Use this guide to remove your power button for cleaning, or to replace a scuffed button cover. This guide is for the aluminum button cover, not the mechanical button itself. Use the power button cable guide to replace the mechanical switch.
You can also use this guide to replace the upper cable bracket.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly cable bracket from the logic board.
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
Use a spudger or a fingernail to disconnect the home button cable connector.
Use a spudger or a fingernail to disconnect the display data cable connector.
Use the flat end of a spudger to disconnect the digitizer cable connector.
Remove the front panel assembly from the rear case.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the iPhone.
Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
Remove the following Phillips screws from the upper cable bracket:
One 2.9 mm screw
One 2.2 mm screw
Remove the upper cable bracket from the iPhone.
Use the flat end of a spudger to lift the power button and flash assembly cable connector up off of its socket.
Lift the volume control cable connector up out of its socket on the logic board.
Remove the following four Phillips screws from the Wi-Fi antenna:
One 1.5 mm screw
One 1.4 mm screw
Two 2.1 mm screws
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the Wi-Fi antenna from the iPhone.
Remove the two 1.6 mm Phillips screws from the grounding bracket.
Remove the grounding bracket from the iPhone.
Remove the following Phillips screws securing the angled logic board bracket.
One 2.6 mm screw
One 1.3 mm screw, located horizontally in the upper sidewall of the iPhone.
Remove the angled logic board bracket.
Remove the single 1.2 mm Phillips screw securing the antenna interconnect cable to the logic board.
Use the point of a spudger to fold the antenna interconnect cable up out of the way of the logic board.
Use the flat end of a spudger to lift the camera cable connector straight up out of its socket on the logic board.
Fold the camera cable up out of the way of the logic board.
crwdns2935267:0crwdne2935267:0Standoff Screwdriver for iPhones$5.49
Remove the following screws securing the logic board to the rear case:
Two 1.9 mm Phillips screws
One 2.3 mm standoff screw
Use the flat end of a spudger to lift the battery connector end of the logic board up slightly, just enough to grab with your fingers.
Lift the battery connector end of the logic board and pull it up and out of the rear case.
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Gently pull the battery adhesive tab away from the battery, toward the bottom of the iPhone.
Try not to pull against the battery or the lower components, or you may rip the adhesive strip.
Continue pulling, allowing the strip to slowly slip out from between the battery and the rear case. When you feel increased resistance from the strip, stop pulling and continue with the next step.
When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery.
Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
Peel back the second battery adhesive tab from the bottom left edge of the battery.
Again, gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
Continue pulling the adhesive tab until you feel increased resistance, and then stop.
When you feel increased resistance from the adhesive strip, pull it gently around the lower left corner of the battery.
Continue pulling the adhesive tab upward and away from the left edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
If you removed both adhesive strips successfully, skip the next two steps and continue on Step 46.
If either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card under the logic board edge of the battery.
Press the card in at several points if necessary to break up the adhesive behind the battery.
After peeling or prying out all adhesive, remove the battery from the iPhone.
Remove any tape covering the upper left rear-facing camera screw.
Remove the following Phillips #00 screws from the rear-facing camera bracket:
One 1.5 mm screw
One 2.1 mm screw
Remove the rear-facing camera bracket.
Carefully remove the antenna interconnect cable from the rear case.
Remove the rear-facing camera from the iPhone.
Remove the single 1.2 mm Phillips #00 screw securing the flash bracket.
Remove the flash bracket from the rear case.
Remove the two 2.2 mm Phillips #00 screws from the power button bracket.
Use the point of a spudger to gently push the flash and microphone modules up out of their respective holes in the rear case.
Begin to peel the flash/microphone/power button assembly cable up from the rear case starting from the connector end.
Continue to peel the cable up, being particularly careful of the narrow component ends of the cable.
Remove the flash/microphone/power button assembly cable from the phone.
Grip the power button by the metal bar to pull it free from the rear case.
The power button is held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane.
crwdns2935229:092crwdne2935229:0
crwdns2947412:013crwdne2947412:0
Ive recently done a full housing change on my iphone 6 plus to a black one since doing it the power button doesnt work its rock solid i used original power button (space gray) and original flex cable once istalled it just wont press
The only way it works is if i leave the power button screws slightly loose which is a pain becasue the button loosens itself anyone had anything similar or is it the way its been installed ?? All other buttons work correctly mute switch and volume buttons
marcusdean2009 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello marcusdean2009 this problem occurs because the new carcass have the power button screw hole a little bit long than the original one. And yes, you will have to let the power button screws slightly loose to make the power button work
Ricardo Gomes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My power button is a little bit loose. There's still clicking sound but not same as the other normal button,the button also seems 'into' or 'concave ' compare to normal button.while the power button with long shape also seems just have a clicking sound when I press the middle part of button but not the upper and lower part of button.when I press the upper and lower part,it is soft and without clicking sound and springing feel. I used to replace the flex cable, but it still loose,is it the matter of the quality for the flex cable or the improperly attach of rubber gasket or the scuffed of little metal tip of the power button? Please reply me.
cyg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, after e I've assembled the iPhone power button is ok .... the flash does not work and the rear camera does not take more photos...i can see word the rear camera and i can record a video but no photo. How can i fix it?
Michele - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great job on this guide. What could have been a pain in the butt has been an easy fix/replacement thanks to this guide. Thank you for taking the time to do this. Just plain awesome.
Jesus Juarez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
