Use this guide to remove and replace the rear cameras in the iPhone 11 Pro Max. All three camera modules are replaced as a single unit.
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
Insert your pick into the top-right corner of the phone.
Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
Slide the pick to the top left corner and cut any remaining adhesive securing the display.
Pull on the small nub on the suction cup to remove it from the front panel.
Remover: Mover algo, agitándolo o dándole vueltas, generalmente para que sus distintos elementos se mezclen.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
My Y000 didn’t work on my screws. Does anyone know why?!
Podéis usar el verbo quitar o retirar.
Remove the bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
The second connection from the battery to the daughterboard should also be disconnected even just as an extra precaution.
Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
What do you do if one of the screws gets stripped? I can get it out.
Solder a paper clip to it
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Remove the display assembly.
Use a Y000 driver to remove the two 1.5 mm screws on the left side of the rear camera cover.
Remove the Face ID flex cable bracket.
Use a Y000 driver to remove the two 1.2 mm screws securing the rear camera cover.
Lift the camera cover from the edge closest to the battery, and remove it.
Use a spudger or a fingernail to disconnect the first two camera cable connectors by prying them straight up from their sockets.
Use a spudger to disconnect the third camera—its connector lies underneath the cable you disconnected in the previous step.
Slide the point of your spudger under the left edge of the camera assembly.
Gently lift up to lever the cameras out of the iPhone.
Remove the rear-facing camera assembly.
رائع جدا جدا جدا
Good work here
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Max Answers community for help.
crwdns2935229:016crwdne2935229:0
Great guide, everything worked well. Was able to replace the rear camera on the iPhone 11 pro max w/o any problems.
رائع جدا لتخيير شاشة
How about my rear camera is not working good after replacement the x2 is not focus on the object and the x1 and .5 have a same angle and blurring slightly
Wie soll mann das Handy ausschalten wenn das Display defekt ist oder nicht angeht?
Elias_Will Diamondblock - crwdns2934203:0crwdne2934203:0
Usáis mal el verbo remover
Vicente Tortajada - crwdns2934203:0crwdne2934203:0
