iPhone X Bluetooth Antenna Replacement
  1. iPhone X Bluetooth Antenna Replacement, SIM Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, SIM Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, SIM Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone X Bluetooth Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
    Do not read any simcard in iphone
    PRAVEEN KUMAR - crwdns2934203:0crwdne2934203:0
    Mon iPhone n'a pas de connectivité réseau.
    michelin louis - crwdns2934203:0crwdne2934203:0
  3. iPhone X Bluetooth Antenna Replacement, Pentalobe Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • If the screws are stripped or damaged, replace the screws.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    There are 6.81mm long screws!
    Daniel - crwdns2934203:0crwdne2934203:0
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - crwdns2934203:0crwdne2934203:0
    Same issue for me too, how do I get the stripped screw out?
    patronics - crwdns2934203:0crwdne2934203:0
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - crwdns2934203:0crwdne2934203:0
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - crwdns2934203:0crwdne2934203:0
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - crwdns2934203:0crwdne2934203:0
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - crwdns2934203:0crwdne2934203:0
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - crwdns2934203:0crwdne2934203:0
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - crwdns2934203:0crwdne2934203:0
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - crwdns2934203:0crwdne2934203:0
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - crwdns2934203:0crwdne2934203:0
  4. iPhone X Bluetooth Antenna Replacement, Mark your opening picks: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Mark your opening picks: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Mark your opening picks: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    an old credit card will do that job, although you'll have to pull a little bit more if the credit card is thicker than the picks, just again, be careful and don't insert it that far
    Russ Torrez -
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
    Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
    Alasdair Cameron - crwdns2934203:0crwdne2934203:0
    I bought the kit of five just in case. I used two and marking them at 3mm was definitely helpful.
    Megolina - crwdns2934203:0crwdne2934203:0
  5. iPhone X Bluetooth Antenna Replacement, Tape over any cracks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Tape over any cracks: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Tape over any cracks: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  6. iPhone X Bluetooth Antenna Replacement, Anti-Clamp instructions: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Anti-Clamp instructions: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Anti-Clamp instructions: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  7. iPhone X Bluetooth Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  8. iPhone X Bluetooth Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - crwdns2934203:0crwdne2934203:0
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  9. iPhone X Bluetooth Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    • If you use a hairdryer or heat gun, do not heat to much because that can result in damaging the screen.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - crwdns2934203:0crwdne2934203:0
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - crwdns2934203:0crwdne2934203:0
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - crwdns2934203:0crwdne2934203:0
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - crwdns2934203:0crwdne2934203:0
    thaks for this advise, I was looking for this as I dont have a heat gun haha, nice hack
    Andres Chaparro -
  10. iPhone X Bluetooth Antenna Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - crwdns2934203:0crwdne2934203:0
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - crwdns2934203:0crwdne2934203:0
  11. iPhone X Bluetooth Antenna Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel, not the screen itself.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - crwdns2934203:0crwdne2934203:0
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - crwdns2934203:0crwdne2934203:0
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - crwdns2934203:0crwdne2934203:0
  12. iPhone X Bluetooth Antenna Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  13. iPhone X Bluetooth Antenna Replacement, Screen information: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - crwdns2934203:0crwdne2934203:0
    Mercie mais trop trop de détails
    PACOME SERI - crwdns2934203:0crwdne2934203:0
  14. iPhone X Bluetooth Antenna Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
  15. iPhone X Bluetooth Antenna Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - crwdns2934203:0crwdne2934203:0
  16. iPhone X Bluetooth Antenna Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the small nub on the suction cup to remove it from the front panel.
  17. iPhone X Bluetooth Antenna Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - crwdns2934203:0crwdne2934203:0
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - crwdns2934203:0crwdne2934203:0
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - crwdns2934203:0crwdne2934203:0
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - crwdns2934203:0crwdne2934203:0
  18. iPhone X Bluetooth Antenna Replacement, Display Assembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
    • Three 1.1 mm screws
    • One 3.1 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - crwdns2934203:0crwdne2934203:0
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - crwdns2934203:0crwdne2934203:0
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - crwdns2934203:0crwdne2934203:0
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - crwdns2934203:0crwdne2934203:0
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - crwdns2934203:0crwdne2934203:0
    不要将螺丝拧得太紧,因为这样会损伤主板导致各种奇奇怪怪的问题,比如屏幕不显示(显示黑色)但是触摸可以用等等,务必按照螺丝原来的顺序安装回去,我的iPhoneX就因为没有正确安装导致主板损坏,而iPhoneX是双层主板,这无疑增加了它的维修成本与费用
    bingshan888888 - crwdns2934203:0crwdne2934203:0
  19. iPhone X Bluetooth Antenna Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - crwdns2934203:0crwdne2934203:0
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - crwdns2934203:0crwdne2934203:0
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - crwdns2934203:0crwdne2934203:0
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
  20. iPhone X Bluetooth Antenna Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - crwdns2934203:0crwdne2934203:0
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - crwdns2934203:0crwdne2934203:0
    Thanks, already did it)
    Stephen Hedrick -
  21. iPhone X Bluetooth Antenna Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  22. iPhone X Bluetooth Antenna Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Snap ‘em in like little Legos.
    Ray Johnson - crwdns2934203:0crwdne2934203:0
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
  23. iPhone X Bluetooth Antenna Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - crwdns2934203:0crwdne2934203:0
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - crwdns2934203:0crwdne2934203:0
  24. iPhone X Bluetooth Antenna Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
    Do this sensor affect face id?
    bonglkv - crwdns2934203:0crwdne2934203:0
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - crwdns2934203:0crwdne2934203:0
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - crwdns2934203:0crwdne2934203:0
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - crwdns2934203:0crwdne2934203:0
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - crwdns2934203:0crwdne2934203:0
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - crwdns2934203:0crwdne2934203:0
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - crwdns2934203:0crwdne2934203:0
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - crwdns2934203:0crwdne2934203:0
    I have damaged the front panel sensor assembly flex cable. Does it carry multiple channels of info or is it just one solid piece that can be soldered back together? If not, will the phone still work except Face ID?
    Bodger Rabbit - crwdns2934203:0crwdne2934203:0
  25. iPhone X Bluetooth Antenna Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - crwdns2934203:0crwdne2934203:0
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - crwdns2934203:0crwdne2934203:0
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - crwdns2934203:0crwdne2934203:0
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - crwdns2934203:0crwdne2934203:0
    Just to confirm the face id is not affected when replacing the earpiece assembly? Am I correct
    mubeen.2011@hotmail.co.uk - crwdns2934203:0crwdne2934203:0
    Sorry for the late response, but you are NOT correct. Replacing the earpiece speaker assembly will result in the loss of Face ID functionality. That's the whole assembly, including the speaker, dot projector and flood illuminator. If you unsolder the speaker from the assembly, that can be replaced by itself without losing Face ID, but any other part will cause it to quit working.
    Jerry Wheeler -
    That cable on the left does not exist on my iphone x, wtf? The linked video does not user the exact tools of the kit and ends in the middle of the procedure. Consequently my phone did not work after the „repair“. Won‘t even close properly and the display is not working anymore. That‘s some money down the toilet. So everyone, who is not really good at repairing, think hard if you really wanna try. I have to buy a new phone now.
    Heiner Seidl - crwdns2934203:0crwdne2934203:0
  26. iPhone X Bluetooth Antenna Replacement, Lower Speaker: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Lower Speaker: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to touch the three rows of grounding pads near the bottom of the iPhone.
    • Remove the seven screws securing the bracket below the Taptic Engine and speaker:
    • Two Y000 1.9 mm screws
    • One Y000 1.2 mm screw
    • One Y000 1.6 mm screw
    • One Phillips 2.4 mm screw
    • One Phillips 1.7 mm screw
    • One Phillips 1.5 mm screw
    For battery replacement:
    It is not necessary to remove Taptic Engine and speaker to replace a battery. Go straight to the step #33
    Additional video: https://youtu.be/2GfBOlJEW10
    Alexander - crwdns2934203:0crwdne2934203:0
    I wish I seen this before I did all that! Thank you for that information. Next time I do something like this. I'm gonna pay more attention to the comments.
    Eric Marino -
    Removing the Taptic Engine and speaker greatly improves your chances of getting the battery adhesive strips out intact. If those break, you’ll have a much tougher time.
    Jeff Suovanen -
    Boy, I tried to skip removing these items but was unable to get the glue strips out with them in place, not much to grab and tabs were kind of stuck to a seam in the battery, and hard to tell the difference between the seam and the strip tabs. For me I had to remove these items to get this done.
    marshallburchard -
    I stopped removing things after getting the display side off. There were 3 screws stripped on the speaker cover which wouldn't come out so I punted. Just pried the battery out with a smudger tool and some patience, starting at the top and working towards the bottom. New battery is in and working fine.
    Andy Price - crwdns2934203:0crwdne2934203:0
    The 2.4mm screw identified as “green” needs a Y000 screwdriver
    seb6po - crwdns2934203:0crwdne2934203:0
    Thanks for not removing the following steps. this made me break the connector for the bottom speakers >:(
    Andrew Romano - crwdns2934203:0crwdne2934203:0
    The color codes are missing from my display — only on this step.
    nat2 - crwdns2934203:0crwdne2934203:0
    The screws color and quantities in list don’t match the schematic ! I wish i had a magnetic screw mat before starting, because not only i removed the Taptic Engine and speaker unnecessarily, but i also lost a screw ?
    fb.mailing.lists - crwdns2934203:0crwdne2934203:0
    For first timer, dont think its possible to skip these steps and remove battery. It’s hard to remove the glue
    Wex - crwdns2934203:0crwdne2934203:0
    Does anyone know the purpose of this bracket "with grounding pads"? What would be the possible side effects if it was damaged or not connected properly during reassembly?
    Anne Aunyme - crwdns2934203:0crwdne2934203:0
    Hello, in my case the grounding pads are damaged. I've had problems since EMC. When I try to charge wirelessly, the iphone starts wild button presses (Gosting).
    Does anyone know, where I can get new grounding pads (with or without bracket)?
    Ulrich Höfelmeyer -
    I had to remove the tactic and speaker could not get the glue strips out so glad the steps to do so were in this guide.
    P Bond - crwdns2934203:0crwdne2934203:0
    Sure would like to know WHY the warning "Be careful not to touch the three rows of grounding pads..." What would or could happen if I did touch them??
    Chad Gagnon - crwdns2934203:0crwdne2934203:0
    Removing the battery strips is a major PITA, just skip this step and everything onwards, remove the one strip on the top part of the battery (according to step 33) and for the bottom part of the battery, pry it off with a plastic spudger.
    Yes, this is not the elegant solution, but the quickest and easiest one. This method is better, as you don't want to keep the old battery anyway, so why bother. (You must not puncture the battery though! But as long as you're only working with a plastic tool and are careful, nothing can happen from my experience.)
    speaker gasket - crwdns2934203:0crwdne2934203:0
    Remove the adhesive from the top part of the battery, squirt some ipa into the bottom part and it will come off easily, then skip to 38.
    Kim Boulton - crwdns2934203:0crwdne2934203:0
  27. iPhone X Bluetooth Antenna Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bracket from the edge nearest the battery. Don't try to remove it fully, as it's still connected via a small flex cable.
    Ulrich Höfelmeyer - crwdns2934203:0crwdne2934203:0
  28. iPhone X Bluetooth Antenna Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the bracket out of the way, use the point of a spudger to pry up and disconnect the flex cable underneath.
  29. iPhone X Bluetooth Antenna Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    My bracket was in two pieces.
    Jim Steward - crwdns2934203:0crwdne2934203:0
  30. iPhone X Bluetooth Antenna Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.1 mm Y000 screw securing the speaker connector cover.
    Effectivement ;-) Merci pour les bons yeux et la remarque !
    Claire Miesch -
  31. iPhone X Bluetooth Antenna Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker connector cover.
  32. iPhone X Bluetooth Antenna Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
    As mentioned in a comment by timblake2112 (see step 29), this step is not necessary and can be skipped skipped. I would advise you to do so, as removing your speaker is guaranteed to ruin your gasket and rubber seal. This will result in loss of water resistancy of your iPhone and could potentially harm the sound quality of your speaker.
    Try removing the Taptic Engine without removing the speaker. It might still be possible removing the battery adhesive strips and your speaker will stay in its original condition.
  33. iPhone X Bluetooth Antenna Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When prying up the speaker, take care not to damage the flex cable you just disconnected. If necessary, hold it to one side so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
  34. iPhone X Bluetooth Antenna Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  35. iPhone X Bluetooth Antenna Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker.
    You don’t need to remove the speaker and ruin its gasket. You can wiggle and slide the taptic engine out without removing the speaker. I’ve done this twice on rear shell replacement jobs.
    timblake2112 - crwdns2934203:0crwdne2934203:0
    Maybe I'm a bit daft, but where's the instruction just how to line up the speaker gasket when replacing? I only have one so I'd like to avoid wrecking it. And I completely cleaned off the old one in order to do a good job of things. Why no simple instruction from part supply link?
    MrRoundel - crwdns2934203:0crwdne2934203:0
  36. iPhone X Bluetooth Antenna Replacement, Replace the speaker gasket: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Replace the speaker gasket: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Replace the speaker gasket: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speaker's gasket is not reusable. During reassembly, follow this step to replace the gasket.
    • Use tweezers to peel off and remove all the old gasket from the frame and speaker.
    • Use a microfiber cloth and isopropyl alcohol to clean all the gasket's adhesive residue from the frame and speaker.
    • Before installing the speaker gasket, find its proper orientation on the bottom of the speaker—the large cutout on the gasket should go around the speaker grille mesh.
    • Remove the larger, clear liner from the gasket and use tweezers to carefully put the gasket into place on the bottom of the speaker.
    • To avoid touching the exposed adhesive, only grip the gasket by the outer edges of the liner.
    • Use your fingers or a spudger to firmly press the gasket into place to secure it with the adhesive.
    • Remove the remaining liner and put the speaker into place, making sure the speaker connector doesn't get stuck underneath.
  37. iPhone X Bluetooth Antenna Replacement, Taptic Engine: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Taptic Engine: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.3 mm Phillips screw securing the Taptic Engine.
  38. iPhone X Bluetooth Antenna Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
  39. iPhone X Bluetooth Antenna Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Taptic Engine.
  40. iPhone X Bluetooth Antenna Replacement, Battery: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The iPhone X's battery is secured to the rear case by four pieces of stretch-release adhesive—one on the top cell, and three on the bottom.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the side edge of the battery.
  41. iPhone X Bluetooth Antenna Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the first battery adhesive tab from the bottom edge of the battery.
    • Each tab has a small loop in the center; insert a tool through the loop if you're having trouble grabbing hold of the tab.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    hole breaks instantly on pulling. adhesive tab does not release from side of battery
    Dominick garton - crwdns2934203:0crwdne2934203:0
    I had a lot of trouble with this. Only two came out properly and the others snapped off. I heated up the back of the phone with a hair dryer then used the flat end of the spudger to slowly pry it off right to left, bottom to top.
  42. iPhone X Bluetooth Antenna Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the above step to separate the remaining two adhesive tabs from the bottom edge of the battery.
    • Take care not to damage the speaker cable connector just below the center adhesive tab.
  43. iPhone X Bluetooth Antenna Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips.
    • To increase your odds of success:
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strips flat and unwrinkled as you pull.
    • Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
    • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
    • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
  44. iPhone X Bluetooth Antenna Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab one of the outer battery adhesive tabs and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
    I found it easier to grab the end of the adhesive strip sideways with narrow tweezers, "twirl " the tweezers to wrap the strip around them a few times, then gently pull the strip with the tweezers.
  45. iPhone X Bluetooth Antenna Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the strip on the opposite side, leaving the center strip for last.
  46. iPhone X Bluetooth Antenna Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the center strip, being careful not to snag it on the speaker flex cable.
  47. iPhone X Bluetooth Antenna Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The final pull tab lies very close to the Face ID hardware. If damaged, Face ID can only be repaired by Apple, so work with care.
    • Peel and separate the pull tab on the final adhesive strip, on the top edge of the upper battery cell.
    surtout ne pas passer avec la spatule par le bas, vous risqueriez d arracher la nappe du volume et du nfc,
    Ludovic Klein - crwdns2934203:0crwdne2934203:0
  48. iPhone X Bluetooth Antenna Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull and remove the final adhesive strip.
    • The strip may fling the battery when it separates from the iPhone, so hold your hand over the battery to secure it—but don't press down on the battery itself, or the added pressure may cause the adhesive strip to break off underneath the battery.
    • If you removed all four adhesive strips successfully, skip the next step.
    • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • Be careful not to damage the ribbon cables or the wireless charging coil directly underneath the battery.
    • For alternative methods to unstick the battery from the case, continue to the next step below.
  49. iPhone X Bluetooth Antenna Replacement, Alternative method to unstick the battery from the case: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Alternative method to unstick the battery from the case: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
    • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
    • Wrap the ends of the string around a cloth (or wear gloves) to protect your fingers.
    • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
    • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
    if you use a guitar string, remember NOT to use a METALLIC guitar string.
    Ross King - crwdns2934203:0crwdne2934203:0
    flexible plastic rules with alcohol work too
    I can confirm that IPA (Iso Propyl Alcohol) and, in my case, the plastic plectra in any iFixit kit worked a treat.
    P Bond -
  50. iPhone X Bluetooth Antenna Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the battery from the bottom edge and remove it from the iPhone.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Reinstall the Taptic Engine and speaker before installing a new battery. This helps keep the battery aligned correctly during installation.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery does not come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    When reinstalling the battery, the Taptic Engine does serve as a useful way to orient the battery, but it should also be noted that if you push right up against that as you install the battery (as I did) and don’t pay any attention to power connector (shown in step 14), there is a risk that the connector from the battery will not line exactly with the connector port on the board. Mine was only off a mm so I had to get a little creative to try to get it to stretch to reach and connect to the port on the board. Just keep that in mind as you place the battery (with adhesive) down.
    Jesse Bolane - crwdns2934203:0crwdne2934203:0
    Connect the battery first then put it in place. Other way it is hard to adjust power connector.
    I would also HIGHLY suggest re-installing the speaker as well before installing the battery - it was a very tight squeeze as the bottom-right of the battery was snug against the speaker when I tried to get that back in.
  51. iPhone X Bluetooth Antenna Replacement, Front Camera Assembly: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Front Camera Assembly: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Front Camera Assembly: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the flat end of a spudger, disconnect the three front camera assembly cables:
    • The dot projector.
    • The front camera.
    • The infrared camera.
    This thing is highly prone to damage. Treat it with baby hands! Mine stopped working after changing my buttons and I was super careful
    Ryan Kamfolt - crwdns2934203:0crwdne2934203:0
  52. iPhone X Bluetooth Antenna Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The camera cables are lightly adhered to the midframe.
    • Using the tip of a spudger, start at the connector and slide the spudger between the IR camera cable and the case to separate the cable from the case.
    • Repeat for the front camera cable.
  53. iPhone X Bluetooth Antenna Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat to loosen the adhesive on the front camera assembly.
  54. iPhone X Bluetooth Antenna Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front camera assembly.
  55. iPhone X Bluetooth Antenna Replacement, Logic Board: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the following cable connectors.
    • The WiFi Antenna connector.
    • The Wide-Angle Camera connector.
    • The Power Button / Flash / Microphone connector.
    • The Telephoto Camera connector.
    • The Dock Flex connector.
    • The Button / Wireless Charging connector.
    • The Cellular Antenna connector.
  56. iPhone X Bluetooth Antenna Replacement, WiFi Antenna Connector: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, WiFi Antenna Connector: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the WiFi Antenna cable connector.
  57. iPhone X Bluetooth Antenna Replacement, Wide-Angle Camera Connector: crwdns2935265:057crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Wide-Angle Camera cable connector.
  58. iPhone X Bluetooth Antenna Replacement, Power Button / Flash / Microphone Connector: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Power Button / Flash / Microphone Connector: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Power Button / Flash / Microphone cable connector.
  59. iPhone X Bluetooth Antenna Replacement, Telephoto Camera Connector: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Telephoto Camera Connector: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Telephoto Camera cable connector.
  60. iPhone X Bluetooth Antenna Replacement, Dock Flex Connector: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Dock Flex Connector: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Dock Flex cable connector.
    • Bend the cable 90 degrees straight up to allow clearance to remove the logic board.
  61. iPhone X Bluetooth Antenna Replacement, Button / Wireless Charging Connector: crwdns2935265:061crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Button / Wireless Charging Connector: crwdns2935265:061crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Button / Wireless Charging cable connector.
  62. iPhone X Bluetooth Antenna Replacement, Cellular Antenna Connector: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Cellular Antenna Connector: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Cellular Antenna Connector: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Cellular Antenna cable connector.
    • Bend the cable out of the way.
  63. iPhone X Bluetooth Antenna Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:063crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The logic board cannot be removed with the SIM card tray in place. If you failed to remove it earlier, take it out now.
    • Remove the two Phillips mounting screws.
    • One 2.7 mm Phillips screw.
    • One 2.1 mm Phillips screw.
    • Remove the 2.0 mm Phillips grounding screw.
    • Remove the grounding tab.
    • Be sure to replace the metal grounding tab in the same orientation.
    Impossible de retirer la vis de terre. J'aimerais savoir si je peux continuer ou si je dois absolument retirer la vis et la fiche de terre.
    Fix Mom - crwdns2934203:0crwdne2934203:0
  64. iPhone X Bluetooth Antenna Replacement, Retract the SIM Eject Pin: crwdns2935265:064crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the SIM card is ejected, a pin slides out from the frame and pushes on the eject lever in the SIM card carrier. The pin needs to be pushed back into the frame so it will not block the removal of the logic board.
  65. iPhone X Bluetooth Antenna Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:065crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of fine tip tweezers to slide the SIM card eject lever toward the side of the case.
    • The eject lever should look like this when you're done. The pin will no longer block the removal of the logic board.
  66. iPhone X Bluetooth Antenna Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The logic board assembly is mounted on two posts going through the lower board and are secured to the upper board. In order to remove it, you must lift it evenly straight up to clear the stand-offs.
    flip phone over and dump it out
    Thomas Ngo - crwdns2934203:0crwdne2934203:0
  67. iPhone X Bluetooth Antenna Replacement, Bluetooth Antenna: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone X Bluetooth Antenna Replacement, Bluetooth Antenna: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.3 mm Phillips screw securing the antenna to the rear camera frame.
    • Remove the 1.5 mm Phillips screw securing the antenna to the case.
    This step has a duplicate screw from step 66. When reassembling the phone by following the steps in reverse, it messes it all up because in order to put this 2.3mm screw in, you have to put in the cameras and the bar that holds them down, but then when you get to step 86 the flash can't go in because the camera went in too soon. So I think if we simply remove the 2.3mm screw removal from this step then disassembly and reassembly should work out okay.
    Sandy Andlow - crwdns2934203:0crwdne2934203:0
  68. iPhone X Bluetooth Antenna Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:068crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone X Bluetooth Antenna Replacement: crwdns2935265:068crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the end of the cable off the post on the back of the case.
    • Peel the cable from the rear camera housing with a spudger.
    • Remove the bluetooth antenna.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
76,035 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
This is a really excellent guide. Thank you very much for the help!
cammci - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 238
crwdns2942667:0crwdne2942667:0 12,063
