iPhone XR Lower Speaker Replacement
  1. iPhone XR Lower Speaker Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
    One of my gaskets was as shown in your second photo, the other had been worked into the threads (as if smeared) probably from the factory and was completely unusable.
    In place of replacements (unsure of where to purchase) I just used a clear silicone caulking on both screws upon reassembly to offer at least some water seal. I wish these gaskets were included with the gasket waterproofing sealant kit!
    Erica - crwdns2934203:0crwdne2934203:0
    Is there any place to buy these screw gaskets? I haven’t seen it mentioned anywhere but one of mine was pretty much chewed up. Silicone should work but I’d prefer the oem solution.
    Chilinh Nguyen - crwdns2934203:0crwdne2934203:0
    I found a place on Amazon that sells them. It's cheapest to get a full set of screws than to get just these. $5-$6 USD.
    J Olin -
    If I transfer the data from the old to the new battery with an icopy, don't I get an error message?
    David Julian Krause - crwdns2934203:0crwdne2934203:0
    how am i supposed to know if the battery is below 25% if the screen won't turn on?
    Beth Jackson - crwdns2934203:0crwdne2934203:0
    Spoiler alert! I just followed all the steps and if you bought the anti-clamp you might save a lot of time and some unreversible steps.
    I recommend that you read all the steps before beginning and follow the steps up to the point where the guide removes the screen (step 23). After that read again the precautions of step 41 and try the next thing:
    - Using something like the iOpener hot bag, heat up the back side of the phone where the battery is glued to for some minutes
    - Alternatively use a 3d printer heat bed at 60 degrees Celsius
    - Once the back of the phone is hot to the touch, enough to make it uncomfortable to the touch, find a portion of the battery with a smooth surface and attach the anti-clamp to it and the back of the phone
    - Follow the steps 4 and 5 to detach the battery from the frame
    If this procedure works you will not have to remove some elements such as:
    - lower speaker black tape (step 28)
    - lower speaker water proof gasket (step 33)
    I hope that someone find this helpful. Happy fixing!!
    Julio Beltran - crwdns2934203:0crwdne2934203:0
  2. iPhone XR Lower Speaker Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone XR Lower Speaker Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    This looks like a repeat of Step 3.
    GenjideGaulle - crwdns2934203:0crwdne2934203:0
  4. iPhone XR Lower Speaker Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone XR Lower Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone XR Lower Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Please UPDATE THIS STEP to say 'insert the opening pick underneath the PLASTIC FRAME OF THE SCREEN' and not the screen. Way too many people are taking this as the way to do it then posting their screen looks different when it's open when they've actually removed the screen leaving the frame in place. It's not rocket science.
    [deleted] - crwdns2934203:0crwdne2934203:0
    Thanks for the suggestion! We updated this step to clarify that.
    Arthur Shi -
  7. iPhone XR Lower Speaker Replacement, Heat up the screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    An alternative to the Iopener or heat gun is to heat water to EXACTLY 80 degrees F (cooking thermometer is great for this) and pour into a reinforced ziplock type bag. Leave the bag on the screen, but be sure that none of the hot water rests on the zipper portion, as the water is hot enough to soften that seal and leak out on to your device! This meat had is my personal favorite as the heat is distributed very equally and precisely as compared to a heat gun, but is more accessible than the Iopener.
    Colin Wylie - crwdns2934203:0crwdne2934203:0
    When using an iOpener, rest the glossy (transparent) side on the phone so it contacts the phone and conducts heat easily
    Afiq - crwdns2934203:0crwdne2934203:0
  8. iPhone XR Lower Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone XR Lower Speaker Replacement, Lift the display slightly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Lift the display slightly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Lift the display slightly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone XR Lower Speaker Replacement, Separate the screen adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Separate the screen adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Separate the screen adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    I think it's important to note that depending on how a screen was damaged, make sure to insert the pic under the black bezel directly under the actual screen. This bezel is a frame around the digitizer. I unknowingly inserted the pic between the bezel and the screen, and separated them both. I did this all the way around the phone. So I basically had to struggle to keep together two different sections of the display assembly because of this mishap, until I removed all the ribbon connectors. It made things much more difficult.
    Dave - crwdns2934203:0crwdne2934203:0
    An edit to my above comment: by digitzer, I mean the LCD shield. My apologies.
    Yeah it’s helpful to just look at the screen they sent you. You’ll have a better idea of where to pry or stick your razor blade under!
    ryandlent - crwdns2934203:0crwdne2934203:0
  11. iPhone XR Lower Speaker Replacement, Screen information: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick at the marked spots, as you may damage the cables.
  12. iPhone XR Lower Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    My replacement screen for the XR has a black rim but it looks pink. Is that normal?
    Irwin Cantor - crwdns2934203:0crwdne2934203:0
    You can use some Isopropyl alcohol in a syringe with a thin needle to soften even more the adhesive around the screen. But be careful so as not to overdo it. Just a few drops. It will become more easier to remove the screen.
    Dan Brock - crwdns2934203:0crwdne2934203:0
    Step 11 says not to insert your pick around the right side to avoid damaging cables, then Step 12 says to insert it on the right side. Help, I'm confused!
    ingwis - crwdns2934203:0crwdne2934203:0
    Hi there!
    Thank you for the feedback! The wording in step 11 was definitely ambiguous, so we have changed it! You only need to avoid the marked spots rather than the right edge.
    Alex Diaz-Kokaisl -
  13. iPhone XR Lower Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  14. iPhone XR Lower Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone XR Lower Speaker Replacement, Open the iPhone: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Open the iPhone: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement, Open the iPhone: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    sure looks like the "hinge" is on the right hand side to me.. not left...!
    Doug Trout - crwdns2934203:0crwdne2934203:0
    If you leave the suction cup attached to the screen during the “hinging” process, it makes for a very handy holder for the screen until it’s completely detached.
    Richard Deubler - crwdns2934203:0crwdne2934203:0
    What about the sticky black adhesive clinging to the inside of the case?
    Ronald - crwdns2934203:0crwdne2934203:0
  16. iPhone XR Lower Speaker Replacement, Unscrew the battery connector cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Unscrew the battery connector cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Definitely make sure all three lobes of your tool are aligned before use (it’s a little harder to tell with this style of bit) and apply even and adequate pressure to ensure it grabs as you spin the driver to prevent disfiguring the lobes/slot of the screw head.
    Unfortunately my Y000 tool was perhaps not the best fit (tolerance a bit off) in these screws and I ended up stripping out the heads of all three of these. I started to panic but after I sanded the tip of my Y000 bit down a little with super fine grit (1000CW-C) sand paper to flatten the domed tip (visible with macro lens) and give it a bit more bite I was able to remove and reinstall without issue—in fact I had to remove and install them twice since I forgot my adhesive tape during reassembly, so the screws survived and the sanded bit worked.
    +1 to above comment. I bought a cheap kit from Amazon and the Y000 screw driver is not good for this job. I’m concerned that I may have disfigured the heads and i type this comment in the midst of my fix :D Be gentle and assess if you can remove at least one screw with your driver before rummaging through all three and other similar screws holding display connector as well.
    Shan Potti - crwdns2934203:0crwdne2934203:0
    Update to above comment. I got hold of a Y0.8 screw driver bit (lucky to find an ORIA screw driver kit in my office) and it works like wonders :) Now back to work…
  17. iPhone XR Lower Speaker Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone XR Lower Speaker Replacement, Unscrew the display connector cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Unscrew the display connector cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
    What if the screw is damaged and you can’t get one out?
    Kashawn Benjamin - crwdns2934203:0crwdne2934203:0
    Same issue here. These screws are a lot thighter than the others. Maybe add a caution notice to be patience with these ones.
    What you can try is superglue to make it attached to the screw.
    Lennard - crwdns2934203:0crwdne2934203:0
  19. iPhone XR Lower Speaker Replacement, Disconnect the digitizer: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Disconnect the digitizer: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  20. iPhone XR Lower Speaker Replacement, Disconnect the display: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Disconnect the display: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to disconnect the display cable connector.
    The new display cable isn’t snapping in but I was just able to snap in the old one. Did I break the new one somehow?
    Andrew Pierson - crwdns2934203:0crwdne2934203:0
    Same it is really frustrating, just keeps slipping up and its bound to get damaged
    Daniel Maldonado - crwdns2934203:0crwdne2934203:0
  21. iPhone XR Lower Speaker Replacement, Unscrew the logic board connector cover: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Unscrew the logic board connector cover: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
    Phillips screw 1.3 mm on last step is not working. The small clipped bracket has been damaged. This screw perhaps should be the first, before 1.2 Y000. - To be confirmed by others.
    Dmitri - crwdns2934203:0crwdne2934203:0
    I’m not sure it makes much if any difference, but we went ahead and swapped the order for you guys. Thanks for your comments!
    Jeff Suovanen - crwdns2934203:0crwdne2934203:0
    I just repaired another XR, and you are right! It doesn’t make any differnerce in the order these screws come out. I still damaged this fragile piece. As I work on more of these, I’ll figure out a way to remove this screw without damaging the clip. For now everyone, just use extra caution when removing the 1.3mm phillips screw! Thanks Jeff
    fabianowens -
    I’ve now done at least 6 of these so far and I have fairly consistent good results by taking the 2 Philips head screws out first, then doing the Y screws.
    Stow -
    Is this piece important for the repair if broken? I have broken it on a home repair. What is it used for? Is it a grounding connection or is it completely unimportant. More information needed please
    Squishy Horses - crwdns2934203:0crwdne2934203:0
    I’m wondering that too. Is this piece important?
    Phillip Gross -
    My clip broke too! on iphone XR. Any word on necessity?
    Beth Buer - crwdns2934203:0crwdne2934203:0
    I can confirm that taking out the 1.3 mm screw first then the 1.5 mm screw works the best. If done correctly, you should be able to to remove the rest of the screws and pull the panel off with the clip still attached to the panel. For reassembly, start with the 1.5 mm screw then the 1.3 mm screw.
    Carlos Oulman - crwdns2934203:0crwdne2934203:0
    I don’t remove the small screw at all. I just slide out the metal cover plate and slide back in to reassemble.
    Kyaw-Zin Win - crwdns2934203:0crwdne2934203:0
    this is what i have done as well. Care is still needed to avoid damaging this part. However, it is seemingly far less prone to damage or loss and thus less risky for this repair process.
    Justin Parsons -
    I too broke this shield. In looking over this problem I believe it’s best to loosen, but not remove, either screw first then the other. To be clear, loosen the red or yellow screw but only just to break it free, then the second screw. Then remove both and the others and the shield should remain in one piece. I put it back with the broken part (on the red screw) and made sure the two are in contact so there’s conductivity as these shields serve a purpose other than just holding in connectors. My phone works fine with this fix.
    pgrobin - crwdns2934203:0crwdne2934203:0
    Is this small bracket important if broken??
    Phillip Gross - crwdns2934203:0crwdne2934203:0
    Mine is broken and my apple pay doesn’t work. Something to do with NFC antenna this little clip??
    Marcos Fernández - crwdns2934203:0crwdne2934203:0
    I'm guessing so. I replaced a screen on a phone I bought from a friend. I noticed this bracket was broken when I disassembled the phone but didn't think much of it. When I reassembled it my NFC also does not work. Bummer. A lot of people in these comments have asked if it is crucial that this bracket be connected. Can someone from iFixit or other please reply to those comments?
    Larry Jorgenson -
    On the 1.3 mm screw I actually chose not to remove it. I broke it loose then used the tip of the spudger to simply twist the bracket out of the way, with the screw still attached. Then I could remove the larger bracket.
    mpalma - crwdns2934203:0crwdne2934203:0
    Kyaw-Zin is right because the shield contains of two tin parts. But there is another option:
    1. Unscrew the yellow and orange screws first.
    2. Lift the shield gently that it can turn about 20° anticlockwise.
    3. Open the red screw and let the shield turn with it the first degrees.
    Daniel Brehm - crwdns2934203:0crwdne2934203:0
    The first time I did this repair, I didn’t see the comments ahead of time and broke the bracket, even removing the 1.3mm screws first. The second time I did the repair, I was prepared and being extra careful, but the simple act of turning the 1.3mm screw head was enough to break it. If I ever have to do this repair again, I’ll just leave the screw in and try to slide the plate out with the screw (and bracket, hopefully) still in tact, as per Kyaw-Zin Win.
    Debbie Thompson - crwdns2934203:0crwdne2934203:0
    None of the screw driver bits I got fits the 1.3mm and 1.5mm screws. How do I remove them?
    Jonatious Joseph Jawahar - crwdns2934203:0crwdne2934203:0
    Same issue as above. The bits provided in the kit do not work with the 1.3mm and 1.5mm screws
    Graham Hammell - crwdns2934203:0crwdne2934203:0
    Further to above comment about bit not working. Had to go and purchase another PH000 from Home Depot and that worked
    I’ve broken that little bracket attached to the red screw. Is it important and can I get a replacement????? Thanks all
    steve.arfa - crwdns2934203:0crwdne2934203:0
    Broken the clip. Is this important??
    kyledrumtutor - crwdns2934203:0crwdne2934203:0
    Yikes, broke mine too. Oh god. Think perhaps the delicate 1.3mm should come out first when everything else is secure...
    Don't remove the 1.3 Phillips screw! Twisting this screw will break the smaller bracket that is clipped to the larger. Remove all the other screws. Block the smaller bracket from moving as you gently slide the larger bracket horizontally toward the battery until free. The smaller bracket can stay in place while the screen is replaced. When reassembling, support the small bracket by backing with a spudger or similar tool.
    doug68242 - crwdns2934203:0crwdne2934203:0
    I just broke the smaller bracket also :( I didn´t notice these comments until now :(
    It looks like part of the antenna for NFC, as all except NFC works on my iPhone now.
    It should be repairable using some wire wrap wire, either twisted around the two screws that connected that part of the bracket (or soldered in place). I will try and report back if it works.
    Richard Croyle - crwdns2934203:0crwdne2934203:0
    Success!! I managed to re-construct the small arm of the bracket by screwing the 1.3mm screw back in with some 0.3mm enamel wire soldered into what was left of the small bracket arm on the screw, then the other end of the enamel wire I wrapped under the 1.5 wire screw's head (enamel exposed to bare metal), then screwed both screws down. also I lifted up the small metal arm with a screw driver (to make sure it reconnects with the display grounding square) ..and NFC worked again (slightly different antenna pattern mind (need to place cards slightly higher up the rear of the phone). Anyway works again :)
    do you think it would be possible to repair without the use of microsoldering?
    i brought a new bracket set for the xr and replaced the old one but even with that nfc/apple pay still doesn't work. i'm questioning if i put a wrong size screw or something else
    prolificgmabit -
  22. iPhone XR Lower Speaker Replacement, Disconnect the front sensors: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement, Disconnect the front sensors: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
    During testing, make sure your proximity sensor is not on upside down, as it’s easy to connect upside down. Your phone will boot loop if it’s on incorrectly.
    Tristan England - crwdns2934203:0crwdne2934203:0
  23. iPhone XR Lower Speaker Replacement, Remove the display assembly: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    unclear if this is where screen removal ends
    I had the same question, but the answer is yes. Steps 21-30 are removing parts from the original screen that need to be reattached onto the new screen. You are no longer working inside the frame, but on the back of the screen itself.
    amclean78 - crwdns2934203:0crwdne2934203:0
    I apologize for missing these comments initially, but yes that’s correct, the screen is removed now and the rest of the guide goes on to other parts, either in the phone or on the back of the screen. Good luck with the repair!
    Adam O'Camb -
    The alternate method of removing the battery should be highlighted as a standard option. There is so much more work and potential to damage the parts than if you left them in place and carefully with plenty of heat remove the battery. I so wish I had seen this before!
    Martin Kappeyne - crwdns2934203:0crwdne2934203:0
  24. iPhone XR Lower Speaker Replacement, Lower Speaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws securing the bracket below the Taptic engine and speaker:
    • Three Phillips 1.4 mm screws
    • Two Phillips 1.7 mm screws
    • One Phillips 1.9 mm screw
    • One Phillips 1.6 mm screw
    Why remove all this stuff for the battery? Is it necessary to do any of steps from here to 32 for the battery at all?
    Paul Butterworth - crwdns2934203:0crwdne2934203:0
    Removing these parts facilitates removing the bottom adhesive tabs but is not necessary. If you remove the upper adhesive tabs, then heat the backside of the lower ones (which you do if you couldn't get the tabs out), the battery comes out easily. Removes 14 steps from this procedure.
    teamhudson - crwdns2934203:0crwdne2934203:0
  25. iPhone XR Lower Speaker Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bracket from the edge nearest the battery. Don't try to fully remove it, as it's still connected via a small flex cable.
  26. iPhone XR Lower Speaker Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the bracket out of the way, use the point of a spudger to pry up and disconnect the flex cable underneath.
  27. iPhone XR Lower Speaker Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  28. iPhone XR Lower Speaker Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piece of black tape and the small rubber rectangle covering the Taptic Engine connector cover.
  29. iPhone XR Lower Speaker Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the five screws securing the lower speaker:
    • One 2.8 mm standoff screw
    • Standoff screws are best removed using a dedicated standoff driver or driver bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 2.3 mm standoff screw
    • One 2.3 mm Phillips screw
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
    I was able to get the 2.8mm standoff screw out with a 1.5 mm flat head from my iFixit kit but was not able to find anything to get the 2.3mm screw out. Buying the standoff screwdriver begrudgingly. I wish I'd known about this before I started.
    leeprobert - crwdns2934203:0crwdne2934203:0
    I was able to get the 2.3mm stand-off screw out by using my 1.5mm flat head to push along the outside of this screw. Took a bit to fully back it out but it worked just fine.
    Stretch - crwdns2934203:0crwdne2934203:0
    Recommend PH00 for the 1.8 and PH000 for the rest.
    Sam Omiotek - crwdns2934203:0crwdne2934203:0
    I recommend a 2.5 mm flat for the orange and red stand off screws.
    Russell Angrignon - crwdns2934203:0crwdne2934203:0
    use the sharp end of the spudger to stick into the standoff screws - it will hold well enough to position the screw and start threading it in - then use 2.5mm flat to tighten
  30. iPhone XR Lower Speaker Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small bracket on the top right corner of the speaker.
    • Remove the Taptic Engine connector cover.
    When reassembling the speaker bracket, stick the flat end of a spudger on the right side while screwing it down so it doesn’t fall out the side and to maintain its alignment.
  31. iPhone XR Lower Speaker Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger under the top edge of the speaker near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker.
  32. iPhone XR Lower Speaker Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  33. iPhone XR Lower Speaker Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone XR Lower Speaker Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker.
    • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
    • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
    you may be able to reuse the gasket if you heat the glue. You may want to consider this because I can’t find the gasket through ifixit.
    HAYDEN MYERS - crwdns2934203:0crwdne2934203:0
    do we have to remove all the extra stuff such as this if we're just replacing screen display? what is the importance?
    destiny velasco - crwdns2934203:0crwdne2934203:0
    If you want to get the surface prepped nicely, tightly roll up the corner of a KimTech wipe, add some IP, then gently use your spudger tip to wipe excess gasket material from the area. Take your time!
    Tal Pipkin - crwdns2934203:0crwdne2934203:0
crwdns2935229:021crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
211,808 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
Where can I buy a replacement gasket for the speaker?
Darrian Aguirre - crwdns2934203:0crwdne2934203:0
ok, troubleshooting help:
- the original speaker was sounding tinny (potentially water infiltration?)
- replaced the speaker, and I am only getting audio out of the earpiece speaker.
- tested with the original speaker, and no audio from the original either.
- double checked everything is reassembled correctly, forced restart, still nothing.
- presumably something else broke, or was damaged during my teardown, but I'm not sure what 😅
Noah Smith - crwdns2934203:0crwdne2934203:0
Rápido e prático. Obrigado!
Daan.ll - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 118
crwdns2936753:030crwdne2936753:0 651
crwdns2942667:0crwdne2942667:0 67,788
