iPhone 8 Plus Rear-Facing Cameras Replacement
  1. iPhone 8 Plus Rear-Facing Cameras Replacement, Pentalobe Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    what do I do about super stripped screws?
    Ean Palacios - crwdns2934203:0crwdne2934203:0
    I’m sorry, your comment slipped past my radar earlier. For future fixers that might see this and ask the same question, you can check out our stripped screw guide for some detailed advice.
    Adam O'Camb -
    Do you need a toolkit like the essential toolkit
    Adam Palmer - crwdns2934203:0crwdne2934203:0
    Hi Adam. Having a tool kit with all of the listed parts above is best. The screw heads are very small and each set of screws needs a very specific type of driver to remove them without stripping any of them.
    Kyle Luksa -
  2. iPhone 8 Plus Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
    Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
    Alasdair Cameron - crwdns2934203:0crwdne2934203:0
  3. iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Bien, y a-t-il des boutiques spécialisées elle-même se charger de l’opération de changement de l’écran de l’iPhone 8 plus je suis un littéraire. Je renonce à le faire moi-même mais j’assume les frais le prix de l’écran. Merci de répondre dans un commentaire suivant Cordialement
    Acquaviva - crwdns2934203:0crwdne2934203:0
  6. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
    6/14/23 I did this repair but used a heat gun on low for 60 seconds. This allowed me to open the case as the instructions say, but in the end the Home button failed. I probably over heated it. I used this "go around" for a virtual Home button. I don't care about touch ID:
    https://www.youtube.com/watch?v=LbTlUm4p...
    laryball - crwdns2934203:0crwdne2934203:0
  8. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Warning ! If you pull too hard (reheat the underside of the display again), you create an gap of air between the glass and the lcd display !
    When you replace the display assembly you end up with gray stains on the display.
    Result: you have to buy a new display (assembly).
    Arnoud - crwdns2934203:0crwdne2934203:0
    Using just the single suction cup that is included in the battery replacement kit probably wouldn’t open the device. An iOpener and an iSlack should be the recommended method. However, you can get it open with just the single suction cup and iOpener, but does take a lot of time.
    Get an iOpener and iSlack with the battery replacement kit.
    Chris - crwdns2934203:0crwdne2934203:0
    I used a flat x-acto (#18) blade knife tool to gently pry back the screen enough to allow me to insert the pick near the bottom corner. I then worked the pick under the screen as mentioned in steps 5 & 6 below then. This worked really well for me.
    Kyle Luksa - crwdns2934203:0crwdne2934203:0
    I used the suction cup without heating the phone - the adhesive came away quite easily without applying any heat. Maybe due to age of phone (nearly 4 years old). Worth trying.
    Ben Vinnerd - crwdns2934203:0crwdne2934203:0
    I can’t get the single suction cup to work. Hate being stuck on the simplest step!
    Donny - crwdns2934203:0crwdne2934203:0
    My screen was very shattered, and was quite hard to get suction, as my tape was very low quality. However, after pulling it up a little bit, I was able to insert a regular razor blade into the very small gap and used that as a lever.
    Michael Scroop - crwdns2934203:0crwdne2934203:0
    Oh my goodness! Don't do that again. You can definitely damage something in the phone if you use a sharp metal razor blade..
    cytur -
  9. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    After multiple tries and using a very hot iOpener, it will not open.
    Kenneth Ewald, Sr. - crwdns2934203:0crwdne2934203:0
    In sheer frustration, I pulled out my trusty pocket knife and managed to lift the bottom of the screen slightly, but in the process, cracked the glass from the bottom to the home button. The case is open now.
    this was by far the most difficult part. be diligent and follow the “firm and constant pressure” guide... the “gap” will be extremely “slight”. you will be able to slide a corner of the pry tool even if you cannot see the gap.
    Colleen V - crwdns2934203:0crwdne2934203:0
    This needs a TON of strength and most likely a partner. Your strong partner will pull up the screen with the suction cup and you will put the pick into the small gap that appears.
    cytur - crwdns2934203:0crwdne2934203:0
  10. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    Do not go over the top otherwise you can crack the screen. Sadly happened to me :(
    The instruction should be:
    “Stop near BUT BEFORE REACHING the top left corner of the display”
    Leonardo Piga - crwdns2934203:0crwdne2934203:0
  11. iPhone 8 Plus Rear-Facing Cameras Replacement, Screen information: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    I had really good luck using a hairdryer on some of the more stubborn portions of adhesive.
    Jessica Kirsh - crwdns2934203:0crwdne2934203:0
  13. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    Be very careful at this step. The glass at the top will break very easy when the display is lifted too much.
    Gerdschi D - crwdns2934203:0crwdne2934203:0
  16. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Das “links” ist auf dem Foto rechts.
    Matze Diamond - crwdns2934203:0crwdne2934203:0
    Das ist falsch. Wenn man auf das iPhone sieht, ist der Home Button unten. Auf dem Photo ist deutlich sichtbar, dass die linke Seite angehoben wird.
    Hans - crwdns2934203:0crwdne2934203:0
  18. iPhone 8 Plus Rear-Facing Cameras Replacement, Battery Disconnection: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Battery Disconnection: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    The Phillips screwdriver bit is the PH000. The measurement refers to the screw length.
    Jack Harry - crwdns2934203:0crwdne2934203:0
  19. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower display cable bracket.
  20. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    When I reassembled the iPhone 8 Plus, I had to plug it into a Lightning cable to wake it up (just pushing power button wasn’t sufficient).
    browniestarmite - crwdns2934203:0crwdne2934203:0
  21. iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I got hold of a iPhone 8 Plus with cracked screen that I am planning to fix.
    Here is my problem:
    When I tried to take out the screen from my phone, (step 15-18) I was curious about the new screen, so I tried to connect it. It was completely dead! Then I tried the old cracked one, and suddenly that was dead to! This is a phone that some fool has been inside earlier and changed battery, but I suspect he has done some more really stupid things. The Taptic Engine is living its own life and vibrating every time I slightly touch the home button. (I have a new Taptic Engine) The phone is also full of dust and small particles that does not belong there. One tri-point Y000 screw (step 18) is even missing! Now the biggest problem is that both screens are black! I know the phone is on, because I hear voice command speak when I turn on the power. The screen worked before I tried to change it? And one last thing: My new LCD screen came with new flex cables. Is it possible to switch over, so I can use the old ones?
    smikalsen - crwdns2934203:0crwdne2934203:0
    Hi,
    Is your problem solved?
    Daniel Leprince -
    Be careful of damaging MOSFETs by the LH side of the large lower display cable. After replacing the battery and turning the device on, the phone showed low charge and didn't have a charging symbol even after plugging into multiple cables and chargers. Turns out I had damaged the logic board attempting to disconnect the connector.
    Chris Cerrudo - crwdns2934203:0crwdne2934203:0
  22. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
    I used the other end of the spudger on this connector and it seemed to work a little better for me. I came in from underneath the top-right edge instead of the bottom right.
  23. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
    una vite da 1mm e due viti da 1.2 mm???
    Matteo Carachino - crwdns2934203:0crwdne2934203:0
    Ciao Matteo! Grazie per l’osservazione. Ho appena modificato il testo :) La traduzione è aperta a tutti. Hai quindi la possibilità di fare le tue suggestione direttamente nel testo e sei il benvenuto se vuoi usare di questa possibilità nel futuro. Grazie ancora per la vigilanza! Saluti, Claire
    Claire Miesch -
    The tool kit does include a 1.0 or1.2mm screwdriver! How am I supposed to remove those screws?
    peter frommer - crwdns2934203:0crwdne2934203:0
    Bought the screwdriver that supposedly fits these screws and it still doesn’t work.
    hypercarduser - crwdns2934203:0crwdne2934203:0
    My bracket looks different. Can’t get these screws out.
    Ray Rushing - crwdns2934203:0crwdne2934203:0
    kit came with wrong bit. i received 2x P02 (penta tips) and no tri point y000.
    Christopher Shane Gripp - crwdns2934203:0crwdne2934203:0
    There is no such thing as a trigger point y000 screwdriver. Why couldn't they use Philips like the rest of the screws.Nobody knows what these trips point y000 even look like. this is a scam to force you to buy a new phone.
    Al tb - crwdns2934203:0crwdne2934203:0
    y000 tri-point screw driver comes with the iFixit repair kit at minimal cost
    godo - crwdns2934203:0crwdne2934203:0
  24. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket covering the front panel sensor assembly connector.
  25. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
    What happens is this strip is torn and how does one fix it
    Mijinyawa Dauda - crwdns2934203:0crwdne2934203:0
  26. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Should there be a step somewhere in here to point out when to remove the blue plastic from the new iFixit screen?
    Paul Santora - crwdns2934203:0crwdne2934203:0
  27. iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Y000 screws securing the rear camera connector cover bracket:
    • One 1.4 mm screw
    • One 1.4 mm (nonferrous) screw
    • This screw tends to not be attracted to a magnetized screwdriver. Make sure to reinstall it in the correct place—a magnetized screw may interfere with the compass.
    the standoff screw underneath the left screw came loose together and was impossible to detach from the screw. In a later step (49) it was possible to remove it together with the antenna flex cable
    nilsplackle - crwdns2934203:0crwdne2934203:0
  28. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket.
  29. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the rear camera module cover plate:
    • One 1.8 mm Phillips screw
    • One 2.7 mm (nonferrous) standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
    Yeah, the flathead screw driver is not really a good option for the standoff screwdriver bit. I managed to remove the standoff screws easily enough, but replacing them with the flathead was laborious.
    andystills - crwdns2934203:0crwdne2934203:0
    Does the second screw (nonferrous standoff 2.7mm) actually exist? My phone has not had any repairs before but did not have this screw, and the previous step says there's a Y000 screw (for the bracket) in what appears to be exactly the same location as this step says the standoff screw is.
    bbaovanc - crwdns2934203:0crwdne2934203:0
  30. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover plate from the rear camera module.
  31. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  32. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up the rear-facing camera assembly from the top edge of the iPhone.
    • If you have trouble, switch to the point of your spudger and lever the camera out from its top right corner.
  33. iPhone 8 Plus Rear-Facing Cameras Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear-facing camera assembly.
    Using the small supplied none-conductive baggy you get in your parts repair kit, it is generally advised to put your camera sensor in said bag to protect it from dust or other debris as this will not come off the sensor and will mean another repair where one could have been avoided.
    Imname62 - crwdns2934203:0crwdne2934203:0
crwdns2935229:052crwdne2935229:0
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
443,273 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,981crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Worked Amazing! I feel so accomplished doing this myself! Thanks for the Step By Step guide! I can’t wait to fix something else now!
Ryan Carnahan - crwdns2934203:0crwdne2934203:0
I completed this repair on this iPhone 8 Plus after I damaged the cameras myself. I managed to succeed in chipping off all of the back glass panel of the phone successfully. Removing this shattered panel was the hardest iPhone repair job I have ever done. At the very end, I attempted to wiggle off the metal housing over the cameras that was originally part of the back glass. After removing this housing, I discovered that I had damaged both cameras. In retrospect I should have removed the cameras from the inside of the phone before prying off this housing.
The back glass removal is the most impossible task for this phone and should be attempted only by crazy people with an appetite for pain. I will document with a “repair story.” —CW
cpwittenberg - crwdns2934203:0crwdne2934203:0
Any idea on what the cable running beside the camera to the right is for? Mine is broken and can’t seem to figure out what it is for.
Heather Clinton - crwdns2934203:0crwdne2934203:0
I'm also wondering what that cable running beside the camera to the casing is used for. I can't find the correct screw to fix the cable to the casing as I have purchased a replacement cable and want to install it correctly. What screw dimensions and type of screw fits that cable to the casing?
ahjohl -
Does anyone know if you can 'extend' the camera connector cables? I'm trying to make a bespoke CCTV system from old iPhone I have lying around using manythings...
Adam Sheldrake - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 209
crwdns2942667:0crwdne2942667:0 47,122
