The mini has landed! It’s iPhone 12 teardown time—again—and while the phone may be small, this teardown is bigger than ever. It’s so big, we had to split it into two parts! We even dished on all the chips and other 5G hardware differences between the US version and those sold to our friends in the EU. (Yes, we tore down both.)
Meanwhile, we’re chasing a whale of a teardown week! Arm your harpoons and take a look at our Xbox Series X teardown, a side-by-side PlayStation 5/Xbox comparison, and oodles of live video teardowns. And if even that’s not quite big enough for you, check out the full iPhone 12 Pro Max teardown.
Feeling overwhelmed by all the new tech? Fix what matters instead! We’ve put together a list of our favorite gifts—from our workshop to yours, to help you and your favorite fixer keep the repair spirit going strong. Want some more community spirit? Keep up on our YouTube channel, Instagram, or Twitter for all the latest inside-out adventures—or sign up for our newsletter and always be in-the-know.
            Sometimes big specs come in small packages, and that's certainly the case here. We grabbed both the US and EU models so as not to miss anything:
            A14 Bionic with fourth-generation Neural Engine
            5.4 inch (2340 × 1080 pixels) Super Retina XDR OLED display with True Tone and HDR
            Dual 12 MP camera system with ultra-wide angle (ƒ/2.4) and wide angle (ƒ/1.6) cameras
            64, 128, or 256 GB of storage
            5G (sub-6 GHz and mmWave) connectivity, plus 4x4 MIMO LTE, 802.11ax Wi-Fi 6, Bluetooth 5.0, and ultra-wide band (UWB)
            MagSafe 12 W wireless charging
            IP68 rating, water resistant to a depth of 6 meters for up to 30 minutes
            iPhones are fully onboard the "normal is big, and big is really big" train—despite continued calls for a return to the wee phones of yore.
            Unfortunately, a return to a (slightly) smaller size doesn't mean a return of our friend the headphone jack. RIP to an OG.
            The iPhone 12 mini does bring an interesting new feature: increased grille asymmetry (presumably to Jony Ive's chagrin). It appears that the smaller phone needs a little more space for that antenna band.
            As is the case for the other iPhones 12, a small mmWave window on the side marks the US models, while the EU's feature some regulatory tribal tattoos.
   crwdns2935267:0crwdne2935267:0Heavy-Duty Suction Cups (Pair)$14.95-
            iPhone design may change over the years, but the Pentalobe screws remain the same. Good thing our toolkits have all the bits you'll need.
            Like its siblings, the iPhone 12 mini's display is held down by some tough adhesive. It's no match for some heat and the big gunssuction cups.
            With the Pentalobe screws gone and the adhesive sliced, the display opens in the same lefty-loosey manner we've seen in the iPhone 12 and 12 Pro.
            Alright, we're done with "Operation"—who wants to play a little "I spy"? Compared to the regular 12 we see:
            Two display cables instead of three
            A miniaturized battery, Taptic Engine, and loudspeaker
            Some migrated display silicon
            The upper sensor assembly, containing the speaker, Face ID, and sensors also got a rework to fit its slightly smaller home.
            This is the first time we've seen "más" cameras in a "menos" iPhone. It's impressive to see, especially if no corners were cut in the process.
            The mini camera (left) has the same ƒ/1.6 wide-angle and ƒ/2.4 ultra wide-angle cameras found in the regular iPhone 12 (right). The wide-angle module also features optical image stabilization (OIS)—and we have the X-rays to prove it!
            Removing the speaker reveals the 12-series-standard (and festive) orange ingress-prevention gasket.
            Considering the already shrunken Taptic Engines, we're surprised to see an even shrimpier one in this mini.
            This tiny Taptic Engine measures 15.14 mm x 10.9 mm x 3.44 mm—25% smaller than the motor in the 12 and 12 Pro.
            Taking advantage of that "extra" space: a beefier cable and socket.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Grab your tweezers and pull! These standard stretch release tabs are mighty big compared to their petite home, but we've got the muscle for this mini.
            This mini battery packs a surprising 8.57 Wh. That's more juice than the iPhone SE 2020's 6.96 Wh, but understandably short of the 10.78 Wh of the standard 12 it's stacked on top of.
            While its three bigger siblings offer 15 W wireless charging, the mini sips up juice at a slightly less thirsty 12 W.
            We’re back after a much needed catnap! But superheroes never sleep—and Creative Electron has saved the day with this neat X-ray.
            What can we learn? As usual, the dark bits are the dense, often magnetic parts of the phone, namely:
            OIS magnets on the lower camera, earpiece, and loudspeakers, as well as the teeny Taptic Engine.
            Perhaps most interestingly, we see the MagSafe ring has been miniaturized ... kinda.
            But what are those dense spots in the upper sensor array? Time to investigate.
            The US face-facing cameras are once again packing a little something extra where the EU edition was bare.
            Their absence in the EU iPhone may suggest this is a third mmWave antenna of some sort (although it doesn't look like any mmWave antenna we're familiar with). We tried blasting it with X-rays, but it refused to talk.
            It makes you wonder whether someone at Apple earned their paycheck for the year miniaturizing the ambient light sensor even further to free up this space. Where'd it go?
            Let's check out these logic board sandwiches. For reference, the US version is on top in these images, EU below. (Don't read into it—that's just how the chips fell.)
            First, the similarities—the US and EU upper sections are identical and have the same spread of chips on both sides.
            The lower sections are a bit more interesting. (Note: SIM readers are the same, but we only desoldered it from the US version.) Here's where the US board starts accommodating all that mmWave tech:
            An extra socket, which connects to the front mmWave antenna mentioned in the previous step
            A Murata 1XR-482 mmWave front-end module
            A Qualcomm SMR526 intermediate frequency IC, working in conjunction with Qualcomm's SDX55M 5G modem
            One more mmWave antenna right on the board
            A flex cable soldered to this patch, which connects to the side edge mmWave antenna
            After learning the finer points of US vs. EU sandwicherie, let's tuck into the (mostly familiar) US silicon layers:
            Apple APL1W01 A14 Bionic SoC with Micron MT53D512M64D4UA-046 XT:F 4 GB LPDDR4 SDRAM layered over it (same as the iPhone 12/12 Pro)
            1UED, most likely a U1 ultra-wideband chip similar to the USI chip in other iPhones
            STMicroelectronics STWPA1-3033ABM wireless charging IC, possibly something similar to their STWBC-EP chip
            KIC M224 BE0408 TWNA 12031, 64 GB of Kioxia NAND flash memory
            Qualcomm SDR865 5G and LTE transceiver
            Qualcomm SDX55M 5G modem-RF system and SMR526 intermediate frequency IC
            Apple APL1094 power management IC
            Processor PCB IC identification continued:
            Texas Instruments SN2611A0 Li-Ion Battery Charger
            Apple/Cirrus Logic 338S00537 Mono Audio Amplifier
            Apple/Cirrus Logic Unknown Audio Codec
            NXP Semiconductor CBTL1614A1 Display Port Multiplexer
            Samsung S2DOS24 Display Power Management
            Apple 338S00564-B0 ? Power Management
            Texas Instruments LM3562A1 LED Driver
            And a little more US silicon:
            Murata 583 and Skyworks 53807 diversity receive modules
            USI 339S00761 WLAN / Bluetooth module
            Qualcomm PMX55 power management IC
            Avago 8200 high/mid-band power amplifier with integrated duplexer
            Skyworks 5824x power amplifiers
            Broadcom BCM15960A0
            IC identification, continued:
            Bosch Sensortec unknown accelerometer
            Texas Instruments SN61280 li-ion battery DC-DC converter
            Maxim Integrated MAX8510 120 mA LDO regulator
            STMicroelectronics ST33JZ90 secure microcontroller
            Qualcomm QET5100 envelope tracker
            Like the day after Thanksgiving, we pick from the leftovers sitting in the fridgecase.
            We pilfer some ribbon cables, antennas, microphones, the flash module, and the Lightning connector.
            Emulating its larger brethren, the last component that comes up is the MagSafe coil & button assembly.
            The iPhone 12 mini is a small phone with big ambitions. We're surprised by how familiar the internals look compared to other iPhones this year, given the differences in size among them.
            Miniaturizing components like the speaker and Taptic Engine conserves some space, but battery capacity still takes an unfortunate hit.
            Last but not least, does the mini manage to score big on our repairability scale? Keep scrolling to find out.
- The two most common smartphone repairs—display and battery—are well-prioritized here.
- Most major components are modular enough to be accessed/replaced independently.
- Specialized screws complicate repairs, but remain preferable to overuse of glue.
- Waterproofing measures make many repairs more difficult, but safeguard against (extremely difficult) water damage repairs.
- Glass covering the rear housing is fragile and impractical to replace—a single drop could necessitate replacing the entire body of the iPhone.
crwdns2935195:0crwdne2935195:0
crwdns2935097:0crwdne2935097:0
            crwdns2935199:0crwdne2935199:0
crwdns2947412:013crwdne2947412:0
I wonder how Apple manages to keep thermals under control. Usually, the top of the SoC is cooled in most phones, but it looks like the only method of cooling this device is through the back of the logic board. I know it works, but it just doesn’t seem like the best solution.
The Node level used in creating the A14 uses much smaller lithography widths (5 nm) than other SoC’s so the chip runs cooler!
DanJ -
hi i need video am new here to learn
Great effort, thx. Will we get some teardown wallpaper for the 12 mini?
Definitely! Stay tuned for some wallpapers!
