Use this guide to replace a broken, cracked, or non-responsive screen on your iPhone 15 Pro.
You'll need replacement screen adhesive to complete this repair.
Note: Due to Apple's parts pairing restrictions, on iOS 17.6 and earlier, True Tone and auto brightness are disabled after a screen replacement, even when using an original Apple screen. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore functionality on genuine parts.
Unplug all cables from your phone.
Hold the power and either volume button and slide to power off your phone.
If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
Pull the Anti-Clamp's blue handle backward to unlock the arms.
With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
Squeeze the cups together to create suction.
Pull the blue handle forward to lock the arms.
Turn the handle one full turn (360 degrees) or until the cups start to stretch.
As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
Insert an opening pick into the gap.
Remove the Anti-Clamp using the pull tabs on the suction cups.
Skip the next two steps.
Apply a suction handle to the bottom edge of the screen.
Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Heat the right edge of the screen until it's hot to the touch.
Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
Rotate your pick so the flat edge is under the screen.
Twist the pick to increase the gap between the screen and the frame until the right clip releases.
Insert a second opening pick to the right of the first pick.
Slide the first pick back to the bottom right corner of the screen.
Slide the second pick to the top right corner of the screen to separate the adhesive.
Leave these picks inserted to prevent the adhesive from resealing.
Heat the top edge of the screen until it's hot to the touch.
Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
Heat the left edge of the screen until it's hot to the touch.
Rotate your pick around the top left corner of the screen.
Slide your pick to the bottom left corner of the screen to separate the adhesive.
Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
Swing up the right edge of the screen like the front cover of a book.
Prop up the screen so you can access its cables without straining them.
Use a Y000 screwdriver to remove the six screws securing the logic board cover:
Four 1.6 mm‑long screws
Two 1.3 mm‑long screws
Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
Lift the cable to disconnect it.
Remove the screen.
To reassemble your iPhone, follow this guide to apply new adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
crwdns2935229:014crwdne2935229:0
Very helpful
Pls also make the videos of your guides available on YouTube so it can be more understandable
Where the hell do you buy the replacement display on the iFixIt website?
You can buy it at selfservicerepair.com it is a lot cheaper there
This adhesive is way more annoying than it has any logical reason to be.
