Valve Index Headset Tether and Trident Cable Replacement
  1. Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  2. Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
    Do you sell replacement clips?
    TomCatT - crwdns2934203:0crwdne2934203:0
    I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
    Stephen Smith - crwdns2934203:0crwdne2934203:0
    (above comment is meant for the eye tube replacement guide, since the steps appear to be shared between guides)
    Stephen Smith -
  3. Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  4. Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tether cable straight back out of the headset.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
crwdns2935229:015crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87 919 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
blub blub - crwdns2934203:0crwdne2934203:0
Thanks, the clip was giving me problems and this gave me the confidence that I was on the right path. :D
William Wilkins - crwdns2934203:0crwdne2934203:0
Again this autor doesn't understand the meaning of replacing, he just shows us how to dismantle the headset, not how to reinstall it correctly. Useless guide...
Jason Bouchard - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 121
crwdns2936753:030crwdne2936753:0 535
crwdns2942667:0crwdne2942667:0 37,132
