Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement
  1. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the button at the base of the stylus.
    • The stylus will partially eject.
    • Remove the stylus.
  3. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the right edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain to below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
    I try to find the correct celsius value to heat the bag or direct temp to the sides of the phone. A reference should be a good thing to have. I have a heat bed I use to heat it up. I think 80c can work
    Tobias Müllauer - crwdns2934203:0crwdne2934203:0
    The iOpener did not heat up enough to preform this step. I had to use a heat gun to soften the adhesive. Only takes about 30 seconds to get enough heat on the phone to start to be able to pull the shells apart.
    Anthony S - crwdns2934203:0crwdne2934203:0
  4. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Adhesive information: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Adhesive information: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  5. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    I found the suction cup included with the kit did not allow enough leverage to slide the pick into the phone. I ended up having to purchase their Anti-Clamp "Clampy" as well.
    Once I used "Clampy" with a heat gun, the phone opened right up.
  6. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  7. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the bottom edge: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  8. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  9. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the bottom adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the bottom adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the left edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  11. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
    Take your time with this corner, I ended up breaking the rear glass here. I found sliding the pick in deeper and cutting the adhesive from the inside out worked the best.
  12. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  13. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the top edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  15. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the top adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the top adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  16. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
    Just use the very tip of the pick, go deeper when you feel it slide without much resistance. You will know when you get through all adhesive. The feeling is much more smooth.
  17. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the remaining adhesive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the remaining adhesive: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  18. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    Adhesive may be able to be reused when you assemble.
  19. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
    Apply a bit of heat here as well, with either a hair dryer of heat gun. It doesn't hurt. The pick has trouble cutting otherwise.
  20. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the NFC antenna and charging coil: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
    Easy screws to loose. I use a magnetic mat so I can keep track of them.
    Blue painters tape also works, due to very weak adhesive. Just set screws of the back until reassembly.
  22. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the loudspeaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  23. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  24. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  25. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
    When reassembling, plug phone in and turn on. Make sure everything is connected correctly.
  26. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the lower 5G mmWave antenna: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the lower 5G mmWave antenna: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the lower 5G mmWave antenna press connector.
  27. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the lower 5G mmWave antenna: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the two 3.5 mm-long screws securing the antenna bracket.
  28. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of your spudger between the lower screw mount of the antenna bracket and the frame.
    • Pry up on the bracket until you can grab it with blunt nose tweezers or your fingers.
    • Remove the lower 5G mmWave antenna.
  29. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before reinstalling the lower 5G mmWave antenna, replace the bracket with a new one. If you don't have a new bracket, skip this step.
    • Remove the antenna and connector from the old bracket.
    • Remove the L-shaped adhesive liner from your new bracket.
    • Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
    • Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
  30. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the upper 5G mmWave antenna: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the upper 5G mmWave antenna: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the upper 5G mmWave antenna press connector.
  31. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of your spudger in the gap between the bottom edge of the 5G mmWave antenna and the motherboard.
    • Pry the antenna out of its recess until you can grab it with your fingers or blunt nose tweezers.
    • If the antenna feels stuck, apply a heated iOpener for two minutes to soften the adhesive.
    • Remove the upper 5G mmWave antenna.
  32. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the adhesive on the upper 5G mmWave antenna before reinstalling it. If you don't have replacement adhesive, reuse your old one or use custom-cut adhesive.
    • Remove the existing adhesive from the antenna with blunt nose tweezers or your fingers.
    • Remove the clear liner from your new adhesive.
    • Apply the new adhesive to the bottom of the antenna, with its round end farthest from the connector.
    • Remove the green liner from the adhesive before reinstalling the antenna in the frame.
  33. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the motherboard.
    • Repeat for the secondary interconnect located to the left of the primary cable.
  34. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the charging board.
    • Repeat for the secondary interconnect cable.
  35. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the interconnect cables from the frame.
    Reassembly: Remove battery protective if you haven't already.
    Kristoff-Antonio Forrest - crwdns2934203:0crwdne2934203:0
  36. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the charging board: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  37. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry up the charging board: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry up the charging board: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger under the charging board opposite the USB-C port.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  38. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
  39. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the laser AF module: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the laser AF module: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the laser autofocus module press connector.
  40. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard cover: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the motherboard cover.
  41. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover and laser AF module.
    • During reassembly, press down on the cover to secure its clips to the frame.
  42. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the front-facing camera press connector.
  43. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the fingerprint reader press connector.
    Not the fingerprint reader - this is for the S Pen features
    S22Ultra - crwdns2934203:0crwdne2934203:0
    Cheap OLED screens (not original) won't have this connector and the s pen doesn't work.
    S22Ultra -
  44. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector.
  45. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the stylus' press connector.
  46. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the 3.5 mm-long screw securing the motherboard.
  47. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the motherboard up: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the motherboard up: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the top left of the motherboard and the frame.
    • Pry the motherboard up until you can grab it with your fingers.
  48. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the motherboard by the left edge and remove it from the frame.
    • Be careful not to catch on any loose cables.
    • During reassembly, be sure the cables are above the motherboard when reinserting it.
    5 ribbons to lift.
    Front camera
    Fingerprint reader
    Screen (if still attached)
    Stylus
    Battery
  49. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the earpiece speaker and vibration motor: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the two 3.2 mm-long screws securing the earpiece speaker and vibration motor.
  50. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of your spudger underneath the bottom edge of the earpiece speaker and vibration motor.
    • Pry the earpiece speaker and vibration motor up from its recess and remove it.
  51. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the front-facing camera: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  52. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
    • Use the pointed end of your spudger to pry the front-facing camera from its recess.
    • If the camera doesn't loosen, use your SIM card eject tool to scrape away the epoxy surrounding the camera.
  53. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt nose tweezers to grab and remove the front-facing camera from its recess.
    • Work slowly to avoid tearing the fragile cable.
  54. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, prepare your new frame for the front-facing camera:
    • Remove the black adhesive liner from the front-facing camera recess.
    • Peel and remove the foam liner from the new frame.
    • This liner isn't necessary for the repair.
  55. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before installing the front-facing camera in your new frame, apply new adhesives onto the frame and the camera:
    • Remove the two large clear rectangular liners from the adhesive sheet and place the adhesives on the sides of the camera recess.
    • Remove the liner from the main adhesive piece and place it in the center of the camera recess with its pull tab facing the bottom of the frame.
    • Remove any adhesive residue from the front-facing camera module.
    • Remove the liner from the thin piece of adhesive and place it on the top edge of the camera.
    Don't forget the liner with the pull tab. Almost messed up
  56. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the front-facing camera:
    • Remove all four blue adhesive liners from the camera and the frame.
    • Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
  57. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the display: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the display: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the display cable press connector.
  58. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the display cable: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the display cable: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the display cable from the frame.
  59. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
crwdns2935229:037crwdne2935229:0
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
85,559 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:012,954crwdne2935297:0
crwdns2947412:035crwdne2947412:0
What about the adhesive when reassembling? Do I need to apply more? Or, does the original adhesive, reseal itself?
Kenny GuessWhat - crwdns2934203:0crwdne2934203:0
Hi! The Samsung Self Repair kit includes replacement adhesive to seal up the back cover. As mentioned in Step 18, follow this guide to clean your phone and apply the adhesive with an official replacement. If you don't have replacement adhesive, cut your own adhesive using double-sided tape, as described in this guide. Note that water resistance depends on how well you reapply your adhesive.
If you don't have access to either of these options, and your existing adhesive is in great condition, you may temporarily reuse the existing adhesive. I recommend shaping the adhesive exactly how it was before disassembly, and heating it with a heat gun or hair dryer to soften it before installing your back cover. Exercise caution when heating the phone, and follow this guide as a reference for heating your device.
Clay Eickemeyer -
So I have a stupid question but I was told that if you had a different color phone that the Amoled screen had to match the casing of the phone or it would affect the effectiveness of the screen and the calibration. This sounds so incredibly stupid to me but is this true?
Marie Faulkner - crwdns2934203:0crwdne2934203:0
Anything regarding part compatibility is important to us. May I ask where you heard this, and in what context? My initial reaction is that the screens are compatible, since there is no calibration software, anyway. There is only fingerprint sensor calibration.
Clay Eickemeyer -
@cashewclay I'll second what Marie said - I've heard the same when I called one of the authorized samsung repare centers, they said that they have had multiple odd issues when screen mismatched the back of the phone. Agree that it sounds weird.
Elizabeth -
Been following this guide and unfortunately the replacement screen with frame I got has a different bracket for the Upper 5mm wave antenna, so it doesn't fit back into it. The new one has a little bump out in the middle of the silver bracket (and the molded frame itself). The old one is as pictured here in the guide. The antenna part has a perfectly straight edge, so there's no way to get it in to fit. Any ideas?
Mike W - crwdns2934203:0crwdne2934203:0
Figured it out - to anyone reading this! The 5mmWave radio is different in the Intl models vs the USA "U" models and the frame has a different molding and the aren't compatible! I ordered a replacement screen and frame, from a reputable US vendor, listed as the U model and all the packaging too- and it wasn't. You'll see various parts listed all over online for sale that says 908U or 908B/E interchangeable. They are not! The shell is different so the upper radio antenna doesn't fit and it's impossible to make it fit. You need to make sure you're truly getting the U model frame with any replacement screen.
Mike W -
and if i buy only the screen without the frame but in the publication it has an international version and my cell phone is the us version if it is the same compatible or only the version finished in u is compatible, my mobile phone is the sm-s908u1 please help where to buy
LEO LEO -
Pretty good guide. Had my screen replaced in about 3 hours, took my time to avoid cracking the back glass and was good to go. Had to reheat the i-opener tool about 7 times lol.
The only issues i had was the adhesive for the lower 5G antenna. The adhesive was stuck to the clear plastic much more than the green one, so i had to apply it "flipped" where the bump on the top faced the left instead of the right. Also had an issue with the upper 5g antenna adhesive as it was way too stuck to the plastic and half of it separated when i peeled it off, even when i carefully tried to slice one edge with a razor to promote separation and curling the plastic back. This is however an issue with samsung and not ifixit, obviously.
Overall impressed with the kit.
Oh, and the spudger tool doesn't work too well to remove the front facing camera as it just bends. Use the blunt end metal pliers instead but just be careful.
Ben Sterling - crwdns2934203:0crwdne2934203:0
S pen won't connect after completing this repair. Tried multiple. No luck.
James Stephan - crwdns2934203:0crwdne2934203:0
I see where you disconnect stylus module, is this accessible if I were to open up the ultra s22 ultra myself? Can I just press into place firmly? Or did I get faulty Samsung Genuine Equipment?
James Stephan -
Hi James, I would first recommend trying the troubleshooting solutions provided here: https://www.samsung.com/us/support/troub...
If nothing works, we can check if it could be a physical issue. It's best to check software before opening up your phone again! Feel free to reply here with your findings.
Clay Eickemeyer -
Any knowledge on when these screens will be back in stock?
A A - crwdns2934203:0crwdne2934203:0
Check back next week and we should have them back!
Clay Eickemeyer -
I am lucky to have picked a repair kit and screen last time it was in stock. E-mail notification was almost mandatory as they sold out fast!!!
That being said, my repair was quick and easy to follow along with this guide.
Thank you.
Right to repair is good for everyone!
Stephen Daem - crwdns2934203:0crwdne2934203:0
Thank you for the feedback, Stephan! I'm glad your repair went well.
Clay Eickemeyer -
Does this kit include the actual glass of the screen and the digitizer?
XtaCy696 - crwdns2934203:0crwdne2934203:0
Correct. This kit is the entire screen, attached to the frame and battery.
Clay Eickemeyer -
Oh my god, I was following this guide and in the part when you have to remove the wireless charging thing, I broke the screen ribbon ☠️, I didn't know it was passing below, I had to order a new one, people be careful with this stage
Reyna Isabel - crwdns2934203:0crwdne2934203:0
For future fixers, the step in question is Step 19 of this guide. An appropriate picture and some text is now added to help prevent this!
Clay Eickemeyer -
i can't seem to open self repair assistant apk. i can't calibrate finger recognition.
Young Yoo - crwdns2934203:0crwdne2934203:0
If you haven't done so, already, I'd recommend posting this as a question in the S22 Ultra Answers Forum.
Clay Eickemeyer -
Is it possible to just replace the glass on the screen? Or must you replace the entire screen/battery assembly if the touch screen still functions but the outer lens is cracked?
Oak Metcalfe - crwdns2934203:0crwdne2934203:0
If you can find a replacement part that is just the screen, you may be able to follow this guide (which is for the S21 Ultra—the specific instructions will vary) to remove just the screen and glass panel.
Clay Eickemeyer -
Thank you, I used this guide a few days ago once my part arrived and I completed the repair within 1 1/2 hours. Posted on IG as well. Did this to my personal device first before I offer it up to potential customers. Not as difficult as made to seem. You just have to be patient!!! Thank you again to the author of this tear down/guide and to iFixit for having the parts and tools needed. Need to find out the warranty on tweezers though they seem to bend/break very easily.
Freddie Lopez - crwdns2934203:0crwdne2934203:0
Does the battery and screen (not with kit, that was out of stock, just the part that includes both the screen and battery) come with adhesive? If not, should I purchase the back, front, or both adhesive parts to replace the screen and battery?
Beecat - crwdns2934203:0crwdne2934203:0
Hi Beecat,
The part should come with at least the front camera adhesives. The only other adhesive you'll need to complete this repair is the back glass adhesive. Have you already purchased your part?
Clay Eickemeyer -
Just wondering, could I use the 908U frame for a 908B phone?
Lab DaQ - crwdns2934203:0crwdne2934203:0
FYI, the part did NOT come with camera adhesive (see my previous message)
Also, in step 56, there is a plastic bit not in the original frame (the transparent greenish one) that's never explained.
Se puede instalar una pantalla de s22ultra sm s908u para remplazar una rotación del modelo sm s908b.
Ricardo Castro Marisy - crwdns2934203:0crwdne2934203:0
disculpa ahora que no esta esa pantalla disponible algun otra idea como comprar una pantalla genuina para el sm-s908u1 ayuda porfavor con un enlace gracias
LEO LEO - crwdns2934203:0crwdne2934203:0
For step 55 can you use double sided tape somehow?
Zephyrshop.org - crwdns2934203:0crwdne2934203:0
Hey there, Zephyrshop. For context, this adhesive functions just to keep the front-facing camera in place and aligned with the cutout in the display panel. If you can cut adhesives to the right shape and feel confident that the camera won't move or rattle when the phone is potentially dropped, then you should be fine to use double-sided adhesive. We recommend very strong tape such as Tesa or 3M, so long as you can cut it small enough.
Clay Eickemeyer -
what heppens when i vice verse the Mainboard Flex Cable i connect the main and the sub, does it damage the phone?
Tinashe Tafirei - crwdns2934203:0crwdne2934203:0
Hi, greetings from Finland. I ordered a replacement screen, but it came only with a screen panel. How can I get the broken screen replaced on my old frame with this new part? It seems this guide is for a replacement part where the screen and frame are already glued together.
Arttu Haho - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 62
crwdns2936753:07crwdne2936753:0 497
crwdns2936753:030crwdne2936753:0 2,037
crwdns2942667:0crwdne2942667:0 92,836
