MacBook Pro 13" Touch Bar 2017 Display Assembly Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the display assembly of your MacBook Pro 13" Touch Bar 2017.
Before starting this procedure, you may want to check with Apple to see if you qualify for a free repair. If your display’s backlight has stopped working, or the display shows vertical bright areas along the entire bottom of the screen (a.k.a. “stage lights”), your MacBook Pro may be eligible for Apple’s display backlight service program.
For your safety, drain your MacBook Pro's battery below 25% charge before starting repairs.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Four 3.4 mm screws
Sur le mien A1708 EMC3164 j’ai 4 vis de 6,2 (les coins) et 2 vis de 3,4 celles au milieu en bas
Ce tutoriel n’est pas dans la bonne section !
c’est le 13” avec touch bar et non celui avec les touches de fonction .
l’autre tuto nommé “écran complet” est le bon
Bonjour Vincent,
Si vous cherchez le même tutoriel pour le MacBook 13” non Touch Bar, le voici : https://fr.ifixit.com/Tutoriel/Remplacem...
Before you start I suggest you get magnifier eyeware as screws and connectors are very small and good lightning are a big PLUS
Completed whole steps in over 4 hours….but worth it. Works back perfect and battery error message is gone….
Nothing beats a properly grounded ESD workstation, and a grounded wrist strap.
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
The instruction implies that sliding the pick up to the side of the case releases the clip. This is far from the truth; it takes a pretty strong force to pop the clip open. The plastic pick is a good start, but you need to reach in and pull the middle of that side of the case pretty hard.
Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Look at Step 8 pics 2 and 3 to see exactly where the clips are that need to be released. Taking the bottom cover off my MBP took for ever because I didn’t realize the clips were not right around the edges as the wording suggests. Once I realized this, it came off quickly and easily.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
On the 2018 model, there are two more clips that need to be popped on the sides in the middle. Then it slides out easily.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Please be VERY careful, I torn up my battery cable and had to replace all the battery.
Apple worked on my computer and did not put the tape back. I'm assuming it's not important?
Gently peel back the small piece of tape covering the battery board data cable connector.
While the tape in this step was definitely attached to the ribbon cable, I accidentally pulled it off during Step 9, thinking that it was a tab to remove the larger tape covering the whole battery connector. It didn’t seem to do any harm.
Ha, yep, me too, I just ripped it right off!
Leo -
Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
Be very careful here. I had to repeat this procedure several times on my MacBook Pro to replace faulty monitors. Eventually, after being opened and closed so many times, the small black locking tab came right off of the connector. Now my battery connection is broken and I can only use my MacBook when it is plugged into the power supply. I’m trying to find a way to securely connect the battery cable without this little locking tab (maybe with tape or something), but so far no luck. Does anyone at iFixit have any advice for me?
Like Jamie said, use mass amounts of caution here. The lever is very fragile, and mine came off as well - and I’m not exactly a muscular guy. Without it, the connection cannot be made to the data connector, and the computer will not think that a battery is installed. I had to finagle my connector with tweezers and a spudger back into place (and the picture above makes it look normal sized. The picture lies. It is TINY! We’re talking smaller than a small eyelash tiny), and then used some of the adhesive battery strip to hopefully keep it in place.
The previous comments are not exaggerated. There ain’t NOTHIN’ to that locking bar. I found it helpful to zoom in with my phone to work on it. It really requires no force to move, I imagine the tape is there to hold it down.
Disconnect the battery board data cable by sliding it out from its socket.
Slide parallel to the logic board, in the direction of the cable.
Fold the battery board data cable to the side and out of the way.
The cable is held down with adhesive. Be very gentle with the delicate cable as you peel it back.
Also, remove the cable from the battery and reuse it later if your battery didn’t come with one, as was the case with mine.
Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
Why is my screwdriver not turning even when I have the correct screwdriver and the screw is not stripped
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Dies ist kein Stecker sondern eine Kontaktplatte, die nur leicht angehoben werden muss. Dann am besten mit etwas Tesafilm isolieren.
(Translation for myself and others; Thanks for the nice tip by the way!) This is not a plug but a contact plate that only needs to be lifted slightly. Then it is best to isolate with some scotch tape.
S Woo -
Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
Remove the cover.
Pry the display board flex cable straight up from its socket to disconnect it from the display board.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
Use a pair of tweezers to remove the two aluminium covers.
When re-installing the display, be careful to make sure that the display cable from the logic board sits properly ABOVE its connector on the display hinge.
What is the exact size of these screws? lost one trying to put it back in and trying to figure out what I need to buy
Step 20….those are T4 Torx screws, not T3.
Is this step necessary? actually i did it, but when installing the new screen, i found the 2 aluminum covers already in the new screen, so i installed the new one without taking them out…
after it worked, i believe we can skip this step.
my laptop is 2017 15”, 1707
Isn't it better to remove these two covers during reassembly to have less friction?
Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
The 1,1mm screws are completly stuck, I have the screwdrivers but the screws are just not turning. Any tips how to take them off ?
I tried other screwdrivrer and put a rubber on it while trying to take it off but nothing works,
Had the same problem with my ‘quality’ P2 screwdriver. A dirt cheap set from Ya Xun, nr. YX-6025 saved the day
I found that a form downward pressure and gentle slowly increasing rotational pressure consistently worked
The 1.1 screws are at a slight angle (on the 2018 model, not sure about the 2017 one) so make sure you angle your screwdriver around 10° off vertical towards the rear edge of the machine.
Stripped a number of these with two different repair kit screwdrivers (other brands). Waiting on a 3rd screwdriver to arrive and then will resort to super glue or a dremel to fit a tool to these and remove. Terrible time with this.
Just removing four LCD screen’s now. This is the worst part by far. I have what I thought was a reasonable quality Baku BK-338 P2 Pentalobe screwdriver. I am onto the third display removal and the WiFi antenna removal is where the fun begins. On the first two WiFi antenna, about five (too depressed to count them) screws rounded out in the pentalobe head. I managed to get them all out using flush cutters - gripping them with the cutters as flush as I could to the surface of the antenna and just trying to get them to rotate CCW a little to “break the seal“ so to speak without cutting in so deep as to totally mangle the head and locking them in even tighter :)
Then I pushed them tangentially with one arm of some stout tweezers and slowly worked them out. Got them all out with minimal damage to the brass part of the antenna but I am confident it will still function OK. On the third one now and four rounded out so I better get back to it. A totally s**t way to attach them and far too many screws IMO. My biggest tip is using a quality tool like the Wera or Wira brands, pushing down into the screw and carefully and slowly applying rotation force. Have some flush cutters on standby in case you round any screws out and good luck.
F# Apple for making pentalobe screws and f# them for using this many.
Wiha calls the P2 driver a 1PL
Pay attention: in both sides the two 3,9 mm T5 Torx screws they are different from each other.
DO NOT mix then otherwise you will won’t be able to install then again correctly.
Wiha 1PL worked perfectly. the 2PL was too big.
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
A good check that the antenna cables are connected properly, is to gently wiggle the wire. The connector will move back and forth without disconnecting. If you press too hard when reconnecting, the soft brass can become damaged, and you'll need a new antenna bar.
Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
Use an opening pick to lever out the antenna cable assembly in the areas shown.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
Reversing this step was the hardest part for me. There is a small “tunnel” that runs under the heat pipe which the 3 antenna cables plus the securing bracket must be threaded through. The shortest cable easily got stuck or pushed off to the side under the heat pipe. After many attempts, I found success by bending the 3 wires ever so slightly to the left before inserting them in the tunnel, so that when they make it through the tunnel, they were more prone to stay straight. It was easy to grab them one by one with tweezers by doing that. Just have to be very careful.
To easily fit the antenna cables – turn the whole antenna assembly about 90 degrees ccw and wiggle it a bit back and forth. Since the cables are a bit prebent they quite easily “pops” up – no need to tie them together. The last trick is to not forget the metal tab – using tweezers or a spudger to help guide the tab in position.
I was very nervous about reversing this step (2016 model) but had very little trouble getting the wires back through the channel (only took me a couple minutes). I had a harder time reconnecting them, but did manage that as well.
Remove the antenna cable assembly.
I had a LOT of trouble re-installing the three antenna cables underneath the heat pipe! The only way I could get them through was to use clear tape to bind the three antenna connectors together tightly into one pointy end. I was able to push that through into place, but I was not able to push the three separate wires through.
It’s possible to avoid this problem by just not removing the antenna assembly entirely. I secured the three cables and the screw holder together with a small cable tie to avoid them slipping out. You can fit the new screen without removing the assembly completely.
Thanks dkraermer2 for that tip of wrapping all 3 wires into a narrow point. I used Capton tape. The metal screw holder needed help as it catches on a ridge in the MB. I used tweezers to “Lift” it over that last ridge.
Make sure the antenna cable assembly locates correctly on reassembly. It is important to install this down onto its locating lugs, not pushing from the rear of the machine towards the front. There is a small ‘u’ shaped cutout on bottom of the assembly and a metal tab which must locate into the corresponding ‘u’ shaped lug and slot cut into the metal of the top case. If this is not located correctly there is a good chance that the screen will foul when opening and closing resulting in an audible click as it catches the antenna assembly.
+1 for BrianS comment. The U shape is a placeholder for the antenna and is located at antenna center. If this ever happened to you, fold gently the antenna strip to leave 3 mm space from the antenna main block, and place the antenna center first in oder for the antenna to fit into the U shape properly.
+1 to both BrianS and Xavier Fischer’s comments above. Even when the lug and the cutout are identified, it’s not easy to tell if it’s been seated correctly until you test the hinge. I found Xavier’s suggestion worked.
Putting the three antenna cables to snap onto the connectors again, It felt like I succeeded after much struggle. But after putting it all together - the screen is black. External monitor works though. 2 of 3 feels certain though as it seems on place.
Once all 16 antenna screws are removed along with single screw securing wifi simply loosen the antenna and while holding each end , ROTATE it and pull away gently so as to not disturb the bend of the wifi wires passing thru the heat pipe. The wires are never physically touched and they keep their “natural” bend. To reassemble, holding antenna, guide the two wi-fi wires and the securing lug thru heat pipe as the antenna is rotated into place . There is a very narrow milled slot on the underside that the antennas metal shield must fit into or else it will cause the snapping clicking noise ( spoken of earlier in this guide )as the display assembly hangs up during its opening / closing. Make sure if need be, the spacing between the metal shield and plastic body of antenna is the same as the ridge between the milled slot and the milled out area moving towards rear of palm rest. Alignment is important.
I was able to install the new screen without removing the antenna cables, I just loosen the antenna screw and uplift the antenna enough to get the screen cables out and reinserted new cable underneath, a helper might come handy while you install new screen.
Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
Repeat this step with the right cover spring of the display cable assembly.
When placing back the holder for the display cable I used the wrong length screws and the bolts connected to the connector strip came off. Is this a concern as I am having back light issues in that I can see the outline of an image but its very dim. Thank you.
Fully open your MacBook and gently place it keyboard-side-down on a table so the screen hangs over the edge.
Support the screen with one hand and use your free hand to remove the six T8 Torx screws securing the hinges.
Firmly secure the main body of your MacBook with one hand.
With your free hand, push the left side of the screen up and towards the bottom of your laptop to free the left hinge.
Free the right hinge and remove the screen.
Make sure the screen hinges are fully open and guide them into their recesses in the frame.
Partially tighten the six hinge screws.
Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
Fully tighten the hinge screws.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
After following the guide and replacing the screen with a new one I am having a problem in that the screen is black almost with a faint glow of the apple logo but its pretty much dark and black all the way. Did I miss something?
Thanks
Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
Macrepair SF - crwdns2934203:0crwdne2934203:0
@mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
Jeff Suovanen -
Thats right! You don't want power running while working on your logic board.
Dan -
This did not work when running High Sierra.
Kyle B - crwdns2934203:0crwdne2934203:0
Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
Cool_Breeze - crwdns2934203:0crwdne2934203:0
I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
Brian - crwdns2934203:0crwdne2934203:0
Is this step necessary if my mac can turn on? Battery fully dead(
Nursat b - crwdns2934203:0crwdne2934203:0
BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
Jason Sherron - crwdns2934203:0crwdne2934203:0
This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
Patrick Machacek - crwdns2934203:0crwdne2934203:0
Not able to do that with damaged screen
richardjgreen - crwdns2934203:0crwdne2934203:0
If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
Roberto Sanchez Bustos -
Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
Adrian Vizik - crwdns2934203:0crwdne2934203:0
Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
Roberto Enrieu - crwdns2934203:0crwdne2934203:0
running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
result: `AutoBoot %00`
Marek Polák - crwdns2934203:0crwdne2934203:0
Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's:
nvram -p | grep 'auto-boot'
to display the current state, the default istrue
- and then to change it,sudo nvram auto-boot=false
which turns it off.Ed Mechem -
This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
Grant Ormsby - crwdns2934203:0crwdne2934203:0
It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
tommy404 - crwdns2934203:0crwdne2934203:0
I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
hatuxka - crwdns2934203:0crwdne2934203:0
BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
bcardanha - crwdns2934203:0crwdne2934203:0
I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
peter sussex -
When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
johann beda - crwdns2934203:0crwdne2934203:0
When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a
pwd
(print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.Ed Mechem -
I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
Mircea Comanici - crwdns2934203:0crwdne2934203:0
After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
Ed Mease - crwdns2934203:0crwdne2934203:0
This should be the default. IMO I tell you to power on - not the lid.
G Sena - crwdns2934203:0crwdne2934203:0
Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
maël muzelet - crwdns2934203:0crwdne2934203:0
Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
Claire Miesch -
Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
Tom Markham - crwdns2934203:0crwdne2934203:0
If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
arichard2401 - crwdns2934203:0crwdne2934203:0
For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
Nicholas R Licato - crwdns2934203:0crwdne2934203:0
Just replaced my 2018 15" MBP battery. Running Sonoma.
I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
Cédric Bontems - crwdns2934203:0crwdne2934203:0
After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
Now, after replacement of the battery, this is all I get to see.
No reset of NVRAM nor PRAM helped.
Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
webrockers - crwdns2934203:0crwdne2934203:0
I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
I missed connecting the left TouchID sensor from step 31.
webrockers -
Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
Jack - crwdns2934203:0crwdne2934203:0
I followed the instructions on my old 2017 MacBook Pro A1707 and I have to say these were the clearest and best instructions I have found on the internet for anything, really. I am about to power up the machine, so we'll see. I'm sure if it doesn't work, it something I was careless with - the instructions matched the hardware perfectly. Def impressed.
Michael L - crwdns2934203:0crwdne2934203:0
