Phone will not turn on or turns off periodically
No matter what you do, you cannot get your Droid DNA to turn on.
Battery needs charging.
Everyone forgets to charge their phone every once in a while! Try plugging the phone into a power source using the appropriate charger.
Bad Battery
There are several problems your phone battery might have with different symptoms. The most obvious sign of a bad battery is that the cell phone shuts itself off. Other common symptoms include: the charge does not last, the battery is swollen, or there is excessive heat coming from your phone. If any of these are the case, your battery may need to be replaced. Here is a link to a replacement guide for the battery:
HTC Droid DNA Battery Replacement
Bad display
It is possible that the phone appears to be off because of a bad LCD Screen. You may need to replace the LCD screen. (GUIDE URL WILL BE UP SOON)
Bad motherboard
Another possible root of the problem could be that your phone's motherboard is fried. Your motherboard may need to be replaced. Here is a replacement guide for the motherboard:
HTC Droid DNA Motherboard Replacement
Phone will not charge
Despite how long you plug in your charger, your phone will not charge.
Cable Malfunction
It is entirely possible that the problem does not lie with your phone. Sometimes, the charging cables have broken wires or a broken micro USB connector. Try using a different cable to charge your device, if available.
Bad Battery
If the phone is able to charge, but the charge does not last very long, your battery is most likely dying and may need replacement. Here is a link to a replacement guide for the battery:
Broken Micro USB Port
Your device may not be charging because the micro USB port (where you plug in the charger) is broken. You may need to replace the Micro USB port. Here is a replacement guide for the Micro USB port:
HTC Droid DNA Micro USB Port Replacement
SIM card error message
A SIM card identifies you as a mobile subscriber and holds anywhere from 32KB to 128 KB of data from your phone. If a SIM card error message appears on your phone's screen, it is likely due to one of the following issues.
Reset SIM Card
There are times when the SIM card loses connection to the phone. Try removing the SIM card and putting it back to the phone.
Restart Phone
Restart the phone to reestablish the SIM card connection. If you are still getting a SIM card error message, the next solution may be your best bet.
Bad SIM Card
When the phone gives a SIM card error message, the problem usually lies in the SIM card being faulty. If the SIM Card is malfunctioning, it most likely needs to be replaced. Here is a replacement guide for the SIM Card:
HTC Droid DNA SIM Card Replacement
Phone runs slowly
Your Droid DNA does not seem to be running as quickly as it did when you first got it.
Overloaded Cache
One simple reason that your DNA is moving slowly is that the cache may be overloaded. Try clearing the cache through stock recovery. You will not lose any data or anything so do not worry! Here are the steps you will need to follow:
1. Shut down the device.
2. Hold down the volume down and the power button simultaneously until you boot into the HBOOT Menu
3. Select the RECOVERY option using the volume buttons
4. Your phone will show the white HTC screen, then you will see a black screen. It will take a while but it will say "Failed to mount SD" four times. Wait until it turns into a red triangle with an exclamation point inside the triangle and from there, hold down the Volume Up and then press the Power button. You will see a small list, this is stock recovery.
5. Select wipe/cache.
Factory Reset
As a last resort, you can try doing a factory reset. WARNING! This will remove all data on your phone, so back up any important files to an SD (Secure Digital) card before doing a factory reset. Here are the steps you will need to follow:
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Phone camera will not turn on
The camera app freezes or the camera will not take pictures.
Force the Camera App to Stop
Sometimes the camera app freezes, and simply forcing the app to stop will solve the problem. You can do this by going into Settings>Applications>Select all, and then find the camera application and then hit the buttons "Clear Data," "Clear Defaults" and then "Force Stop."
Factory Reset
See the Factory Reset instructions above.
Bad Camera
Occasionally, the front or back camera is causing the malfunction, not the phone. in this case the broken camera may need to be replaced. Here are the replacement guides for the front-facing and rear-facing cameras:
HTC Droid DNA Front-Facing Camera Replacement
HTC Droid DNA Rear-Facing Camera Replacement
Cayce Rast
crwdns2935283:010/13/14crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-2, Benson Fall 2014 crwdns2935289:0Clemson, Team 1-2, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S1G2
Dear sir,
I am using HTC Verizon, since I have installed the new Verizon update, it's has changed my settings. Every time I make a call it's automatically add the extension +10.. yet I am in Uganda and our extension is +256 .
I will appreciate if I can receive any help from you.
Kinds regards,
FREDDY.
Freddy Massamba - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 36
crwdns2959996:0crwdne2959996:0 12,960
