iPhone 8 Screen Replacement
crwdns2936621:0crwdne2936621:0
  1. iPhone 8 Screen Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - crwdns2934203:0crwdne2934203:0
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - crwdns2934203:0crwdne2934203:0
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - crwdns2934203:0crwdne2934203:0
    Maybe the screw is stripped…
    Gabriel-Science -
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - crwdns2934203:0crwdne2934203:0
    Does it lasted longer ?
    Gabriel-Science -
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - crwdns2934203:0crwdne2934203:0
    Same problem. The kit comes with a screw driver, but not for this pentalobe screw. This is a problem.
    Yuji Ishitsuka - crwdns2934203:0crwdne2934203:0
    I had to search what screwdriver bit I had to use from the ifixit toolkit; it's the P2 bit. (Maybe it's more obvious if you bought the battery kit, because it only has one type of pentalobe screwdriver.)
    Nathaniel Zielstra - crwdns2934203:0crwdne2934203:0
    I drained my battery completely before I did this thinking it might help prevent a fire if I accidentally puntured it. I don't know if that is the case... but figured it couldn't hurt.
    Megolina - crwdns2934203:0crwdne2934203:0
  2. iPhone 8 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
    Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
    Alasdair Cameron - crwdns2934203:0crwdne2934203:0
    I bought the kit of five just in case. I used two and marking them at 3mm was definitely helpful.
  3. iPhone 8 Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 8 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 8 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 8 Screen Replacement, Heat the display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    No hair dryer so GENTLY heated over stove burner
    John Toth - crwdns2934203:0crwdne2934203:0
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - crwdns2934203:0crwdne2934203:0
    I was about to ask the same Question...
    Enno Winch -
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - crwdns2934203:0crwdne2934203:0
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - crwdns2934203:0crwdne2934203:0
    Hey, that's smart !
    Gabriel-Science -
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - crwdns2934203:0crwdne2934203:0
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - crwdns2934203:0crwdne2934203:0
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - crwdns2934203:0crwdne2934203:0
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - crwdns2934203:0crwdne2934203:0
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - crwdns2934203:0crwdne2934203:0
    It won't work if you don't throw it in the lava.
    Gabriel-Science -
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - crwdns2934203:0crwdne2934203:0
    Hairdryer works fine for this step. No issues.
    Agree! Just did it for 2 times to make sure I didn't overheat the phone.
    André Lopes -
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - crwdns2934203:0crwdne2934203:0
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - crwdns2934203:0crwdne2934203:0
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - crwdns2934203:0crwdne2934203:0
    This part was actually much easier than I thought. I used a hair dryer on max for 2 minutes on each side of the phone, less than half an inch away from the phone, just on the bottom half. It was hot! Screen came right out!
    Nuno Lopes - crwdns2934203:0crwdne2934203:0
    I used a tube sock full of about 1 cup of white rice. Tied a knot in the top of the sock. Put the sock of rice in the microwave on 60% power for 1 minute. Kept doing this until the temp felt right. Put the sock of rice down, put bottom edge on sock, then covered w/ other half of the sock/rice. Put a piece of paper towel between phone and sock/rice to absorb any moisture. When lifting up on front panel, I rested the phone on the sock/rice. Worked nicely once I got the temp of the rice high enough.
    (threw the rice away later :-) )
    Burning Sensation - crwdns2934203:0crwdne2934203:0
    “Threw the rice away later” has to be the best advice here. I wrapped my phone in a small heating pad and turned it up to 6 of 8. Worked great in 5 min or less! No need for water bottles, microwaves, heat guns, volcanoes, …. I kept the heating pad later ; )
    dantegd - crwdns2934203:0crwdne2934203:0
    I popped my iPhone under a desk lamp with a 60w filament light bulb in it, switched it on, (See this photo) then read the iFixIt instructions and comments. By the time I’d done that, the glue had softened enough to start work. I managed to do the whole process, slowly and methodically, without incident. The iPhone even worked after I’d put it all back together. So we’ll done iFixIt. Another satisfied customer!
  7. iPhone 8 Screen Replacement, Separate the display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement, Separate the display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - crwdns2934203:0crwdne2934203:0
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - crwdns2934203:0crwdne2934203:0
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - crwdns2934203:0crwdne2934203:0
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - crwdns2934203:0crwdne2934203:0
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - crwdns2934203:0crwdne2934203:0
    This was the time consuming part. I’d recommend having a thin bladed knife or similar to get things going. I used the small blade on my Swiss Army knife, but be careful. When it goes, it can be unexpectedly sudden. I also used a strong rubber band to stop any excessive opening of the screen.
    This was easier than I thought it would be. I used the suction cup that came with the kit and put the edge of it below the home button so the home button was inside of the suction cup. There was just enough room for it so it had full contact with screen. I didn't have packing tape and turns out I didn't need it.
  8. iPhone 8 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - crwdns2934203:0crwdne2934203:0
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - crwdns2934203:0crwdne2934203:0
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - crwdns2934203:0crwdne2934203:0
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - crwdns2934203:0crwdne2934203:0
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - crwdns2934203:0crwdne2934203:0
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - crwdns2934203:0crwdne2934203:0
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - crwdns2934203:0crwdne2934203:0
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - crwdns2934203:0crwdne2934203:0
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - crwdns2934203:0crwdne2934203:0
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - crwdns2934203:0crwdne2934203:0
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - crwdns2934203:0crwdne2934203:0
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - crwdns2934203:0crwdne2934203:0
    I used an electrician's heat gun for 90 seconds. Worked well. You don't have to pull up on the suction cup very much AT ALL. I bought a special, thin, Jerry Rig Everything metal spudger off Amazon. It easily made the first cut and then I used the blue plastic triangles with the 3mm marks to score around the rest of the edges. I did this in the exact order of the instructions and it worked well. Careful, slow and patient wins the day here. Careful at the top. Don't just lift up on the screen, definitely push the screen down toward home button as there are a couple of clips holding the screen to the body at the top of phone.
  9. iPhone 8 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - crwdns2934203:0crwdne2934203:0
  10. iPhone 8 Screen Replacement, Screen information: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - crwdns2934203:0crwdne2934203:0
  11. iPhone 8 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    No pick in the kit you sent me.
    Ted Cooper - crwdns2934203:0crwdne2934203:0
  12. iPhone 8 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    There was no "small nub" but a fingernail popped the suction cup off easily.
  13. iPhone 8 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - crwdns2934203:0crwdne2934203:0
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - crwdns2934203:0crwdne2934203:0
  14. iPhone 8 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    I had trouble sliding down the display and found I hadn't separated the stop enough.
    Jeffrey Anderson - crwdns2934203:0crwdne2934203:0
    When you are pulling the display downward, be very careful! I pulled a little too hard and the display cables tore from the downward (toward home button) motion. Now I have to replace the display! 😭
    So Munch Love - crwdns2934203:0crwdne2934203:0
  15. iPhone 8 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - crwdns2934203:0crwdne2934203:0
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - crwdns2934203:0crwdne2934203:0
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - crwdns2934203:0crwdne2934203:0
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - crwdns2934203:0crwdne2934203:0
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  16. iPhone 8 Screen Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
    can same length screws mixed up?
    Brook布魯克 - crwdns2934203:0crwdne2934203:0
    It is not ideal, but possible for these screws.
    Arthur Shi -
    using the repair kit i purchased with my screen replacement, i am currently having issues removing these screws with the PH000. please help
    Mark Ordaz - crwdns2934203:0crwdne2934203:0
    I was too, thankfully I had another set that contained the PH00 bit, that worked great for me.
    William Mitchell -
    Ok. My screw is stuck. How do I remove it? Philips head is stripped.
    Kristina Graham - crwdns2934203:0crwdne2934203:0
    Solved it myself. Firm pressure did the trick.
    Kristina Graham -
    Takes a little pressure with the Philips head
    Upon this step, I noticed I had no bracket or screws. I had my screen replaced previously and I’m disappointed to find out the repairperson made no effort to replace these parts. I’ll start trusting myself more to do my own repairs.
    O D - crwdns2934203:0crwdne2934203:0
    took me awhile to figure out I needed to use PHOO bit for the 2 -1.3 screws
    It is important to keep careful track of the screws' position. Have a tidy workplace -- a few times when I tried to re-attach the very tiny screws with the tweezer, they slipped and flew away and I almost lost them.
    can you strip the screws / how can you tell if its strip or not
    antonio - crwdns2934203:0crwdne2934203:0
    I was lucky enough to do this on a ship where the electrical shop has a jeweler's mirror! I would have had to get more magnified readers if I had tried this on shore... Also, I used plastic containers with lids to separate each group of screws and their corresponding brackets, putting a little note inside each.
  17. iPhone 8 Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Make sure you pry the battery connector off from the right hand side as shown in the picture. Theres a delicate component on the logicboard near the battery connector called a Mosfet which is linked to the battery charging software. If you knock it off accidently you’ll loose battery charging and the phone will boot loop and youll need to have it re-soldered back on.
    Gareth - crwdns2934203:0crwdne2934203:0
    I can confirm this as I learned my lesson by unknowingly prying the mosfet off. The phone will not charge now and is useless. I really wish they would add a note about this on Step 12 as a warning.
    Jeff -
    So this is it. You don’t have to go any further removing the screen. You can replace the battery right from this point.
    John M - crwdns2934203:0crwdne2934203:0
    I wish I saw this comment 2 hours ago
    Kenneth Moore -
    If I have to repeat this, I'd also consider removing replacing the battery at this point. The loose display must be then carefully fixed so the connectors don't break. And then it is not possible to re-attach the waterproof seal.
    The waterproof seal was included in the kit, but there were no instructions for it so I now skipped that. I later found YouTube video which seems to describe it (starting at 7:40):
    https://www.youtube.com/watch?v=RcgGRhaX...
    Matti Haveri -
    This is where I broke my phone, a phone that was working quite well, paid for in full. Just because I had a cracked screen. Be super careful when connecting the cables. I was in a hurry and not paying attention, used too much force when re-connecting and broke those teeny little pins that could not be repaired. A tech tried for an hour to no avail. cautionary tale. Good luck
    The display ribbon is a certain length and allows for some give, but behind it is hidden the Home button/TouchID ribbon, which sits against what amounts to a razor blade. This ribbon is much more taut than the display one, and therefore you have far less freedom of movement than you think you do. This is absolutely an intentional trap to discourage replacing your own battery. Quite frankly, it’s despicable.
    Anyway, so beware of that, because although I was very careful and did not even swing the screen very far (not more than 90°), the Home button ribbon tore and now needs to be serviced. Home button is disabled now.
    Apple should be ashamed of themselves for this. Please do look at the legislation effort that people are doing to try to get this kind of sabotage illegal, as well as all sorts of other gimmicks they pull. For a company that makes phenomenal products, they’re controlling like an abusive spouse.
    Dan Knight
    daniel - crwdns2934203:0crwdne2934203:0
    That happened to me and I could not figure out how it got broken. It's the home button and fingerprint reader.
    But I'm not bothering to get it fixed and I'm not replacing the entire screen. I went into system prefs/accessibility and activated the on-screen home button. Oh, well.
    Mangled Jargon -
    I cannot get the new battery reconnected to the connection port. Any tips/tricks? New and old battery connections appear similar. It wasn't difficult to disconnect to old battery.
    Robert Ast - crwdns2934203:0crwdne2934203:0
    Some reports here seem to indicate that the battery must be the very last connector to re-connect because otherwise there might be malfunction in some display components?
    It wasn't difficult to disconnect to old battery. But the most difficult part for me was to get the new battery reconnected to the connection port. I tried many times to carefully position and press it down with my fingertip or the flat end of the spudger but it did not hold its position. Maybe I pressed too weak because I was afraid breaking the connector and the mosfet above (?) it. But finally to my surprise it connected (at that point I temporarily booted the iPhone with the loose display to verify that the battery was connected). Whew, it succeeded!
    The connectors have very little "click" to them when they do seat properly, and are covered with soft foam. Very challenging to attach them by feel, and having the screen propped up, blocks light from exactly where you need it.
    Steve Trotman - crwdns2934203:0crwdne2934203:0
    Make sure the new battery connector cable has similar length and width to the one of the original battery. I got a third party battery and the cable was longer and not folded in a "U" way near the connector, like the one in the genuine battery was, only folded at a 90 degree angle. That "U" actually perfectly fits in the small space between battery and connector port, so the cable doesn't stick up thus making connecting it or closing the screen impossible. So fold the cable, connect it, and while holding it to prevent it from disconnecting, stick the battery so the "U" curve of the cable sits down just between battery and connector port.
    Reconnecting this after I replaced the battery was the hardest part that took the most care and patience. The connector is attached to the battery itself and it had to be bent/folded in exactly the right angle to fit into its mate.
  18. iPhone 8 Screen Replacement, Disconnect the display and digitizer: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement, Disconnect the display and digitizer: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I broke the lower display connector. Is it possible to replace that part separately or do I need to buy a full screen replacement?
    Ross Mckellar - crwdns2934203:0crwdne2934203:0
    You need to buy a new screen
    conrad veldhouse -
    이렇게 친절하게 정성스럽게 분해도 올리신 분은 처음이네요 진정 프로/ 기타 나머지 잡것들은 대충 올려 돈이나 벌어보자는 업자num들/ 배터리 교체하는 유툽 영상보다...업자가 올린 ...배터리 교체는 따라했으나 그후 배터리 교체와는 전혀 상관 없는 액정 뒤판을 jo빤다고 설명도 없이 뜯어 그것까지 따라하다 액정이 나가버려 지금 무주공산에서 홀로 검색하다 이걸 보게됨
    평생놀아난다 - crwdns2934203:0crwdne2934203:0
    The tip about how to re-attach press connectors without damaging them should really be at the last press connector step since we're following the steps in reverse order to reassemble.
  19. iPhone 8 Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to disconnect the second lower display cable.
  20. iPhone 8 Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    If you are replacing the adhesive liner, the remaining release liner strips will interfere with the two outer screws. I had to cut a working section out of the liner at each location and move it aside with the spudger.
    Thomas Tritt - crwdns2934203:0crwdne2934203:0
    This part is throwing me for a loop. Having difficulty finding the read head for these screws. Is it the same size as the two small 1.3mm screws in step 12?
    Jared Hensley - crwdns2934203:0crwdne2934203:0
    These are the same size screws mentioned in Step 17.
    Douglas Walker -
    ended up getting it with the PH000, I must of just been rushing it.
    My bracket looks different and none of the screw heads I have fits.
    Ray Rushing - crwdns2934203:0crwdne2934203:0
    Mine too? Any help?
    George Waller -
    These screws did not stick to the magnetic screwdriver. Extremely difficult to get them back in place - but with some patience i succeeded :)
    Niklas Brammer - crwdns2934203:0crwdne2934203:0
  21. iPhone 8 Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
    Do you have a link for the flex cord shown in the pictures so I can purchase it? Having a hard time locating that exact assembly
    Regal Carveiro - crwdns2934203:0crwdne2934203:0
    It’s of a piece with the front camera.
    xint - crwdns2934203:0crwdne2934203:0
    ここの、マザーボード側のピンが数本なくなっていた場合
    交換するには、どの部品名で探せば良いですか?
    ren12o7.2011 - crwdns2934203:0crwdne2934203:0
  22. iPhone 8 Screen Replacement, Remove the display assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Hi ifixit, if you find my method dangerous, please remove it.
    After Step 17, I skipped Step 18 to Step 28.
    At Step 29, I lifted up the four adhesive black pull-tabs to expose the white adhesive side. Next, I use hot air gun and blow on the back cover of the iphone for about a minute (maybe a hairdryer will work too) .
    Warning: Don't overheat the iPhone, or you may accidentally ignite the battery.
    I think the temperature was around 60 DegC.
    Extreme Caution: Do Not overheat. I use my hand to gauge the hotness. Careful not to burn yourself or the board.
    I was able to pull out all the white adhesive tapes easily as the adhesive soften.
    DO NOT TRY this method if you are a novice or inexperience! I am not responsible if you hurt yourself or damage your iphone!
    Hey John! I’m glad the repair worked out for you!
    From our research, applying heat does soften the adhesive strips, but it also causes them to lose structural integrity and break more easily. That’s why we normally suggest using heat after the strips are already broken. Removing the Taptic Engine definitely takes a few extra steps, but we feel that it gives fixers the best chance of pulling out the adhesive strips intact.
    Arthur Shi -
    I agree with John, skip 18 through 27. These are to make it easier to remove the battery adhesive. I replaced the batteries on two IPhone 8s. The first one I did all that stuff and the adhesive still broken and I had to carefully pry the battery out anyway. When I reassembled the phone the Home button no longer worked. Looking it up, this is apparently fairly common due to all the fragile wires involved in these steps. The second I skipped these steps and when I reassembled it everything worked fine. Not one of the eight (both phones) adhesive strips came out properly. I fully drained the batteries before doing the repairs. By the way, I use the virtual home button on the one phone, it’s a little annoying, but the phone is still usable if you’re not ready to shell out for a new phone.
    Gary Berman -
    I also skipped removing the Taptic Engine. I could only half-way pull the lower battery tapes and completely the upper tapes after carefully prying them loose with the tweezer. I then used a hair-dryer for a minute to warm the battery and the other side of the phone (I used my other hand to make sure I did not apply too much heat. Make sure you do not blow the tiny loose screws away with the hair dryer!) and then slowly lifted the upper battery somewhat with the Opening pics tool, then re-heated the lower remaining tapes and quite easily lifted the battery out.
    I had bought two-sided tape to reconnect the battery but it had the tapes pre-installed (I wonder if it is necessary to tape the battery at all?).
    Matti Haveri -
    I also skipped these steps. I won’t say it was entirely successful - two of the four adhesive strips broke and could not be grabbed with tweezers. But I had gotten most of the adhesive out already and the battery was quite loose, so I used a warmer under the phone, then gently slid a flat plastic blade under one end of the battery and slowly worked it up the phone. (Dental floss would have been safer-don’t do what I did, kids!)
    Matt D - crwdns2934203:0crwdne2934203:0
    Likely can skip step 18-28 and all the risks. Battery tape is relatively removable by the following method
    - use a tweezer to pull up a corner of each tape. Then use fingers to peel back all the black tab on top of battery
    - use 2 hands. Index and thumb on both. Pull about 1/4” with one hand, hold the tension and pull 1/4” with the other hand. Alternate, go slow. Pull out all 4 tape completely. I think the pause after each 1/4” while holding the stretched tape firmly prevents the tape from over stretching to become too thin and break.
    - Don’t apply heat, I would guess that makes tape softer and break easier.
    Have tried other methods and failed in the past. Pulling too fast (tape will snap) or use a tweezer to twist/roll (sharp edges will cut tape) Anyway, just use index/thumb on both hands and alternately pull slowly
    I did do 2 iPhone 8 battery change this way. One removed all tape without breaking. Another broken all 4 tape after about 1/3 pulled so likely some factory assembly differeces.
    I second this, this method works well in most cases. Removing the haptics helps to keep the angle low and pulling the tape as straight as possible
    Hein Blöd -
    Howards method for removing the adhesive works like a charm. The only addition I made was to slightly warm the back of the iphone on a rice pack (used for sore neck muscles—haha). Going back and forth between hands is really crucial. While on hand gives a gentle pull, the other holds the phone from moving. Slow back and forth. Thanks.
    Lynn Thomas - crwdns2934203:0crwdne2934203:0
    Struggling with the glued down display, then properly cleaning all the remains of the old seal, then positioning the new seal is 95% of this job. I purchased my phone refurbished and it clearly had already been serviced once, there were remnants of an old seal below the current seal due to improper cleaning and prep that made getting the phone open harder than it needed to be.
    For my 2nd iPhone 8 battery replacement, I chose not to remove the display completely, or the Taptic Engine and I was successful. You have to pay extra attention and it is a bit trickier to keep the display from moving around too much, but I think minimizing the amount of screws and connections to take out, the better. You can easily lose the screws and you have to mind which ones go where, as there are so many different lengths. YMMV.
    In retrospect, I also would have skipped ahead to step 33. I didn't, but my efforts at removing the adhesive tape were also unsuccessful so steps 23-33 were for naught. Ended up applying isopropyl alcohol, then warming the back, and finally just physically levered the battery out. Battery was slightly deformed and became slightly warm, so as soon as I got it out I just put it outside on a brick.
    But the replacement worked.
    Peter Benson - crwdns2934203:0crwdne2934203:0
  23. iPhone 8 Screen Replacement, Remove the home/Touch ID sensor bracket: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Screen Replacement, Remove the home/Touch ID sensor bracket: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.2 mm screw
    • Remove this screw first. Excess pressure may bend the home button bracket if you remove the 1.3mm screws first.
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
    Bei meinem iPhone waren das Y00 Schrauben, nicht Y000
    Andreas Veeser - crwdns2934203:0crwdne2934203:0
    If the screw on the home button is broken, you can bend the metal sides upwards and pull down out of the phone and push and refold into the new display. Example: https://www.youtube.com/watch?v=DTCQA-jn...
    Andy Knapp - crwdns2934203:0crwdne2934203:0
    Andy Knapp - wherever you are - you saved me. NOTE: the iphone 8 has four tri-wing screws - that means you need a tri-wing screwdriver. I ordered an entire replacement set and mine had one in there, but it does not mention anything about tri-wing in these instructions… so. Hope that helps someone.
    Paula Lofland -
    On my iPhone, these were Y00 screws, not Y000
    Dutch version speaks of one 1,3 mm screw, but has 3 of those screws.
    Fonne Van Gils - crwdns2934203:0crwdne2934203:0
    There is a difference between Y00 and Y000. I realized this after unknowingly trying the Y000 and damaging the tip of the screwdriver, as the metal is apparently softer than the screw. I was able to use the corner of a flat metal file to make the cheap Y0000 work (which came with the replacement kit) by making 3 adjustments: 10 filing down the tip, 2) filing the shoulders to make the tips more pointed, and 3) cleaning out the 3 channels to remove burrs from the tip edges.
    Robert Lanzafame - crwdns2934203:0crwdne2934203:0
    Note on the bracket, it’s above the attached washers to the plate backing the screen. The image here is obscured by the yellow and red circles. Also, the bracket has a red herring hole that doesn’t serve an apparent purpose - don’t freak out and think you lost a screw
    Wandra - crwdns2934203:0crwdne2934203:0
  24. iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry under the left edge of the home button cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
    To have a better view on this connection I have removed the metal plate covering the back of the glass. Its a thin piece of metal held by 9 screws. To unscrew the 8 screws you need the screwdriver head with 3 sides like the Mercedes Benz symbole. The last is with a phillips near the camera.
    forhereyesonly - crwdns2934203:0crwdne2934203:0
    I thought I was going to tear the cable doing it the way it’s suggested in the guide. After examining the cable on the replacement screen, I found it easier to hold the bottom connector pressed against the screen with one leg of needle nose tweezers whilst gently prying off the top connector with an opening tool.
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    See step 22 to get a clearer picture of what the connector looks like when it is separated from its socket. Your replacement screen will have a new socket (i.e., the bottom piece of the connector). My replacement screen had a new socket attached to the unit by a thin piece of plastic. For reassembly, when working the Home Button/Touch ID assembly back into the new screen, I had to work the connector cable under the socket in order to get the connector re-attached.
    Be extra careful with this step: it wasn’t clear to me from the description that the connector wrapped from underneath to connect, nor did my set come with picks. I used a blade from the wrong side, inadvertently (but way too easily) severing the connector and destroying the function of the home button and thus the entire phone.
    Jennifer Indeliclae - crwdns2934203:0crwdne2934203:0
    Be careful, I initially didn’t found the connector and nearly ripped the cable. The connector leads to a cable that goes under the metal plate. Found a YouTube video with very good close ups for this part (go cell phone repair detailed version)
    Svenja Büsing - crwdns2934203:0crwdne2934203:0
    I initially didn’t found the connector and cable and nearly broke it. The connector leads to a cable that goes under the metal plate, I needed YouTube video with good close ups to understand the setup.
  25. iPhone 8 Screen Replacement, Remove the Touch ID sensor: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    • Don't overheat the display. It should be slightly too hot to touch comfortably.
    The stove top works well also. Remember, as the main instructions say, it should be slightly too hot to touch comfortably.
  26. iPhone 8 Screen Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Screen Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
    My original assembly broke trying to follow this step carefully. :(
    Ann - crwdns2934203:0crwdne2934203:0
    This one’s kind of hard to reconnect. Just remember to be gentle, take your time, and use your hands so that you can really feel it out.
    Keep in mind, there’s a tiny rubber ring gasket between the Touch ID button and the display. In my experience when removing the button, the gasket stuck partly to the the button and partly to the display. I gently removed the part that was sticking to the display and guided it back on the button. If you’re missing that gasket it won’t be waterproof.
    Sam Tropper - crwdns2934203:0crwdne2934203:0
    I used a heat gun set at 300*F to heat up the glass side for about 20 seconds and on connector side for about 10 seconds (touchscreen was a little too hot to the touch). Pulled connector with fingers and pried off with plastic tool.
    anonymous 6745 - crwdns2934203:0crwdne2934203:0
  27. iPhone 8 Screen Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
    Instructions were great. Putting the connections back is a bit of a hassle, but patience is your friend. Phone is up and running. Thanks iFixit.
    pwpfef01 - crwdns2934203:0crwdne2934203:0
    Couldn’t get the Home Button (original one I was transferring) to work. I know the instructions said something about not tightening down the 4 screws around the Home Button too much, but how much is too much. Also, a day later, the screen I bought starting having green vertical lines. Took everything back apart and started from scratch the next day and still had the same 2 problems. Just for the heck of it, I put the old cracked screen back on the phone and everything started working again. Figured I wasted about 6-8 hours total on this rather small project and I’m right back where I started again. Something definitely wrong with the screen I ordered and I’m very disappointed. I’ve bought products from ifixit before and they worked, but no such luck this time. Anyone know how I get my 70 bucks back?
    Todd Skobjak - crwdns2934203:0crwdne2934203:0
    Hi Todd!
    I’m sorry to hear about your experience! Please contact our customer support and we will get the issue resolved!
    Arthur Shi -
    They charged you $70 bucks for a new replacement screen for an iphone8 and it didn't even work right that's crazy they are over charging people considering my wife only payed $23 for a new replacement screen kit that comes with the new screen and everything else you need to change it out plus a extra screen protector and I just finished replacing the screen and so far so good no green vertical lines running down my screen. I like ifixit because they show me how to fix what I need to fix but I don't think I will be buying anything from them anytime soon.
    Lincoln -
    I greatly support Ifixit… but.. for me the same story as Todd Skobjak. Put in the new screen. Touch button is not found. Retried with screws loosened and refitting the plug. Nothing. Put the old screen back and the touch button worked again. So.. something with the new provided screen from Ifixed must be the case. I'll also get in touch with customer support.
    Ifixed: not only check the screen but also the cable to the touch button!
    Ton Vaes - crwdns2934203:0crwdne2934203:0
    What’s the trick here?
    Getting an “unable to activate Touch ID” after replacing the home button and a new screen - somewhat similar to that above. Any troubleshooting steps/resolution? I loosened, tightened screws holding the assembly, no effect.
    schaferjon - crwdns2934203:0crwdne2934203:0
    The button is paired with the motherboard. if you change the screen, always attempt to retrieve the original button.. otherwise touchid will not be available
    Bill McNamara -
    The instructions for this home/touch button repair were spot on! The special tip in red for Step 19 was extremely useful because that was exactly what I encountered while attempting to remove the original home/touch button from the original front screen. Step 21 and accompanying photos were a life saver as well, but this process did require heating the screen with my wife’s hair dryer several times to be able to gently pry up the adhesive for the home/touch button ribbon without ripping it to pieces. And yes my phone worked great after completing this repair. Time spent meant money saved and a personal satisfaction and pride in a job well done. Thank you Team iFixit!
    Jeffery Anderson - crwdns2934203:0crwdne2934203:0
    the steps to move the front camera and speaker to the new screen are missing, right?
    martijn.klabbers - crwdns2934203:0crwdne2934203:0
    do you really neec to replace the home button?
    ineedtoreplacemyphonescreen - crwdns2934203:0crwdne2934203:0
    Do you foget to pick up and set the inner camera?
    Or, is that too easy for you to instract in it...?
    Actually I got that by myself,,,
    M Moto - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help. Or if you’re in the market for a new device, consider getting a refurbished iPhone 8 from our friends at Backmarket!
crwdns2935229:0416crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
213,039 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:038crwdne2947412:0
And do you just wing it for the front camera, proximity sensor etc ?
kyle - crwdns2934203:0crwdne2934203:0
This guide assumes you’re replacing the entire display assembly, with those parts included. If you bought a bare display then yes, you’ll have to transfer those additional components over, and that’s beyond the scope of this guide—although as mentioned in the introduction, we’re working on adding guides for those additional components as well.
Jeff Suovanen -
wait a second… Are you saying that when we change the screen it is also necessary to change the front camera?
Caio Antonius - crwdns2934203:0crwdne2934203:0
@eitantonius A lot of new screens come with a replacement front camera already installed. They cost a bit more, but make the job easier. You can save a few bucks if you buy a stripped-down display, but you’ll need to go through some additional steps to transfer the original front camera (and a few other components) from your broken screen to the new one.
Jeff Suovanen -
I cracked the camera glass (housing) on the back of the phone. Is it possible to replace without replacing the entire back of the phone/case?
Chris - crwdns2934203:0crwdne2934203:0
yes, but it is almost impossible. it involves removing the actual glass from the back housing, and the entire backside has a strong adhesive. Its recommended not to do that as it can result in either cutting yourself, or damaging the wireless charging coil thats found behind the glass.
RaggedMyth Gaming -
Is there any update on the ambient light sensor yet? Is it working with the new beta version of IOS12? I would be delighted to hear about it.
valentijnawc - crwdns2934203:0crwdne2934203:0
Auto Brightness works on all versions of iOS 12 that we’ve tried. True Tone does not. However, if you have your original display, there’s a fairly inexpensive (~$75 USD) device that can clone the data from the original display to the new one and restore True Tone. They’ve been around for a while and most repair shops should have one by now.
Jeff Suovanen -
any idea when the guide for full replacement will be available?
Cody Robinson - crwdns2934203:0crwdne2934203:0
Replaced screen a success now it is stuck on a boot loop….. help please.
kevin s love - crwdns2934203:0crwdne2934203:0
Boot loop can be caused by bad proximity sensor, which is moved to the new screen from the old. Or if you got one that came with it, it may be defective.
Idaho iRepair -
So, the original screen has these three tabs that slide in the recesses in the top of the phone case, all your pictures show only the aftermarket screens with two aluminum rectangulars (at the top of the screen). Isn’t that going to possibly cause the screen to pop out eventually (if the adhesive fails for say) since there is nothing physically holding it in place?
andyradchishin - crwdns2934203:0crwdne2934203:0
There are no aftermarket parts shown in this guide—that’s an original Apple display on a brand-new iPhone. You might be thinking of a different model? But to answer your question, yes, if the clips aren’t secured correctly then there’s a chance of the screen coming loose at the top.
Jeff Suovanen -
Will Touch ID work after the repair? That is my only concern about the repair.
Pietro Romanato - crwdns2934203:0crwdne2934203:0
As stated at the top, it will work fine provided you are careful to transfer the original home button to your new screen, without damaging it.
Jeff Suovanen -
Used the iFixit screen replacement parts and this guide. Guide was spot on and replacement screen weeks perfectly! Thanks for the guide!
Uno de los conectores a presión al parecer se me ensucio o doblo, por no hacer presión a los lados como aconsejan. que debo hacer
yeico_king_22 - crwdns2934203:0crwdne2934203:0
One of the pressure connectors seems to get dirty or dommed, for not pressing the sides as advised. I have to do
There should be an advisory to be careful when unscrewing the very first screws—mine stripped very quickly and easily. One failed attempt and getting that screw out is nearly impossible.
Zachary Veitch - crwdns2934203:0crwdne2934203:0
Hello, is the replacement camera the same quality as the original? And if not, would it be difficult to get this kit and swap my original camera over? Thank you.
Jakub Wheeler - crwdns2934203:0crwdne2934203:0
I did change my display but did not disconnect the battery while doing it. Now the microphone does not work anymore. Did I connect something wrong or did I damage the mic with the connected battery? (A different “how to video” of youtube does not disconnect the battery :( )
Philipp Ahrens - crwdns2934203:0crwdne2934203:0
My screen is cracked and chipping away in places. It is leaking black ink over most of the top left corner of the screen. Would this repair be able to fix that?
Greyson Haynes - crwdns2934203:0crwdne2934203:0
Hi Greyson,
Yes, this repair will make the screen new again! If this damage is due to a serious drop, you may need to fix some other things—the frame may be slightly warped, or other components may be damaged.
Arthur Shi -
This is inconclusive.
When replacing the display, you purchase (or part of your purchase) a “iPhone 8/SE 2020 Display Assembly Adhesive “ kit, but there are no instructions (even in the kit) on how to apply it.
Why is that?
Anyname - crwdns2934203:0crwdne2934203:0
Hello! The link on how to reapply the adhesive is actually in the conclusion section of this guide. Here is a quick link!
Arthur Shi -
Great instructions! Worked well for both disassembly and assembly. Thanks!
Zachary Schmidt - crwdns2934203:0crwdne2934203:0
Hi!
I successfully replaced my broken display with the replacement display from ifixit and most of the time it works well.
But since the repair it happens very often that the screen does not react anymore after the phone wakes up. I can unlock it via finger print, but it does not react on any touch. After hard reset, it runs again well till it freezes next time. Currently, it happens ~5 times per day, which is especially annoying, when I got a call and can’t take it…
What could be the reason for that?
Thanks!
Niels
nklan - crwdns2934203:0crwdne2934203:0
Hi Niels, it sounds like it could be a loose digitizer connection. Try opening the phone back up, disconnect the display, blow any debris out of the connectors, and carefully reconnect them. If that doesn’t work it could be a faulty display. In that case contact our support team for some help.
Adam O'Camb -
Hello, meanwhile I found out, that the failure is directly linked to the NFC sensor.
When I use Apple Pay or another iPhone is very close to mine, the display freezes and only releases after a soft reset.
Seems like the NFC sensor doesn’t work properly after the display exchange. Any idea what I could do?
Thank you!
Niels
nklan -
I need a piece of the screen from the front and the back the glass to both is broken Is it available or only the front ?
Ali - crwdns2934203:0crwdne2934203:0
Worked absolutely fine. Found though that I stripped the head on the first pentalobe screw (schoolboy error) I had to find a 0.3mm drill to drill it out and everything went fine thereafter.
matt - crwdns2934203:0crwdne2934203:0
I have party successfully replaced the screen, but I have two serious issues.
1: The battery does not charge after the unit have powered up, so it charge up to 4% then it turn on and stop charging, what errors can I have done to cause this.
2: My cellnetwork does not find any services, I am able to connect to Wi-Fi, but no cellular service, what errors can I have done to cause this?
Thanks for a great guide.
/Anders
margurithe - crwdns2934203:0crwdne2934203:0
I need iPhone 8 digitiser where can i get it?
Habibur Rahman - crwdns2934203:0crwdne2934203:0
Can i connect screen to iphone 8 without home button,front camera and these thing to try if it works or i have to put everithing on its place before i start it ? Cant i just put the 2 screen cables to its place and start it ?
Hanus Rabel - crwdns2934203:0crwdne2934203:0
To remove camera: I heated up screen front with heart gun set at 300*F (20sec front and 10sec rear), I pried up with fingers and repeated heating procedure. I used a piece of tape (sticky side up) to remember the screw location as I removed them.
wish the guide had at least covered the water seal install, very tricky to get right. recommend ordering more than one if you have the option. used the ifixit kit, works great!
bmx6454 - crwdns2934203:0crwdne2934203:0
The instructions do not show any steps of reassembly. I understand you can follow the same steps in reverse order however how do I install the seal that is included with the repair kit.
chrish0001 - crwdns2934203:0crwdne2934203:0
This isntruction is incimplete, it does not describe the need of speaker and sensor switch to new screen.
jakeemsnakeem - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 99
crwdns2936753:07crwdne2936753:0 560
crwdns2936753:030crwdne2936753:0 2,362
crwdns2942667:0crwdne2942667:0 620,437
