iPad Mini Wi-Fi Front Panel Assembly Replacement
  1. iPad Mini Wi-Fi Front Panel Assembly Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - crwdns2934203:0crwdne2934203:0
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - crwdns2934203:0crwdne2934203:0
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - crwdns2934203:0crwdne2934203:0
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - crwdns2934203:0crwdne2934203:0
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - crwdns2934203:0crwdne2934203:0
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - crwdns2934203:0crwdne2934203:0
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - crwdns2934203:0crwdne2934203:0
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - crwdns2934203:0crwdne2934203:0
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - crwdns2934203:0crwdne2934203:0
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - crwdns2934203:0crwdne2934203:0
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - crwdns2934203:0crwdne2934203:0
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - crwdns2934203:0crwdne2934203:0
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - crwdns2934203:0crwdne2934203:0
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - crwdns2934203:0crwdne2934203:0
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - crwdns2934203:0crwdne2934203:0
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - crwdns2934203:0crwdne2934203:0
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - crwdns2934203:0crwdne2934203:0
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - crwdns2934203:0crwdne2934203:0
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - crwdns2934203:0crwdne2934203:0
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - crwdns2934203:0crwdne2934203:0
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - crwdns2934203:0crwdne2934203:0
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - crwdns2934203:0crwdne2934203:0
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - crwdns2934203:0crwdne2934203:0
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - crwdns2934203:0crwdne2934203:0
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - crwdns2934203:0crwdne2934203:0
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - crwdns2934203:0crwdne2934203:0
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - crwdns2934203:0crwdne2934203:0
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - crwdns2934203:0crwdne2934203:0
    Can’t you just use a hair curler instead?
    Aspect22 - crwdns2934203:0crwdne2934203:0
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - crwdns2934203:0crwdne2934203:0
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - crwdns2934203:0crwdne2934203:0
  2. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - crwdns2934203:0crwdne2934203:0
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - crwdns2934203:0crwdne2934203:0
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - crwdns2934203:0crwdne2934203:0
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - crwdns2934203:0crwdne2934203:0
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - crwdns2934203:0crwdne2934203:0
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - crwdns2934203:0crwdne2934203:0
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - crwdns2934203:0crwdne2934203:0
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - crwdns2934203:0crwdne2934203:0
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - crwdns2934203:0crwdne2934203:0
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - crwdns2934203:0crwdne2934203:0
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - crwdns2934203:0crwdne2934203:0
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - crwdns2934203:0crwdne2934203:0
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - crwdns2934203:0crwdne2934203:0
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - crwdns2934203:0crwdne2934203:0
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - crwdns2934203:0crwdne2934203:0
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - crwdns2934203:0crwdne2934203:0
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - crwdns2934203:0crwdne2934203:0
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - crwdns2934203:0crwdne2934203:0
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - crwdns2934203:0crwdne2934203:0
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - crwdns2934203:0crwdne2934203:0
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - crwdns2934203:0crwdne2934203:0
  3. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - crwdns2934203:0crwdne2934203:0
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - crwdns2934203:0crwdne2934203:0
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - crwdns2934203:0crwdne2934203:0
    This thing melts when placed up side down in the microwave…
    Mark - crwdns2934203:0crwdne2934203:0
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - crwdns2934203:0crwdne2934203:0
  4. iPad Mini Wi-Fi Front Panel Assembly Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - crwdns2934203:0crwdne2934203:0
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - crwdns2934203:0crwdne2934203:0
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - crwdns2934203:0crwdne2934203:0
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - crwdns2934203:0crwdne2934203:0
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - crwdns2934203:0crwdne2934203:0
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - crwdns2934203:0crwdne2934203:0
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - crwdns2934203:0crwdne2934203:0
  5. iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    In case of broken glass, here are some hints:
    - I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
    - Test your tape to make sure it sticks really well to the glass.
    - Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
    - Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
    - Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
    - Don't overlap edges of the tape: butt-join them instead.
    - If needed: repeat in other direction.
    - If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
    Good luck, you brave person!
    volty - crwdns2934203:0crwdne2934203:0
    This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
    Bill Roughen - crwdns2934203:0crwdne2934203:0
  6. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
    I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
    jaromhyde - crwdns2934203:0crwdne2934203:0
  7. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you may risk cracking the glass.
    This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
    robloomis - crwdns2934203:0crwdne2934203:0
    just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
    echow2001 -
    for shattered screens I cover the screen with tape. I find packing tape works best for me.
    George - crwdns2934203:0crwdne2934203:0
    I had a second suction cup - one on the glass and one on the aluminum - and the heated gap opened easily.
    Karl Harnish - crwdns2934203:0crwdne2934203:0
  8. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
    you have to pull up on the suction cup harder than you might be comfortable with!
    jfaulks1 - crwdns2934203:0crwdne2934203:0
    thanks jfaulks1 (I did not copy and paste lol)
    iliketrains kid - crwdns2934203:0crwdne2934203:0
  9. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  10. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
  11. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  12. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  13. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
    I left my iOpener on the bezel the entire time I slid picks in. worked great
  14. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    Gezz this is though! Cracked the glass while replacing it.
    Padraic Hoselton - crwdns2934203:0crwdne2934203:0
  15. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  16. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  17. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  18. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    Shattered my screen pretty bad here, making it so that whenever I continued to move the pick the glass separated and I couldn’t continue moving it. Be VERY gentle moving the pick; almost no force is required.
    Jasper Holden - crwdns2934203:0crwdne2934203:0
  19. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  20. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top right opening pick around the corner to fully release the top edge of the glass.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  21. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  22. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
  23. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  24. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  25. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  26. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
    • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
    • Insert the pick slightly deeper and work it back toward the home button.
    • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
  27. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat and reapply the iOpener to the top bezel of the iPad.
  28. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
    • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
  29. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift slowly and gently to further detach the adhesive along the lower edge.
    Really, add a few more pics and a few more picks, see how long and difficult you can make this guide. 26 steps to get the top screen off is ridiculous.
    B. A. Computer Services - crwdns2934203:0crwdne2934203:0
    Not ridiculous for those of us who do not run a computer service company. Heck, I even read your comment hoping for more information.
    Karl Harnish -
  30. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
    • If reusing the front panel assembly during reassembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
    I recommend wearing latex gloves or be sure not to put too many finger prints on the front or back of this front glass when lifting it or completing the remainder of the steps. I made this mistake and upon installing the new LCD and putting the iPad back together I realized that I left a few finger prints on the inside of the front glass. After re-securing the adhesive strips putting the iPad back together there are now unremovable fingerprints visible when the LCD is turned off. Just a recommendation on the gloves or be sure to wipe both sides of the front glass clean before putting all back together.
    Christian Screen - crwdns2934203:0crwdne2934203:0
  31. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
    • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
    • Return the front-facing camera housing to its recess in the rear case.
    this didn’t happen to me BUT the glue was still sticking to the top of the glass because one pick had gone OVER the glue and the other under, so I had to pull the glue off and cut it with scissors
    OK this was glue, it was the tape from step 35!
  32. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Small pieces of foam tape cover the top and bottom right-hand screws securing the LCD to the rear case.
    • Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
    • Remove the triangular tape covering the lower right LCD screw.
  33. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top left LCD screw may be covered by adhesive tape from the front panel.
    • If the tape is present, use the flat end of a spudger to pry the tape up and away, exposing the LCD screw beneath.
  34. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.9 mm Phillips #000 screws securing the LCD to the rear case.
    In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
    mitja
    Mitja Jankovic - crwdns2934203:0crwdne2934203:0
    Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
    Walter Galan -
    The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
    sandro - crwdns2934203:0crwdne2934203:0
    On mine the top right screw is longer
    oliver - crwdns2934203:0crwdne2934203:0
    top right is longer on an ipad mini 2 retina wifi 32GB
    sagert - crwdns2934203:0crwdne2934203:0
    ipad mini wifi no screws are longer
  35. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to peel up the small piece of tape connecting the LCD frame to the right speaker.
    I wonder what does this sticker stands for…
    K8L - crwdns2934203:0crwdne2934203:0
  36. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A thin strip of foam tape on the LCD frame is covering a piece of tape connecting the LCD to the panel beneath it. To proceed, you'll have to break and peel up some of the foam tape to expose the tape hidden beneath.
    • Use a pair of thin tweezers to pull up the top of the foam tape surrounding the LCD.
    • Be careful not to touch the LCD with the tweezers, as you may damage the display.
    • Use the tweezers to peel the foam tape up to expose the top of the LCD.
  37. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of a spudger between the LCD frame and the tape on the top of the LCD.
    • Slide the spudger along the space between the LCD frame and tape, separating the tape from the LCD frame.
    I finished a successful replacement of my screen following these instructions. Thanks.
    Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
    Kenneth Snyder - crwdns2934203:0crwdne2934203:0
  38. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
    • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
    • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
    I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
    bababooey - crwdns2934203:0crwdne2934203:0
    The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
    Brandon Lukasik - crwdns2934203:0crwdne2934203:0
    This step is what destroys my LCDs :(
    Dan Harris - crwdns2934203:0crwdne2934203:0
    Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
    brauliox - crwdns2934203:0crwdne2934203:0
    I have broken about 10 of the 50 or so iPad minis that I have repaired. I always try to have a LCD on hand. I’ll have to try the fishing line trick!
    northstar - crwdns2934203:0crwdne2934203:0
    I also recommend doing step 45 first (removing the two pieces of foam tape at the bottom).
    I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
    Jenny Lawson - crwdns2934203:0crwdne2934203:0
    I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
    lemerise - crwdns2934203:0crwdne2934203:0
    nothing Brocken after
    (I did not read the comments before doing it lol)
  39. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the guitar pick into three more locations down the left side of the LCD and bend it over in each location, to slide the LCD over to the right side of the rear case.
  40. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now switch to the right side of the LCD, and pry with the guitar pick in several places along the side to shift the LCD back to the left.
    • Repeat this and the previous step a few times, until the LCD is easily moved left and right.
  41. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
    • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
    • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
  42. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
    • The goal is to separate the adhesive, not to pry the LCD up, so keep the pointed tip of the spudger as low as possible to prevent bending the LCD.
    • If inserting the spudger causes the corner of the LCD to bend up, repeat the steps with the guitar pick to further loosen the adhesive.
    These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
  43. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous procedure along the top of the LCD.
    • Insert the flat end of the spudger between the LCD frame and metal backing plate and gently push the spudger in across the top of the device, separating adhesive.
  44. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue with the left side of the LCD: insert the flat end of the spudger between the LCD and shield plate and insert the spudger as far as it will go.
    • At this point the LCD should be loosened from the adhesive holding it. If it is not, re-insert the spudger on the right side or top to fully free the LCD.
  45. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the LCD up a couple inches from the rear case to ensure it's free from the adhesive.
    When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
  46. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two wide strips of tape connect the LCD to the speakers.
    • While holding the LCD with one hand, Insert the flat end of a spudger into the gap between this tape and the left speaker.
    • Gently pull the LCD away from the speakers while rotating the spudger outward to separate the tape from the speaker.
    I recommend removing these two pieces of foam tape prior to loosening and lifting the LCD.
  47. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of the spudger into the gap between the right speaker and the LCD tape.
    • While pulling the LCD away from the speakers, rotate the spudger outward, widening the gap and releasing the tape from the speaker.
  48. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the LCD over and rest it on top of the front panel glass.
    • Do not attempt to remove the LCD from the iPad, as it is still connected by its data cable.
  49. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Shield Plate: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the LCD shield plate to the rear case of the iPad:
    • Two 2.6 mm Phillips #00
    • Thirteen 1.7 mm Phillips #00
    • One additional 1.7 mm Phillips #00 on some devices.
    At the iPad mini retina Wi-Fi there are only 7 screws.
    On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
    On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
    gfriedman99 - crwdns2934203:0crwdne2934203:0
    I have a missing plate and screws
    Keah Smith - crwdns2934203:0crwdne2934203:0
  50. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger underneath the center of the LCD shield plate from the bottom end of the iPad.
    • Pry up on the spudger to free the plate from the sides of the rear case.
  51. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD shield plate from the iPad.
    theres a lip on the rear case that prevents you from lifting this straight out, be careful to not bend the plate.
    Once the LCD is clear of the shield, wiggle a long plastic spudger up the center between the shield and the battery to gently bend the shield. That will help in getting it away from the sides and make it easier to come out.
    Bill Shannon - crwdns2934203:0crwdne2934203:0
  52. iPad Mini Wi-Fi Front Panel Assembly Replacement, Battery Connector: crwdns2935265:052crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
    Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
    jessabethany - crwdns2934203:0crwdne2934203:0
    Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
    Walter Galan -
    Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
  53. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  54. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
    Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
    Mattis - crwdns2934203:0crwdne2934203:0
    I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
    Grillwrecka -
    Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
    Andrew Kivell -
    There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
    jessabethany -
    After unplugging the battery place a guitar pick in-between the two connections.
    While continuing to work on the iPad you may inadvertently cause the two connections to touch.
    Michael Vovaris - crwdns2934203:0crwdne2934203:0
    Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
    WolfyHD - crwdns2934203:0crwdne2934203:0
    I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
    Rory Filer - crwdns2934203:0crwdne2934203:0
  55. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
    • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
    Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
    Does it shares the same shape/size of the LCD connector between the ipad mini wifi only WHITE and the other one ipad mini 32gb BLACK?
    muhammadbukhari10 - crwdns2934203:0crwdne2934203:0
  56. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame.
    • While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
    • Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
    • It may help to twist the spudger, to spread the gap the rest of the way and separate the LCD from the tape.
    Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
    Dave Davidson - crwdns2934203:0crwdne2934203:0
    When this tape damage, how we can take a new?
    Muhammed Kilic - crwdns2934203:0crwdne2934203:0
    When this tape are damage, how we can order and take a new one?
    Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
    on mine this tape was already loose.
  57. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
    • Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
  58. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the LCD from the iPad Mini.
  59. iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
    • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
    • Gently pry the digitizer connector up from its socket on the logic board.
  60. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the digitizer cable board up from the rear case.
    Be careful not to dislodge any of the surface mount components next to the connectors. This is sometimes a reason for the digitiser not working.
    Simon - crwdns2934203:0crwdne2934203:0
    There is adhesive holding it down, so it may take some time to get it off. It helped me to push with my spudger on the piece with the yellow text instead from the same side.
    I put the iOpener under the iPad to weaken the adhesive for this step.
    Nathan Lloyd - crwdns2934203:0crwdne2934203:0
  61. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the front panel from the iPad.
    == After step 55 ==
    Before installing your new digitizer (front panel), make sure to put the necessary bends on the new digitizer's ribbon cable. Look at the old panel that you've removed to see the bends that you'll need to make. Without doing this, once you are at the last step of laying down the digitizer, the cable may bunch-up in between the glass and the iPad's aluminum frame. Thus, it will not allow that corner to sit flush and glue down. If you didn't make the bends, you can use the tweezers at that point to situate the cable. It is just easier to do this beforehand. Do not make the bends as if you were folding paper. You run the risk of damaging the ribbon by doing so. You just want enough pressure to make the cable retain a bend. Again, look at and copy the cable from your old panel.
    Good Luck!!!!
    Mike - crwdns2934203:0crwdne2934203:0
    If your panel is shattered, you may want to have some canned air to get rid of all those pesky little glass pieces that fly everywhere. I used a Giottos air blaster because that is all I had at my disposal.
    Mike -
    might be better to use a vacuum for safety reasons. you really dont want glass shards all over the place
    If your case corners are damaged from being dropped, seal across the corners with wide packing tape, then grind them out carefully with a small motor tool. Use a corner piece from the broken screen (adhesive side upwards) as the template. Keep removing aluminium until screen piece above fits snug and flat. Remove all traces of metal filings before reassembly.
    Jennifer Fordyce - crwdns2934203:0crwdne2934203:0
    Good tip! Most times the corners are damaged.
    northstar -
  62. iPad Mini Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Your replacement panel may come with this cable pre-adhered.
    • On the replacement front panel, remove the small piece of adhesive backing from the digitizer cable.
    • Fold the digitizer cable back over onto itself and press firmly to secure the adhesive.
    The old glue was full of tiny shards. I rubbed it all away with many Q-tips and petroleum ether. To protect the LCD I used a sheet of heavy paper. Cleaning took a lot of patience.
    Still should have listened to Mike: The digitizer ribbon cable went between the frame and the panel. It was bent too sharply. Touch worked, but the home button did not. When i tried to reopen, the glass cracked. Big disappointment, but ill try again!
    luc - crwdns2934203:0crwdne2934203:0
    Same here, so suspect I have the same problem, didn't see these comments until after I finished!
    Took me nearly 2 hours to remove the glass because it just shattered even more every time I used the sucker. Used IsoPropanol to clean.
    Checked all was working with the new digitiser and home button by starting iPad before sealing the glass shut, all ok.
    Stuck it all down, home button works occasionally, but also siri bleeps on it's own sometimes as if someones pressing the button. Also, if I press either side of the home button I get a reaction as if I've pressed the home button, or sometimes I get the double tap action and sometimes Siri, makes me think that there is something shorting / touching that shouldn't be, unless it's the ribbon.
    Will order another kit and give it another go shortly as the glass is sure to break when you re-open.
    Barry Tresadern -
    @Barry Tresadern
    I had the same problem with the home button acting crazy. The problem is on the new screen there are metal contacts that are exposed and they are touching the metal frame making it seem the button is being pressed. If you look on the old screen you'll see strips of tape covering these metal contacts. You can either peel them off and put them on the new screen or just use some electrical tape.
    Patrick -
    With this step, im looking for a replacement screen. I cant seem to see the same connector as the one illustrated here. Is there 2 ribbons mixed there?
    James - crwdns2934203:0crwdne2934203:0
    James, I think you're referring to the IC chip that most glass panels do not include. If you do not have soldering knowledge (and a lot of confidence and time) then it's crucial that you purchase a panel that has the IC chip attached, otherwise you will need to remove the old one from the broken assembly and re-solder it on to the new one - honestly not worth the time involved unless you know what you're doing.
    Katie -
    I've been able to replace a shattered screen. Took about an hour and a half. This consisted of mostly cleaning the shards. I wish there were some glue in the kit - I don't know if there is enough left from the previous screen to hold the new one. I'm likely going to use craft glue to make up the difference. Any other suggestions?
    [deleted] - crwdns2934203:0crwdne2934203:0
    Heating the glue with a hair dryer or heat gun helps or you can buy very thin double faced tape.
    Michael Vovaris -
    I thought that it was a successful repair and resealed the iPad and turned it back on after replacing the digitalizer and the LCD screen, yet neither the home button nor the power button are working. After holding the power button, the power will come on but just one "click" the screen does not react. I tried moving the tape around the home button from the broken digitalizer to the new digitalizer, yet neither button works. I need help ASAP, I don't want to damage the iPad screen more by leaving it unopened for extended periods of time. Any suggestions?
    James Johnson - crwdns2934203:0crwdne2934203:0
    the new pannel comes with a yellow tape on those contacts. Do not remove it. (or replace it !)
    ZARAGOZA - crwdns2934203:0crwdne2934203:0
    Yes..do not remove this tape!
    Banu -
    Yes I learned the hard way as well, be sure you leave the yellow plastic tape over the back of the home button and surrounding circuitry or put tape over this area before install. New screen installed and the home button isn't working :-(
    Ken Bauer -
    THANK YOU Patboy2008, you saved me a friendship and a lot of heartache. I was racking my brain trying to figure out why the home button was on the fritz. Siri kept interrupting, the screen would go black, then flick on, then apps would randomly open, then it wouldn't even give me enough time to punch in my passcode. It was all about those two SILLY pieces of tape. Sure enough reopened it and noticed that the new screen didn't have the two black pieces of tape the old screen had. So glad I dug it out of the trash and transferred those pieces. It works like a charm now. Oh and this was so much harder to fix than the iPhones. The hardest part is getting the front panel off and if it's broke it'll come off in the tiniest of pieces. I hard shards of glass in my fingers that you were like invisible splinters. Be careful and take your time with this one.
    iKimmy - crwdns2934203:0crwdne2934203:0
    Thanks for comments. Yes, do pay attention the the metal bands in the bottom frame of the front panel. DO cover a trip of electric tape on it. You will find the random moving and touching away.
    shanhaidong -
    It pays not to take the protectors off the glass panel adhesive until you have fitted the panel and turned on the ipad to test functionality a few times. (Once the adhesive sticks, it's very difficult to take the panel back off.) Also, I ended up applying two layers of electrical tape over the copper contacts on the panel before the random actions stopped. Now I am closing my third repair on the same machine. Let's hope this one sticks.
    philippschuller - crwdns2934203:0crwdne2934203:0
    In a kit purchased in June 2019, this operation was already done.
    Clément Marshall - crwdns2934203:0crwdne2934203:0
  63. iPad Mini Wi-Fi Front Panel Assembly Replacement, Front panel preparation: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front panel preparation: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is a good time to power on your iPad and test all functions before you seal the display in place. Be sure to power your iPad back down completely before you continue.
    • If you're installing a new front panel assembly, it may need the following preparation:
    • Peel the large clear plastic liner off of the inside of the glass.
    • Peel any blue plastic backings covering the adhesive around the perimeter of the front panel assembly.
    • Once removed, the adhesive strips will be exposed. Don't remove these backings until you're ready to install the front panel assembly.
    • Don't remove any copper coverings from the outlined region, such as yellow kapton tape or black electrical tape.
    • Ensure the glass panel is free of fingerprints and grime before installing it on your device.
    I just received a new front planel and the digitizer connector is wrapped in a black electrical tape. I removed to check for the adhesive between circuit and connector but didn't see any, I re-wrapped in the original black tape which I think should be left alone. Also there was a yellow tape over the back of the home button and circuitry between the digitizer cable and home button. I removed this when I removed the blue plastic on the adhesive but I don't think your suppose to. After repair, home button doesn't work which might be because removing that tape.
    Ken Bauer - crwdns2934203:0crwdne2934203:0
  64. iPad Mini Wi-Fi Front Panel Assembly Replacement, Transfer the smart cover magnets: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement, Transfer the smart cover magnets: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you install your new front panel, you'll need to transfer the smart cover magnets on your OLD front panel to your new front panel.
    • Place the edge of a plastic opening tool on each side of the magnet near the top left corner of the front panel assembly.
    • Carefully wedge the edge of the right plastic opening tool underneath the magnet.
    • Steadily hold the right plastic opening tool in place.
    • Wedge the left plastic opening tool underneath the magnet and simultaneously pry and push it towards the right plastic opening tool.
    • This will require some force as the smart cover magnet is held in place with strong adhesive.
    On the new front panel with the adhessive pre-installed, there are perforated area on the blue plastic you can peal away just for the magnets without exposing the rest of the adhesive.
    I found these come off much easier after applying heat to the area for 5 seconds.
    Korey Bennett - crwdns2934203:0crwdne2934203:0
    On the kit purchased in June 2019, magnets were included in the replacement part.
  65. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If necessary, use a pair of tweezers to partially peel back the piece of tape covering the smart cover magnet near the lower left corner of the front panel assembly.
    In the kit as of July 2019, there is an area of adhesive (separate from the edge adhesive) on the screen where you want to relocate the magnets. It is in the rough shape of the magnet, so you can see how to orient the magnet (curve parallel to the curve of the case corner). When you close up the screen, the magnets fit into the depression above where the tabs of the LCD are (the ones you remove the screws from in step 31). The magnets shouldn’t be too far away from the copper-colored rim of the interior of the screen, or they will not fit into the depression and may crack the screen when you press it to close. Definitely dry fit!
    Sara Austin - crwdns2934203:0crwdne2934203:0
    Hi, I’d like to know if this magnets are necessary to maintain the screen attach, if they do something beside the adhesive. Thank you for your help.
    castrofabian - crwdns2934203:0crwdne2934203:0
  66. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the previously described procedure to remove the smart cover magnet near the bottom left corner of the front panel assembly.
  67. iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini Wi-Fi Front Panel Assembly Replacement: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In this step you will be transferring the smart cover magnets to the NEW front panel assembly.
    • Use a pair of tweezers to carefully place the upper left smart cover magnet in place.
    • Repeat the procedure with the bottom left smart cover magnet.
    • If necessary, use the edge of a plastic opening tool to flatten the piece of tape adhered to the bottom left smart cover magnet.
    Do not forget to remove the protective film from inside of new digitizer, remove black insulating tape from bottom of old digitizer and place on new one, covering any and all exposed copper. Take your time - the repair is not hard but it is time consuming
    David D - crwdns2934203:0crwdne2934203:0
    Thank you for mentioning that! I don’t think I would have noticed until too late.
    ted -
    BEFORE you close everything up power up your ipad and make sure all the buttons and functions work properly, charging, rotation, home button, sleep button
    Chris Grayden - crwdns2934203:0crwdne2934203:0
    Step 66, it is important to put the magnets in the same Exact place and orientation or you could break the glass (again) during installation.
    Phil Fite - crwdns2934203:0crwdne2934203:0
    The orientation of the magnets may also be important to the devices’s ability to wake/sleep in response to the cover being opened and closed.
    ciradrak -
    No mention is made of using any adhesive during the installation of the new panel. There are gobs of adhesives for many different purposes. Is there any recommendation for re-establishing an adhesive for the new panel?
    Jim Dutton - crwdns2934203:0crwdne2934203:0
    Step 35b : watch for LCD white screw tabs as you pull up LCD panel so that they don't bind at the bottom and break off (definite crack)!
    Step 46: was easier, at least for me, to insert spudger between frame and digitizer board (left side) rather than trying to get under it from its right side.
    All of this & they could have simply made the connector cable on the front glass a snap on connector & cut out 60 steps of this repair.
    Gary - crwdns2934203:0crwdne2934203:0
    I was repairing the broken glass on my iPad. A lot of the broken glass was in small fragments along the edges which made sliding the pick underneath to loosen the glass quite difficult. Things would go well until I hit a small island of broken glass and the pick would stall as the glass wouldn’t budge. It took several re-heating cycles with the microwave heat pad and a lot of patience to break those loose. In retrospect, probably could have ignored them until the bulk of the glass was removed and then _gently & patiently_ chisel them out separately.
    Still had ghost touch issue with the iPad mini so I ended up purchasing Kapton tape on Amazon and used it to cover the entire bottom part of the iPad mini 2 where the Home button is, not just the gold connectors as previously suggested. Apparently this is a common issue with the iPad minis where the digitizer and home button are grounded to the iPad’s chassis. Thankfully, that resolved the issues of ghost touch and my daughter’s iPad is now working like a charm. Just wished your iFixit digitizers were properly prepped with Kapton tape from the factory. Hope this helps with other iFixit customers suffering from the same issue.
    Yousef Ghalib - crwdns2934203:0crwdne2934203:0
    I believe I finally figured out the issue with the iPad mini. I feel like an idiot! It was improper installation. Ghosting on a the iPad mini was caused by creasing the digitizer flex incorrectly. It can NOT be allowed to bend backwards and touch the adhesive for the screen (I checked--mine and was bent backwards and creased due to it sticking to the adhesive). The flex must gently bow forward towards the LCD and not be allowed to crease. Unfortunately the digitizer is compromised and unusable. We’ll need a new digitizer but this time I wont make the same mistake
    One of the more difficult/frustrating issues I had during reassembly was the tendency of the digitizer cable to place itself between the frame & the glass. This prevented the glass from seating completely in the frame & I believe would have caused damage to the ribbon cable had I not noticed it. I had to use a flat tool to guide the ribbon cable away from the frame as I lowered the glass into place. I am not in a position to do it, but I hope a reassembly document will be added to these instructions, as it’s not simply a matter of “following the instructions in reverse order.”!!!
    kevs - crwdns2934203:0crwdne2934203:0
    Good tip! I replaced a digitizer myself after a shop had done it once already. Aside from new cracks, there were problems with dead spots on the screen, and the lock button would shut down but not sleep the screen. The screen I took off looked like the digitizer cable had been pinched like you noted, and I wonder if that was causing the problems.
    ted -
    If your ipad has a dented corner, you may need to trim the new glass a bit so that it fits flush. The ipad I worked on had been dented in the corner, which what cracked the screen in the first place. The dent pushed in the metal lip enough that a replacement screen would sit on top of it, so that a little too much pressure on the glass will make it crack again. A diamond-coated file will work to file off some of the glass on the corner. Full sized Leatherman multi-tools often have a diamond coating on the back side of the coarse file — it works great. Just be patient as it takes a while to grind off.
    ted - crwdns2934203:0crwdne2934203:0
    You Could Add One more Step: When assembling the screen it is necessary to tuck the digitizer cable back into the tablet as it wants to fold toward the outer edge and prevent the digitizer glass assembly from laying flat against the framework. You can do that with a Spudger by pushing the cabole back into the tablet as you close or seat the glass digitizer.
    Larry Bennett - crwdns2934203:0crwdne2934203:0
    At which step during reassembly to remove blue protective film on the adhesive is never mentioned. I did it too early and thought of preserving it with cling film which does not peel off afterwards. Don't do this. I suggest removing this stuff just before turning “the page” back on.
    Where can you buy the magnets? (not from ifixit)
    Emerald - crwdns2934203:0crwdne2934203:0
    There is no mention anywhere about ingress of dust between the cover glass and the LCD…is this a nonissue??
    Jordan Clayson - crwdns2934203:0crwdne2934203:0
    Just finished the digitizer replacement by buying a new one for $10 rather than pay $120 to get it repaired. Everything works great! A few tips that weren't mentioned:
    1) I used a hair dryer on low heat for 30-40 secs and it softened the adhesive enough to pry it open.
    2) If you have the wifi iPad (non-cellular), you don't have to worry about the antenna when prying, as it doesn't have one.
    3) Be sure to remove the old adhesive by pulling it off the iPad frame so your new digitizer can sit tight and flush. Most new digitizers have adhesive included (very convenient), just peel off the blue cover vinyl as your final step.
    4) Try to use something to cover the LCD screen from fingerprints and dust. I had to use a wet wipe to gently wipe down the LCD. I couldn't get every smudge off but it proved not to matter as it was not noticeable upon completion.
    Hope this helps!
    Christian Lee - crwdns2934203:0crwdne2934203:0
crwdns2935229:0449crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
509.429 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.038crwdne2935297:0
crwdns2947412:053crwdne2947412:0
This really isn't that hard of a repair, I struggle more with iphones than an iPad. Just be careful and diligent when you work. Hardest part for me is the stupid adhesive haha
Brendan McDonnell - crwdns2934203:0crwdne2934203:0
ifixit is forgetting crucial steps in this repair. First off they need to make note of the small magnets on the back of the digitizer which are needed to use the smart cover feature on the ipad. And second they need to make note of the issues people are having with the touch acting up as soon as the digitizer is laid back down. you need to put tape on the contacts of the digitizer so that it does not directly touch the frame. also the iopener burned my microwave, your better off just using a heatgun and guitar picks/spudger.
info - crwdns2934203:0crwdne2934203:0
Hi, I am having the exact issues where the touch is not responding. Where exactly do I need to put tape on the contacts of the digitizer so that it does not directly touch the frame? Can you explain in detail. Thanks.
yungwun619 -
Either it was updated or you overlooked it. For newcomers, the info implied about is covered in Step 60-63.
Keypad -
Again, ifixit leaves out a VERY important part that will BREAK the LCD if you forget to remove them. The sides of the LCD in the ipad mini has tape on it as well(you can even see the tape in the pictures above in the tutorial). If you do not remove this tape before inserting a tool under the sides of the LCD the LCD will BREAK! You must remove the foam ALL THE WAY AROUND THE LCD and peel back the tape from not only the top (as in the tutorial), but the sides of the LCD as well, holding it to the metal shield behind the LCD. The tape can be replaced, or re attached later, but it HAS to be removed before attempting removal of the LCD itself. I wish I would have known this before digging into the ipad mini. Fix the tutorial PLEASE!
Edward - crwdns2934203:0crwdne2934203:0
too LATE, I BROKE THE TAPE lcd =((((((
Quynh Vu -
It is in there, in steps 41-46. You must’ve just looked it over.
TheYootz Media Group -
I completed a repair using this guide this past weekend. It took 2.5 hours mostly because the screen was too shattered to use the suction cup, and I had to clean up all the little bits of glass and adhesive. But the repair was a success! The iPad worked perfectly after I was done with the rebuild. I did forget to put back the two mini magnets that were for the smart cover but it was too late and I wasn't too worried about it at that point. Thanks again for a great guide.
Gregory Caporale - crwdns2934203:0crwdne2934203:0
I was using the guide on the google app for Android and it was not as complete as this version on the website. Otherwise this was a great guide! Thanks again for the very detailed steps and photos.
The only issue I had was the screen was shattered and made the use of the suction cup useless. I just continued to heat and remove the shards of glass a little at a time.
paulmcneely - crwdns2934203:0crwdne2934203:0
Place clear packing tape or a screensaver on the shattered glass before you start and generally the suction cups will stick.
Patti Pender -
The adhesive on the packing tape will liquify under the heat of yhe iopener making it pretty useless. Heating and chipping seems to be the way to go. Ifixit eally should have adressed this ahead of time as i am assuming most people will be teplacing shattered screens. I mean why else would you go through this?
David Stotz -
Hopefully someone can help me. I have replaced the digitizer, but something is wrong. The digitizer is basically unresponsive, and acts like it is being touched in multiple places at once. This only happens when fully assembled. I tested with the digitizer NOT mounted to the chassis, and it works perfect. Is this a grounding problem?
bradj47 - crwdns2934203:0crwdne2934203:0
Do you have to replace the smart magnets? is this a necessary step if you do not use the smart covers?
Michael - crwdns2934203:0crwdne2934203:0
I didn't. No need.
Patti Pender -
This guide and the pictures are the best way to destroy your ipad, sorry to say so. If you insert the picks as deep as shown, you cut various wires such as the 3G antenna, the camera, the home button - all of them are placed on both narrow sides of the ipad. Further on you risk scratching the LCD surface, which consists of a dark foil that you may scratch off.
So to make it short: Fingers away from this guide!
dadoc - crwdns2934203:0crwdne2934203:0
There is no 3G antenna on the Wi-Fi version. Use the correct guide for your device and these issues go away.
The guide carries warnings where the cables and antennae are and cautions you where to place picks.
Patti Pender -
After connecting the new digitizer I plugged in the LCD the digitizer and the battery connectors, installed the metal shields and tried to power on the iPad. Unfortunately the screen is grey white while booting, only half the Apple is visible and upon booting the colours are strange but I can use both the digitizer and the home button. Do you think I damaged the LCD during the process or did I break anything on the motherboard?
finn2k1 - crwdns2934203:0crwdne2934203:0
I would check that the lcd cable isn't trapped or kinked under itself when plugged into the board. The iPhone 5 does exactly this when the cable isn't located spot on.
Gavin -
I did this over the weekend, took about 2 hours all told, as others have said cos the glass was shattered.
I found it very easy to just use a hairdryer to melt the glue enough to get the panel and digitiser off the chassis.
Unfortunately the home button is behaving a little oddly, and Im guessing its grounding out as it keeps kicking back to the home screen.
Ill report back when I have found out more.
Gavin.
Gavin - crwdns2934203:0crwdne2934203:0
This was my first attempt at repair. So I went with an older model. He's what I've learned. Quite a bit of attention was made to keep the digitizer connected to the device. In my case, I was replacing it, so it didn't make a difference if I kept the broken glass attached. It was pretty annoying to have glass all over the place (even after taping) when I could have just cut the ribbon cable. Secondly, as previously posted, bend your ribbon cable on the new digitizer FIRST. But, it's not clear how it should be bent. After folding the digitizer back, it becomes straightened back out a bit before you use it as an example for the new cable. It should really be folded up accordion style so that there's a tight backward S shape to it. If you don't get the fold right the first time, just reheat the corner, pull just enough on the suction cup to slide a guitar pick in and push the cable into it's little space where it belongs.
jefowler4th - crwdns2934203:0crwdne2934203:0
Good thing! I did it with success!!
Few things to make it easier for new users, said above but now clear.
- if your glas is shattered, its hard to remove it. But keep tryin it will work if you give it enough time.
- be careful at removing the lcd. The glue is holding it back on the metal plate. Slow an easy.
- bend the flex cable of the front panel before you reassemble. Or be very careful if you already reassembled but have to glue the glas onto the body. Push with a stump tool onto the cable until its an "s" and fits into the gap.
- finally, there are many versions of new glas. The adhesive isnt very strong on them. Maybe put some extra glue under the glas. Otherwise it wont stay fixed.
Good Luck
harry - crwdns2934203:0crwdne2934203:0
I did my iPad Mini repair yesterday, took me 4 hours because I was slow and careful and it was my first time with this device, and here is my 2 cents'worth:
If the glass is cracked I wouldn't bother with taping it. I put the tape on, found I couldn't proceed because I couldn't get any suction with the suction cup, so took the tape off again.
Disconnecting the battery and LCD connectors is a swings and roundabouts thing. If you leave them connected, especially the battery connector, and you short something, you have a bad situation. However, if you disconnect them, and in the process of doing so, you damage the delicate connector. that is also a bad situation. I did it without disconnecting them and it worked OK.
The tape over the copper contacts is important. I put ordinary clear tape over the contacts and I got random movements on the screen. Then I put a strip of electrical tape on top of that and the random movements improved. Then I put another strip of electrical tape on and it's OK now.
Peter Gray - crwdns2934203:0crwdne2934203:0
Another couple of things: the self adhesive strip around the edge of the new screen isn't anything like the original glue. It's OK for a temporary repair while you see if the thing works or not, but to make it permanent you really need to use iGlue or whatever Apple uses.
When I reassembled the unit I found that the front facing camera wasn't quite aligned with the spyhole in the front glass. This is because the camera is on a flexible mount which allows for a couple of millimetres movement in all directions. You just need to watch this when reassembling.
Mischief managed, though it would have been nice if there was process for changing out the home button. One I ordered did not come with one. Ended up going to YouTube to find a video on how to do those steps.
Greg Beaudry - crwdns2934203:0crwdne2934203:0
how to order a digitizer for ipad mini 1
kent bacalso - crwdns2934203:0crwdne2934203:0
Why didn't anyone cover how to tak out the home button and replace it in the new digitizer?
gocaps25 - crwdns2934203:0crwdne2934203:0
Troubles with the home button why isnt there steps on how to put it ?
Marvin - crwdns2934203:0crwdne2934203:0
How do you remove the old adhesive?
There is nothing in the repair kit to remove the adhesive.
Pierre St Gelais - crwdns2934203:0crwdne2934203:0
Did this fix the other day and everything works except the iPad won't charge past 2 percent and keeps restarting.
Any help on what is causing this?
Thanks!
Steve - crwdns2934203:0crwdne2934203:0
Did the repair everything works except the screen keeps acting like the magnet case is on and turning itself off at random I took the magnets out and am still having the same issue.
Robert - crwdns2934203:0crwdne2934203:0
Well the yellow tape that came with the new screen came off replaced it and works like it should make sure the yellow tape stays on the screen
I did it. Everything whent smoodly but one small problem. The digitaser reads nothing. :( the button works.
Sandor Falkesund - crwdns2934203:0crwdne2934203:0
Didn't work. =( Did the whole replacement, seemed to go mostly okay, but when I powered the device back on the touchscreen is completely unresponsive. My daughter is very sad, and I'm out $60. All the connectors clicked into place, so I have no clue what I did wrong, or if the part is bad, but the thought of spending another 2+ hours re-doing it is more than I can stand.
bh - crwdns2934203:0crwdne2934203:0
I had successfully done 5 minis with no issues the last one had ghost touch then the digitizer died i think I damaged the digitizer flex I used kapton tape over the copper contacts this should stop the screen jumping and ghost touch be very careful when bending the digitizer flex it so easily damaged take time to get it right. For sticking the digitizer back down the adhesive supplied is not man enough to keep screen down on its own so I used IPAD ADHESIVE TAPE DOUBLE SIDED REDTAPE SUPER STRONG STICKY comes in different width's Easily got on eBay I found 'this worked the best and so far had no issues with digitizer lifting since using this tape
Jon maccallum - crwdns2934203:0crwdne2934203:0
Followed this to replace a broken LCD. Turned out I needed the front screen with digitizer. Word of warning: I might have been a bit rough removing the screen first time and damaged the digitizer.
Stephen - crwdns2934203:0crwdne2934203:0
After doing this repair the cameras aren't working... :( The camera app starts up and appears to be working with all the white buttons, but the screen is black. I can change between front and back camera (I see that it does it because one of the cameras has HDR.
I don't know what to do here. I've tried to reset it with the power- and home button but that doesn't fix it.
Any ideas?
Krister Turøy - crwdns2934203:0crwdne2934203:0
If you're on the fence about your abilities, give this a try. It really isn't too bad.
I decided to remove the old (shattered) digitizer with an Xacto knife as I had seen elsewhere. That made quick work of that stage, but I would recommend gloves and being extra careful on the sides. The rest is fairly familiar, a lot like an iPhone if you've ever repaired one of those.
Another tip is to use a magnet from your fridge to keep the right screws together.
Wesley Applequist - crwdns2934203:0crwdne2934203:0
The new adhesive doesn't stick very well and the side of the screen keeps popping up and I don't know what to do what should I do about this?
Peter Carlson - crwdns2934203:0crwdne2934203:0
Hi Peter! As with all adhesives it will work best on a clean surface. If you can pop the glass up without damaging it or the adhesive, you may be able to check for any dirt or leftover adhesive, and rub down the case with some isopropyl alcohol to clean up any grime or finger oils. You can also check for misplaced cables or other components that didn't settle back correctly. If you don't want to risk reopening the device, you may be able to help set the adhesive by applying light pressure for a few hours. Warning though, if there is a hard high-point on the case anywhere, adding pressure on the device may cause the glass to crack in that location. Stack a few mid-sized books on the iPad overnight to help activate the pressure sensitive adhesive, you don't need to press hard, just light pressure over time will help. You can also check out our Answers forum for more help. Good luck!
Sam Goldheart -
Me tomó como 3 horas completarlo por que fui super cuidadoso y pendiente para no cometer un error. Es tedioso por los detalles pero facil de hacer con las herramientas correctas (utilize las de ifixit). Si tienes prisa busca el dia adecuado para hacerlo con calma ya que vale la pena hacerlo uno mismo. Tener mucho cuidado al sacar el LCD y de eliminar bien la pega que tenia en el marco del digitizer para que selle bien el nuevo. Thank you ifixit!
ORLANDO ENCARNACION - crwdns2934203:0crwdne2934203:0
Just completed this repair. Left the ipad out in the sun, playing music while I worked outside. It overheated, and afterwards exhibited “ghost touches” making it nearly impossible to use. It also had a dead spot on the touch screen just above the home button. Research indicated the digitizer was a likely suspect. Sure enough, that fixed it! These instructions were great. A few differences in what was taped and where as the LCD came out, but everything else was spot on. The kit I received from ifixit had kapton tape over some exposed copper at the bottom of the new screen assembly. That may have been all that was necessary, but I put some scotch tape over the copper touch screen traces at the bottom of the screen as well. The copper traces along both sides and the top appeared to be covered completely by a thin plastic sheet, just like the original screen, so I did not tape them. So far, no ghost touch behavior! Thanks for the great site!
Matt Mischnick - crwdns2934203:0crwdne2934203:0
My son dropped our iPad Mini 2 and the glass shattered. Other than that it works perfectly. My question is, do I have to replace the LCD or can I just buy the glass (much cheaper, around $20) and replace that? It seems that repair would be much simpler as well. Thanks in advance.
Richard Cacciato - crwdns2934203:0crwdne2934203:0
Hi Richard, sounds like you only need to replace the glass, although I highly recommend you buy a replacement digitizer that includes the home button. We also have iPad Mini 2-specific digitizer guides. You can find the iPad Mini 2 Wi-Fi guide here, and the iPad Mini 2 cellular guide here.
Sam Goldheart -
Thanks, Sam. How can I tell for sure if I need to replace the digitizer as well or only the glass? As I said, the iPad seems to work perfectly other than the shattered glass.
Richard, my bad on terminology, the digitizer is embedded in the top glass, if the display is undamaged, then you won’t need to replace the LCD, just the digitizer/glass.
Sam Goldheart -
Successfully repaired cracked screen, although more difficult than I anticipated after replacing screens on iPhone 5 and 6. I should have read more of the comments before starting.
The packing tape I used wouldn’t hold suction after heating, find tape with heat resistant adhesive, or pick out multiple pieces.
When I removed the protective film from the inside of the new screen, the yellow tape covering the Home button ribbon came with it, which caused the Home button to short out when the screen was put in place. Replacing the yellow tape solved the problem.
kimhoover - crwdns2934203:0crwdne2934203:0
well i started this repair got the iopener and everything took it slow, got the glass of relised that it was the screen protector (am fixing for a friend). *facepalm* great practice though
GLaDOS .V42 - crwdns2934203:0crwdne2934203:0
I feel that instead of putting plastics in the microwave, the iOpener, you could use a sock filled with sand as an alternative for a heat source to soften the adhesive around the screen.
I feel like there should be more steps than just 66 steps but they’re missing, why?
Nathaniel Egot - crwdns2934203:0crwdne2934203:0
Excelente tutorial, OJO con los pegamentos del LCD a la altura del Botón Home. es muy fácil quitarlo. Todo super explicado.
crodrigocorona - crwdns2934203:0crwdne2934203:0
The prior screen was ghost-touching some spots so I tried replacing with new. Now neither will respond. Any suggestions to troubleshoot or have I bricked it? Or perhaps an updated for the jargon: plated? :( it?
mark40 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 334,562
