Follow this guide to replace the screen on your iPad Pro 11" 3rd gen.
If your battery is swollen, take appropriate precautions.
The LiDAR sensor assembly attached to the screen is paired with the Face ID hardware. You'll need to transfer it to your new screen to keep Face ID functionality.
Some photos show the battery connector blocked with two card strips. While this is an optional method, it's more reliable to fully discharge the battery. Ignore this visual discrepancy as you work through the guide.
Unplug any cables and fully shut down your iPad.
Camera module, ambient light sensors, proximity senor, and front microphone
Display cables
Screen magnets
LCD edges
Apply a heated iOpener to the right edge of the screen for two minutes.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backward to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Insert a new opening pick in the gap you just created.
Slide the pick along the right edge to separate the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick to the right of the ambient light sensor.
Slide the pick along the middle section of the top edge, stopping when you reach the left ambient light sensor.
Insert a new opening pick to the left of the ambient light sensor.
Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner below the existing pick.
Slide the pick around the bottom right corner to separate the adhesive.
Slide the opening pick along the bottom edge, stopping at the USB-C port.
Leave the pick in to prevent the bottom edge adhesive from re-sealing.
Insert a new opening pick to the left of the USB-C port.
Separate the remaining bottom edge adhesive.
Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
There are flat sections of the frame which require an opening pick to be inserted horizontally.
Insert an opening pick at a 45˚ angle just above the bottom left corner.
Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
Lower the opening pick so it is horizontal to the screen.
Continue separating the left edge adhesive until you reach the next indented section of the frame.
Separate the remaining adhesive, making sure to follow the instructions exactly as written.
Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
Slide the pick horizontally and don't insert the pick more than 5 mm.
Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
Grab the top right and bottom left corners of the screen.
Slowly slide the screen towards the bottom right corner to separate it from the frame.
Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
This (step 23) is by far the hardest part, the glue, even in warmed-up state, is quite strong and the panel extremely fragile.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
One 1.3 mm screw
One 2.0 mm screw
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers or your fingers to remove the bracket.
Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
Grip the right edge of the screen and fold it open like a book.
Lay the screen down over the left edge of the iPad.
Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
Two 2.0 mm screws
Three 1.3 mm screws
Use tweezers or your fingers to grab and remove the lower cable shield.
Use the pointed end of a spudger to pry up and disconnect the top two display cables.
Disconnect the two remaining display cables.
Grip the right edge of the screen and lift it away.
The LiDAR sensor assembly is composed of four total sensors:
Two ambient light sensors
One proximity sensor
One microphone
I broke off the right most ambient light sensor. How much trouble am I in?
why is this photo inverted?
This photo is flipped. The microphone is on the side furthest from the silver brace held on with two screws. Microphone can also be identified by the angled cable. The ambient light sensor has a thicker, straight cable.
Heat an iOpener and apply it to the top of the screen for two minutes.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Insert one arm of your angled tweezers between the ambient light sensor and the screen.
Pry up to separate the sensor from the screen.
Repeat this procedure for the other ambient light sensor.
The ambient light sensor system is constructed with a few component parts arranged in layers starting with its connection cable down to the last part that is attached to the glass.
It is not super clear from the photos/instructions between which layers we need to pry to separate the sensor from the part that touches the glass. I'd like to see a straight on view of the exposed layer.
I think I ended up separating the ambient light sensors incorrectly; my exposed sensor layers don't look the same as those you see of the stock part for sale on this site. Those have that layer with the small circle, but the instruction photos here show that layer left attached to the glass.
My FaceID doesn't work and I suspect it may be because of this mistake I made.
Yes, the diffuser was a black film layer with a white milky circle.
We broke one of the sensors off from the cable, and ended up just having one working ambient light sensor.
FaceID however continued to work with that one sensor in the end.
quak -
Following the guide instructions left the diffuser layer of the ambient light sensor adhered to the screen. The use of an Exacto knife with a straight 6mm perpendicular blade, was used to separate this layer from the screen. All of the other sensors were separated successfully with the use of the Exacto knife.
Thank you for that hint! A carefully applied Exacto knife worked much better than the original recommendation, for all of the sensors!
quak -
Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
Slide the tweezers toward the screen while prying to separate the sensor from the screen.
Peel off any tape covering the microphone.
Any hints on re-applying the tape? It didn't stick anymore properly.
maybe a small bit of Tesa tape, just holding down a corner. This being a microphone, I'm hoping it should operate OK even if it's not perfectly flush with the glass. I don't want to try E6000 glue, because that could gunk up the microphone's diaphragm.
nclee -
Slide an opening tool under the microphone to separate its adhesive.
Pry up to separate the microphone from the screen.
Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
Continue sliding your opening pick under the LiDAR sensor assembly until it's completely separated from the screen.
Remove the LiDAR sensor assembly.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Align the LiDAR sensor assembly on your replacement screen.
Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
Applying the E6000 was very cumbersome, as the cable was quite springy and lifted up the sensors. We needed to weigh the sensors down for some hours to really have them stick.
E6000 adhesives are not mentioned in the materials list at the top, I believe this should be included.
The iFixit screen Fix Kit does not come with E6000 adhesive.
The display cable connectors are located under a bracket near the bottom right corner of the screen.
A step should be added here to remove the screen magnets from the old screen and glue them onto the replacement screen. These magnets did not come on the screen purchased from iFixit. These magnets can be seen in the first picture of step 43 on the left side of the picture.
Slide an opening pick under the non-removable display cable to loosen it from the bracket.
Use a Phillips screwdriver to remove the two 1.2 mm screws securing the display cable bracket.
Remove the display cable bracket.
Use the flat end of a spudger to pry up and disconnect the narrow display cable.
Remove the narrow display cable. Set it aside for reassembly.
Disconnect and remove the wide display cable. Set it aside for reassembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 3rd Gen Answers community for help.
crwdns2935229:011crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Sind original iPad Displays device lockt? Wenn ich zwischen zwei gleichen iPads die Displays austausche erwarten mich dann Probleme oder kann ich das ohne Schwierigkeiten machen?
Is it possible to replace the LiDAR sensor assembly w/o losing the current Face ID configuration or is the original flex cable necessary to restore the function?
The author did not address the rare earth magnets. Heap replacement screens do not come with either the ribbon cables (you covered this which is really important) and your iPad also has two small bar magnets comprised of two rare earth magnets each under the right bezels. They have specific polarization that will engage and hold down any flip cover case. If you remove them from your broken display with markings first, good, if one went flying as with my shattered screen I found the poles aligned quite nicely using my case cover to mark orientation. —CM
The screw sizes/color coordinations are wrong, the 5 screws covering the screen ribbon and battery ribbon have 3 short screws and 2 long screws, the 2 long ones go up top and 3 short ones on bottom of cover plate.. and the upper lidar/ambient light ribbon cover the long screw goes up top and short screw on bottom of that cover plate.. the instructions color codes are exact opposite and this should be changed in instructions…. Annnnnd 500 for a %#*@ screen is flippin absurd wth is goin on ifixit I love u guys but this is starting to feel like a %#*@ apple store
Just successfully completed this morning. I marked the correct orientation and transferred the cover magnets from the old display to the new. If you have a FDM 3D printer, the print bed is great for heating up the screen. I placed the iPad on a pre-heated 90C printer bed for a couple of minutes and the adhesive came off very easily.
