HTC Droid DNA Battery Replacement
crwdns2869540:0crwdne2869540:0: 18K
3
24
90
18,090
crwdns2955950:0crwdne2955950:0: 6
crwdns2960004:04crwdne2960004:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 16
crwdns2959974:016crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 40 - 45 crwdns2931279:0crwdne2931279:0
Use this guide to replace your HTC Droid DNA's battery.
    1. HTC Droid DNA Battery Replacement, Remove the SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    2. HTC Droid DNA Battery Replacement, Removing the SIM Card Tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Removing the SIM Card Tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull out the SIM Card Tray with your fingers.
    1. HTC Droid DNA Battery Replacement, Loosen the Phone Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Loosen the Phone Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the USB cover on the bottom of the phone is removed first.
      • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
      • Take your time. A lot of force is necessary to loosen the front panel.
    2. HTC Droid DNA Battery Replacement, Pull the Casing Apart: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly pull the panel apart from the back of the phone.
      • Apply a moderate force to pry the panel from the back of the phone.
    3. HTC Droid DNA Battery Replacement, Remove the Black Tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Set the device down so that the bottom of the phone is facing to the right.
      • Gently take off the piece of black tape surrounding the motherboard.
      • Be careful not to rip the tape.
    4. HTC Droid DNA Battery Replacement, Remove the Yellow Tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    5. HTC Droid DNA Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
      • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    6. HTC Droid DNA Battery Replacement, Remove the Void Screw: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    7. HTC Droid DNA Battery Replacement, Remove the Screw Retaining Bracket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate your phone back 90 Degrees counter-clockwise.
      • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    8. HTC Droid DNA Battery Replacement, Remove the Connector Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following Phillips #000 screws from the motherboard:
      • Four 1.6 mm screws
      • Two 1.5 mm screws
    9. HTC Droid DNA Battery Replacement, Unfasten the Connectors: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Unfasten the Connectors: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your pry tool to unfasten the connectors on both sides of the motherboard.
      • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    10. HTC Droid DNA Battery Replacement, Remove the Yellow Tape: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to remove the two pieces of yellow tape shown.
    11. HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    12. HTC Droid DNA Battery Replacement, Disconnect the Connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
      • Be careful not to bend the Flex Cable of the Connector.
    13. HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    14. HTC Droid DNA Battery Replacement, Disconnect the Connector: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
      • Be careful not to bend the Flex Cables for the Connector.
    15. HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Flipping up the White Board: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the phone 180 degrees.
      • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    16. HTC Droid DNA Battery Replacement, Disconnect the Connector: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to disconnect the cable on the top left of the motherboard.
    17. HTC Droid DNA Battery Replacement, Flipping up the Black Board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Flipping up the Black Board: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    18. HTC Droid DNA Battery Replacement, Disconnect the Small Ribbon Connector: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    19. HTC Droid DNA Battery Replacement, Remove the Black Wire: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the long black wire on the left of the motherboard.
    20. HTC Droid DNA Battery Replacement, Remove the Two Black Wires: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Reorient the phone so that the green camera board is farthest from you.
      • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    21. HTC Droid DNA Battery Replacement, Remove the Screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    22. HTC Droid DNA Battery Replacement, Remove the Motherboard: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Remove the Motherboard: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    1. HTC Droid DNA Battery Replacement, Separate the Housing: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the pry tool to separate the housing of the phone from the battery.
      • Try not to damage the adhesive holding the battery.
      • The adhesive holding the battery in place is very strong. Use the pry tool in multiple spots around the battery to loosen the adhesive.
    2. HTC Droid DNA Battery Replacement, Remove the Battery: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Droid DNA Battery Replacement, Remove the Battery: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly pull up the battery with the prying tool.
      • Remove the battery with your fingers.
      • Try to keep the black paper in place around the battery. However, should it rip, that is okay.
crwdns2935229:016crwdne2935229:0
Madeline Tran
crwdns2935283:010/14/14crwdne2935283:0
707 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-43, Amido Fall 2014 crwdns2935289:0Cal Poly, Team 4-43, Amido Fall 2014crwdne2935289:0
CPSU-AMIDO-F14S4G43
crwdns2935297:0108crwdne2935297:0
Will the replacement battery need adhesive for it? Or will the adhesive still be there on the bottom of the phone? Thanks!
Adam - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for posting this hope I now get a few more years out of my DNA for not much money.
Gerry Lingner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 18,090
