Valve Index Headset Tether and Trident Cable Replacement
crwdns2942287:0crwdne2942287:0Follow this guide to replace the tether and trident cable on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
crwdns2944105:0crwdne2944105:0
Use your hand to gently pull the face gasket straight off of the headset.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Do you sell replacement clips?
I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
(above comment is meant for the eye tube replacement guide, since the steps appear to be shared between guides)
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Pull the tether cable straight back out of the headset.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
crwdns2935229:015crwdne2935229:0
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
Thanks, the clip was giving me problems and this gave me the confidence that I was on the right path. :D
Again this autor doesn't understand the meaning of replacing, he just shows us how to dismantle the headset, not how to reinstall it correctly. Useless guide...
