Plastic Tooth Zipper Slider Replacement
  1. Plastic Tooth Zipper Slider Replacement, Gather materials: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Gather materials: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Gather materials: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gather tools and the two pieces required for a plastic tooth slider replacement:
    • A replacement slider that is the right size and style
    • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
    • A top stop
    • There are two types of metal top stops, both of which can be used on plastic tooth zippers (reference image #3).
  2. Plastic Tooth Zipper Slider Replacement, Locate the top stop: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Locate the top stop: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Locate the top stop: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unzip the zipper.
    • Locate the top stop at the top of the zipper on the side with the slider.
    • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
  3. Plastic Tooth Zipper Slider Replacement, Remove the top stop: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Remove the top stop: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Remove the top stop: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wear safety glasses to protect from projectile pieces.
    • Use end nippers or flush cutters to remove the top stop.
    • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop.
  4. Plastic Tooth Zipper Slider Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel away the rest of the top stop from the zipper tape.
    • Use a lighter to lightly singe any fraying zipper tape.
  5. Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the damaged zipper slider up and off the zipper tape.
    • Discard the zipper slider responsibly.
  6. Plastic Tooth Zipper Slider Replacement, Attach the new slider: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Attach the new slider: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Attach the new slider: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
    • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
    • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
  7. Plastic Tooth Zipper Slider Replacement, Place the new top stop: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Place the new top stop: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Place the new top stop: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a replacement top stop and position it around the edge of the zipper tape directly above the top teeth, where the old stop was located.
  8. Plastic Tooth Zipper Slider Replacement, Attach the new top stop: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Attach the new top stop: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Tooth Zipper Slider Replacement, Attach the new top stop: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use pliers to crimp the top stop into place.
    • Check that the new stop effectively prevents the new slider from coming off the zipper.
crwdns2935229:062crwdne2935229:0
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
90 040 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020 931crwdne2935297:0
crwdns2947412:023crwdne2947412:0
Where do I get the parts needed?
jonaskrat - crwdns2934203:0crwdne2934203:0
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - crwdns2934203:0crwdne2934203:0
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 395
crwdns2936753:030crwdne2936753:0 1,969
crwdns2942667:0crwdne2942667:0 782,659
