iPhone 7 Wi-Fi Diversity Antenna Replacement
  1. iPhone 7 Wi-Fi Diversity Antenna Replacement, Pentalobe Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
    Cooper Chase - crwdns2934203:0crwdne2934203:0
    Confirmed, the screws have a black ring seal around the head.
    rcheing - crwdns2934203:0crwdne2934203:0
    From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
    ballina5ny - crwdns2934203:0crwdne2934203:0
    I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
    Mark Lieberman - crwdns2934203:0crwdne2934203:0
    in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
    Jan-Tijn Oppermann -
    3.4 mm is the height of the screw and is not related to the screw driver code.
    Ahmad Vaziri -
    the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
    Martin Frutos, Nuñez - crwdns2934203:0crwdne2934203:0
    The bottom screws are Pentalobe, not Phillips.
    Bram Driesen -
    Before starting, I would recommend backing up your Iphone’s data just in case.
    Jon Moylan - crwdns2934203:0crwdne2934203:0
    If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
    Ryan Huebert - crwdns2934203:0crwdne2934203:0
    Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
    Cynthia Lamb - crwdns2934203:0crwdne2934203:0
    I’m technically challenged. Is there a premier national service who can professionally install a replacement battery got my 7 +?
    Richard - crwdns2934203:0crwdne2934203:0
    Do the screws come out in total?
    YVES THEUGELS - crwdns2934203:0crwdne2934203:0
    They may come out or may not. If you loosen as much as you can and they don't come out you should still be able to pry open the bottom. Once you get the screen off you can then push the screws out from the inside.
    Anthony Falabella -
    Is it the P2 you should use for the bottom??
    I heated the bottom of the phone with a hairdryer and then used a syringe to put a couple of drops of acetone directly into the bottom two screw holes. I GENTLY pulled on the screen with the suction cup and used the pry tool to GENTLY separate the screen. The sealant is applied around the entire display so be very careful pulling it off so you don’t break the fragile display cables.
    Anthony Scaminaci - crwdns2934203:0crwdne2934203:0
    At first it was very difficult to open, per instructions. I used a heat/ice pack and nuked it for 1 minute. The pry tool wasn’t working so I carefully used my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, place the taptic engine before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit. Good job on hosting the video, Gwendyl.
    Klaus Preiss - crwdns2934203:0crwdne2934203:0
    I love the fact that the screw bit and shaft are magnetic! I almost lost a screw and found it attached to the magnet.
    I used a heat/ice pack and nuked it for 1 minute. At first the display cover was very difficult to open with the pry tool, per instructions. The pry tool wasn’t working so I carefully used the blade of my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, see the taptic engine in place before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit because I placed it almost too low.
    I replaced the lightning connector assembly and reassembled. The old one did not 'click' into the cable and had corrosion inside, it needed the cable to be placed in a specific way to charge. The new part - does not recognize that a charger is plugged in at all.
    I backtracked the assembly - took it apart, put it back again - and find that every thing on the part works - the mic, speakers, taptic engine.
    The original problem with the cable still persists. Any ideas?
    H K - crwdns2934203:0crwdne2934203:0
    get a new batt to replace whilst you 're at it
    Graham Sargerson - crwdns2934203:0crwdne2934203:0
  2. iPhone 7 Wi-Fi Diversity Antenna Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone 7 Wi-Fi Diversity Antenna Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Wi-Fi Diversity Antenna Replacement, Heat the display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    No hair dryer so GENTLY heated over stove burner
    John Toth - crwdns2934203:0crwdne2934203:0
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - crwdns2934203:0crwdne2934203:0
    I was about to ask the same Question...
    Enno Winch -
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - crwdns2934203:0crwdne2934203:0
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - crwdns2934203:0crwdne2934203:0
    Hey, that's smart !
    Gabriel-Science -
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - crwdns2934203:0crwdne2934203:0
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - crwdns2934203:0crwdne2934203:0
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - crwdns2934203:0crwdne2934203:0
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - crwdns2934203:0crwdne2934203:0
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - crwdns2934203:0crwdne2934203:0
    It won't work if you don't throw it in the lava.
    Gabriel-Science -
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - crwdns2934203:0crwdne2934203:0
    Hairdryer works fine for this step. No issues.
    tripmusic - crwdns2934203:0crwdne2934203:0
    Agree! Just did it for 2 times to make sure I didn't overheat the phone.
    André Lopes -
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - crwdns2934203:0crwdne2934203:0
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - crwdns2934203:0crwdne2934203:0
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - crwdns2934203:0crwdne2934203:0
    This part was actually much easier than I thought. I used a hair dryer on max for 2 minutes on each side of the phone, less than half an inch away from the phone, just on the bottom half. It was hot! Screen came right out!
    Nuno Lopes - crwdns2934203:0crwdne2934203:0
    I used a tube sock full of about 1 cup of white rice. Tied a knot in the top of the sock. Put the sock of rice in the microwave on 60% power for 1 minute. Kept doing this until the temp felt right. Put the sock of rice down, put bottom edge on sock, then covered w/ other half of the sock/rice. Put a piece of paper towel between phone and sock/rice to absorb any moisture. When lifting up on front panel, I rested the phone on the sock/rice. Worked nicely once I got the temp of the rice high enough.
    (threw the rice away later :-) )
    Burning Sensation - crwdns2934203:0crwdne2934203:0
    “Threw the rice away later” has to be the best advice here. I wrapped my phone in a small heating pad and turned it up to 6 of 8. Worked great in 5 min or less! No need for water bottles, microwaves, heat guns, volcanoes, …. I kept the heating pad later ; )
    dantegd - crwdns2934203:0crwdne2934203:0
    I popped my iPhone under a desk lamp with a 60w filament light bulb in it, switched it on, (See this photo) then read the iFixIt instructions and comments. By the time I’d done that, the glue had softened enough to start work. I managed to do the whole process, slowly and methodically, without incident. The iPhone even worked after I’d put it all back together. So we’ll done iFixIt. Another satisfied customer!
  7. iPhone 7 Wi-Fi Diversity Antenna Replacement, Separate the display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Separate the display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - crwdns2934203:0crwdne2934203:0
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - crwdns2934203:0crwdne2934203:0
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - crwdns2934203:0crwdne2934203:0
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - crwdns2934203:0crwdne2934203:0
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - crwdns2934203:0crwdne2934203:0
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - crwdns2934203:0crwdne2934203:0
    This was the time consuming part. I’d recommend having a thin bladed knife or similar to get things going. I used the small blade on my Swiss Army knife, but be careful. When it goes, it can be unexpectedly sudden. I also used a strong rubber band to stop any excessive opening of the screen.
  8. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - crwdns2934203:0crwdne2934203:0
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - crwdns2934203:0crwdne2934203:0
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - crwdns2934203:0crwdne2934203:0
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - crwdns2934203:0crwdne2934203:0
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - crwdns2934203:0crwdne2934203:0
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - crwdns2934203:0crwdne2934203:0
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - crwdns2934203:0crwdne2934203:0
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - crwdns2934203:0crwdne2934203:0
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - crwdns2934203:0crwdne2934203:0
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - crwdns2934203:0crwdne2934203:0
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - crwdns2934203:0crwdne2934203:0
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - crwdns2934203:0crwdne2934203:0
  9. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - crwdns2934203:0crwdne2934203:0
  10. iPhone 7 Wi-Fi Diversity Antenna Replacement, Screen information: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - crwdns2934203:0crwdne2934203:0
  11. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    No pick in the kit you sent me.
    Ted Cooper - crwdns2934203:0crwdne2934203:0
  12. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - crwdns2934203:0crwdne2934203:0
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - crwdns2934203:0crwdne2934203:0
  14. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    I had trouble sliding down the display and found I hadn't separated the stop enough.
    Jeffrey Anderson - crwdns2934203:0crwdne2934203:0
    When you are pulling the display downward, be very careful! I pulled a little too hard and the display cables tore from the downward (toward home button) motion. Now I have to replace the display! 😭
    So Munch Love - crwdns2934203:0crwdne2934203:0
  15. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - crwdns2934203:0crwdne2934203:0
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - crwdns2934203:0crwdne2934203:0
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - crwdns2934203:0crwdne2934203:0
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - crwdns2934203:0crwdne2934203:0
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  16. iPhone 7 Wi-Fi Diversity Antenna Replacement, Battery Disconnection: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Tri-point Y000 Screwdriver
    $5.99
    Ahhh shoot! accidentally ordered tri-wing vs tri-point (must have just looked for y000).. It seems they only did this to annoy repair folks because not everything is tri-point on the phone...
    Steve - crwdns2934203:0crwdne2934203:0
    These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
    Jeff Hurst - crwdns2934203:0crwdne2934203:0
    The Y000 took out one of the screws but not the other 3. I even tried the PH000 as suggested but nothing.
    dbright - crwdns2934203:0crwdne2934203:0
    What driver do I need to remove these screws i’m stuck
    Nasser Nader - crwdns2934203:0crwdne2934203:0
    i cant use, the Y000 it isnt working.
    joscarlos91 - crwdns2934203:0crwdne2934203:0
    What if I stripped a screw what do I do??
    Jacob Ramos - crwdns2934203:0crwdne2934203:0
    Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
    Stephen Babbage - crwdns2934203:0crwdne2934203:0
    It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
    Jim Staples - crwdns2934203:0crwdne2934203:0
    Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
    Magne Eivindson - crwdns2934203:0crwdne2934203:0
    For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
    Erik Fredriksen - crwdns2934203:0crwdne2934203:0
    What do I do if I Stripped one of them?
    Adam Corral - crwdns2934203:0crwdne2934203:0
    Can’t get them removed what to do ?
    cowling_luke - crwdns2934203:0crwdne2934203:0
    Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
    jimpoolio - crwdns2934203:0crwdne2934203:0
    You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
    Kyle Webb -
    The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
    Harmony - crwdns2934203:0crwdne2934203:0
    Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
    Chris Bennett - crwdns2934203:0crwdne2934203:0
    If you can’t get the bit to grip the screw properly, you can use a little bit of the water-proof sealing between the bit and the screw. That worked for me. Hope this helps anyone.
    jvalaamo - crwdns2934203:0crwdne2934203:0
    Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
    Gina Torres - crwdns2934203:0crwdne2934203:0
    I used a bunch of medicine cups to track my screws. You need like 12 if you want them all in cups. I ran out. There are so many different sizes that literally vary by 1mm. The tolerances on these things are tight.
    Ray Bieze - crwdns2934203:0crwdne2934203:0
    I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small.  use a magnetised screwdriver,  or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
    scallyteacher - crwdns2934203:0crwdne2934203:0
    Absolutely ridiculous had to go get a different one just stupid
    mark golling - crwdns2934203:0crwdne2934203:0
    I couldn’t get the lowest one out and just turned the metal bracket out of the way and replaced battery.
    qwerty77x - crwdns2934203:0crwdne2934203:0
    Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
    Galen Wollenberg - crwdns2934203:0crwdne2934203:0
    The top screw in the step was much longer than 1.2mm. It has the same head as the 1.2mm, but different than the 2.4mm. It’s good to keep track of where they came from.
    All are so small that I thought I’d lost one, when it was still sitting in the phone.
    Mark - crwdns2934203:0crwdne2934203:0
    To help tell if the screw is turning, put a small dot from a marker on the head of the screws.  This helped me to know I wasn't just stripping the head.
    Darren Thibodaux - crwdns2934203:0crwdne2934203:0
    try heating the iPhone with a hairdryer or a bag of rice or about 60 degrees in an oven for 3 minutes . It has worked for me. If the screws don’t come out while hot the will come out as the iPhone cools.
    David Howard - crwdns2934203:0crwdne2934203:0
    A small tapered triangle file using moderate pressure did the trick for me.
    Jack - crwdns2934203:0crwdne2934203:0
  17. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower connector bracket.
    my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
    Josh Martin - crwdns2934203:0crwdne2934203:0
    This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
    Oscar Moreno - crwdns2934203:0crwdne2934203:0
    So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
    Am I going to run into trouble with this bracket missing?
    Ian Fritz - crwdns2934203:0crwdne2934203:0
    Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
    Ian Fritz -
    I also forgot to put the battery shield in, and adhered the display. I’m tempted to leave it like that. However, your negative experience is a good data point telling me to not be cheap.
    Ordered a new adhesive , under $2 shipped from eBay.
    Yishai Sered -
    Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
  18. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
    Julian Eltrich - crwdns2934203:0crwdne2934203:0
    Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
    I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
    The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
    It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
    jason - crwdns2934203:0crwdne2934203:0
    In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
    Dave Miller - crwdns2934203:0crwdne2934203:0
    Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
    Tomoharu Eguchi - crwdns2934203:0crwdne2934203:0
    VERY IMPORTANT NOTE: Please READ the reply here by jason.
    It is very easy to knock off or nudge the little pins near the battery socket, see https://guide-images.cdn.ifixit.com/igi/... and https://guide-images.cdn.ifixit.com/igi/....
    Those pins are the data lines to extract battery info: temperature, charge, etc. If you accidentally nudge/knock off them the phone could appear to work normally, even for a few days. But then you will start getting wrong battery reads and then after that it may suffer a reboot loop. If you enter settings > privacy > analytics & improvements and you scroll down you will find panic errors from thermalmonitord that there are missing sensors (TG0B or TGXXX) and you will have to micro solder them. DO NOT NUDGE THEM and double check the socket connector when reconnecting the battery.
    PJM - crwdns2934203:0crwdne2934203:0
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all! Careful removing the lower bracket - mine was stuck to this battery connector, which came up with the bracket. Luckily no cable or connector damage. Be careful. Thank you all!
    after installing new ifixit battery kit, note the foam on the new battery is thicker than old apple one, managed to remove the old foam and swap to new battery connector, sheild plate now level
    Neil Mills - crwdns2934203:0crwdne2934203:0
  19. iPhone 7 Wi-Fi Diversity Antenna Replacement, Display Assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Display Assembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Display Assembly: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
    iPhone Display Adhesive Replacement
    minimalist - crwdns2934203:0crwdne2934203:0
    MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
    Arjun Nagarajan - crwdns2934203:0crwdne2934203:0
    Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
    garrett peek - crwdns2934203:0crwdne2934203:0
    An earlier comment said to re-apply the suction cup to the right side of the display so that it acts as a stand when the phone is partially opened. That’s a great idea, and helps a lot for this step and the next.
    Hey – I broke one of these flex cables and I cant find them to purchase anywhere. Can somebody help me? It’s the LCD connector first and what is the second flex cable for? Thanks!
    Chan Ty - crwdns2934203:0crwdne2934203:0
    I broke the second (smaller) display connector flex cable.
    1) Is it replaceable or repairable?
    2) Where can I get the replacement?
    Ben Blom - crwdns2934203:0crwdne2934203:0
    Same happened to me. What solution did you find? Could you replace a part to make it work? Thank you!
    Viktoria -
    I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
    Thanks for advice!
    Bjorn - crwdns2934203:0crwdne2934203:0
    this point is the most important in the whole manual.
    Please pay attention not to strain the flex cables or they will end up breaking
    Jose Joaquín Sanz Iniesta - crwdns2934203:0crwdne2934203:0
    I should have been more careful - the second cable tore off.
    My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
    Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
    I’ve now had to order a replacement screen.
    Stuart - crwdns2934203:0crwdne2934203:0
    Echo minimalist’s comment here. Prop the display up and skip to step 19 to save time and remove risk.
    .A. - crwdns2934203:0crwdne2934203:0
    If you replace the screen and there is no display apply io propyl alcohol 99.9 & purse to both connectors on the screen and on the iPhone with a clean toothbrush and let them dry for 45 minutes and then fit the screen and reassemble the iPhone..
    It works for me . when I get a new screen I do t5his before fitting it.
    I tried to save time by not removing the screen during battery replacement as some comment here, HOWEVER, I ended up having to use a little force to remove the battery and in the process broke the second, lower smaller cable, resulting in loss of home button function and needing to get a new screen. Next time I will follow these steps and completely remove the screen during a battery replacement
    chrislacey - crwdns2934203:0crwdne2934203:0
    I removed the screen and cable still got ripped during reassembling :(
    Viktoria -
    There is a critical fact missing from the steps here, for reassembly: That bottom (underlying) cable is longer than it should be. Loads of people are reporting that the Home button is dead after this repair, but the cables aren't torn. I'm pretty sure this is why. Here is a picture of the problem.
    When reassembling the phone, you must poke this cable back into the body of the phone while you bring the halves together, or you will crush, crimp, and destroy the cable.
    Gavin Stokes - crwdns2934203:0crwdne2934203:0
    I’m only reading your very useful comment now, after the exact thing happened to me and my cable got ripped during reassembling phone. Would you be able helping me naming this part, so I can look for a new one? Thank you very much!
    Viktoria -
    thanks gavin. ifixit should have included this piece of info.
    soupamanx -
    Can somebody help me with the name of the part that these cables belong to? The bottom one got ripped during my battery replacement, I need a new one but unsure what to look for.
    Viktoria - crwdns2934203:0crwdne2934203:0
  20. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
    It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
    Makana Sylva - crwdns2934203:0crwdne2934203:0
    If you’re having trouble removing these screws;
    the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
    If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
    If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
    If you already stripped the screw head take the phone to a shop before you break it.
    there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
    Vegeta Barrett -
    The right screw kept spinning, tried different levels of force but didn’t work. I left the screw on and bent the shield to get to the cable.
    s h - crwdns2934203:0crwdne2934203:0
    I used a #1 flat head tip to loosen.
    Peter Pearson - crwdns2934203:0crwdne2934203:0
    I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
    Therese Peffer - crwdns2934203:0crwdne2934203:0
    Use the PH000 and apply a little more force before spinning, should come right out!
    Sierra Scolaro - crwdns2934203:0crwdne2934203:0
    ^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
    Jeff Suovanen -
    the two screw i have are stripped and i have n way of getting either screws off whats my next bet
    Alexis Marie Colon - crwdns2934203:0crwdne2934203:0
    The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
    Ryan Welborn - crwdns2934203:0crwdne2934203:0
    Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
    Jeff Suovanen -
    I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
    rcarswell - crwdns2934203:0crwdne2934203:0
    Use the J00 bit. Worked perfectly
    efazio588 - crwdns2934203:0crwdne2934203:0
    PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
    I’d do this step before removing the ribbon cables by the battery connector. That way you can disconnect all of them at the same time.
    i used the little +-shape 30 mm screwdriver (not the Y…but the + shape).
    mason - crwdns2934203:0crwdne2934203:0
    the cable tore. is that it i need a new phone?
    patricia loving - crwdns2934203:0crwdne2934203:0
    You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
    jack jones - crwdns2934203:0crwdne2934203:0
    Reconnecting this cable and coverplate took a good 20 minutes. O_O
    Nicole Crome - crwdns2934203:0crwdne2934203:0
    What can I do to remove the screw (I stripped it)
    Alex Vu - crwdns2934203:0crwdne2934203:0
    I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
    I skipped this step. Just be really careful not to pull on the screen.
    Takumi Arai - crwdns2934203:0crwdne2934203:0
    The guide says they changed these to the Y000 “at some point in the t middle of the product’s lifecycle”…
    That can’t be true, I have a *day one*, preordered iPhone 7, and mine had, unmistakably, Y000 screws!
    and also, I’m just faithfully following the guide here, but can anyone clarify *why* is is necessary to entirely remove the display AND the Taptic Engine at all? The battery seems accessible just fine… oh well
    PS- I’m doing this on an older backup iPhone 7. My iPhone 12 Pro just went berserk and stopped working completely a little over a year after I got it day one of its release… since the iPhone X I’ve only had easily breakable, overly sensitive phones. I’ve had every numbered iPhone except for the 8 (I got the X released at the same date) and the 11, and man, are these newer iPhones post X fragile!
    Cam F - crwdns2934203:0crwdne2934203:0
    This worked for me! As mentioned use PH000 and apply pressure and then unscrew the screws. They are tiny, adhere to a piece of tape so you don't lose them.
    Rosie J - crwdns2934203:0crwdne2934203:0
    Indeed - I also had some problems with the righ screw: ...a standoff screw that is screwed into the frame - like above explained...! Suddenly I had three screws in front of me and was a little surprised... Ok You have to mount first this screw again - with a small flat srewdriver - otherwise You could not fix the Metalstripe on both sides, because the second small screw has no grip!
    Fridtjof Schüssler - crwdns2934203:0crwdne2934203:0
    Not screw related: Mark the top of the cover with a felt pen or sharpie before removal. I didn’t and on reassembly, spent a few minutes trying to work out which way it went back on - Doh!
  21. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Das ist sehr mutig, das Kabel dort so zu strapazieren.
    Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
    Detlef Menninger - crwdns2934203:0crwdne2934203:0
    Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
    Victor Bui - crwdns2934203:0crwdne2934203:0
    @victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
    Jeff Suovanen -
    This is the only connector that is quite easily possible to put back in the wrong way. If you do so, the phone will just get into a continuous loop where it shows the boot screen, goes blank and then shows the boot screen again and again. If this happens, do not despair-just put it back in the right way.
    Roy Mathew - crwdns2934203:0crwdne2934203:0
    After putting together, I had a continuous loop boot up (as noted above). I saw articles where this (front panel sensor connection) was the reason. I disconnected this connection and the boot up loop stopped. I tried reconnecting several times but had the same problem (boot up loop). However, it turns out that I needed to apply extra pressure when installing until a heard a (faint) second click when pressing down. Note - before I was using the spudger to press the connection together, which didn’t do the job. I ended up using my finger to press harder to get it to click in. Solved that issue.
    Ed Scannell - crwdns2934203:0crwdne2934203:0
    The ribbon cable on this step is torn. Is this something that can be replaced? Is this only to the earpiece?
    John Daily - crwdns2934203:0crwdne2934203:0
    Sarah Valencia - crwdns2934203:0crwdne2934203:0
  22. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
    Guy Cooley - crwdns2934203:0crwdne2934203:0
    Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
    @victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
    Jeff Suovanen -
    This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
    trent bost - crwdns2934203:0crwdne2934203:0
    @trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
    Jeff Suovanen -
    If the instructions are followed step by step, then adding the adhesive comes before changing the battery.
    If I had to do it all over again, I'd skip adding the adhesive, because you have to disconnect the battery, plus the two lower display connecters and the front panel sensor assembly connector. It was a nightmare trying to marry the components back together without disturbing the wire prongs, and I don't even want to talk about reinserting the tiny screws that kept twirling around on the tip of the screwdriver as well. It wasn't worth the time or aggravation!!
    If you decide to skip this step, just avoid using your iPhone near water.
    Ich habe das Display nicht abgenommen, sondern mit Hilfe von Tesafilm und Styroporstücken in einem Winkel von ca. 80° Winkel fixiert und nicht demontiert! Das ging auch sehr gut und ich musste nicht noch mehr von den empfindlichen Steckern zum Touch und Display trennen!
  23. iPhone 7 Wi-Fi Diversity Antenna Replacement, Barometric Vent: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    The barometric vent seems to have some foam cushioning towards the bottom of the case? does this get damaged via removal I wonder?
    Phil - crwdns2934203:0crwdne2934203:0
    I’m stucked with the right screw, can't get it out. Any ideas?
    Racecar - crwdns2934203:0crwdne2934203:0
    Edit: I’ve lifted the taptic engine without unplugging it. Removing the battery stripes didn't cause any issues.
    Racecar -
    I didn't see the necessity, so I didn't remove the Barometric Vent since I decided I wasn't going to uplug the Taptic Engine, although I did remove screws for the Taptic Engine, but I didn't unplug it. I believe the point of removing the Taptic Engine is to gain access and space to pull the adhesive strips off the battery. If you attempt and are able to remove the adhesive off the battery, then I believe it's NOT necessary to remove the Barometric Vent nor the Taptic Engine.
  24. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the vent.
  25. iPhone 7 Wi-Fi Diversity Antenna Replacement, Taptic Engine: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Taptic Engine: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  26. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    My screws are stripped here. Please help, I don’t know what to do!
    Salva Alcón - crwdns2934203:0crwdne2934203:0
    My screws are also stripped here, but the phone has never been opened before!
    Kyle Webb - crwdns2934203:0crwdne2934203:0
    Hey Salva and Kyle, sorry to hear about all these stripped screws! For help with removing them, check out our guide.
    Adam O'Camb - crwdns2934203:0crwdne2934203:0
    I had a new phone. These screws were missing when I disassembled it. Not sure what QC Apple has, but it ain’t great. If they’re missing it’s not the end of the world. You can just disable taptic touch.
    I had my 7 battery replaced by an Apple Authorized dealer. Around 2 weeks after the taptic engine started to make a !&&* of a noise when it was activated (sounded as if it was loose)… then 1 month after that… it stopped working completely. fast forward 8-9 months later, the battery they had replaced just wasn’t holding its charge anymore (phone was spending more time plugged in charging and depleting very quickly = full charge lasted about 1-2 hours). Having bought the ifixit battery and have gotten as far as this step, I could see that all three of the 1.6mm screws were just floating around in the compartment and the taptic engine was just being held on via it’s ribbon lead. WTF?! Screws aren’t stripped and I managed to fix it in again. Why would these screws be floating around like this??
    another person checking in here to assure you that, if you find a stripped screw (or more) at this step, you’re not crazy. I have one as well! I’m in dis-effing-belief. This phone has NEVER been serviced by anyone, and was allegedly brand new when purchased.
    To the person suggesting a dremel tool to remedy this…. *blink**Blink*. Are you kidding me right now? *slap*. Vibrating the !&&* out of all those sensitive parts - not to mention what one slip could end in your phone being effectively sawed in half.
    Cunning Stunt - crwdns2934203:0crwdne2934203:0
  27. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Taptic Engine.
  28. iPhone 7 Wi-Fi Diversity Antenna Replacement, Speaker Assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  29. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  30. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Hey may i ask…what is the use of both of the antenna cables?i just opened my iphone 7 plus and i found both of the cables are broken.if both of the cables are broken,what does it effect on my iphone?
    Mohd Wazirul - crwdns2934203:0crwdne2934203:0
    I'm missing the black thing from my antenna and I have no signal, could this be the reason why? Is the black thing insulation?
    Keah Smith - crwdns2934203:0crwdne2934203:0
    These doodads are a pain to route and reconnect. I probably spent 15 minutes just on this part of reassembly. One of them is connected to the new part. It won’t have the soft grommet on top.
    One of these came away from its base. The one nearest the battery.
    When I reassemble it I’m thinking just a bit of glue at the side once re attached to base, so lomg as it touches the base contacts?
    Any comments?
    ANDREW - crwdns2934203:0crwdne2934203:0
    I am having the worst time imaginable trying to reconnect the antenna cable coming from the lightening connector assembly to the logic board. It’s barely long enough and will not snap into place. There’s a minature gold pin sticking up from a circular gold ring on the logic board and I must have spent an hour on this one step. The antenna end has the female end. Everything else went well. The antenna connector from the old lightening assembly will connect relatively quickly. I’m beginning to think the new antenna connector female end might be defective. I’m ready to cut the black antenna wire and try to solder in a longer piece using the old connector assembly. Any ideas? HELP !!!
    David Sandrof - crwdns2934203:0crwdne2934203:0
    These can be tricky to reconnect. I found the best way is to hold the connector with tweezers and use the point of a spudger on top of the connector in the other hand. Slowly moving the connector with the tweezers while applying gentle pressure with the spudger, you will eventually feel the connector and its seat line up and you can snap into place. Don’t force it, when it is lined up it is easy so you have to patiently work on aligning it.
    David Ege - crwdns2934203:0crwdne2934203:0
    please say which antenna is which, impossible to know now
    Mitchell Thompson - crwdns2934203:0crwdne2934203:0
    Tip that helped me: remove the standoff screw next to the clip before derouting (or, upon reassembly, rerouting) the cables. This gives you a lot more space to work with! (Note: I only did this on reassembly, so I don’t know if there are any gotchas on disassembly.)
    T Murrills - crwdns2934203:0crwdne2934203:0
    Please pay close attention to witch one goes where or take a picture bad mistake made.
    michael - crwdns2934203:0crwdne2934203:0
  31. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  32. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
    They pull off to the side.
    Ark - crwdns2934203:0crwdne2934203:0
    This was an oddly challenging step, lifting the speaker slightly from the top end allowed me to slide the tips of one side of the tweezers in between the cable and the speaker, prying it out rather than grabbing and pulling which feels dangerous.
    Jesse de Vries -
    difficile a retirer. Les 2 tables sont clipsés sur le haut parleur. Il m’a bien fallu 10 - 15 minutes pour arriver a les retirer. Aucune astuce a vous donner, a part de la persévérance.
    Guigui - crwdns2934203:0crwdne2934203:0
    One cable seems to stay attached to the speaker. Don’t try to pry it off the speaker! This is shown in the video but not in these photos.
    Cynthia Lamb - crwdns2934203:0crwdne2934203:0
  33. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  34. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker.
    Reassembly tip: after aligning the speaker with the bottom edge, instead of lowering the speaker into place, keep the speaker raised slightly and push the cables back into the clip (which were removed in step 28) with the flat end of a spudger. In doing so, though, make sure that the cable from the lightning connector piece remains above the flat metal piece protruding out the left side of the speaker.
  35. iPhone 7 Wi-Fi Diversity Antenna Replacement, Wi-Fi Diversity Antenna: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement, Wi-Fi Diversity Antenna: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the antenna from the clip on the speaker.
  36. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the tab by lifting up with tweezers and separate the tab from the speaker.
  37. iPhone 7 Wi-Fi Diversity Antenna Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Wi-Fi diversity antenna.
    When installing the new antenna, it seemed at first that the grommet hole for the screw on the left side did. It line up with the holes on the speaker and case. The key is to gently use the flat end of the spudger to nudge the ribbon up against the speaker and down. Then it lines up well and the antenna cable routes easily through the clip channel.
crwdns2935229:035crwdne2935229:0
Scott Havard
crwdns2935283:006/27/16crwdne2935283:0
50.572 crwdns2915208:0crwdne2915208:0
crwdns2935297:031crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Qual’è e dove si trova l’antenna dei dati cellulare? Non quello del Wi-Fi
Nicola Canato - crwdns2934203:0crwdne2934203:0
questa guida risolve il problema del wifi grigio?
Nino Galletta - crwdns2934203:0crwdne2934203:0
vyřešili jste problém?
Lukáš Netečný -
Is this a potential fix for an iPhone that won’t allow the wi-fi to be turned on? The phone has been fully restored to factory but still won’t allow the wi-fi to be turned on. It is crossed out in the Control Center, and won’t allow it to be toggled on in the Settings.
bluebee_technology - crwdns2934203:0crwdne2934203:0
Hey i have same issue with wifi did you get any solutions?
Yash fixs -
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 139
crwdns2942667:0crwdne2942667:0 75,991
