crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Xbox Does Not Turn On
The Xbox is not powering on.
Power cable fault
Make sure the power cable is securely plugged in the console and the wall outlet.
Internal power supply issue
Your Xbox has an internal protection in case of a power surge that cuts power to the console. To reset that protection :
  1. Unplug the cable from the wall outlet
  2. Wait 10-20 seconds
  3. Plug the cable back in the wall
  4. Turn on console
Other issues
If the light on the console turns on and stays on, follow the no video output troubleshoot.
Faulty power supply
If the issue was not resolved by any of the above steps, your Xbox might need to have the IR blaster replaced.
Faulty Power Switch on IR Blaster
If the issue was not resolved by any of the above steps, your Xbox might need to have the power supply replaced.
Faulty motherboard
If the problem persists, consider replacing your motherboard.
Loud Fan
The Xbox turns on but emits a constant scraping noise from the inside.
Bad ventilation
The first step in eliminating problematic fan noises being emitted from the console is to relocate the console to a well ventilated area. If the fan noise does not subside, a diagnosis of the fan component is recommended.
Foreign object in fan
The Xbox One S Digital Edition fan must be inspected for dirt accumulation. Cleaning is advised If there is visible dirt accumulation within the fan. Follow the fan replacement guide, use compressed air to get rid of dust and dirt sitting on the fan or in the console and see if the noise stops. (Be careful to not spin the fan when applying compressed air as it might induce a current in the system and damage the motherboard. Hold the fan in place or disconnect it when cleaning).
Dislodged bearings
If the noise does not subside after cleaning, the fan bearings may be malfunctioning and must be replaced in order for the console fan to serve its ventilating function.
Bent top chassis piece
If the noise persists, the chassis might have to be replaced.
No Video Output
The Xbox is on and running, but the expected Xbox visuals are not on the TV or monitor.
Restarting
First things first , turn your Xbox off by holding the power button for 10 seconds, then turn it back on. If nothing changes, keep reading.
Wiring issue
Most commonly, the HDMI is not plugged in correctly. Check that the HDMI cable is firmly plugged into both Xbox and TV. Also check that the HDMI cable is connected to the “out to TV” port on the Xbox One S. Finally confirm that your TV is on the correct source channel, matching the port the HDMI is connected to your TV. Example (HDMI1 vs. HDMI2).
AVR setup
If you are using an audio-video receiver(AVR) adaptor, turn off the TV, AVR, and Xbox. Then turn everything back on in this order:
  1. TV
  2. Once TV is displaying, turn on AVR
  3. Xbox
Then switch the input source of AVR off of the Xbox HDMI then switch back to it. Lastly, reset the AVR and proceed to use your Xbox.
Faulty Motherboard
Unable to Download New Content or Games
New content and games cannot be added to the console
Lack of free space
Check the internal storage usage in the settings of your Xbox. If the remaining space is smaller than what you are trying to download, you will need to remove other games or add an external storage system.
Software is not up to date
Some content might require the Xbox to be running the latest update in order to be downloaded. Update your system by pressing the Xbox symbol at the top of the controller and selecting the System > Settings > Updates & Downloads. Try again after the update completed.
Faulty hard drive
If the issue persists, the hard drive might need to be replaced.
Xbox Powers Down Unexpectedly
While in use the Xbox turns off without being told to or the power button being pressed.
Overheating issues
This usually happens because the Xbox is overheating due to a variety of different issues. First, make sure that the Xbox’s ventilation system, the various slits in the plastic case, is not covered with any objects that would impede airflow into the Xbox.
Settings issue
This could also be a settings issue, press the Xbox symbol at the top of the controller and select the System > Settings > Power, and then select the Turn off or restart button.
Other issues
If the Xbox continues to power off while in use this could be a problem with the Power Supply and it should be replaced.
Jules Hajjar
crwdns2935283:010/10/19crwdne2935283:0
2,122 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G6, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G6, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G6
crwdns2935297:096crwdne2935297:0
crwdns2944067:015crwdne2944067:0
My Xbox has the update error but I haven't been able to get to the troubleshooting menu help please??
kazwoodman70 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My digitally preloaded Xbox One does not work. No lights or anything else. Suggestions??? Email to fesmit2015@gmail.com Thanks
Felicia Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My power on light comes on for about 2 sec and goes back off. Help
Berg Mandrake - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I did all it and my xbox or controller won’t turn on
Micah - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My xbox one s will not load gta5 online
Robert Russell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:030crwdne2936753:0 142
crwdns2959996:0crwdne2959996:0 14,301
