crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
crwdns2959928:0crwdne2959928:0 ↓If your iPhone 12 Pro screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
The combined earpiece speaker + sensor assembly affixed to the back of the display is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement. It contains the flood illuminator, which is part of the biometric Face ID security feature. If it is damaged or replaced, Face ID will cease to function, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an Apple-authorized technician can restore Face ID function.
Note: On iOS 17.6 and earlier, True Tone functionality is disabled after a screen replacement, even when using an original Apple screen. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality on genuine screens purchased from Apple.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
Spudger4.9
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
To avoid damaging your screen in the next steps, note the following:
There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the plastic screen bezel when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
If you're using a single suction handle, apply it to the bottom edge of the screen.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick at a steep angle into the gap.
Remember to insert the opening pick under the thick plastic bezel to avoid damaging your screen.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
Leave the pick in the top left corner before continuing.
Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
Rotate your pick around the top left corner of the screen.
Slide your pick to the bottom left corner of the screen to separate the adhesive.
Rotate your iPhone so the right edge faces you.
Open the iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a fingernail to disconnect the display cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove four screws securing the front sensor connector cover.
Three 1.1 mm-long screws
One 1.4 mm-long screw
Swing the cover up from the left until the small clip on the right unhooks.
Remove the cover.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Remove the display assembly.
Remove the four screws securing the speaker/sensor assembly to the back of the display.
Two 1.4 mm long Phillips screws
One 1.7 mm long shouldered Y000 screw
One 1.2 mm long Y000 screw
Use the point of a spudger to gently pry up the top edge of the speaker.
Flip the speaker assembly over—down and away from the top edge of the display.
Use a hair dryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
Use the point of a spudger to lift and separate the ambient light sensor from its notch in the front panel.
Continue sliding the spudger underneath the ambient light sensor and its cable to separate the adhesive securing the cable.
Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
Use the point of a spudger to lift the proximity sensor and flood illuminator module out of its notch in the front panel.
Remove the earpiece speaker and front sensor assembly.
Proximity sensor
Flood illuminator
The module must be positioned so that these components are not obstructed by any adhesive.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Answers community for troubleshooting help.
crwdns2935229:051crwdne2935229:0
Die Anleitung hat prima funktioniert, vielen Dank!
Allerdings hat sich nach ein paar Tagen herausgestellt, dass an der oberen Kante der Geräts das Display nicht (mehr?) plan mit dem Gehäuse abschließt, sondern dass das Display leicht über das Gehäuse hinausragt. Ich kann das Display zwar mit den Fingern wieder hinunterdrücken, so dass es dann plan aussieht, aber sofort nach Loslassen wird es gleich wieder angehoben - als wenn von innen was nach oben drückt.
Jetzt kann man natürlich sagen "na und?", aber das praktische Problem besteht nun darin, dass nun Staub eindringt und sich auf der Selfie-Kamers sichtbar ablagert (und vermutlich auch auf dem Face-ID Dot-Projektor)... un natürlich Zweifel an der Wasserdichtigkeit bestehen.
Bevor ich das Gerät erneut öffne und nochmal den Klebering austausche: woran könnte das liegen? Muss man beim Schließen des Gehäuses irgendwas besonders beachten? Z.B. dass irgendwelche Nasen etc. einrasten müssen oder so, die das Gerät an der Oberkante verschlossen halten?
Andreas Gärtner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
这个指南真是太详细了,非常感谢,我想知道你们都是在哪里购买到新的屏幕的
humi317317 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, I’m having trouble lifting the screen — it’s really stuck, and even heating it with a hairdryer doesn’t make it move at all. What temperature should I reach?
cristiano - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Kit claims to have all the parts and tools necessary. In addition to a several items like a ruler, marker etc. it doesn’t contain a heat gun or hair dryer needed for the job. A list of additional items would be helpful so they can be collected b4 work begins instead of making false claims.
Also, maybe a word or two about replacing the screen would be helpful instead of suddenly ending when the screen is detached. My screen came with something that looks a bit like a screen protector. What is it?
Overall the steps are clear but they don’t provide a guide to replace the screen.
Bartwick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
