Camcorder will not turn on
First, make sure the battery is in the camcorder.
Battery is depleted
Connect the charger to the battery charging port on the camcorder and to a power source. If you are plugging your charger into a power strip, make sure that the strip is plugged into the wall, and that the switch is in the "on" position. Let the battery charge for a few hours before next usage.
Power source is not supplying electricity
If the camera still will not turn on after being connected to a power source for a few hours, the power source might not be supplying electricity. Try to connect the charger to a different power source.
Battery is not charging
Connect charger correctly
Double check that the charger is connected correctly to battery charging port on the camcorder.
Switch power supplies
Make sure the power source you are plugging your charger into supplies power. Do this by trying a different power source. If the battery is still not receiving charge after a few hours, consider purchasing a new battery. Review the repair guide for changing the battery.
RCA CC310 Battery Replacement
Bad charger
If the charger is correctly plugged into the camcorder and to a power source that supplies electricity, then the charger may not work. Consider purchasing a new charger.
Tape will not eject
First make sure that you are pressing the "EJECT" button above the tape deck.
No power
Check that the battery is charged and the camcorder is on.
Tape gate release is broken
If the camcorder is charged and the "EJECT" button is functioning properly, but the tape still will not eject then the motor may need to be replaced.
Viewfinder is black or not clear
Lens cover is on
Take the lens cover off from the lens.
Autofocus is off
Near the front of the camcorder, by the side button panel, move the switch from "Manual" to "Autofocus." If image is still not focused, switch option back to "manual" and rotate the lens until the image is focused.
Lens is dirty
Gently blow on your lens. This should remove any dust or dirt that lingers. Use a cloth to rub the lens free of fingerprints or remaining dust. Don't press to hard on the lens. For dirt, consider using a cleaning brush specifically for lens. Use the brush very lightly as well.
Replace the viewfinder
Make sure both the lens and the viewfinder lens are clean. If still unclear, rotate the focus knob located on the left side of the viewfinder until the image is focused. If the image is still not clear, refer to the repair guide on replacing the viewfinder.
RCA CC310 Viewfinder Replacement
Camcorder will not play video back
First make sure there is a tape in the deck.
Slide switch to "PLAYBACK"
Be sure to slide the camera/playback switch to playback located on the top button panel.
Tape is dirty
If playback screen is blue or not playing, it is possible that the tape is dirty. If you have compressed air, use it with the straw attachment to blast air on either side of the openings the tape feeds through. Also blast air in the hole on the underside of the tape. This will dislodge dust and dirt that may have accumulated. Try playback again to see if viewing has improved.
Cable is shorted
Check the cable connecting the camera and the viewfinder. If there are cuts or breaks in the cable, then that could be the reason the video is not playing back. Consider replacing the cable to play the video back.
No audio during playback
Turn up the volume
Check that the volume dial on the bottom-rear of the camcorder is turned toward "max."
Cable to speaker is shorted
If audio is not playing back after you have turned the volume dial completely toward "max," the cable may be shorted that connects to the speaker. Review the repair guide for replacing the on board speaker.
RCA CC310 Onboard Speaker Replacement
Onboard microphone malfunctioning
If the audio is not playing back after you have turned the volume completely toward "max," the onboard microphone may be broken. Review the repair guide for replacing the onboard microphone.
RCA CC310 Onboard Microphone Replacement
Wrong time displayed
The wrong time is displayed in the viewfinder.
Clock battery is dead
If the timestamp clock in the viewfinder resets after changing the camcorder battery, your clock battery has died. Check the back panel of the camcorder for the "Clock Battery" latch and replace the clock battery. To do this, push the clock battery down, and the battery should pop out. Make sure the side of the battery with the writing is facing outward when replacing.
Reset the time
Find the flip down door under the side button panel. Set the time using the "select" and "advance" buttons.
Effect buttons not working
First, make sure that the camcorder is turned on. If there is water damage, or the camera is on and the buttons aren't functioning still, you may have to replace the effect button circuit board. Review the repair guide below to do this.
RCA CC310 Effect Button Circuit Board Replacement
Ashley Katchadourian
crwdns2935283:001/20/11crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-20, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-20, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G20
crwdns2935297:084crwdne2935297:0
crwdns2944067:05crwdne2944067:0
Can i play mini dv with my sony trv18e camcorder without a battery in it .?(Don't have bettery) using only ac power adaptor.
Md Shahed - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is probably a long shot but I recently purchased a used rca cc310 on FB marketplace. I got it to properly eject by replacing a disintegrated belt with a rubber band and it worked perfectly. Cleaned the heads and it started showing picture through the viewfinder. Assumed I had a hidden gem in near working order, and I still do. Everything was working up until recently. The viewfinder and camera module do seem to still need some warming up (and a few knocks to the casing) to display but one issue has arisen. When I go to record or playback a tape (that is when the tape is to be taken up with the reel, played/recorded at normal speed) it just won't do it. Every other feature works. FF, RW, the motor feeding the tape to the spool works. Just when it's trying to playback or record the spool wont turn. I suspect it's a wiring issue, because there's no obstruction, and the motor driving that spool operates with other tasks. Help? It's a specific issue
Samuel Walton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’m not sure if this is your problem but I ran into similar issues with my CPR-350 SVHS camcorder. The tape would wrap around the play head but not move. I needed to replace the pinch roller which is the rubber cylinder before the play head. it was old and not gripping the tape enough. Also I ran into additional issues due to the video head being dirty. It wasn’t visibly dirty but the tape had trouble with it anyway. I cleaned it with alcohol Q tips and an old tooth brush then it worked a lot better .
Also there is at last 1-2 more rubber belts in there, a square tubular belt and a flat belt. I ordered replacement belts for those and the eject belt because rubber bands have a really short lifespan and if you can get them to work, they won’t last more than a couple years.
Good Luck,
Anton
Anton Doiron - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do you buy a replacement part like a circuit board for the VHS RCA?
Elizabeth Celestial - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I don’t think you can anymore. You’d have go back in time to 1989 and contact RCA :)
A possible option is to look on ebay for a used model then pull the circuit board out of it. I’ve seen parts also for sale. I also use shopgoodwill.com for finding these things. I wanted parts for one of mine but ended up getting one in better shape so I don’t want to take it apart.
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 6,220
