crwdns2952163:0crwdne2952163:0
crwdns2869449:0crwdne2869449:0
crwdns2959928:0crwdne2959928:0 ↓You may want to iron your waterproof jacket if it's gotten a little wrinkly, or if it's just been washed and you don’t have access to a dryer but still want to restore its water-repellent finish. Applying heat is key to both smoothing out the fabric and reactivating the DWR coating. While a dryer is ideal for both of these purposes because it evenly distributes heat across the entire garment, using an iron is better than no heat at all!
Every jacket is different, so pay close attention as you iron. Avoid ironing over drawcords, zippers, or other closures that can create a bumpy surface or risk damage. If you don’t have an ironing board, no problem—just fold up a towel on a solid heat-resistant surface like a table or countertop to create a makeshift ironing station.
Related Tutorials
Related Wikis
Tailor's Hamcrwdns2942747:0crwdne2942747:0 crwdns2959944:0crwdne2959944:0crwdns2931591:0Amazoncrwdne2931591:0
Sleeve Boardcrwdns2942747:0crwdne2942747:0 crwdns2959944:0crwdne2959944:0crwdns2931591:0Amazoncrwdne2931591:0
Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
Flatten your jacket with your hands.
Set the iron to its lowest heat setting, below 230 °F.
Lay a dry towel over the area of your jacket that you'll be ironing.
Smooth out the towel with your hands.
Iron in one smooth stroke, running parallel to the zipper.
Remove the towel and inspect the jacket.
If the fabric looks unchanged, increase the heat slightly and try again.
If the area looks smooth, move on to the next section.
To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
crwdns2935229:024crwdne2935229:0
crwdns2947412:017crwdne2947412:0
Thank you, good advice for younger generation who have clue.
keirakeith26 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I hope the non-English comment is also in the same form as the first 3.
Eva - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
