Xbox One S All Digital Edition Fan Replacement
  1. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Fan Replacement, IR Blaster: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, IR Blaster: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  8. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  9. Xbox One S All Digital Edition Fan Replacement, Wifi Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Wifi Card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  10. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the WiFi Card from the metal chassis.
  11. Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Fan Replacement, Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement, Fan: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the 4-pin connector on the side of the fan assembly.
    • Disconnect the cable from the motherboard.
  15. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry the fan tabs up and away from the heatsink.
    • Getting the fan detached can take some force. A metal tool might be required.
  16. Xbox One S All Digital Edition Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan away to fully remove it.
crwdns2935229:08crwdne2935229:0
Jules Hajjar
crwdns2935283:010/10/19crwdne2935283:0
2,122 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G6, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G6, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G6
crwdns2935297:032crwdne2935297:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 291
crwdns2942667:0crwdne2942667:0 12,755
