How to Find a Style Number on Your Patagonia Clothing
Return to the Patagonia Care & Repair homepage.
Technical Guides
Lifestyle Guides
Stain Removal
Read how to deal with different kinds of stains with our Stain Removal Help Page:
Water Repellency
DWR
A DWR (durable water repellent) finish keeps moisture from saturating the outer fabric of your garment. Our proprietary Deluge® DWR finish lasts substantially longer than standard DWRs, but still requires proper care for optimal performance.
If water no longer beads up on your shell, it’s time to apply another coat of DWR finish. We recommend replenishing the DWR once per season, or more often if the garment undergoes heavy use or washing. Our favorites are Storm® products, though there are many good products on the market.
Whatever you choose, be sure to use a spray-on for 2-layer garments (with a hanging mesh liner) and a wash-in for 3-layer garments (with an interior fabric protecting the barrier).
How does it work?
Durable water repellent (DWR) is a chemical applied to the face of waterproof fabric at the factory to help keep moisture from saturating. But over time, dirt, salt, oil, sunscreen, bug repellent, wax, even chocolate, will reduce its effectiveness, causing the outside of a jacket or pants to absorb water – often called “wetting out.” When this happens, your outerwear may feel cold and wet. And it will not perform like it did when it was new.
How do I test my garments?
It’s pretty simple. If water beads up and rolls off your garment, your DWR is working. If water soaks into the fabric and turns a darker shade, then you need to reapply DWR.
Fabric Care
Ironing
In general, Patagonia garments do not require ironing. However, if you’re trying to make a good impression on “the parents,” and you want to sharpen the crease down the front of your pants after an afternoon of bouldering, you should check the iron symbol on the care label of your garment first to make sure it can be safely ironed. If the iron symbol has a line through it – don’t iron. The dots on the label correspond to how much heat you should use – fewer dots mean less heat.
Flammability
Like most synthetics, our shells, fleece and Capilene® fabrics will melt or burn if exposed to flame or direct heat. They are not flame resistant; do not use them near ANY direct source of heat or flame.
Dry Cleaning
Patagonia doesn’t make anything that requires dry cleaning. Our clothes are designed for rugged adventures, and thus are made to be worn and washed with little fuss. More importantly, the EPA estimates that 85% of the dry cleaners in America use perchloroethylene, or “perc,” to clean garments and textile products. This chemical solvent has significant human and environmental risks. We make clothes that wear and perform beautifully without all that.
Fabric Conditioner
Generally we don’t recommend using fabric conditioners or softeners on our products. They can cause seam slippage in clothing with open-weave construction, and can decrease overall durability.
Washing Instructions
Washing instructions are printed on a white tag inside our garments. Follow these instructions to help your gear have a long, interesting life. For Patagonia garments, in general, wash in cold or warm water with mild laundry detergent (with a preference for nontoxic and biodegradable) and dry on a clothesline. We recommend Granger's products because of their outstanding performance and bluesign® approval.
For a guide to the product care symbols that you may see used on our clothing care tags, click here.
Gladiodor® Garment Odor Control
Odor control has become de rigueur for technical knits in the outdoor clothing marketplace. Gladiodor garment odor control is our solution. Gladiodor treatments are thoroughly tested for functionality, initially and after washing. To pass our lab testing, the treatment must be effective even after 50 washes.
We recommend washing garments that feature Gladiodor garment odor control in cold or warm water with mild laundry detergent (non-toxic, biodegradable types preferred) and dry it on a clothesline if possible. You can also use a dryer on a low heat setting. (Line drying saves energy and reduces environmental impact).
GORE-TEX® Fabrics
GORE-TEX® fabrics will provide optimal performance if kept clean and free from dirt, sunscreen, oils from skin and perspiration.
Machine-wash GORE-TEX® garments in warm water (104º F/40º C) using a mild powdered or liquid detergent, we recommend using Granger's Performance Wash. Make sure to rinse garments well to remove all of the detergent. Don’t use a fabric softener.
Tumble dry on a warm setting. The dryer’s warmth helps renew the fabric’s durable water repellent (DWR) finish, which keeps the outer fabric from becoming saturated in wet conditions.
If water no longer beads up on the garment, it’s time to put on another coat of DWR finish. We recommend replenishing the DWR finish once per season, or more often if the garment receives frequent use and washing. Our favorites are Granger's® products, though there are many good products on the market. Whatever you choose, be sure to use a spray-on for all garments made from GORE-TEX® fabric.
To remove grease from a garment, dampen the stain and rub in dishwashing detergent. Then wash the jacket in warm water with plenty of mild laundry detergent. If the stain persists, sponge it with a safe cleaning fluid (Renuzit® or Carbona®) or mineral spirits, which can be found at most markets or home improvement stores.
To get gum or sap off of a garment, first freeze the sap or gum with some ice, then use a dull butter knife to scrape off as much as you can. Next, soak the garment in a water/white-vinegar solution, and machine wash with warm water and detergent.
H2No® Fabrics
It’s important to keep your H2No® garment clean for optimal performance. Wash any H2No® garment in a washing machine in warm water (104º F/40º C) using a mild detergent. Make sure you rinse the garment well to remove all of the detergent. Don’t use a fabric softener.
Tumble dry on a warm setting. The dryer’s warmth helps renew the jacket’s durable water repellent (DWR) finish, which keeps the outer fabric from becoming saturated when you’re in wet conditions.
If water no longer beads up on your garment, it’s time to put on another coat of DWR finish. We recommend replenishing the DWR finish once per season, or more often if the garment receives frequent use and washing. Our favorites are Granger's® products, though there are many good products on the market. Whatever you choose, be sure to use a spray-on for two-layer garments (with a hanging mesh liner) or a wash-in for three-layer garments (with an interior fabric protecting the barrier).
To remove grease from an H2No® jacket, dampen the stain and rub in dishwashing liquid. Then wash the jacket in warm water with plenty of mild powder laundry detergent. If the stain persists, sponge it with a safe cleaning fluid (Renuzit® or Carbona®) or mineral spirits; you can find both at your local grocery store.
To get gum or sap out of a garment, first freeze the sap with some ice, then use a dull butter knife to scrape off as much as you can. Next, soak the garment in a water/white-vinegar solution, and machine wash with warm water and detergent.
Merino Wool Baselayer
Merino’s odor-resistant properties allow you to wear your garment multiple times between washings (ideal for road trips). That said, when even your dog refuses to share your sleeping bag, machine wash your merino baselayer in cold water and detergent, we recommend Granger's Merino Wash. Tumble dry on low temperature, or dry flat to save energy and reduce environmental impact.
Merino Wool/Nylon/Polyester/Spandex Blends
We blend fibers to provide comfort, moisture-wicking, stretch and long-term durability. Fiber blends withstand wear for a long life and resist odor, so you’ll still have friends when you’ve finished your trail run.
Machine wash fabric blends in cold water and tumble dry on low temperature (or hang them out the window on the drive between Bishop and Tuolumne).
Polartec® Powershield® Pro
Clean your Polartec® Powershield® Pro garment in a front-loading washer with cold water (85º F/30º C) and a mild detergent. Tumble dry on low heat to improve DWR (durable water repellent) finish performance. (Line drying saves energy and reduces environmental impact).
PrimaLoft® Insulation
Machine wash your Primaloft® garment with a mild detergent on a gentle, cold-water cycle. Tumble dry on low or line dry.
Regulator® Insulation
Machine wash your Regulator® Insulation in cool to warm water with a mild laundry detergent (nontoxic, biodegradable types preferred). Dry by hanging on a clothesline or in the dryer on a low heat setting. (Line drying saves energy and reduces environmental impacts).
To remove grease from the polyester fibers of Regulator® Insulation, first try a liquid detergent rather than a powdered one in your washing machine. If the grease persists, rub the stain with a cotton ball or cotton cloth dampened with a few drops of denatured alcohol (found in the paint section of most home stores) to break up the grease, then wash as normal.
UPF Fabrics
Lacking fur, feathers or scales, we humans have to think up clever ways to protect ourselves from the sun. Products with a UPF (ultraviolet protection factor) designation provide built-in sun protection that won’t wear off.
Elements of the sun-protection strategy can range from yarn selection to fabric construction to the use of special finishes (especially for light colors). To launder fabrics with a UPF rating, simply wash in cold water and tumble dry low (or line dry to reduce environmental impact).
Capilene®
Machine wash Capilene® garments in cool to warm water with a mild, powdered laundry detergent (nontoxic, biodegradable types preferred). Line dry or tumble dry on low heat. (Line drying saves energy and reduces environmental impact).
To remove grease, first try washing the garment by hand with a good liquid dishwashing detergent, rather than machine washing it with a powdered laundry detergent. If the grease persists, rub the stain with a cotton ball or cotton cloth dampened with a few drops of denatured or isopropyl alcohol (found in the paint section of most home stores) to break up the grease, then wash as directed by the garment care tag.
Cashmere
Wash cashmere by hand in cool water. Use mild shampoo or liquid dishwashing detergent with a pH level below 7. If you use powdered laundry detergent that requires warm water to dissolve, let the water cool before adding your garment. Let the garment soak quietly in the basin or gently swish the garment, but don’t agitate, twist or rub it. After soaking, rinse with fresh water until the water runs clear. Gently squeeze excess water from the garment.
Air-dry a cashmere garment by laying it flat on a dry towel and stretching it to the correct size and shape before drying.
You can remove stains from cashmere by spot-washing with a natural stain remover like vinegar or lemon juice. (Test in an inconspicuous place first).
Cotton
Wash your organic cotton gear in cool to warm water with mild laundry detergent (non-toxic, biodegradable types preferred) and dry it on the line if possible. You may also use a dryer on a low-heat setting. (Line drying saves energy and reduces environmental impact).
Down Insulation
Wash your down garment in cold water in a front-loading machine with a gentle detergent. You can find specific detergents made specifically for washing down items. Machine dry on no to low heat (may take a few cycles) with two to three clean tennis balls added to the dryer to restore fluff. DO NOT bleach, iron or use fabric softener. We recommend using Granger's Down Wash.
Hemp
Wash any garment made from hemp in cold or warm water with mild laundry detergent (non-toxic, biodegradable types preferred) and dry it on a clothesline if possible. You may also use a dryer on a low heat setting. (Line drying saves energy and reduces environmental impact).
Lambswool
Wash lambswool garments by hand in cool water with a bit of dishwashing liquid, or Granger's Merino Wash. Let the garment soak in the basin — don’t agitate the water, twist, rub or wring out the garment. Then rinse with fresh water until the water runs clear. Gently squeeze out excess water.
Air-dry your lambswool garment by laying it flat on a dry towel and stretching it to the correct size and shape before drying.
You can clean up stains on lambswool by spot-washing with a natural stain remover like white vinegar or lemon juice (test in an inconspicuous place first).
Nylon and Nylon/Spandex
Machine wash nylon garments in cool to warm water with a mild laundry detergent (nontoxic, biodegradable types preferred). Line or tumble dry on low heat.
Organic Cotton and Organic Cotton/Nylon/Spandex/Tencel® Lyocell Blends
Wash in cool to warm water with mild laundry detergent (nontoxic, biodegradable types preferred) and line dry or tumble dry on low heat.
Polyester
Wash polyester in warm water in a machine set to Permanent Press. Use a mild laundry soap (non-toxic, biodegradable types preferred) and line dry if possible. You may also use a dryer on a low heat setting, just make sure to remove it from the dryer quickly to prevent wrinkling.
To remove stains from polyester, try a few drops of dishwashing liquid directly on the stain and rub until the stain starts to lift. Rinse thoroughly with clean water.
Polyester Mesh
Machine wash your polyester mesh fabric in warm water on the “permanent press” setting. Use a mild powdered laundry detergent (non-toxic, biodegradable types preferred) and dry it on a clothesline if possible.
To remove stains from polyester mesh fabrics, try a few drops of dishwashing liquid directly on the stain and rub until the stain starts to lift. Rinse thoroughly with clean water.
Polyester/Nylon Blends, Polyester/Spandex Blends and Polyester/Nylon/Spandex Blends
Machine wash your polyester or polyester blend garments in warm water on the “permanent press” setting. Use a mild powdered laundry detergent (non-toxic, biodegradable types preferred) and line dry, or tumble dry on low heat. (Remove it from the dryer quickly to prevent wrinkling).
To remove stains, try a few drops of dishwashing liquid directly on the stain and rub until the stain starts to lift. Rinse thoroughly with clean water.
Polyester/Organic Cotton Blends
Wash your polyester/organic cotton blend in cool to warm water with mild laundry detergent (nontoxic, biodegradable types preferred) line dry, or tumble dry on low heat.
Recycled Polyester
Machine wash polyester in warm water on the ”permanent press” setting. Use a mild laundry detergent (nontoxic, biodegradable types preferred) and dry it on a clothesline if possible. You may also use a dryer on a low heat setting, just make sure to remove it from the dryer quickly to prevent wrinkling.
Recycled Nylon
Machine wash your recycled nylon garments in cool to warm water with a mild powdered laundry detergent (non-toxic, biodegradable types preferred). Line dry or tumble dry on low heat.
crwdns2944067:016crwdne2944067:0
Hi, thanks for this great resource - I noticed that the link in the Care Instructions section is missing “you may see on our clothing care tags, click here."
Jonathan Robinson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Thanks , just to know how cat ionic DWR works on merino wool
Nilay - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My black outterwear down, 100% polyester, zip up jacket has faded in color from that nice jet black to dull faded out greyish black.
Would dry cleaning or washing help restore the original jet black color back to my beloved jacket? It has never been washed or dry cleaned. Should I just send it in for repairs?
Thanks.
Kathy
kathygoodwoman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks so much for you care and washing instructions, I have never seen better! Although you you probably don’t sell this fabric, but I would really love instructions for a dearly loved garment, a simple plain coloured (deep purple) top, made of silk (bought from a charity shop and I’ve worn it for years but slowly it has accumulated dark stains- probably food and perspiration, despite very careful washing and ironing (it is my only “good” garment for”visiting the parents”) I would very much appreciate your comments
Alison Kenyon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a very pulled synthetic jacket. Everything sticks to the fabric. How can I safely remove the pills without damaging. I only find instructions for de-pilling/ de- linting.
Sondra E - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
