crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone Will Not Turn On
When the power button is pressed, nothing happens
BLU Energy X is not charged
The phone has an expected battery life of three days with normal usage. A new BLU Energy X comes with a micro USB charger but any equivalent micro USB charger will also work. Plug the charger into an outlet and the phone into the charger and it should be ready for use in a couple of hours.
Battery is drained
The extended lifetime of a battery is limited and dependent on usage and charging habits. Though the BLU Energy X has a"Super Battery" it is technically not removable. Removing the battery will result in a voided phone warranty. If the battery is drained the phone can either be sent back to BLU for repair in order to maintain the warranty on the phone or the battery can be replaced using the BLU Energy X Battery Replacement Guide.
Display on phone is damaged
If charging the phone and replacing the battery has not resolved the issue, the screen may need to be replaced with anew one.
Motherboard is damaged
The motherboard in the phone may be damaged, causing it to not respond when pressing the power button. If this is the case the motherboard will need to be replaced. Use the Motherboard Replacement guide to assist with the replacement.
Phone Will Not Charge
When the phone is connected to a charger it does not charge the battery
Charger is damaged
If the phone charger has exposed wires or if there are any spots in the wire that have been repeatably bent, there may be damage to the charger preventing it from sufficiently charging the device. Plugging the phone into a different micro-USB charger that does not show any signs of damage should allow it to charge.
Battery is drained
Phone Will Not Connect to Wifi
When attempting to connect to the internet through wifi, the phone fails to connect
There is no signal
Often times wifi routers are the cause connection issues. Check to see if the signal from the wifi router is strong enough to use. If access to the wifi router is available reset the router.
The password to the wifi is wrong
Verify with the owner of the wifi router that the password being used is correct. If not, use the new password they give to you.
Internet setting on the phone needs to be reset
Turn the wifi setting on the phone off then on again. Attempt the connect to wifi. If the phone does not connect, check the proxy setting and turn it off
Screen Freezes
While using the phone, the screen either temporarily freezes for a few seconds, or the screen permanently freezes and is unresponsive
Too many applications are open
Smart phones are great tools because applications allow for users to do some many different things and entertain themselves in many different ways. If too many applications are open at once, the phone may not be able to keep up and freeze. If the screen is temporarily freezing, close some of the applications that are not being used. If the screen freezes and the phone becomes completely unresponsive, turn the phone off by either holding down the power button or removing the battery. Restart the phone, and it should run normally.
App will not close
While on the home screen, press the rightmost button at the bottom of the screen (it is in the shape of a square). This will bring up a list of apps currently in use. Swipe to the left or right of the app to close it. You can also select the 'x' button in the top right corner.
Hardware is damaged
If the phone has been through a traumatic such as a fall some of the internal components may have been damaged, causing the phone to not respond properly. If this is the case the motherboard will need to be replaced.
Camera Will Not Focus
When using the camera on the phone the image appears but it is unable to focus
Broken camera
If the phone has been through some rough times such as serious falls or hard hits, the camera could have been damaged preventing it from focusing while in use. If the camera in the phone has been damaged it will need to be replaced. Use Back Camera Replacement guide or the Front Camera Replacement guide to replace the camera with the issues.
Melinda Bailey
crwdns2935283:002/08/16crwdne2935283:0
122 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 12-2, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 12-2, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S12G2
crwdns2944067:05crwdne2944067:0
I just need my screen fix it's broke the Blu energy x 2 the glass I s crack
Margarita Mitchell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My phone has stopped downloading. I can no longer download any apps or games. The downloading bar and or screen comes up and says it is. But after hours the bar is still just cycling around with nothing downloaded.
rude40 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 2,258
