iPhone XS Max uses both the primary loudspeaker and the earpiece speaker together to produce stereo sound. Use this guide to replace the primary loudspeaker at the bottom of the phone only. Replacing this speaker can help resolve issues such as loss of sound, poor sound quality, and distorted sound.
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
besteht da die Gefahr das sich das Displayglas vom lcd löst?
Besteht da die Gefahr das sich der Kleber vom Displayglas löst?
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
I need help. I inserted the pick under the screen, but above the touch screen. When I lifted it, all I see is the silver touch screen instead of the interior of the iPhone. How do I to opening the screen the right way from here?
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Comment répare un Face ID XS max
Bonjour @jenkeydany62670 Les capteurs Face ID était appairés à la carte mère en usine, il n'est possible de les remplacer qu'avec une nouvelle "paire". Ou bien, il faut se tourner vers un centre de réparation Apple officiel.
Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
Pull on the small nub on the suction cup to remove it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
Two 1.1 mm screws
One 1.5 mm screw
One 3.7 mm screw
Hi i'm Daniel, the guide is perfect!!! I'm enjoying my brand new ifixit Battery!!!
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the three Y000 screws securing the display connector bracket:
Two 1.5 mm screws
One 1.1 mm screw
I am replacing the screen for the 2nd time - the first repair was done by someone else, and the first 2 screws are 1.5mm and the last screw is 1.1mm… If I put the screw back in am I risking Long Screw Damage?
I think that the outside screw (red one, one the right) is actually 1.5 mm or something longer than 1.1. Looked that way to me.
From the top, the screws are: 2 x 1,5mm + 1 x 1,1mm
I can confirm the above comments on the screw length. Pls correct it in the description!
Thanks for all your comments! I'll amend this step.
Hi, I just changed the screen on my XS Max and for this bracket I used 2 x 1.1 mm and 1 x 1.5 mm.
Starting from left to right:
- left 1.1 mm (I tried with 1.5 mm like in the above picture but I felt that it didn't wanted to go deeper so I didn't forced and I tried it in the middle and it fit perfectly)
- middle 1.5 mm
- right 1.1 mm
For the two brackets I had 7 screws, I aligned them on the desk by length and I had 2 x 1.5 mm, 4 x 1.1 mm and 1 x 3.7 mm.
Good luck and I hope it will help someone!
Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
Mine still won’t respond even after reseating any ideas? Ground issue?
Carefully lift the cable until the adhesive separates.
Remove the display assembly.
No olviden que para que pase el Face Id tienen q cambiar el flex que va encima de la camara delantera con mucho cuidado ya q si le ponen otro flex no funcionara.
Remove the five 1.4 mm tri-point Y000 screws securing the bracket below the Taptic Engine and main speaker.
La imagen no corresponde con un caso real de XS MAX. Tenedlo en cuenta a la hora de volver a montar el dispositivo.
Tornillo Tri-point = Tornillo de tres puntas
What should I do if I stripped one of the Y000 screws. Not sure if it got rusted from water damage.
Gently lift to unstick and remove the bracket, being careful not to bend it.
If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the bracket is not recommended, as this may bend the spring contacts along the top.)
Remove the 1.3 mm tri-point Y000 screw securing the speaker connector cover.
Push the speaker connector cover towards the battery, and then lift to unclip and remove it.
Use the tip of a spudger to pry up and disconnect the speaker connector.
crwdns2935267:0crwdne2935267:0iFixit Precision 4 mm Screwdriver Bit$2.99
Remove the three screws securing the speaker:
One 2.7 mm Phillips screw
One 2.9 mm standoff screw
One 3.1 mm standoff screw
Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
Gently pry up and lift the top edge of the speaker slightly.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
Remove the speaker.
Welche Dichtung soll hier verwendet werden?
After pulling the speaker out, watch that the adhesive didn’t bring the plastic speaker hole and small grill membrane insert out. If it wiggles out a little, push it back in. I thought it was remaining adhesive and removed them both by mistake- a headache to put them both back.
crwdns2935229:021crwdne2935229:0
Will a phone wipe/restore from back up be needed after the replacement?
Mijn iphone bodem-speaker maakte af en toe ene krakend geluid of deze viel volledig uit. Ik heb de telefoon naar een reparateur gebracht… maar ook de nieuwe box die is geïnstalleerd doet het alleen als ik druk op het scherm uit-oefen. Het lijkt daardoor dus te komen, doordat de speaker niet of niet goed contact maakt met het punt waar het zijn stroom vandaan haalt. De medewerker van de reparatie-zaak heeft het de hele tijd over kortsluiting? Maar dat lijkt me sterk, daar een beetje druk zowel bij mn oude als de nieuwe speaker resulteert in een werkende box. Echter is dit niet ideaal voor het scherm, en ook niet de ideale oplossing als ik muziek of video’s afspeel. Hebben jullie tips waar het misschien aan kan liggen? Waar de medewerker naar kan kijken? De telefoon is nu al twee dagen bij die winkel met tot op heden nog niet een werkende onderspeaker tot resultaat.
Hopelijk heeft iemand de gouden tip.
Groetjes,
Wes
