be aware that the frame which holds the electronics is quite thick! Lift everything wide enough and do not shove an opening pick between the glass and the frame, this would destroy the display!
MKL1987 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 116
crwdns2936753:07crwdne2936753:0 642
crwdns2936753:030crwdne2936753:0 2,606
crwdns2942667:0crwdne2942667:0 65,487
