iPhone 13 Screen Replacement
Kyle Smith
crwdns2944107:0crwdnd2944107:0Kyle Smithcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:010crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 6, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
If your iPhone 13 screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this repair guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
Note: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality on genuine screens purchased from Apple.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
  • iPhone 13 Screen
    iPhone 13 Screen
crwdns2944105:0crwdne2944105:0
  1. iPhone 13 Screen Replacement, Remove the pentalobe screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  3. iPhone 13 Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Tape over any cracks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 Screen Replacement, Heat the bottom edge: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Screen Replacement, Apply a suction cup: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Apply a suction cup: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  9. iPhone 13 Screen Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Lift the screen slightly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The adhesive on the 13 model is certainly, "very strong." Keep this in mind when performing the repair. I had never opened up an iPhone as recent as the iPhone 13 and this adhesive that Apple uses for the water tight seal is strong. I had not been patient enough when opening my iPhone 13 that I had actually broken the screen. I was swapping the battery, but now I have to actually buy a new display assembly.
    Michael Carannante (Mikey) - crwdns2934203:0crwdne2934203:0
  10. iPhone 13 Screen Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Heat the right edge: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 13 Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Separate the right adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 13 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    But you can't get the phone too hot and you can't leave your phone on the charger while doing the fix
    Hi Man - crwdns2934203:0crwdne2934203:0
  13. iPhone 13 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 13 Screen Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Heat the left edge: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 Screen Replacement, Screen information: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  16. iPhone 13 Screen Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Separate the left adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 13 Screen Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Open the iPhone: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you haven't removed your suction handle, remove it now.
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 13 Screen Replacement, Unscrew the battery and display connector cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the three 1.3 mm screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 13 Screen Replacement, Remove the battery and display connector cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover.
  20. iPhone 13 Screen Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 13 Screen Replacement, Disconnect the display cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the display cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 13 Screen Replacement, Unscrew the front sensor connector cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three screws securing the front sensor connector cover:
    • One 1.7 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.8 mm Y000 screw
    What do the screws look like as I lost mine and bought a replacement set however it’s a mixture of all the different screws required for an iPhone 13 and I only need these 3
    S4mb - crwdns2934203:0crwdne2934203:0
  23. iPhone 13 Screen Replacement, Remove the front sensor connector cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Remove the front sensor connector cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
  24. iPhone 13 Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover.
    • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
  25. iPhone 13 Screen Replacement, Disconnect the front sensors: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the front sensors: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  26. iPhone 13 Screen Replacement, Remove the screen: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Remove the screen: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Why is the removal of the proximity light sensor from the back of the screen not covered in this tutorial?
    Jenny Lawson - crwdns2934203:0crwdne2934203:0
  27. iPhone 13 Screen Replacement, Unfasten the front sensor bracket: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
    • Use a Y000 screwdriver to remove the three 1.4 mm-long screws securing the sensor assembly bracket.
  28. iPhone 13 Screen Replacement, Remove the front sensor bracket: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Remove the front sensor bracket: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
  29. iPhone 13 Screen Replacement, Heat the front sensor assembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  30. iPhone 13 Screen Replacement, Disconnect the ambient light sensor: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the ambient light sensor: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the ambient light sensor and its recess in the screen.
    • Pry up with the pick to separate the ambient light sensor from the screen.
  31. iPhone 13 Screen Replacement, Disconnect the proximity sensor: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the proximity sensor: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the proximity sensor and its recess in the screen.
    • Pry up with the pick to separate the proximity sensor from the screen.
  32. iPhone 13 Screen Replacement, Reposition the proximity sensor: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement, Reposition the proximity sensor: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
  33. iPhone 13 Screen Replacement, Disconnect the microphone: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the microphone: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Disconnect the microphone: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
    • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
  34. iPhone 13 Screen Replacement, Remove the front sensor assembly: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Remove the front sensor assembly: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 Screen Replacement, Remove the front sensor assembly: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
    • Insert an opening pick under the left side of the front sensor assembly.
    • Slide the pick under the assembly to separate it from the frame.
  35. iPhone 13 Screen Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 Screen Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Remove the front sensor assembly.
    • When transferring the assembly to a new screen, follow these instructions:
    • Connect the sensors to their slots in the frame to help align the main section of the assembly.
    • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
crwdns2935229:062crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46 160 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Complimenti per le istruzioni ben fatte ! Potrebbe essere utile ricevere ad ogni riparazione l’elenco dei pezzi di ricambio da acquistare con i relativi codici così da quantificare anche il costo della riparazione. Utile anche per non sbagliare l’acquisto. Ciao, Roberto
Roberto Garancini - crwdns2934203:0crwdne2934203:0
Can we now change the display without FACEID issue?
kerozine84 - crwdns2934203:0crwdne2934203:0
Yes. You can.
Louis Osborne -
Is it possible to get the TrueTone function back with a Display Programming Device like a JC V1S?
Igor H - crwdns2934203:0crwdne2934203:0
Ciao ottima spiegazione, però perché con la flat sensori collegata alla scheda madre il display è scuro invece se la scollego il display torna luminoso? Io ho utilizzato un oled della GX.
Il problema è il sensore della live che si è danneggiato oppure bisogna fare qualche programmazione?
leonardo.147 - crwdns2934203:0crwdne2934203:0
Replaced display and exchanged front assembly on iPhone 13. Screen turns on and looks good, but it doesn’t respond to touch.
chadwhick7 - crwdns2934203:0crwdne2934203:0
defective digitizer or the cable for the display was pinched in a way probably when closing that damaged the ribbon cable
ubeiuwfbeib -
Wow Good.
Thank you.
I'm also planning to repair it.
이광희 - crwdns2934203:0crwdne2934203:0
Will it fix the face ID problem
Ethan Pillay - crwdns2934203:0crwdne2934203:0
As of November 2024, if I buy this screen on this website and I go do a screen repair, will face ID stay without having to do anything else?
usern200 - crwdns2934203:0crwdne2934203:0
Thats correct.
Ben Ansin -
Hi,
does the Face ID still work even with third parties screens? Or only with the original / iFitx it one?
BuBuMilano - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 241
crwdns2936753:07crwdne2936753:0 1,538
crwdns2936753:030crwdne2936753:0 7,011
crwdns2942667:0crwdne2942667:0 208,930
